2019-01-22, 06:09:43
Pages: 1 2 3 4 5 [6]
Author Topic: Public Release & Translation of Dutch Patents by Arie De Geus  (Read 63786 times)
This should work:
http://www.americanantigravity.com/files/audio/Arie-DeGeus-Mar2006.mp3
Dug it out of the html file.   O0
Thanks Matt, I'm capturing the stream also and will see if I can improve the quality.
This guy is something special.  Sure would like to spend some time in his laboratory.
Indeed he was Matt  O0
He was on his way to sign a funding deal in Europe but was found dead in his car at the Airport   :-\
ION did you notice he explains how the polarizer works, it uses gravitation he mentions a piece of film (maybe thin metal film????) on a razor edge 29:00 onwards,he calls it polarization of electrons and explains it has to be orientated correctly, he says he's giving away loads of secrets here  ^-^
Thats a good find Matt, nice to have Part 1 as a pdf, there a lot of other things he published which seem to have vanished Part 2, Part 3, there was also a very important book which studies each element in detail but i forget the title.
It's good to see a picture of him.
     Fluidum Continuum Universalis, Part I (4th edition)
    Fluidum Continuum Universalis, Part II (the Micro-Phenominomae)
    ‘Time’ and Cosmology (2nd edition)
    Physica Primero Descriptio ('Primary Physics')
    Order versus Chaos
A new google translation of NL1030781
Method and apparatus for production of energy through fusion of He₂³ to Be₄⁹.
http://www.overunityresearch.com/index.php?action=dlattach;topic=2469.0;attach=15063
Talks about the ogwall (Vortex Wall) diameter and how the larger the diameter the lower the fusion temperature, uses a tapered vessel and adjustable anode & cathode lengths of arc.
Interesting he claims the Chinese are planning on getting the He2 from the moon in 2017 as it is rare on earth but more abundant there.
Another good read, thanks Peter,
RE:
NL1031962   Energy generating process for producing electricity, comprises electron discharge in flow of nitrogen or air in order to cause nuclear transmutation of nitrogen into carbon monoxide
Arie de Geus
Abstract -- A flow of nitrogen or air, or a plasma thereof, through a reactor (1) is exposed to an electron discharge, resulting in the nuclear transmutation of gaseous nitrogen into carbon monoxide, followed by oxidation of the carbon monoxide to carbon dioxide. A method for generating energy comprises passing a continuous flow of nitrogen or air, or a plasma thereof, through an optionally enclosed reactor in which electron discharge takes place, resulting in the nuclear transmutation of gaseous nitrogen into carbon monoxide, followed by oxidation of the carbon monoxide to carbon dioxide. An INDEPENDENT CLAIM is also included for the process apparatus, comprising a reactor with a pressure reducing means (6) and an inlet (7) for providing an intermittent supply of nitrogen or air; at least one cathode and at least one anode on the inner side of the reactor space ends; a means connected to the cathode (4) and anode (5), used for generating high voltage pulses with a predetermined waveform and frequency between the cathode and anode; a casing around the reactor, through which air flows in order to be heated by the process heat from the reactor; and optional conduits for recirculating the heat-laden air back to the casing.
Resonant Transmutation of Nitrogen in Lung Tissue
http://www.human-resonance.org/lungs.html
Someone needs to test the black compound that forms in a car bulb when it blows, the car bulb either uses 98%Nitrogen & 2% Argon or 100% Nitrogen and with a Tungsten Filament as a Catalyst, when filament blows a DC current forms a magnetic Bias Field and a hot plasma transmuting the Nitrogen to Carbon, we need to prove this, it is also noted that when a car bulb that has a halogen like Xenon gas instead of Nitrogen then the black does not form ;)
Peter
Some years ago now, I and another who goes by the name of Tutanka (Alex) from Florence in Italy, we built a reactor for doing just that. The idea was to be able to break down gas such as CO2 into burnable CO.
Transmutation I do not know, radiation burns, yes I had a bad one on my arm which I put down to RF and no other. Well I had no means of testing other, and the fact we were using high frequency at 70Kv I would have thought of nothing more, maybe that was wrong :-\
Did it work? well the result was, using straight air, a plasma, using expelled air from breathing (higher CO2 content) the plasma was at least twice as bright. So it was assumed that the CO2 was converted to CO and that CO burned up in the plasma (slight pink tinge to the plasma, not stark white).
We try these things but without the correct lab equipment, we do a lot of guessing ???
A very hard vacuum was needed and X rays are a big problem if no protection is used.
Now here in the attached you can see you can do this without direct electric power, but if you combine various principles and combine them into an injector plug, what do you have?
Chet posted this earlier but then deleted it, I think it is possibly significant and so I will repost.
http://www.accelinstruments.com/Applications/WaveformAmp/Magnetic-Field-Generator.html
It claims to double the current in the resonant inductor and therefore doubling the associated magnetic field.
Now when I first had seen the circuit I thought I had seen it before.
Turns out Arie DeGues had a cryptic patent which at a previous attempt seems to be mostly garbage until you realize the only part of the patent that is meant to be of use is the circuit Fig3. the dashed area, I attach the circuit below.
http://www.overunityresearch.com/index.php?action=dlattach;topic=2469.0;attach=14476
Interestingly it matches the circuit pretty much in the above link but has added a centre ground and a series trimming capacitor.
I just simulated the circuit and it appears to run efficently at resonance but with twice the current in the inductor and hence twice the magnetic field strength.
I am not an expert at simulating things but wanted to raise awareness of this circuit.
Peter
Just got back for the evening [saw your PM]
yes I had started a topic on that and then chose to ask around [it was only up for a few minutes]
was not quite certain of the claim " a new resonant circuit" ??b
thanks for reposting it..
saves me some leg work
PS
member Evostars had shared this at Energetic forum in his thread.
http://www.energeticforum.com/renewable-energy/20714-magnetic-field-bifilar-pancake-coil-11.html
he also has a mirror thread at Stefan's ,[but we are having issues with a member there ATM, still waiting for a reply from Stefan]
Only twice the current, in a resonant tank? That's not very surprising.
It's really too bad that "Master Ivo" doesn't actually understand what he's doing, and seems to have swallowed the "Eric Dollar" kool-aid instead.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2019-01-22, 06:09:43
