Well this is looking really promising now. http://youtu.be/rCh-U2DUM94
Quote from: JimBoot on 2015.06.28, 10:12:40
Yes Robert is doing a great job, also I am sure there are a lot in industry who are shaking in their boots if this comes to market at a cheap price ;)
The finished product, 2000 Farad cap the size of a credit card, cheap to make and ecological
https://www.youtube.com/watch?t=22&v=Mno-XDP2o2c
PS shortly to be used on SMD as the electron collector from the complex chemical reaction of electrode.
What is the voltage rating on his capacitors, 3V or so?
Quote from: Centraflow on 2015.08.23, 11:01:50
I watched that video as well O0
The only thing i noticed though,was the cap died quite quickly when he hooked up the larger motor.
So i dont think he has 2000F there.
Here is my version i have been experimenting with-off the grid you could say.
I call it the triphene capacitor,and Mike-you know how i make the graphene that the other two substances are added to O0
I never had much luck with just graphene,but when the other two substances are added,this cell kicks butt.
The only odd thing about it is it's voltage-1.7 to 1.8 volts,no matter how large the cell is.
Anyway-check out the size of it for it's capacity.
https://www.youtube.com/watch?v=yvBckUkjEfM
Quote from: poynt99 on 2015.08.23, 13:08:34
2.7v I believe, I can ask him.
Brad the cap is 2000F tested industrially. It will run the small motor for hours and the large motor for over half an hour.
Yours well done, yes I know how it works O0 1.7-1.8v is what it will do, in SMD by using a buck boost you can get it to self run with no battery until, "lets say", the fuel runs out ;) Power density comes down to surface area, bigger the area the more power (not voltage, that stays the same). By using nano holes you will create a huge surface area :)
Added: Foregot to say the self run SMD has to be kick started but then runs on it's own for days or weeks until the fuel has all been oxidised, the resulting product "in SMD" is hydrogen, the oxygen created the power, though it can all be configured in other ways.
That's impressive Brad!
Wishing you all the best and thanks for sharing
Luc
Why don't you put several in series and use as the electron collector in SMD along with the buck boost circuit I posted for SMD. Pre charge the collectors before switching on, so as to kick start it.
Quote from: gotoluc on 2015.08.23, 16:18:55
Luc
Thanks Luc
I am carrying out cycling test now-100 cycles so far and looking good.
But not much use if the cycle rate is low before the cap dies,and will no longer take a charge.
Quote from: TinMan on 2015.08.23, 23:10:30
Thanks Luc
Yes I agree, the cycle rate would need to be stable and if possible ideally higher than Lithium Ion cells. However, it looks to me that the weight and volume seems much less if we compare it to a 3.7v 18650 which have an average of 2.2Ah with size of 18mm wide x 65mm long and weighing around 46 grams
The best performing 18650 Li-ion 3.7v Battery at this time is the Panasonic NCR18650B @ 3.4Ah.
I had the opportunity to load test one and it's exactly as they claim. I think it's what Tesla Motors is using in their newest Battery Bank.
Very cutting edge stuff you're working with mate!
Luc
RMS's latest vid, showing tap charging with high voltage:
https://www.youtube.com/watch?v=DMiny6uma58
Did some tests myself last night. I used some self made graphene..or at least the hope at the time was it was graphene. Then, dunked it in jar battery electrolyte, from the experiments some of did when Brad showed his super cell mixture videos.
I see a link, not sure if any of it is correct of course.
Annnd didn't really get anywhere C.C
Will be trying some more ideas shortly.
All i'm looking for at the moment, is a variant that runs a JT until the liquids dry out. Then would seal it up, similar to wet caps traditionally.
May I ask what you are using as your insulator (separator), kapton is the logical one, but I have been playing around with compressed spun fiber, problem being to get it thin enough when compressing.
