2026-08-22, 06:46:37
Author Topic: Mikhail Dimitriyev device - an idea  (Read 117 times)
Chet asked of my knowledge of this device in a call last night and I was unaware of it.
It has started to bug me, but not to the point of disclosing personal thoughts on a more public forum, because i'm perhaps way off base.
All is good, nothing negative...just an idea that presented itself and that i'm not sure of, hence posting here.
If I may direct those not aware of the device, to the Energetic Forum thread: http://www.energeticforum.com/renewable-energy/12341-mikhail-dmitriyev-input-1000-w-output-near-3000-w.html
The basics, as I understand them, are that a wheel turns, with a small bike wheel flinging metal pieces outwards at a certain rotation spot. The increased momentum of the more distant weight pulls the wheel faster, using gravity as the prime driver for energy gain.
It linked inescapably to a project i'm presently working on, along with a friend down in Florida. His pendulum is set up on a much larger scale than mine. His build has OU possibilities from various means and has decided to keep it all hush hush, my project has gone in a different direction and so now finds itself unwittingly linked to the Dimitriyev device.
Here's my pendulum rotor concept video (1min 57sec): http://www.energeticforum.com/renewable-energy/12341-mikhail-dmitriyev-input-1000-w-output-near-3000-w.html
If it can be envisaged that the rotational energy will be in effect for a vertical rotor, mounted at the correct height, then the principle can be extended to that shown by Mr. Dimitriyev.
Using an egg shaped cam (as found on car engines), the rotor would turn and a magnet would be flung outward by the cam, on the opposite side to the pendulum magnetic interaction.
Such a force may then increase the speed of the rotor. The increase in speed will affect the pull and push of the magnets of the pendulum and so swing it too faster and/or further per swing.
Or - instead of the rotor increasing in speed, the extra energy is fed from the rotor to do electro mechanical work. A generator motor being driven by the axle on which the rotor sits (perhaps with an engaging/disengaging simple clutch). The rotor speed would then remain constant, but energy directed to power actual loads,
Being as the pendulum power source can be via any means, the output rotor energy is not directly related to the input energy required to run the pendulum.
By careful positioning, the rotor of my current setup appears to form little to no drag on the pendulum.
The pendulum is powered by a solar cell from a garden light, but will also run on tap water. An actual useful device would be powered by stronger means, but it shows how little power such systems need to begin running and then could have such power needs met to....run itself :)
So there we are, is such a thing feasible ?
Hi Mark
Just got in from a long drive home [too long] Woopy has the right idea on this [run without any motor]
If it will do that ,its off to the races from there ,and I know fellows such as yourself will have it
changing our planets orbit in no time............. :)
I took a Shot at trying to collect your idea into my Tired brain .
NG
Gotta hit the sack !
Tomorrow will be better
Thx
Thanks for the heads up, Chet and Slider!  Best wishes for your other projects as well.
I'm still in Missouri helping my son and his family, but have some computer contact.
Latest vid from Mikhail here:  http://www.youtube.com/watch?v=yRDZeXUEMvU
Fellows
I would like an opinion from all that can read this [brutally honest please]
I have made a first contact with the people that are running the Wardenclyffe site.[new owners Non profit]
and after mentioning this on energetic ,was informed that Eric D might have some interest
in being involved .
I have some connection to Higher ups in that project and have no doubt I could effectively put meetings together .
I need some advice here...............
Please remember the original intent of these pages is "privacy" [albeit towards a non private goal]
I will not discuss this outside of these pages.[your opinions or comments etc...]
Also There is no concern about the logistics of getting transport or housing Etc Etc for Mr.D.
thx
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-22, 06:46:37
