2021-10-21, 03:33:12
Pages: 1 2 [3] 4 5
Author Topic: Critical Thinking  (Read 3132 times)
Lets look at orbits are they just falling or are they accelerating?
Physics Classroom
Because travel in a circles requires a change of vector motion, it is maintaining it's velocity, it is accelerating.
You cannot snow a person who knows their physics.
Dave L
So now that we have identified Gravity as an accelerating field force, which can create perpetual motion of an object in orbit, having a constant acceleration, and it never wears out or looses it's charge, we realize the ISS international space station is traveling around the earth on free energy.
Mankind has finally made an advance that is using free energy of the universes built in dynamics.
Tesla's dream realized, using the clock work of the universe to accomplish perpetual motion.
I find it rather interesting that people are so wrapped up in the concept there is no free lunch, all is entropy, they cannot even recognize where free energy already exists when they ponder it. The astronauts get a free ride around the planet, using no fuel other then minor corrections side to side to change the orbital distance, and the area under the curve is a constant, which we can use calculus to determine.
The mathematics is known in our current technology, but it is more then just memorizing a formula, we need comprehension to use the formula wisely.
We also need a feel for the forces, and to begin to recognize there are only 3 necessary to accomplish everything we can observe.
Just as there are only 3 dimensions of space we need to describe any position within it.
Now recently they have been levitating ping pong balls and other light objects using sound vibration in the air. This can change the viscosity or density of the air to a point where a standing wave can support the weight of a ping pong ball and hold it up in the air.
They use two sound waves at 90 degrees to one another to accomplish a stable position of the ball in most of those experiments.
The Field Fabric works similarly at near light velocities, according to Tesla. He used the word Ether as I recall, same thing.
When we play with two magnets it becomes obvious we have force over distance that delivers power through space. It is not very realistic to believe there is nothing between the magnets. We must concede that the magnetic field propagates the space between the two magnets and delivers motive power between them. Magnetic field is the one with the shortest range, and in electrical motors they do everything to reduce the gap between rotor and stator to utilize the greatest power of that field. It is a short range field force and calculated as a volume in space.
However off the end of a magnet we discover the power is rated as the flux lines per square inch a 2 D force.
Indeed if we start to stack 1 tesla neo magnets, we discover it does not matter how many we place in the stack, the power off the ends is no stronger then one of the discs alone. We can stack up 20 or 30 and they are still only 1 tesla off the polar ends.
The only thing we gain in using more in the stack is the separation distance between the poles.
Gravity works in the opposite way, as we add more matter, the weight of an object increases with the volume inside it, a 3D calculation.
Yet according to our physics people Gravity falls off in intensity as a function of the square of the distance, a 2D field force outside the object.
And of course all objects spin around their center of Gravity, not any magnetic poles that happen to appear on the object.
It should become self evident Gravity is not an electrical field force as its reach is far greater then an electric fields reach in space.
If gravity was electromagnetic, then every time we shoot a radio or radar beam at the moon it's orbit might be effected.
The planets are not that fragile. Tremendous magnetic shifts in the sun do not seem to change Earths orbit at all, because it is related the center of the suns mass and the center of the Earths mass.
Like the levitating ping pong ball, gravity is a vibration in the Field Fabric rather then in the air.
If we succeed with an 89/50 application to a car, and experience the loss of inertia with respect to the earth, we also realize this is done using a vibration technique, and not an electrical technique.
We can use an electrical cancelling system to set up the self sustaining field at the correct ratio off the engines circle of power, but the EM is not the driving force we are targeting. Pitting the two fields against one another generates a vibration system, and with it we can target mass vibration, in atoms as well as in the gravitational field, and set up field bubbles to change how an object interacts with Earths Gravity.
The field reach on vibration can be done from inside the car, and EM would have little effect at that range using only a 5 vdc power supply.
Understanding of the Tempic field force opens us to a lot of manipulations we thought were impossible, with very little energy expended to set these fields up. The cool part is that after we set them up they self power.
In martial arts we trained to use the opponents power against them, and the best way to accomplish this is using circular motions.
While a punch coming straight at us is very easy to deflect at 90 degrees, if we instead ride it to the full extension then spin it back at the opponent using a curve, his own retraction of the arm adds energy to the defensive response. If we connect his center of mass to ours, and then spin him around us only a little we can hurl him across the room. The spin gives tremendous acceleration of velocity and when we let go he goes flying much further then a straight on kick to the pelvis. This is similar to using a sling shot.
The geometry of angles of alignment is very important, and in women's self defense I had little old ladies hurling me across the room.
Very empowering when they realize they can take down a man!
Now we investigate Aluminum, and with a coil pulsed, we can see Aluminum will shoot through the air like a projectile, with a powerful pulse of EM, but iron will not do this the same. To accelerate iron we must make a long line of coils and cycle the field down them.
Aluminum is one of our Antigravity metals, as identified by Crandle in the book "They all told the truth".
Aluminum atoms nuclear center, where the mass is located can be spun into a cork screw that alters is acceleration through space.
It's abundance is 100 percent, every atom in Aluminum has this diamagnetic response, and it does not matter which pole of the coil hits the Aluminum, because it repels form both poles just the same.
Iron has less then 1 percent abundance as I recall and most all of its atoms do not respond with the nuclear diamagnetic response to a fast magnetic pulse. Its outer electron shells respond to magnetic fields bending the flux around the nuclear center, where the mass is located.
Aluminum does not bend the magnets flux hardly at all, it passes right through.
Aluminums mass can be vibrated up as a larger coherent vibration field using a caliper or F gen scalar coil, at 86.769 mm / khz right off the NVR table.
Iron at 10.782 mm / khz and only very few of its atoms will respond.
Dave L
« Last Edit: 2021-08-22, 23:02:35 by DaveL »
Dave
Inertia is a good example of what a farce conventional physics has become.
Inertia is described as a property of matter which opposes any change in motion. However anytime someone asks "what is Inertia " it devolves into circular reasoning or complete nonsense. So we should be clear that simply calling inertia a property of matter is a nonsensical answer.
The cold hard truth is that nobody can give a straight answer because they have no idea what it is or where to even start.
I think it's kind of strange that when it comes to the Primary Fields(magnetic, electric, gravic) and Inertia everyone is clueless. The most important discoveries in the history of mankind which controls the actions of the entire universe and nobody has a clue?.
You see when I actually solved the problem what the primary fields and inertia are in reality that's when free energy became easy. So it makes perfect sense that everyone has been misdirected and fed a line of bs. It shouldn't take a rocket scientist to figure out that when we understand what the Primary Fields are we get free energy on a silver platter.
It just boggles my mind that so many people could have such a complete lack of curiosity about something so important.
Here's the real problem...
1)to claim inertia is only a property of matter supposes that matter has acted on or applied a force to itself ergo something from nothing.
2)to claim that inertia is the interaction of matter with the space it occupies requires said space is not empty but full of something like matter or energy.
This is why Einstein later claimed his theory of space/time is nonsense and irreconcilable. It's a classic case of circular reasoning and something from nothing. That is a force acting on nothing or created from nothing, ergo...nonsense.
“Progress is impossible without change, and those who cannot change their minds cannot change anything.” George Bernard Shaw
The force we refer to is called inertia...
No, it isn't.
Newtons Law
"Newton's first law of motion states that "An object at rest stays at rest and an object in motion stays in motion with the same speed and in the same direction unless acted upon by an unbalanced force." Objects tend to "keep on doing what they're doing." In fact, it is the natural tendency of objects to resist changes in their state of motion. This tendency to resist changes in their state of motion is described as inertia."
Dave L
Newtons law was only observed from a point of reference standing on the earth.
From the larger picture we know that nothing ever comes to rest in this universe.
The ball that falls to the ground only appears stationary to the observer standing next to it.
From the moon, the ball is moving around the earth once every 24 hours and around the sun once a year.
It can never come to rest in a universe such as ours.
But as far as Newton could extend his mind in reference to what he observed, the ball setting on the ground is stationary and at rest.
Dave L
This is a lesson in critical thinking or reasoning and being able to see when something is not justified and contradicts itself.
Some may not recognize it but the standard explanation for inertia is on par with thinking one could fly through the air simply by pulling upwards on there own bootstraps. It supposes that a material object made of particle/fields could "act on itself" when it produces a counterforce to any applied force ie. inertia.
The history of the theory is also very interesting, pre-Einstein we had the Aether described as super small particles in motion filling the entire universe. This was replaced with space/time which are actually measures of something not tangible. Let's do a comparison with the current theory...
1)Aether... motional particles filling all space.
2)Dark matter/energy...motional particles filling all space.
Oh dear, the old becomes new again and as Einstein said, space/time is nonsense because measures are not "something tangible" and one cannot reconcile the translation of force without something to translate said force... *facepalm*. In essence it's complete gibberish and like claiming that inch/seconds are responsible for the translation of force. Again... *facepalm*.
How so many came to believe this space/time nonsense which shows a complete lack of critical thinking is beyond me.
The fact is, Einstein and company could not reconcile the math so they fabricated a cult of imaginary nonsense where a measure of something became something in itself, ergo something created from nothing.
As well, nobody should be naïve to think this didn't set back Free Energy by decades. All it requires is some critical thinking and a few reasonable questions...
1) If I apply a force to "something" and it resists said force where did the counterforce come from?... what, when, where, why, how?.
2) A force cannot act on "nothing" thus we could ask how the counterforce called inertia resisted a real force with nothing to act on other than itself, ergo pulling itself up by it's own bootstraps*giggle*.
I don't mean to sound egotistical but I have yet to meet any person willing to go toe to toe on this subject. It's always silence and I can only presume they have no valid argument or rebuttal. It's always seems to be the same old nonsense accusing others of the nonsense they seem to be peddling. So if you want to talk science/physics you had better get your arguments in order or I will roast you. There is no argument which precludes free energy and in fact it is the norm, normal, universal...
The laws of the universe by David Lowrance
1) For as far as we can see within this universe, nothing ever comes to rest, all is forever in motion. This holds true on both the atomic level, and the level of planets, solar systems, and Galaxies. The closest thing to a perceived "rest state" is light velocity. The light photon has the same energy from the point where it begins it's travel to the point where it ends it's travel. Thus the field fabric is a zero loss transmission system for photons moving at light velocity. [Max Planck]
2) The Field Fabric that fills all space, has specific frequencies present inside it that can be found everywhere within this universe. We cannot know what or why this force keeps powering it, but we can prove that it does. [Wilbert Smith - Bashar] It has also been termed the "Source Field" or the "Zero Point Field" and many of it's qualities were defined by Max Planck.
3) Perceived "time flow rate" is a function of the loudest vibration the human brain can synchronize into. This vibration determines how fast it's memory system can operate. As the human conscious vibration field develops larger spherical layering, it's frequency rises and comprehension along with intelligence becomes a faster process. [David Lowrance RM-1 conscious development]
4) There are layers of this universe that exist in various frequency bands, and visible light does not pass between them. These are referred to as densities, rather then dimensions. All space has 3 dimensions and this is "self evident" [Wilbert Smith]. All densities also have 3 dimensions of space, however the higher densities have more layers of information contained within them and at a faster rate of perception.
5) Telepathy is the synchronization of the vibration rate of two brains, and when any two objects come into synchronization with vibration manipulations, energy may pass between them. This was termed spooky action at a distance, and is a conscious phenomena.
Mental and emotional frequencies can pass over great distances, in the healing art of Reiki, and is felt at the receiving end, as one example.
Accurate telepathy between the various races overcomes the language barriers, as it does not have to use serial language but can pass complete states of comprehension as spherical transmissions. This is driven by a very pure state of curiosity, which is a universal request system for accurate telepathic communication.
6) Gravity is a secondary side effect of the field fabrics frequencies generating mass through the convergent splitting of frequencies into sums and differences, products and quotients, to produce the table of elements. The divergent outflow side effects mix and produce a phi ratio vibration system that crashes back inwards at smaller dimensions of convergence, then the atoms use to begin with. This can be calculated for any atom, and for all the atoms. As we add more layering to the atoms up the table of elements there are more frequencies produced and the gravity generally becomes stronger.
7) The Proton is a smaller fractal of the entire universe, and this is why it can produce the strongest force of nature, termed the strong force in physics.
[Nasim Harriman]
There is so much more we can deduce from direct experiment ...
Dave L
Newtons Law
Dave L
Yes.
Inertia is an external force that you "conjure up" by accelerating a body though space.  It is easy to conceive if you fill your space with virtual photons (that are the building blocks of photons) that travel at light velocity, have zero rest mass but have momentum and energy.  And they are at a high density travelling in all directions.  A matter particle has a collision cross section that determines the rate of absorption of these virtual particles, and arriving from all directions they give up their momentum resulting in an inward force as determined by rate of change of momentum.  But matter particles being stable cannot continually absorb, so they also emit , and for each virtual particle absorbed on one side of the matter a virtual particle is emitted (at light velocity) on the opposite side (that's a bit like Newton's cradle).  That emission also creates inward force.  But now imagine a time delay between the absorption and the emission, and hey ho you have matter obeying Newton's Law.  Uniform velocity keeps the inward forces on the body balanced, as absorption rate and emission rate are the same.  But acceleration creates an imbalance because of that internal time delay, such that the body receives a force opposing the acceleration.  It's quite simple really.  You can now answer "what is inertial mass?" as there is a simple formula involving its collision cross section, internal time delay and the momentum and volume density of the space particles.
So using the different mental models of inertia, how can we reduce it, and even null it out, such that we can accelerate faster with less energy?
Dave L
See the paper below.
Some observations of what is,
My parameters for the Field Fabric that fills the universe, would have to result in "spin."
The uniform spin that is present everywhere. From atoms to planets, we cannot separate the presence of spin from what is observed.
At some point the "randomness" must take a directional spin.
The second parameter, must explain light velocity, and the fact that light appears to travel in a straight line, meaning for the most part the field density of space is pretty consistent at the wavelengths of light.
And lastly, from first hand experience, the fabric of the universe, responds to our consciousness at some level of dimension. Structure and form are produced that is extremely organized. IE there is an organizing force present, capable of producing life forms that are extremely complex in structure.
Dave L
We can pass light through a magnetic field, and it is pretty much a straight beam, not bent.
We can pass light through an electric field, and it becomes polarized.
We pass light by a strong gravity field and it is bent.
We can then deduce if light has a magnetic field it must be scalar cancelling, not bent by a magnet.
Light does have electrical polarity of some sort, as it is polarized in a strong electric field.
Gravity is different, able to bend the path of a scalar cancelling field, as light must contain.
So we can identify 3 different layers of field force, that each effect the path of light differently, and thus operate on space [the field fabric] in different ways.
Dave L
The last post is right out of physics 101, and while these effects have all been observed in science, they rarely discuss the difference of the 3 field forces, or the fact that if you are doing an experiment which appears to bend the path of light, you are not dealing with EM fields per say but a different effect which appears to actually bend space time as we would perceive it.
Now in physics we also study the refractive index of different forms of matter which bend light, due to their density, creating a refractive index which we can measure. We know that materials that bend light at the edge of their form, bend it more if the density of the material is higher. Fiber optics uses this principle to contain a light beam. If we exceed the critical angle of the material "all" the light stays inside the fiber.
So in astronomy we see that stars with high gravitational fields bend light as it passes by and we can see things behind the star that should not be visible. But in say looking down into water, the fish are not where they appears to be and it gets worse the greater the angle off of 90 degrees that we observe the fish.
It is basically the field density that bends light. Whether it is the field that forms matter, or the field that forms gravity.
The presence of mass, is able to bend light, and therefore whatever mass is, is not the same as EM fields.
Mass is a field force associated with weight, and the ability to bend the path of light.
The two fields of science are astronomy, and optics.
Dave L
Your theory on what Inertia is sounds similar to my own.
Very few people want to go there because it's a minefield of contradictions with respect to conventional theory. The fact remains that any theory without a means to propagate a real force ends up sounding nonsensical.
In my opinion most don't want to explore inertia because of the can of worms it obviously opens. If as you explained, inertia is basically a particle/field effect we could see it as similar to a mechanical property which can be manipulated.
Obviously once inertia changes then momentum and energy must follow. Hence the reason most are afraid to even bring up the subject. As I said, solve the primary fields/inertia and you get free energy on a silver platter.
"Obviously once inertia changes then momentum and energy must follow. Hence the reason most are afraid to even bring up the subject. As I said, solve the primary fields/inertia and you get free energy on a silver platter."
end quote
Max Planck, and others already have, and if we continue to explore the 3 field forces, it will become more clear why their mental model was right, because it was derived to explain all the observed phenomena of physics. We may never know for sure what it actually is, but we can identify all it's qualities to a point of accuracy in calculations, and maybe that is enough.
When we observe the bending of light in an experiment, we can be relatively sure we are dealing with the force that creates mass and gravity, and it is not simply an EM effect. And with Joe Cell work, and many other vibration experiments, I have observed the bending of light so many times, and few realize what this indicates. This is a very important observation to note in free energy work, because it is a source of energy.
Dave L
Attached is a diagram, one of the most important observations in physics.
To bend the path of light using no optical matter, but a field gradient around a source of energy with no measurable magnetic field and only a very tiny weak electric field.
The field bubble of course is a vibration system programmed onto the tubes using a set of SS calipers, set accurately to the phi pi/2 ratio system of gravity.
Earth CFS
Dave L
Here is the Experimental photo showing the optical bend, and then with lines showing the end of that tube should be behind the edge of the can, but it is not observed to be behind it.
As we can set up self sustaining vibration fields which contain a form of accelerating energy [phi ratio], like gravity, it is not hard to now understand how we can reduce the inertia in a moving car using similar techniques that change the vibration rate at the location of the mass in all the atoms of the car.
If we remember just the physics we have been presented with in this thread.
Ralph Ring describes his work with Otis Carr in building the first official saucer craft designed by mankind on this world from plans made by Tesla.
He said they were flying small model craft all over a valley in California, if the frequency was tuned just right he could shove his hand through the crafts hull, and it was like pushing it through jello.
Many craft have been seen descending through the earths surface, and into mountains.
There is a contactee near Mount Rainier in Washington state that reports a lot of this kind of activity.
This does not violate our known physics at all.
And the people of the 50's and 60's realized that.
Today they are not being taught the same physics.
They are being taught all the same formulas, separated, as though there were no connection between all the field forces.
Wilbert Smith clarifies this for us, what he was taught in physics in his day, gives complete ability to connect all the field forces into a structure that is the very basis of creating matter and energy in a Field Fabric. I used to think he was the one who came up with this, but when I went back to Planck it became obvious he was the one who made all the connection of formula.
The frequency of a photon determines its energy level, and that frequency can traverse space without loosing any of it's frequency.
Every atom on the table of elements will produce photons of light of it's frequency, and this is how spectography can determine what elements are in a star or even a planet. In basic chemistry we learn to place salt and other metals in the flame of a burner to identify the elements by the color produced.
Chromium will produce a greenish color, and I have manifested that one in a Joe Cell, as well as iron and gold, using the Isotope fractals to program the cell. Joe does it by feel, as one can learn to recognize these vibration frequencies by their flavor, and project them into the cells water mass using the mind.
Dave L
I am jumping now what may seem like light years past the basic physics that connects all things into one Field Fabric. But that was the foundation of understanding that allows us to take it this far.
The Isotope level is the point of dimension where psi phenomena can gain 100 percent accuracy. However it does not work with imagination, the chi flows have to be real and sliding your personal frequency is required to get accuracy at this level.
A large portion of the resonantfractals.org site is devoted to bringing this ability together and using it directly in our science.
This is necessary to explain saucer craft and often how they are controlled.
While we can set up scalar coils to control these craft from electronics, we can also do it using the psi phenomena at the nuclear Isotope level.
In this work we need to learn the ABC's of our table of elements, and begin to recognize how to set up these fields using only the mind.
In the Joe Cell we take the cell into a very deep inflow field, and the water goes totally clean and clear.
At his deep level we then inject the isotope frequency of the material we desire the water to manifest, and then reverse the field to outflow, and for as long as we provide additional electrons to form the electron shells around the new isotopes, the water will continue to manifest the element.
This is not magic, it is understanding the structure of matter, and the field forces that hold it together.
Dave L
Earth CFS
Dave L
This would be more believable if you showed the image with your field bubble turned off.  Then we could compare the two images.  Why have you not done this?
How does gravity effect orbits and time?
One may think because one cannot feel gravity while in orbit, that clocks would speed up as if there was no gravity present. This is not the case.
A good article on this Relativity and GPS
There are actually two calculations involved in correcting the clocks on the GPS satellites to an accuracy of 15 meters on the surface of the earth which is 50 ns for light to travel 15 meters.
The first calculation has to do with velocity, and at 14,000 km/hour the clocks on the satellites slow down by about 7 microseconds per day due to relativity.
Next at 20,000 Km above the earth the clocks speed up by 45 microseconds per day, due to about 1/4 the gravity being present.
So the net result is that the clocks on the GPS satellites speed up by 38 microseconds per day.
If digital correction was not provided, the GPS system would fail in about 2 minutes as the clocks on the ground loose sync with the clocks on the satellites running faster and we loose the 50 ns accuracy to measure 15 meters.
What does this prove? Even in orbit where we are weightless, the gravity density still effects our time flow rate.
Orbital velocity is not enough to correct the error at the balance point where an orbit is achieved at 20,000 km out.
GPS would not work without both calculations, pre Einstein, this system could never have been made to operate.
Only the military would spend $10 billion to get a system like that up and working!
Dave L
Now this next step may seem like a real reach of logic, but this is how it actually works in experiments.
The orbital path of a satellite in a circular orbit, compared to the tempic field distance of the gravity fractal that passes through the center of the earth, is a pi/2 ratio for 1/2 an orbit. This is a self sustaining vibration ratio. There is much more going on here then a simple satellite "falling" around the planet.
When we take two stainless steel tubes of different diameter, say 1" and 2", and place the small one inside the larger one for a concentric set up. If we apply a vibration ratio between them of pi/2, both will vibrate up and maintain the vibration energy forever. This will create a field bubble around the two tubes which will never stop vibrating. A Tempic field gradient which stratifies into layers of density.
This ratio will actually work across a small band of ratios, including the phi ratio, which will also self sustain, and well right up to 0.66666...
It does not stop at 0.618.
This small band of self sustaining vibration ratios, that generates a field density around the tube, depending on the mass of the tubes, can extend out a very long distance, compared to the diameter of the tubes, if the tubes have high mass.
Machines
This is not a subtle experiment with two SS tubes of 316 grade at 1 foot long, with .065 inch thickness.
It may drive one out of the lab over time. The pi/2 ratio is tolerable and harmonious, but the phi will create distortions that are uncomfortable to be working around.
Pi/2 creates a self sustaining circular field, but phi creates an accelerating field either inwards or outwards depending on which way you set up the two frequencies to mix.
When two mass vibration frequencies mix in the Filed Fabric, we can get sums and differences, and also multiples, and if we choose our numbers carefully we can get infinities reaching inwards to atomic dimensions. When two frequencies mix we call this fracturing, as each one operates on the other to produce a function. If the function is infinite or an irrational number, we get a very deep penetration into matter at the nuclear mass level.
In lesson 5 we show how this can work to couple the background field of the H1 atom into a SS can and create an inflow vortex of energy that will converge at the center of the space inside the can, and this is not subtle either. The space inside the can will increase in field density, and in theory this will effect the time flow rate as well, slowing it down.
Mediator Fields
You may wonder if all the study of pyramids was real, causing fruit not to rot, and razor blades to stay sharper. Why would that happen at the points of convergence of the pyramid?
If you ever worked with these pyramids, then you owe it to yourself to do the experiment with the SS can and see what happens at the center of the cans volume, it should be far stronger as we couple this directly into a "power source" that is the base frequency of the field fabric. This is the frequency that can manifest an H1 atom in Joe Cell water, and why the cell can go into the breeding mode.
The field fabric wants to generate H1 atoms!
This becomes apparent when we program the NMR charts with H1 = 333000 and all of the elements on the chart now come up in our accurately set caliper gap distance, based on the distances that come out of the chart.
Using these gap distances we can manifest any element on the chart in the Joe cell water, as long as we provide some electrons to form the outer orbits of the isotopes we create.
A JC in breeding mode does not drop it's water level. The inflow field holds onto the atoms and does not let them escape, even through the walls of the cell, where H1 atoms should be able to escape from.
Have we delved deep enough into the physics, to peak the interest in trying some of these experiments?
The curious questioning mind, will find the answers, if it asks the correct questions.
Dave L
« Last Edit: 2021-08-24, 12:41:56 by DaveL »
In these three threads we have introduced a new concept, that of altering gravity, and manifesting elements by using accurate data, ratios, and targeting the Field Fabric as a source of power using mediator field to condition the space around an object.
We are introducing a field force, that EM technology has never covered. Vibration gradients as platonic form energy field bubbles.
The Tempic Field, and the operation of the Field Fabric to manifest and sustain the mass of matter.
We have given examples of how the density of the gravity field alters time flow rates.
How pi/2 running against phi can generate a gravity field capable of bending the path of light, and how the 89/50 ratio can release the gravity field from a car shifting it towards the engine in the car. We stop feeling the inertia relative to the earth, and start feeling it relative to the engine.
When we use 89/50 to fracture the vibration field, we get a finite length in one direction and an infinite one in the other direction, accessing the smallest part of the atoms and delivering the weight to a finite fractal length outside the matter of the engine.
89 / 50 = 1.78
50 / 89 = 0.56179775280898876404494382022472...
The fracturing moving each direction through the field connects a finite fractal length with an infinitely small set of lengths and shifts the weight of the mass. This field applied to a running engine will self sustain, and if the block is Aluminum it will self sustain after the engine is shut down.
Both the pi/2 and the 89/50 can be taken down by summing the two frequencies and dividing by 9 without having to disassemble the devices.
Or layers of the 89/50 field can be taken down one at a time with 1/9 the frequency used to set each one up.
These can be activated and taken down using scalar coils.
Vibration technology is based on accurate scientific data and ties in well with formulas that are already known.
This opens the door to field warps, and gravity manipulation, as it deals directly with the fields that create mass.
That of "convergent" operation to pull energy inwards, as opposed to divergence fields of EM which are entropic.
It gives quantification and measurement abilities to the Tempic field.
Dave L
Pages: 1 2 [3] 4 5
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2021-10-21, 03:33:12
