2026-08-25, 19:10:25
Author Topic: Self-Running Tilting Tray  (Read 7384 times)
Self-Running Tilting Tray video:
US patent, Dr Drush idea
https://www.youtube.com/watch?v=nVSM__R1bqs
« Last Edit: 2015-04-19, 04:53:22 by Valeriy »
Hi Valeriy!
Interesting concept. Did you try it?
Thank you!
I can't think of any reason why this would work. It looks as genuine as a nine pound note. One of your lesser offerings, Veproject.
sure I tried, and it works but on my video only :P
North-south on the left, north-south on the right or vice versa, metal ball, fixed tack in the center.  Any so called "V-gate" will operate in both directions regardless of starting position.  Instead of running from the opening of "V" to the point to an increasing field strength, run the opposite direction and use the weakening field at the opening of the parallel "V" to escape the field using gravity.    The longer you build it the higher it will lift the rolling ball.  It is difficult to wrap a "V" into a Circle, linearly- two parallel angled magnetic lines produce the same effect.  There, I told you.
« Last Edit: 2015-04-26, 05:34:16 by Overboard »
You tell me then
You tell me then
Won't do any good, will it? You will just find a new way to mock me Munchausen.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-25, 19:10:25
