General - Free Energy Related => Miscellaneous Discussions => Topic started by: Tommey Reed on 2014.08.06, 02:00:59
Title: High voltaga Generator
Post by: Tommey Reed on 2014.08.06, 02:00:59
Hi All,
This is a experiment using a secondary winding from a microwave transformer to create higher voltage.
https://www.youtube.com/watch?v=E3pAiHwcuZQ (https://www.youtube.com/watch?v=E3pAiHwcuZQ)
Tom
Title: Re: High voltaga Generator
Post by: ion on 2014.08.06, 14:55:13
Quote from: Tommey Reed on 2014.08.06, 02:00:59
Hi All,
Tom
Tommey
Try putting various AC rated capacitors on the output of the window generator to see if you can find resonance with the turning rotor. The energy being pumped out of the coil should form a resonance with the capacitor and a sweet spot RPM will be found.
While the resonance may seem to load the generator more, you wll be have lots of amps circulating in the circuit. It is a way of impedance matching the crank speed /power input to the generator. You may be surprised when the sweet spot is found.
