2019-01-22, 06:40:51
Author Topic: Any advice on galvanic isolation for USB?  (Read 3375 times)
I have a need for complete USB isolation up to 5kV surges. USB power will be provided by a separate (already isolated) good quality power supply.
There are plenty of products for sale but I build my own. Has anyone succeeded with this task and willing to share ideas?
WW
"As far as the laws of mathematics refer to reality, they are not certain; as far as they are certain, they do not refer to reality." - Einstein
"What we observe is not nature itself, but nature exposed to our method of questioning." - Werner Heisenberg
Thanks.
I'm using that device now since early last year. I'm on my fourth chip  :'(
It certainly eliminates ground loops but tends to fail after several high voltage hits below the published ratings.
Do you have USB isolation for your test equipment?
Hi WW
I have never used USB isolation GULP i have been OK so far, but i guess most of what i have done is low voltage, low power.
I guess you could say that chip must be doing it's job, if the equipment down stream is OK afterwards.
That's the problem  :-[
It took out an old laptop and two USB hubs. I have TVS's between lines and between lines and ground at key points. I was just after preventing ground loops as these can really screw up results.
Maybe I'll use WiFi isolation  ;)
It appears WiFi will work.  ZigBee on a PIC with a USB host port is fine for lower data rates.(I'm collecting data on a circuit wrought with transients using the ADCs in the PIC).
Nothing special about the CUTs. Just a load of problems with ground loops affecting the test outcome.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2019-01-22, 06:40:51
