The Chan Wheel is basically the Milkovic 2 stage pendulum. The only difference is to replace the pendulum with an unbalanced wheel.
The Milkovic 2SO is already an OU device. It leads out Gravitational Energy. The most convincing evidence is that the amplitude of oscillation of the pendulum does not decrease when the Weight is lifted. Energy is NOT transferred from the pendulum. Energy must come from elsewhere. The elsewhere is Gravitational Energy.
The Chan Wheel in its simplest form is a bicycle wheel with lead weight attached to the rim. It can demonstrate that a balanced wheel cannot lift the weight but an unbalanced wheel can. Thus a key factor in leading out or bringing in gravitational energy is the use of a pendulum or an unbalanced wheel.
This new thread will discuss this new discovery in great detail.
https://www.youtube.com/watch?v=p4rgLBU34Oo
The Chan Wheel is made up of two major parts. The first is a bicycle wheel with fishing lead weight attached to the rim. This wheel is attached to a seesaw setup. The other side of the seesaw is the Weight to be lifted.
The second part is the frame.
The two parts are not physically jointed. The first part is just put on top of the frame. The pivot point can be adjusted easily.
https://www.youtube.com/watch?v=HGaQ8a1PIt8
Example of balanced wheel. The wheel spun for a long time but the Weight was not lifted.
https://www.youtube.com/watch?v=Wkis7FUVqKY&feature=youtu.be
Example of the unbalanced Chan Wheel. The Weight was lifted multiple times.
Gravitational Energy was lead out or brought in.
Quote from: ltseung888 on 2014.12.12, 15:08:53
When the weight is lifted, energy is supplied. When it descends that same energy is put back into the system, resulting in no net gain or loss.
Divine Revelation?
The two little angels said to me: "Grandpa, do not be afraid. The Lord is with you."
Now that Christmas is coming, I am preparing the Christmas Gift to the World – the Lead out or Bring in Energy Theory and Devices.
The Gift consists of:
1. The horizontally pushed pendulum can increase the tension of the pendulum string. The vertical component of the tension of the string will bring in gravitational energy. For small angles, two parts of horizontal energy can lead out one part of vertical gravitational energy.
2. The Milkovic two stage oscillator is already an overunity device. The amplitude of oscillation of the pendulum does not decrease when the Weight is lifted. Energy must come from somewhere. This somewhere is the lead out gravitational energy.
3. The Chan Wheel is essentially the Milkovic 2SO with the pendulum replaced by the unbalanced wheel. It is easy to construct. It can demonstrate that the unbalanced wheel can bring in gravitational energy. Once the wheel is balanced, it will NOT bring in gravitational energy.
4. The mechanical engineers have been brainwashed to the concept of balance. Any unbalanced system is considered "evil". That is probably why they never seriously looked at the unbalanced wheel.
5. The Yuen Wheel consists of two or more unbalanced wheels. Experimenting with the size of the wheel, the magnitude and number of weights on the rim of the wheel is likely to yield the Bessler Wheel which can lead out gravitational energy to rotate for 53 days and do some mechanical work.
6. If gravitational energy can be brought in, magnetic or electromagnetic energy must be able to be brought in similarly. We can replace the pendulum with a magnet or do the equivalent of a horizontal pendulum with magnetic fields.
7. The magnetic or electromagnetic fields can be much more powerful than the gravitational field. We can change the polarity, the magnitude and the direction of magnetic or electromagnetic fields easily.
8. We need to focus on resonance – pushing the swing at the right time. If we do it right, resonance can show itself as greater brightness, sharp rise in voltage or power or even physical destruction (e.g. collapsing of bridges).
9. The likely explanation of the source of lead out energy is the Electron Motion or Electron Cloud Energy. Chemical Energy is due to the different Electron Cloud Energy associated with different compounds of the same elements. There is no violation of the Law of Conservation of Energy in Chemical Reactions. There is no violation in Lead Out Energy Devices.
10. We should be able to Lead Out Energy in oscillating, vibrating or motionless flux change systems. Working examples include the Milkovic 2SO, the Chan Wheel, the Pulse Wheels (Newman, Bedini, Wang, Tong , Ting, Laing etc.).
11. The WITTS 40K Electricity Generator is probably one of the best examples. The QEG is learning from it. Resonance has been achieved in multiple locations. It is a matter of time and Grace from the Lord for these QEG devices to achieve overunity and self loop similar to the parent WITTS device.
12. The Chan Wheel will be available for others in Hong Kong to validate, improve and replicate. It is easy to construct and multiple teams are encouraged to do so.
13. The Energy Crisis of the World is essentially over. The oil prices will continue to drop. They will drop even faster if and when China or USA reveals the details of the 225 HP Pulse Motor.
14. Rejoice. The Lead Out Energy Baby is born. It will never die from Greed, Ignorance or Trolls.
15. Blessed be the Almighyt. He is giving FREE, NON-POLLUTING, PLENTIFUL ENERGY to the World. The little angels will have a bright future. Amen.
