2026-08-15, 08:58:26
Author Topic: Electric Outboard Motor from Washing Machine  (Read 3176 times)
Just a fun little project i thought i would share.
Here i am using the rotor and stator from a Fisher & Paykel washing machine as the main parts of the motor.
The rest i had to make--bearing hub,shaft ETC.
This will be a !!free energy!! motor ,as the boat will have solar panels on board  :D
So we will be cruising up the river with no cost in fuel  O0.
Anyway,here is part 1 of the project.
https://www.youtube.com/watch?v=93lmbUHOZwo
This is part 2 of the build.
Here i run through the rewire that has to be done on the stator so as we can run this 3 phase motor on 12 volts.
We also get to see it run for the first time.
As you will see,the rotor is not quite true.
I think it may have been bent when thrown into the scrap bin where i retrieved it from.
It did have a lot of other heavy things sitting on top of it,so i had some digging to get to the rotor.
But im sure i can straighten it up so as it is close to true.
This motor is low RPM,but it has a lot of torque  O0
https://www.youtube.com/watch?v=WBsF8iLGH4c
Only you could turn a washing machine into an outboard motor ;D
Well done O0
« Last Edit: 2019-04-13, 18:46:43 by Centraflow »
Here is part 3 of the build.
Seems we are very low on RPM  C.C,so a prop reconfiguration is required here.
https://www.youtube.com/watch?v=pi9FCIb0Meg
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 08:58:26
