Benches => NerzhDishual => Topic started by: NerzhDishual on 2013.11.08, 21:48:32
Title: Possibility of a Self Charge Device. Or Watt?
Post by: NerzhDishual on 2013.11.08, 21:48:32
More to come....
Title: Re: Possibility of a Self Charge Device. Or Watt?
Post by: NerzhDishual on 2013.11.08, 22:21:17
Hi People,
About: "Charging a capacitor without loss".
Or, more precisely, with few loss, you can consult this simulation picture:
(http://freenrg.info/Pic/Charging-a-Cap-via-Inductor.jpg)
The maths are On You. I'm too not self confident with these maths.
For any explanation and equation, you can also consult:
"DC RESONANT CHARGING CIRCUIT"
http://www.richieburnett.co.uk/dcreschg.html
This is just the begining of the story.
All the Best,
Jean
Post by: NerzhDishual on 2013.11.08, 22:43:26
One part of the story would be these 2 old web pages:
(http://freenrg.info/Pic/Old-Web-Page-1.jpg)
(http://freenrg.info/Pic/Old_Web-Page-2.jpg)
Post by: NerzhDishual on 2013.11.08, 23:12:29
Imo, this previous CCT can be interpreted as:
(http://freenrg.info/Pic/Two_Caps_Serie_Parallel-S-Step-1.jpg)
(http://freenrg.info/Pic/Two_Caps_Serie_Parallel-S-Step-2.jpg)
Please forget the "Scalar wave controller" device.
Think about any 555 or any 4093 (Quad 2-input NAND Schmitt trigger). No?
Post by: NerzhDishual on 2013.11.08, 23:40:19
Now, charging 2 capacitors in parallel and discharging them in series could sound like a great idea.
Unfortunately, the 'official maths' (and the experiments) are telling us that this does not generate any 'OU'.
You bet it would not...
Unless the 'load' in the previous circuit were inductive?
Even is this case, according to the simulation, no 'OU' could be achieved...
*Unless* ......?
To be tested in the real life....
More to come ASAP,
Jean
Post by: NerzhDishual on 2013.11.09, 00:59:46
**Unless**???
Quote (from some vid) of some claimed 'OU' guy (who is banned on this forum):
"....the 'COP' is on the battery. Does the battery went longer, does it take the charge better, does it charge faster? How long could we stay this battery? You're dealing with the COP in the system by charging a battery with this type of  device. Because when I'm saying any COP is developed in the machine whatsoever it's all in the chemical,in the battery.."
(From my froggy understanding).
If this guy is right so "self charge" could be possible.
IMO, there are 3 ways to charge a (lead acid) battery.
1) Brute force: some amps with a voltage charger > Voltage bat.
2) Huge voltage spikes with pratically no current. Often called "Radiant NRG".
3) Huge current spikes (from capacitor(s) discharge).
We are dealing with the 3th method.
Post by: PhysicsProf on 2013.11.09, 01:29:54
  Thanks, ND...  studying what you have provided.  Great to hear from Brest again!
Post by: NerzhDishual on 2013.11.09, 01:53:35
Now, just for the fun, this circuit:
(http://freenrg.info/Pic/Old-web-Page4.jpg)
Obviously a not functioning and obfuscated CCT.
In French: a "Foutage de gueulle" (piss-take) ;
It can be modified for functioning but it is always the same thing:
charging 2 capacitors in paralell and discharging them in series.
No way! IMO.
Gwella gourhemennou a-berz Jean
Post by: NerzhDishual on 2013.11.09, 02:45:52
Hi Prof J.
Great also to see that you are, as usual, very re/active.... :))))
You do not need to (too) "study" anything.
Actually, you lose (almost) no energy when you charge capacitors via an inductor.
This is not 'OU'.
But, if the battery is OK to receive huge (but very short) amps?
In my great laziness, I have not yet tested this very simple CCT:
(http://freenrg.info/Pic/OU-or-Watt-V2.jpg)
Perhaps, one could design a 'near' self charging cct with a small 9 volts bat and a 9/6 volts relay?
Post by: Centraflow on 2013.11.09, 07:59:08
Quote from: NerzhDishual on 2013.11.09, 02:45:52
Hi Prof J.
This is not 'OU'.
Hi Jean and welcome
That last CCT is so much like one I use with an electrolysis cell, which can be found on another thread here, also using an inductor in a type LENR cell. I can tell you now that it works with the cells as the cells generate power. I have never tried without a cell though, all very interesting
from Spain but English
Post by: NerzhDishual on 2013.11.10, 18:07:58
Hi Mike!
Thanks for your feedback. Very encouraging.
Actually I have a lot of such Circuits. Most of them are just simulations but some are 'real' things.
I do not 'get along' with MOSFETS, I have a tendency to blow them up. :((
I will try relays. But relays consume power....
Another version of the previous CCT:
(http://freenrg.info/Pic/OU-or-Watt2.jpg)
A very simple CCT:
(http://freenrg.info/Pic/One-Relay-2-caps.jpg)
Another less simple one:
(http://freenrg.info/Pic/One-Relay-2-caps-One-coil-one-diode-v2.jpg)
The last one, just designed, this very day:
(http://freenrg.info/Pic/One-Relay-2-caps-One-coil-2-diodes-v2.jpg)
All The best,
Jean
Post by: NerzhDishual on 2013.11.10, 18:58:28
Hi People,
IMO, actually, we have, at least, 3 solutions:
Simple "Parametric" stuff:
1) Charging 2 caps in // and discharging them in series...
A very old idea. Kinda "Tesla Switch". Claimed to be working by some people and useless
for others.
More elaborated "Parametric" stuff:
2) Charging 2 caps in // via a coil and discharging them in series... A less old idea.
"Double Parametric" stuff, a more 'tortuous' idea:
3) You energize 2 coils while they are in the 'few Henries' configration.
Then, you let them giving back their NRG to the two caps (in //) when these 2 coils are in
the 'lot of Henries configutation'.   In the attached picture: 0.45 mH versus 227 mH one.
V = L.di/dt + i.dL/dt. No?
The CCT is much more complicated indeed. But worth to be though about, IMO. NO?
A real measurement of one of my bifilar coil:
(http://freenrg.info/Pic/One_Coil_Measurements.jpg)
All the Best from Brest,
Jean
