2018-12-10, 01:57:37
Author Topic: Motor Coil Flyback Feedback Effect  (Read 4107 times)
Hi everyone,
I've been out of the country since November 2nd doing some volunteer work in a Spiritual Organization that help the underprivileged in South Africa.
In my spare time I continue my research. I've been experimenting with Coil Flyback Feedback since I believe it could greatly improve electric motor efficiency and could possibly be applied in transformers which would make a solid state device (no moving parts).
I have made a crude permanent magnet motor (pulse motor) to which I demonstrate the energy saving effect once you capture and re-input the flyback to the pulse motor.
I was originally trying to send it back to the same coil but I lack electronics skills to do it correctly. Isolation of the power source, coil, MOSFET switches are a pain. Timing is another problem.  After over 30 hours and all kinds of blown devices I had to come up with an idea that didn't need all these components just for proof of concept.
I'll let the more talented in electronics come up with a circuit if they feel the pursuit is worthy after seeing my simple proof of concept video.
When first trying to make the feedback circuit I was using a hard drive disk platter and bearing assembly as magnet rotor but when I couldn't get it to work I had to come up with another idea. What I came up with was to mount the HD plater to a shaft of a 12vdc motor I salvaged from an old VCR and send the flyback to it which would Isolate it from the coil and the energy should assist the pulse motor to turn faster.
Well the results are better then I expected!... the pulse motor goes from 200ma with a 6.24vdc input with no flyback to 50ma @ 6.37vdc with flyback feedback at the same RPM.
In the video demo I use my oscilloscope to match up the timing (RPM) before and after. So don't go crazy on the scope shots you see in the video as it was used mostly for that purpose. The probe is across the coil. The scope data is not stable as there are to many peeks to display correct Frequency, Period and so on. So I made some extra scope shots (below) with a standard voltage and current setup through a 1 Ohm resistor. First shot is No flyback feedback with input at 6.24vdc @ 200ma and the next is with flyback feedback feedback at 6.37vdc @ 50ma.  just like it was done in the video. The rotor has 4 magnets so with the new scope shots below the Frequency is 110Hz so we divide it by 4 (magnets) = 27.5 turns per second x 60 (seconds in a minute) = 1,650 RPM the magnet rotor is turning.
Link to video demo: http://www.youtube.com/watch?v=1omqvHXPvOs&feature=youtu.be
I have not seen or noticed any topic on recirculation flyback back in a motor, so to me it looks promising and would like the input of those who are knowledgeable. If I'm missing something or not fully understanding the present electric motors please feel free to enlighten me.
I'm also very open to circuit suggestions that could send the flyback back to the coil but in the same current direction the On pulse did. This could be done during the off time and that energy could be part of the next pulse which should greatly assist the motor.
So to be clear on what I would like the motor and circuit to do, is for the magnet to naturally attract to the coils core (no power), once at center of the core the coil is hit with the energy of the flyback collected in a capacitor of the previous pulse and the balance to top off the cap can be regulated coming from the battery or energy input.
I welcome any other suggestions
Thanks for sharing
Luc
http://i944.photobucket.com/albums/ad290/gotoluc/NoFlybackFeedback.png
http://i944.photobucket.com/albums/ad290/gotoluc/WithFlybackFeedback.png
« Last Edit: 2012-04-04, 00:15:35 by gotoluc »
Nice idea using the DC motor as a means to recycle the inductive kickback Luc.
Indeed, trying to recycle that IK back to the same coil is a challenge. One way would be to use two storage capacitors; while one is being put in series with the battery, the other is collecting the next IK spike, then alternate the caps, and so on. Could be a switching nightmare  :D
6.24V 200ma = 1.25 W
If we assume the motor without saving is 30% efficient, then the output would be bearing heat and is .375 W.
Now we have the same input with saving.
.375W/ .319W = 1.17  ^-^
Anyhoo, If we put a fly back diode, the current would then recirculate in the same direction, right?  If we time it right, would this save energy?
Ultimately I see using an AC cap is better. However now we have to sync it.
Thanks .99 for the reply.
Yes, it can definitely become a difficult task to make such a circuit work :o in the real world.
One thing that I could do to further boost the existing setup is to replace the 12vdc motor with a 1.5vdc motor. This would keep the opposing flyback pulse down to the 1 volt range the the opposing 8 volt range you now see on the scope. This would give further acceleration as a dead short is the best but then you're not sending anything back, just preventing that opposing fight.
Luc
Yes, that could be the case.
This is why a circuit would be needed to test it on an existing motor that we already know is 80% or so efficient.
AC cap is a good idea and I think this is the idea behind the attached pdf patent. However, the balance of this kind of device maybe worse the getting a circuit to work.
Luc
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2018-12-10, 01:57:37
