Below you will find the scope shots of the video demonstration.
An oscilloscope is needed to experiment with reactive power as without it you would be working in the dark.
On the low voltage side of MOT primary you will need a Series Capacitor. It can be many different values of AC Capacitors capable of 220vac which you connect in parallel to make the value you need to get the best current and phase shift (90 degrees is ideal).
You should have many cap values from 1uf to 60uf to combine them to find the ideal value plus or minus 1uf.
I suggest starting around 20uf on 220v MOT's and 40uf on 120v MOT's
Please note that even if you combine caps together to get a certain uf value, that Capacitor bank will be connected in Series to the MOT primary.
For the high voltage side of the MOT you will need many HV 2000vac rated caps of small uf values like .22uf or even smaller as small changes make big differences between the secondary and primary. You can even get good results by shorting the secondary as it's self capacitance maybe enough. So maybe Bifilar winding could also be looked at as a secondary which could have its own self capacitance and require no external caps. But like I say you can just try it shorted at first or attach a resistive load if you're using it as output. Also, best to use high resistance between 300 to 1000 ohms. Each MOT has it's ideal load to get max power out and keeping phase at ideal position.
Tuning to be most efficiency like 0 watts input with10 watts out (which I've done) you will need a perfect 90 degrees phase shift.
It's not easy to do, since as as soon as you connect a load be it Inductive or Resistive our friend Lenz wants to come for a visit. Mostly when it's Inductive!
Now for the microwave oven transformer (MOT)
Why a MOT?... well, it can work with other transformers but my best test results so far was a transformer with a high Impedance secondary (many turns), so naturally a MOT is better suited for this.
I think one could improve over a MOT by maybe using a Utility Line Step Down Transformer which is what could be on Valy's looped generator video (on side close to motor)? don't know if its a large capacitor or a transformer?
See for yourself, here's the link to Valy's looped generator video:
http://www.youtube.com/watch?v=7qa3MmdqdQ0These large utility transformers are designed to step down 7000, 14000 or more Volts AC to 220vac, so it may work better then a MOT? and should be able to maintain very large quantities of reactive magnetic flux within the core which should result in maintaining a next to perfect phase shift when a load (motor) is connected to the low impedance side. But again this would needs to be tested.
Please note that what maybe hidden in Valy box (secret to make the device work) could be a high voltage AC capacitor connected to the HV secondary of the utility transformer and its low voltage coil connected between the 600vac PM generator and the induction motor. Once he gets it started and flips the switch the induction motor run capacitor is probably used as the primary capacitor.
I also could be wrong and the box maybe a transformer and capacitors of a welder as I have seen a few videos on YT that when a welder is operated it stops the utility meter and even makes it turn backwards:
See for yourself, link to video:
http://www.youtube.com/watch?v=jcPKz7uEq-8Anyways, all this needs to be tested to find the best setup
In my Reactive Generator test 1 video what prevented me to further drop the 50 watts used by the induction motor was the limit of my variac voltage output.
I know that may not make sense to you but when you experiment with this you may understand.
To achieve a lower power consumption I would need to get a better phase shift (closer to 90 degrees) and the way to do this would be to reduce the capacitance uf value on the series primary cap bank. However, that action will cause a reaction, so to maintain the induction motor speed I would have to raise the voltage of my variac but I was close to max at 150vac.
Don't be fooled! ... there's better result to be had. I decided to keep it simple by using a standard variac. The potential of what this could become is what is inportant.
Once you start experimenting and get positive results you will better understand the potential. But I'll tell you, it's not as easy as I make it look in my video. It will take time to master this beast.
The other thing I've not mentioned is about the two MOT's I'm using in the video. They are from South Africa, so 220vac. I brought them back to Canada over a year ago because I was working on a reactive battery charger (this is how this all started) and since the Primaries are for 220vac they would have more turns and possibly a higher Inductance then our 120vac version.
My experiments have confirmed that a MOT with a higher Inductance primary requires a lower series capacitance value for the same amount of real power on the load to secondary compared to the 120vac MOT which needs double the cap uf value for the same output. So possibly less capacitive energy in the primary = less current being wasted in the transformer core as heat caused by eddy currents. I could feel the difference of heat between the two when I tested the 220v vs the 120v.
My best score so far on a reactive load on the output of the generator is around 20 Watts without the generator loosing RPM and raising the power requirement to the prime mover.
I chose not to demonstrate this in test 1 video as the you need 3600 RPM for the alternator to output 120vac and thought it was more important to demonstrate the effect of reactive power on the input prime mover (motor) then only a higher output power as I would needed much more voltage (as mentioned above) to get close to the RPM the alternator needs to output 120vac.
However, if it would make you happy to see a reactive circuit connected to the output producing 20 watts at no cost to the grid input, then I can upload a video demo for your entertainment.
This is just the beginning as I'm sure with all of us working together we can develop this to a much greater potential. Also note that this could be used on so many applications like a car alternator producing power for HHO production at no cost (load) to engine.
I also think a solid state version (no moving parts) could be possible.
The application possibilities are endless.
To think that everyone trained in electrical or electronics for the past 100 years have been told that reactive power is not useful is hard to believe!... could this be so? am I dreaming?
For the next few weeks I may not be available to answer posts as I have to complete a job to make a little $ to keep living. So I encourage you not to post other than your experiment results in order to keep this topic clean and easy to understand for the new comers.
All the best with your experiments and please share as I have.
If you steal this thinking of self gain you will not gain anything and failed the test of what it is to be a true being of light.
Love all Serve all
Luc
