Build / Construction Tips and Ideas => Coil Construction => Topic started by: darkspeed on 2010.04.18, 03:37:54
Title: 15" coil winder
Post by: darkspeed on 2010.04.18, 03:37:54
I water-jetted two 15" X 2.5" discs of plexi and mounted them on a "lasy susan" bearing
I am wrapping the form with two layers of polycarbonate film and bonding it with coil dope (Dolph AC-43).
Wire spool rides on a flat roller thrust bearing, 8" x 5/8" bolt, and 5/8 retainer
Once the coil is doped and given time to harden, the disc forms can be removed and the excess polycarbonate can be trimmed from the coil
This creates a ultra thin former / coil with a much lower self capacitance than winding on 15" pvc ( which is not really 15" )
Title: Re: 15" coil winder
Post by: darkspeed on 2010.04.18, 03:38:58
test run... with 28awg c-200
It took about 15 min just turning the rig by hand..
Post by: Grumpy on 2010.04.18, 13:51:30
save that large outer coil for other experiments
Post by: darkspeed on 2010.04.18, 16:40:59
Quote from: Grumpy on 2010.04.18, 13:51:30
