North-south on the left, north-south on the right or vice versa, metal ball, fixed tack in the center. Any so called "V-gate" will operate in both directions regardless of starting position. Instead of running from the opening of "V" to the point to an increasing field strength, run the opposite direction and use the weakening field at the opening of the parallel "V" to escape the field using gravity. The longer you build it the higher it will lift the rolling ball. It is difficult to wrap a "V" into a Circle, linearly- two parallel angled magnetic lines produce the same effect. There, I told you.
« Last Edit: 2015-04-26, 05:34:16 by Overboard »
