Some updates -
Patrick (Cool Joule) mentioned running the motor in the A field. That means turning the drive coil sideways, but i'm unsure what it's supposed to do for running characteristics. His 'Reply' button isn't enabled, so could one of you gents explain that to me ?
I'm a little reticent to change that coil, as it's in the best spot found up to now.
Powdered ferrite is doing well !
What I have are 2 different methods that are being tested. The first, is a dusting of CRT yoke ferrite on paper, using white glue to stick it. The second, is a filling of a small piece of a drinks straw.
They have been initially tried behind a 4x 500ohm coil stack, being used as a pickup coil.
Slow turning of the rotor shows seemingly no negative impact or cogging....perhaps due to the back of the coil being a good distance from the magnets.
As an example, when running, the pickup may show 1.000V. Adding the paper behind the coil turns that to 1.1V.
Next up, is to try different lengths of the straw, but also to increase the depth of ferrite dust on the paper until cogging is noticed at the slow test RPM's.
Reed switch placement has been tried. The idea was 2, side by side in series, on top of the driving coil.
The problem seems to be that my setup uses small broken bits of magnets and their field has trouble reaching up over the top of the coil (?). Also, the pull of the reeds upsets balance...a deficiency in the semi-levitated method i'm using.
That idea was to base it on the PDF as kindly linked by AllCanadian. I like the multiple ring characteristics of the Ossie motor.
Still, on their way are a bunch of 8mmx1mm magnets, which by being larger might well allow that configuration to be properly tried out.
