General - Free Energy Related => Miscellaneous Discussions => Topic started by: Centraflow on 2014.10.23, 11:26:17
Title: Gap power generator
Post by: Centraflow on 2014.10.23, 11:26:17
Has anyone seen this? know anything about it?
https://www.youtube.com/watch?v=fnWuPzAKigs
I find it very interesting, comments please :) those who are into magnetic induction
Title: Re: Gap power generator
Post by: TinMan on 2014.10.23, 12:55:13
Quote from: Centraflow on 2014.10.23, 11:26:17
I remember when he bought out his first design. I then saw his second design pop up some time later. Seems to me to be nothing more than a solenoid engine.But one cant argue that only a permanent magnet will act against an electromagnet with such force--no other material will do this.
They say that PM's cant do useful work--> i say remove them from your PM DC motor,and see how useful it is now.
love the guy's heat test method-i just used my fingers to see how hot the coil got lol.
Post by: Centraflow on 2014.10.23, 14:29:52
Quote from: TinMan on 2014.10.23, 12:55:13
Yeah, shoe string science :D
Post by: Paul-R on 2014.10.23, 14:55:37
Its the current in the coil that does  the business.
Post by: TinMan on 2014.10.24, 13:30:29
Quote from: Paul-R on 2014.10.23, 14:55:37
You can have all the current you like,but without anything for that magnetic field to grab onto,it would simply be a heater.Replace the PM's with blocks of steel insted,and watch most of your torque in your PM motor disappear.
Like i said,nothing is attracted(or repelled) to an electromagnet more than a PM-->nothing comes close.
Post by: Allcanadian on 2014.10.25, 00:19:41
@Tinman
QuoteYou can have all the current you like,but without anything for that magnetic field to grab onto,it would simply be a heater.Replace the PM's with blocks of steel insted,and watch most of your torque in your PM motor disappear.
A PM motor is generally more efficient because the I2R (heat) losses are reduced somewhat. It is also interesting considering what happens because the PM attraction to the core is free however the core is now saturated. This means when we apply a current to the coil the saturated core makes the coil act as a resistance not an inductor so we gain more initially on attraction then we lose more on repulsion as I2R losses...it's a wash.
Now I understand some might assume there is nothing we can do to change this and they might also assume this proves the conservation of energy. I personally believe the conservation of energy is valid however it should  be understood that in every case we always use one magnetic field to act on another. Thus the whole of our conventional technology is based on a system in which we can never really gain anything. It is only when I came to understand what a magnetic field is fundamentally, not what it does what it is, that I began to see some light at the end of the tunnel.
