2021-06-24, 15:31:02
Pages: [1] 2 3
Author Topic: What was missing in the early work on TPU replication  (Read 1466 times)
I have some observations to offer, and I can see people were really attempting to duplicate this unit from a standpoint of back engineering it in 2010. An extremely hard task with no understanding of where the energy comes from...or how 90 degree coils can interact when we know the resonance of the mass of the copper wire. Frequency specific effects can be used.
I noted an effect was discovered on Toriodals where when the wire gauge was changed it stopped working. Trying to hit these very specific mass vibration fields by tweaking is not so easy to repeat at all.
SM spoke of three different frequencies being used to get a self sustaining effect. An atom with three layers, basically that will self sustain at many different levels.
When the mass vibration vector at 90 degrees to the EM fields, is routed to align with the electric field, we get a 4x gain in the voltage with power behind it. The effect is frequency specific in the Mhz ranges, where the mass is resonant.
We also now have a resonance between the mass and the electron shell, that will vibrate up on it's own using turns ratio or voltage ratio.
SM put lots of wire and windings on the vertical coils and only one to three on the horizontal coil, this is close to the correct thinking for the E/P resonance effect that will self sustain.
658.20222 Ratio  V Electron  / V Proton
/4  =  164.550555  E/P
/4  =   41.137638  E/P  [Floyd Sweet VTA Turns Ratio]
/4  =   10.284409  E/P  [100 watt experiment Turns Ratio]
This works for coils with the same area inside the loops, I do not know about changing the area inside the loop but that can be ciphered if necessary.
Ratios that will "lock in" between coils at 90 degrees to one another in copper wire when the current flows through both in series.
SM's first experiment, where he wrapped a coil on a finger then passed the end back through the center, noting the small kicks that increased.
All you need is an F gen and some wire. Then start to cut the wire length to find the strongest effect. The length and the mass are components of this that matter as much as the frequency where it happens. SM found only two wire lengths defining the circumference of his two systems.
The notion this energy is from the magnetic field of the earth, to me is rather silly, as that field is far too weak. We would have to wrap the wire around the entire planet for that to work.
However at 90 degrees to that field we have strong Tempic field vibration coupling to the earth, running E/W and along these lines we have earth nodes at 16 foot centers. We have resonance lengths of copper that can accurately pin point them at 13.5 cm resonance. I would not want to have to locate my FE device on one of these, so I would use a different source of energy.  The E/W lines actually have power of motion in them to spin the planet, 90 degrees to the magnetic field of the planet.
Once we realize there are specific lengths of wire to generate specific effects, then we can use fractal math to increase or decrease the intensity of these reactive mass fields. The energy will form into segments with nodes at each end.
The copper atoms react to the fast voltage changes, they flare up with a mass field that rotates around to quelch the voltage that flies free of its normal control system. The more mass we have the slower it reacts to shut down the HV spike because the mass field in copper is coherent already, that is the entire mass has to turn it's angle of spin to get that voltage back down in control and correct all the atoms back to normal. With scalar coils on a copper sphere we can slow this down to produce longer lasting separations.
You will not actually ever understand a copper atom, until you make a spherical copper transformer with three coil alignments on it.
Now you can feed one coil and monitor the other two in real time and see what happens inside a copper atom in a wire as we move up and down the frequency spectrum from sine to square waves of fast transition. Then change to a scalar cancelling input coil, and see why that does not destroy the energy of the wave. The various opposing flows can be reassembled to put the power back in the output, when the input is cancelling. This works due to the geometry of the fields flowing around the copper atoms. The entire square wave can be recovered in the output coils at 90 degrees to one another.
Specific ratios of frequency sets can create self sustaining forms of fields that will self power and take on a load, reacting to that load to power it, and  then when the load is removed, reacting to that to drop back. In copper both the E field and the T field are coherent in the entire mass, and when they come into a self sustaining resonance ratio, they begin to self power, as an atom self powers.
When we take a wire with a voltage on it and a current, we bend the wire to 90 degree turn, the T field hits the E field between the two and can create  a 4x boost, at specific frequency ranges.
I think SM did pretty much reaveal all these things, but had no way to communicate why or how it worked, thus blind back engineering rarely worked.
No one speaking about the mass of the wire, or the ratios of the turns, or the large field bubble all the way around it that would turn a compass, exactly what we find with cars having Joe Cells in them that also self sustain that type of energy field.
SM had to fight with the phi ratio runnaway condition, and never realized the pi/2 would have completely stablized it, already present in many electronics formulas. He merely stated you have to tune it slightly off the 5 khz peak where it explodes the wires.
phi = 1.618...
pi/2 = 1.57079...
A very slight change in ratios to create a circular never ending loop between the two field forces. Where phi will take off constantly growing, pi/2 will stablize at one diameter and frequency ratio set.
He never revealed the frequencies he used to hit on the Self sustaining form of power, but he did reveal there were inertial mass responses, or gyroscopic effect to moving the coil system when it was operating.
If one believes they can engineer that without knowing anything about the mass of the atoms, or how they react, it will truly be hit and miss tweaking.
There would never be comprehension of how it can be engineered and changed and still work.
The TPU was a good experience many years back for me, and I realized I would need to have more understanding of how mass is generated, and how it comes into play with the electric field.
How does an atom couple an electron field at Ghz range to a Proton [Isotope] field at Mhz ranges, and create stable matter? Matter that continues to recover its form and frequency over an over, without any external batteries?
How in the world can these really high frequencies be down-shifted to power a field at 60 hz?
These are the right questions.
DaveL
These question can be anwered with a couple of discoveries from very meager experiments.
We do not need to spend a lot of money to answer them we only need undersand the correct concepts of the three field forces.
How do we down shift frequency and maintain the power of the higher frequency at the lower frequency output side?
This is the one that throws most people into wild armchair theories, and where they totally get lost, with no good results.
It should be obvious electrical fields do not work like this. One can use turns ratio to change the power to a different form or voltage, but in this transformer process power is always lost. We do not see even a 1 to 1 let alone a power gain present.
Mass vibration is the answer, and I can state the rule, although few would believe it going in, it is too simple.
Geometric reduction of mass vibration gains power as we move to a lower dimension of size, with the coupling to the larger dimensions of size present as octaves. In other words, we couple to a large field of space, and using geometric octaves, the energy will flow towards the small resonance packet we provide it to resonate in. The loose term is inflow, in meditation and Orgone devices. The scientific term is a "convergent field."
This is where the energy comes from, and the nuclear part of the atom teaches us how it works.
Understanding of this concept, requires a calculation between the dimensions of the space and it's frequency.
This is similar to the dimension of an RF radio wave but far more dense and small a field, as it oprates normally at very much smaller dimension then the electron shell. Yet we know the strong force of every atom is much more powerful then it's EM field will ever become.
How can we relate mass vibration dimension to it's frequency?
This is the part few have comprehension of, and even fewer believe is real.
I assure you it is based on current NMR science knowledge as well as data we derive from current science, and a few real experiments.
There are highly specific frequencies that bring up mass vibration fields which can self sustain, at any dimension of octave we would chose.
We then measure the size of these vibration feilds over many trials and note the relationship between scalar coil frequency and field dimension is
mm = khz.
This is the part we need to understand, as with higher frequency we have more volume, and the energy flows towards the smaller volume/frequency.
Energy flows towards the smaller fractal for mass vibration fields. There is no loss in this energy form, it travels directly straight through anything, through it's mass. This is one reason there is really no way to shield from gravity using a natural material.
Electric field will flow towards a larger conductive area to expand outwards as radiant energy, and mass vibration will pull that energy back inwards.
That is a big part of how atoms self regulate their dimensions and frequencies so accurately.
Nissem tells us the Proton is a fractal of the universe. Making it a very powerful field force, considering the giant inflow field it would have access to.
We can however intersect this inflow field at a larger point, and have the same energy flow into a specific element we cut to correct dimensions to vibrate it up at larger size.
There is enough energy in this convergent flow into a proton to create mass, from the background field.
This is how we can downshift a frequency back down and gain power in the process. Higher frequency = more power in a wave, right out of the physics textbooks. When all thqat power couples into a smaller volume of space and flows towards it, that is how we gain enenrgy and bring the energy back to us.
EM losses are always into the upper frequencies during times of loading and high pressures on the field, energy escapes into the noise floor and the frequency rises.
Mass vibration can target a frequency and pull it back down and inwards.
You cannot have free electricity without this understanding of how to gain energy from the background field through the convergent process.
We calculate this as frequency/volume, or frequency/area, or frequency/ distance depending the type of the 3 field forces that exist.
These are the calculations that work.
Tempic field is linear          mm = khz
Electric field is an area       mm squared = khz
Magnetic field is a volume   mm cubed = khz
We also can have three levels of vibration if they are not at 90 degrees or as stated in quadrature to create another field force listed above.
The three field listed about are all constructed from the first one with different arrangements of multiple T fields.
This is more then you need to know, however to begin working with mass vibration fields that pull in energy into a device.
I speak with no connection to spirit, and one says where is the Love.
I speak with the connection to higher self, and one says, that is too crazy to accept!
It is rather humorous to me, how different we all are, and how each person changes with new information.
I Love you all! You are mankinds future geniuses.
What we recieve free, give free.
DaveL
In observing how these fields operate, we have not violated any current scientific laws per say, we violate only the laws of our economic system, which is not based on natural law at all, which gives us all we need to live for free.
We identify where the energy comes from, and that it is not created locally, but is powered from a set of vibrations in a field fabric that permiates the entire universe. Basically what Wilbert Smith stated, and now I fully believe that is true from direct experiments.
We cannot and may not ever know why the universe keeps powering these vibrations, we can only recognize that it does, and it does not hold a grudge against anyone, or withhold this power from anyone whom learns to use it wisely.
Also built into the consciousness of the universe at 4th density in the intelligence to self correct our applications of these fields. If we get it really wrong and cause danger, the beings of 4th will intervene to assist us to shut them back off. It is said that the nukes can no longer be used because "they" have shown on many occasion they can simply shut them off. I do not know if that is true, but I hope that it is.
I think the TPU was shut down due to not realizing how to properly control it. It either heats up and dies or it explodes, and that was not a great design at all. SM knew it would have to be developed further to be useful. He was seeking investors to do that, but free energy is not compatible with a society that is not free. Because he did not have engineering control or understanding the Grey ones would not allow the device to become widespread.
When we can demonstrate accurate understanding of the field forces, we will get a green light from nature to begin using them correctly, in balance, in self sustaing form. I do not do anything publically without "their" permission first, that would be unwise.
DaveL
ESR NMR
These terms need to be understood, they are from current sciences that one can learn about now on the internet without leaving your house, an amazing thing today that was not availible in the old days, where we had to go to a colege or get a book.
ESR Electron Spin Resonance
Basically the frequency of an electron changes with an applied magnetic field, by a specific ratio.
NMR Nuclear magnetic Resonance
The frequency of the nuclear magnetic resonance also changes with an externally applied magnetic field by a specific ratio.
These ratios are different, but because they are both related to the magnetic field intensity in Tesla we can extract the constant ratio operating between them if both are found on the same piece of copper wire with the same current flowing through them generating the same magnetic field through each atom.
We then are able to extract a ratio of the two frequencies that is a constant inside each atom along the copper wire circuit. It may vary between atoms if the wire is approaching wavelength diemnsions, but at every point along the wire the ratio between them will be the same.
That ratio is extracted in a document found here from data freely available to anyone, it is not secret or hidden at all:
E/P Gyromagnetic Ratio and Fractal Extraction
What is not realized in a system with changing values of magnetic field effecting both electron and proton, there is a way to coulpe energy between them from a ratio that never changes. Gyromagnetic ratios, with frequencies that change, by the same amount, can also be related to one another.
So if the electron vibrates at a frequency of 6 Ghz, on the surface of the copper wire, we can be assured the proton is vibrating at 6Ghz/ 658.20222.
The ratio is a constant although the values can be in a state of change.
Now one of the discoveries of "mass vibration energy" is that we can couple to something using a ratio, and the same energy will couple across into our mock up system to catch some of that energy in a system that is not changing.
This may be a mind blower but it works in practice with mass vibration fields.
In this document we use a scalar coil and F gen to very accurately beat the E/P ratio against the background field frequency of 333000 hz and we vibrate up a large SS bowl, and remove the coil and the bowl continues to self power, with no external EM applied to it.
One can extend the hand down into the bowl and feel this dense vibration field bubble present in the air where it converges at the center of the bowl stronger then outside around the bowl.
We have extracted a field force from the ratio between the electron and proton frequencies that exists in every atom.
That is really an amazing example of extracting energy from a relationship / ratio present in all atoms.
Pictured in this document are the two tools with enough accuracy to raise Isotope fields from the back ground field as well.
That F gen has more then 6 digit accuracy, down to 1/100 of a hz. It is also very cost effective.
The technology finally caught up to the point of working these fields with total repeatability.
IE: You cannot expect just any frequency will generate free energy, that is not how it works.
We have to quantify the sources of the energy, and then show how it can be made to flow through an aparatus to become useful energy matching our current powering systems and supporting them.
Convergent inflow energy will jump between elements of a device, using many different methods, but ratio is one that makes it very powerful and easy to grab.
DaveL
Sine Wave targeting, versus square wave slop.
Square waves are shock, earthquake to an atom, very upsetting and very unnatural.
I believe it is the Fourier Transform which can be used to extract a spectrum of frequency blips from a composite wave with non sinusodial wave structure.
We stick in a square wave and out comes a full spectrum of blips at many single points of frequency.
Depending on the rise time of the wave, these blips of splatter, will go higher up the spectrum.
If one of these frequency blips happens to hit a resonance of any kind EM or Mass, it will send energy there.
This is an extremely wasteful kind of system where we can tweak around and never really know what is happening with resonance at various levels.
Yes we will hit on things that work, but consider how stupid this concept is when we realize accurate targeting of the correct frequencies can do what we want without all the splatter across the bands.
We observe a copper coil system fed by a spark gap, and realize the coil will turn the arc into a sine wave, rounding off the corners. All the off frequency energy of the arc is wasted spectrum. We set up an F gen and scan the coil for its resonant sine wave frequency, and discover a sine wave input is a more natural way to energize it using far less power. We do not need to produce the intense energy of a square wave unless we do not know what we are wanting to resonate up. We can understand why Tesla was doing this, but are we not past that yet?
Lets hit all the atoms with a big hammer and see what resonates up? Slop.
If we happen to hit on an SSF we would never understand why, and have no clue what was happening at the nuclear level of the atoms.
As we begin to realize how Self sustaining fields are set up, we can naturally move to using sine waves with far less energy to accurately target correct resonance of both EM and Mass vibration. Two or three frequencies in the end will set up complex fields that work as atoms work to recover themselves.
In order to make this transition we have to learn more about what frequencies work on the nuclear level.
Also we must realize the dangers of EM, versus mass vibration, and which one can be used to downshift frequency along with the power.
Martial arts is about speed power and accuracy. We have to learn where to strike, and then one blow can take an opponent down. If the frequency of that strike is two times faster then the opponent can react, there is no defense possible.
We could use a hand gernade and hit the entire body, but is that really necessary, it is more destructive.
We target correct frequencies, and a 5 volt F gen will do into a scalar cancelling coil, that pulls up the power of the bismuth core with greater mass that will then vibrate itself, using a force that is 137 times stronger then EM.
Is this beginning to make more sense?
Mass into energy.
DaveL
TPU spins the magnetic field at the center of the coil system.
The horizontal coil would project magnetic field with poles runing up and down, and could not produce this field.
The large coils around the toroid if wound naturally would not produce an external magnetic field least of all make it spin.
There is only one kind of coil which can project one pole outwards and one pole inwards. A scalar cancelling coil. Current must flow opposite directions through two wires of a coil system to turn the magnetic field inwards and outwards and cancel it in the normal direction.
So now we realize that we can turn one pole inwards and one outwards, but this still will not make a compass spin up.
We have to use three coils, and two will project a North pole inwards while the other wired backwards projects a South pole inwards, the compass then moves to point at one direction.
Now in order to move this direction of N/S pole which is based on the wiring direction of the scalar coil, we need to set up a second layer of the three coils with the wiring set to move the inwards poles to the next coil location, and then a third layer of scalar coils to again move the South pole to the third coil location. Now we can control the direction of spin, where using only two we could not control the direction of spin.
Now if we switch the 3 coil series on in sequence, we will rotate a compass at the center of the toroidal coils.
Technically this will work, but it may be overly complex using 6 wires, if there is a better way using less wire.
If we instead make three layers of single wire on each of the three coils around the ring, we wire one wire backwards on each one , we still have three circuits, but in each one the South pole will move to point inwards at a different location around the ring. We use 4 conductor wire and wire two against the the other ones so we get a smooth field involving all the wire with three circuits in series around the coil system.
We now have tri wire coils, with three circuits running between them, and if we set up a field that then circulates around all three in sequence we have our spinning magnetic field pointing inwards. This is something we did not understand about scalar cancelling coils back then.
The other thing we did not understand is that these coils can also effect vibration on the mass of the wire, at the nuclear core at very specific frequencies.
Now the second point is that this spinning magnetic field gains speed as the machine comes up. This means it is not frequency locked using electrical oscillators. The field is accelerating on it's own. How can that be done?
We put three different frequencies into the three circuits, each one producing a different orientation of magnetic poles and we do this at frequency ratios between three stable frequencies that produce an acceleration of the poles moving.
Now we get time points where two coils go South inwards and one goes North inwards, then this reverses, but we keep the spin in the same direction.
A sqrt of 2 ratio will power between two frequencies and a pi/2 will stablize. A phi ratio will accelerate.
Knowing what what we know now from mass vibration fields we may be able to now get this working.
The mass will have to rotate also and with three coils it needs to be jerked at 120 hz in 3 phases.
This may come down the three equations being solved simultaneously, to set up two spin systems to self power, mass and EM fields in resonance.
Also rather then targeting the 5khz frequency that causes wire to explode from the mass outwards, we may find a better choice the pulls inwards.
SM ofcorse was looking to bring more energy outwards into the entropy side of the EM field at the cost of major stress on the horizontal loops.
However we do know that it is the small horizontal loops that experience the mass vibration field, and then sit inside the scalar coils with one pole pointing inwards at the three points of outer coils. This is exactly where we place the bismuth core in a scalar coil to access the nuclear level of the atoms.
I would hope this begins to shine some light on what is going on in the TPU, I hope others can follow this.
I believe this can be done more smoothly using correct frequency sine wave resonances.
Scalar coils do not need to be hit with square waves to manipulate the nuclear center of the atoms.
We simply have to locate the mass resosnce frequency of the copper.
DaveL
The last step is to couple the final EM wind around the toriod with the horizontal wire loops to establish the E/P ratio of vibration that will self power as well. These two fields interact at 90 degrees. We can chose any 4x fractal ratio off the E/P ratio.
This should be pretty close, and run with a lot less heat. Best guess.
It should also then become nice to feel it's energy.
Further, when we are done we will have a total comprehension of what we are doing.
DaveL
DaveL
Hi Dave,
Just to confirm, it is the toroid to horizontal winding ratio that we are going to set to any 4x fractal ratio off the E/P ratio, correct?
DaveL
I would submit a much easier to understand explanation based on more conventional phenomena...
What is it we seek to do?, we wish to move some electrons along a wire which constitutes an electron current we can utilize for practical purposes. Normally we would use a changing magnetic field to produce mutual induction however as we know the changing magnetic field is proportional to the current dissipated in the inducing coil. Thus it should be obvious mutual induction or a transformer action cannot produce the effects we want. This is true because the rate of dissipation in the inducer is always greater than the rate of generation in the induced.
That being said, this is not true of a travelling wave like disturbance which actually moves versus alternating in place like a standing wave ie. transformer action. It's actually a very simple concept and we could think of it like a beach ball in ocean waves. The ocean waves alternate vertically and unless there is some impetus in either direction the beach ball simply alternates vertically as well producing an energy balance. However if there is a slight wind then when the beach ball reaches the crest of the wave it can move onto the slope or gradient rolling down into the trough of the wave. Then as the wave alternates the beach ball is once again lifted and once again rolls rolls down wind and the cycle repeats itself. This is not a true travelling wave like a solition but an alternation bias not unlike the beat note in between two frequencies which can mimic a solition.
I believe when SM implied that the perfect wave form timing should be avoided he was referring to the fact that the induced energy or beach ball could become a force in and of itself. In which case it could modify the slope or gradient in which it is moving through the fact it is moving. That is, not only does it become independent of the source but becomes a source within it. We could think of it as the beach balls own inertia not only propelling it along but modifying the wave form which propels it as well.
“Progress is impossible without change, and those who cannot change their minds cannot change anything.” George Bernard Shaw
DaveL
Nice post AC ;)
Thanks Mike
It's important to break things down into there most fundamental form so it's easier to understand. Even more important is to justify our argument with a logical line of reason.
As if to say...
1)A DC current may flow from the source but the energy diverges from it and converges on the sink. The current is born from the source and bound to it.
2)An AC current may flow from the source and alternate direction but the energy diverges from it and converges on the sink. The current is born from the source and bound to it.
3)A solition wave can move in any direction regardless of the current flow because it is not bound to the source which produced it. It is completely independent of the source thus can vary in velocity and direction. As such if it were to find itself within any external gradient of force it can accelerate/decelerate and this change in motion represents external energy.
The line of reason is intuitive, something bound to the source which produced it cannot act independently.
DaveL
I enjoy some of your explinations on what energy is, very well thought out.
So what turns ratio would you use?
DaveL
I really enjoyed you presentations on what is Energy, and it really does prove perpetual systems are possible.
Right out of the testbooks, energy cannot be destroyed! I Love that.
TPU
As I understand it the goal is to produce useful eletric power, and thus the vibration will travel towards the load, as the - EM attempts to escape it.
Power = Voltage x Current x power factor  as I recall. Phase thus determines Power Factor.
The positive charge on the back of a TV will throw a man across the room with no burns.
The negative charge will burn the man in his tracks, without moving him anywhere.
The positive charge has the spin of the mass of the atom behind it, the weight. Electrons operate as microwave frequencies and simply burn things and heat them up.
Waves all travel through a medium, the medium in copper is consistent, but has two layers Nuclear and Orbital.
The positive charge spins in the opposite direction as the negative charge inside these two layers.
In a powering circuit there are two flows of energy moving aginst one another.
SM also spoke of this, two waves crashing into one another, he did not relate that one of the waves was the nuclear, and one was the orbital.
However in the first experiments we trimmed a wire to maximize the platonic form energy, that exploded the wire in platonic form, and that kind of energy has now been identified as an Isotope field, which also gnerates platonic structures.
When the mass of the copper begins to gyrate and spin, that indicates he managed to alter the spin on the positive charge side of the atoms, which we had never witnessed before in any electrical device with no moving parts. The nuclear layer in the copper began to spin it's mass, as a larger coherent field. So what do we know about controlling that layer? NMR technology hands it to us.
Powering circuits do not physicaly vibrate until we place a load on them. Loose wires on a transformer may begin to vibrate under load.
The TPU vibrates without a load, very unique.
Many phenomena of the device, are very different then in normal EM devices, however the goal is the same, to make a circuit that powers a load, and in this loop of energy there must be both a source of energy, and a transfer of that energy through a medium into the load.
That is a very simple concept and does not defy any laws of physics or electronics at all.
For a soliton wave to push something through space it must couple to the mass of its atoms and provide a vibration system that creates one directional thrust. So this is a good mental model, because in the TPU we are coupling to the mass where the positive charge comes from, and are making it become the armateur of a motor by making it spin up inside all copper in a coherent way. This is another of the indications it is a nuclear mass effect, as these field follow a specific law of fractals, they can be expanded or contracted in size and will operate at any level of octave of dimension.
Scalar coils on the ring cause one pole of the magnetic field to converge to the center of the device and the other pole converges inwards into the wire running inside the coils. This has never been done in any conventional motor system I am aware of.
Positive charge has to be rotating in the opposite direction of negative charge, and we have to grab each and manipulate them independently of one another between the two atomic layers. The two waves crashing through one another with different frequency hooks.
In other words we have to end up with the power cyceling at 60 hz on the positive mass loop of wire, as the negative charge zips around it at the correct harmonic in the other direction at much higher frequency. About 658.2 times faster for the two to couple with a T field lock.
We manipulate both the ESR and the NMR frequenices to take on a new relationship that moves it away from the zero point stability to another level of stability. This is a density hop, changing the balance between the two layers in the atoms.
We are working with three field forces at 90 degrees, on two layers of the copper atoms.
Where all three fields become coherent at larger fractal dimension, we have a larger atom.
SM identified only two dimensions of the diameter of the device that he could get to work.
This is a good indication also of a fractal at work, from the Isotope level of the copper atoms.
Mankind will come to have understanding of this, as we grasp deeper into the atom over the next years to come.
Electronics is not enough to underswtand this phenomena.
DaveL
The piece that is missing from NMR science is that we can develop a coherent field on all the Protons using only vibration resonance frequency, and we do not have to use them with a 90 degree 1/4 wave magnetic field pulse.
The range of a magnetic field off iron is very short. When you see a giant field moving a compass at 5 or 10 feet away, that field is riding on top of a nuclear mass vibration field. The T field has much greater range, then the E or M fields.
I know these experiements may be beyond what many in this field of study have played with, that is my reason for being here.
Banging your head on trial and error with 90 degree coils, will never make sense until one realizes what is happening on the nuclear mass level, and that the copper atoms are extractors of energy from the background field.
DaveL
Primary Calculation for a stable interaction.
When I saw the result of this calculation, I immediatly thought of the TPU.
This calculation gives two frequencies, designed to pull energy into the E/P gap, but shoud also stablize at a pi/2 ratio.
F1 15,675.88 Hz
F2   9,979.57 Hz
It is derrived from the E/P ratio as well as a pi/2 SSF.
E Field Creation    2021 - 5 - 27    Dave L
F1/F2 = pi/2
F1+F2 = sqrt [E/P]
F1 = pi * F2 / 2
F2 = 2 * F1 / pi
F1 + (2*F1 / pi) = sqrt (E/P) =  sqt (658.20222) = 25.655452052146732735028762406164...
F1 (1 + 2/pi) = 25.65545...
F1 = 25.65545... / (1+ 2/pi)
F1 = 25.65545../ 1.6366197723675813430755350534901
F1 = 15.67587810272682713754973811585...
F2 = 9.9795739494199055974790242903143...
These are two frequencies that will match the two relationships, to push 1D Tempic field energy into the Electron Proton Gap, with the self sustaining relationship at the 2D level to make them spin against one another. I think...
First Guess!
Checking our math
F1 + F2 =  25.6554520521... which matches the sqrt of E/P
F1 / F2 =   1.57079632679...  which we recognize by now as pi/2
This describes two circular form diameters, which will interact to produce oppositly spinning fields that couple on the 1D field at pi/2 and on the electric 2D field at the E/P ratio. If the fields go out of phase by 90 degrees as expected we will create a generator of electricity between them. Best guess.
A diameter of 15.68 mm does in fact create a circular form in the caliper gap, and more then this it feels electrical.
15.68 / 9 = 1.7422 TDF in case the field gets stubborn.
DaveL
F1 15,675.88 Hz
F2   9,979.57 Hz
Are any of the pulser circuits being used today accurate enough to target these kind of frequencies?
DaveL
F1 15,675.88 Hz
F2   9,979.57 Hz
DaveL
The most up to date DDS type of FGs such as the Rigol DG4162 is easily capable of this accuracy in frequency however, the actual switches used such as mosfets will have a finite rise time on their drains due to the internal non-linear capacitance of these junctions which will change the phase and possibly the duty cycle of F1 and F2.  How much this would affect the outcome would have to be determined.
It is not apparent if SM had this tight of frequency control in his TPUs.
Thanks for this info!
This thread reads like a collection of gibberish and every buzz word for alternative energy that has ever existed.  :D   :o   C.C
Why did the first TPU turn off (output ceased) when flipped over?
This is THE GREATEST clue to it's operation.  It's so profound, I find it hard to believe that whoever suppressed this device allows those videos to still be on YouTube.
Might not be anything but I just notice your frequency of 15,675.88 Hz is very very close to 2 times Schumann resonance when multiplied by 1000.    :o
Two reasons I can think of are:
1) The earth's magnetic field
2) Rotary magnetic inertia. (Can't remember the inventory, might have been the Adams motor, but it was claimed that once the motor was spinning, it would be easier to spin up again in that direction. Something about the space within becoming inertial).
Both are relevant.
1) The Earth's gravitational field was used in the first TPU.  No feedback to boost that field, low output, etc.  The part that SM never seems to conclude is that the reverse is also true.  You can create a gravity-like field.
2) You are referring to "virtual inertia", discovered by Harold Aspden. This is present in the TPU as the field takes time to spin down.
The rotational direction of TPU's is not forced.  They rotate is the same as the Coriolis force, so opposite in north/south hemisphere.
Driving the rotation has the advantage of not changing when in different locals.
Based on the time frame of the TPU's development, I'd guess some friendly engineers who worked at RCA shared some "thoughts" with SM to point him in the right direction.  These devices have been around since at least the 1950's.
Group: Mad Scientist
Would be interesting to know why it might have affected it.  Simply moving a coil through the air wont generate anything via earths mag field, no matter which way you do it as the fields would induce all the portions of the windings around the coil at the same time and polarity, so it cancels out.
Had taken apart a small compass module for a rear view mirror years ago, It had ICs, etc, but also had these 2 small rectangle blocks perpendicular to one another. When I applied magnification, I could see the windings. Very fine wire and apparent core, each sealed in maybe clear epoxy to protect the fine wire. In the pic, you see the coils and I laid a short length of 42awg seen above the coils  in the pic to compare. The 42 is just shy of being thick as one of my hairs on my head. these coils seem to have smaller awg.  But how did they use those coils to determine N S E and W?   Only answer I could come up with was that the coils were input with either alternating pos then neg pulses, or synth ac input, and then probably measured for any bias against each alternating pulse or ac swing to figure it out. Like a magnet biased core of a transformer or inductor.  if the pulse polarity in one direction seems to have more induction one way and less the other, etc etc,
So maybe that would help figure out the coils orientation in the tpu by thinking on those lines.
Example..   If we have a coil with so many turns and say 2in inner dia, and we aim the poles of the coil N and S, earths flux would be present all around and in the coil with flux direction being on axis with the coil.  So if we have a smaller dia driver coil set inside the larger coil and we pulsed it one polarity, and then the other, there should be a difference in the output of the 2in coil for each. One polarity would induce the larger coil with earths mag field influence in repulsion of the driver coil and the other polarity pulse would be in attraction to the earth field, thus there should be a different outcome in output for each polarity.
Lol, take it a step further, wind a 10in dia coil, align the axis with earths field, then set a bunch of driver coils around the outside or even inside the 10in coil diameter, with their axis facing inward toward the center of the 10in coil, or inside dia facing out from center, and pulse them all at the same time. then the earths field that is on axis with the 10in coil would be manipulated in the proper direction to induce the 10in coils windings to produce output. And with the orientation of the drivers to the 10in coil, there would probably be no influence on the drivers if the 10in coils is loaded because of the perpendicular orientations of the coils with the 10in coil. ??? ^-^
If the tpu was earth field sensitive in orientation, then maybe these things I say may help get to the meat of the matter at hand. ;)
Earths field is not weak. We see mech compasses and they are damped or have very weak mag fields so they dont react too fast and teeter around. But in this vid I did, I was very impressed with the earths field using a neo mag disk.  Found this while trying to set the disk up on edge for an experiment and I couldnt get it to stand. Was like, what the..  Thought I had a screw in the bench or something close that was affecting it. But as I went along I realized it was a compass effect. Never seen this before that time, with years of magnet play beforehand. Earth field is not as weak as one might think when it comes to this stuff. While I was going to the vid just now, there was an ad on my vid!  ??? Im not monetized. can they do that? :(
https://www.youtube.com/watch?v=6gOO7OHHeMM
Mags
Flux gate magnetometers use core saturation to measure the earth's field.  Usually they have a circular ring core (or a rectangular ring) that is driven up to saturation.  Then the earth's field adds to the field in one half of the ring while subtracting from the field in the other half.  The subtraction causes a much larger flux change than the addition, so the voltage in coils over each half is different.  Needs two such devices to get x and y components from which the field vector can be deduced.
Well I suppose ring cores are one way of doing it. But has also been done with rod/bar cores. Would the same reasoning you describe as to how it detects the earths field apply to these bar cores?
Mags
If you make an oscillator using a magnetic core ,it is interesting to vary the bias values so it will not start until rotated.
It will also show a different wave form depending on  orientation .
It gives the impression that the earth field is quite strong and useful .
Lester Hendershot was allegedly working on a "better compass" when he was developing his device.
Small torriods and reed switches and magnets are fun to experiment with .
There are 3 pole glass  reedswitches  now available with no/nc
https://www.aliexpress.com/item/10000001194548.html?spm=a2g0o.productlist.0.0.75ee759cu9ZkD4&algo_pvid=72b48e0c-d2fe-408a-8a8b-be71ba31c841&algo_exp_id=72b48e0c-d2fe-408a-8a8b-be71ba31c841-3
They  offer more options .
Pages: [1] 2 3
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2021-06-24, 15:31:02
