Water as Fuel => Stan Meyer's Water Fuel Cell => Topic started by: russwr on 2024.07.26, 17:30:03
Title: The Mythbusters Hydrogen cell video for car engine
Post by: russwr on 2024.07.26, 17:30:03
The tv episode Mythbusters - called "Exploding Pants" is purchasable, and is about running a car engine on vertical water cell hooked to the carburetor, was a deliberate NEGATIVE set up. I counted 14 built in mistakes to not allow engine to run on hydrogen. The electrical circuit that was to be used was really called  "The Hydrostar". The complete original design is on Internet for sale. I have paper manual , but it's now being sold as a computer disc. Mythbusters did not use proper design, nor did they implement the required magnetic wire coil. Even gas engines use air as part of the blend. Their carb was completely closed off. Real usable energy related material will never be shown on tv, local newspaper or on radio general news. You have to your own research and see what others have already done. The man who designed Hydrostar was one of Stan Meyer's technicians in Ohio before Meyer was poisoned . Chambers went to Canada and filed Canadian + US Patent on modified version of Meyer's work.  His Xogen company had showed a display of HIS unit for publicity. The magnetic field energizes the rising ions in solution and increases energy content. Circular concentric pipe electrodes are superior to flat plate electrodes. Pulse quick current only for ALIGNMENT of water molecules polarity. Then pipes hit with high voltage DC pulses for way overunity hydrogen and oxygen gas. (No electrolysis at all)- that's old technology as of now. The Patent pages don't state it but, if flipping drawings pages back + forth , you can see it's easily done as connecting the wires of pipes to the resultant flyback high voltage coming from the wire coil.  !!  Hydrostar US Patent 6126794 by Chambers as studied and read for free on Internet.  (Put that in your pipe and smoke it!)
