One must face science to progress it furtherThe average person facing comprehension of what Gravity is, with a strong desire to one day begin to be able to manipulate it, will usually take a wrong turn, as if they could start from nothing at all, and cipher the whole universe on their own.
This may be an emotional reason of distrust how money corrupts men, in order to survive the present system that has worked for many generations.
However the present science up to discovery of the atom, is very solid in experiments and very predictable.
Up to this level we can verify much of it using our vibratory sensory abilities, because the atoms are both stable, and well understood as to formulas of frequency. And frequency is everything from the Quantum Field Fabric level of comprehension.
Distance is frequency, Area is frequency, and Volume is frequency.This is where the men of advance of our sciences ended up before they were removed from classical recorded science that is taught.
Our first goal after having matured our physical state of being to one of emotional stability, is to then begin to take in as much knowledge towards understanding the atom and what is already a solid science of the atom.
We do not need to go any deeper then the atom, into the level of theoretical "transient particles" which only appear during the destruction of an atom in a collider, or its 3 main particles. Proton, Electron, and Neutron. These are the building blocks of nature, and they are well understood now already, all we have to do is to catch up with what is known about them.
After our study of the atom, and the table of elements, we can start to ask the right questions about how they are created, or can be manipulated as to the 3 field forces that sustain them perpetually. I can tell you, to create an atom of a specific element, all we need is a single isotope frequency and a Joe Cell filled with water. We do not need to know about Leptons or Gravitons, which likely do not exist except for very short periods of time and may or may not even be real.
All we need to understand is the Isotope frequency we desire to manifest, once it is present in the water, we then have to feed it electrons, so the Isotope can organize them into electron shells and the atom is complete. Doing this proves the nuclear Isotope is what organizes and powers the atom.
The Isotope can be pulled up directly from the Quantum Field Fabric, and needs no steps in between to create the so called smaller particles.
This hands us the flow of energy into the 3rd density creation system.
Flow of Power from the Universe
Isotope creation
Electron shell manipulation by the Isotope
Completed atom
Joe cell naturally manifests H1 atoms in breeding mode, which is why it is so powerful as H1 is extremely volatile as a gas and will instantly compress itself to 1/2 volume when it is ignited as H2, which takes very little energy to cause. The H1 Isotope is powered directly from the Field Fabric as the resonance of the surface area of it's conical Isotope system is a direct fractal of it, and it is everywhere in this universe.
If we have this higher knowledge of our current sciences, we are then ready to correctly observe an experiment which can take us further to new levels of comprehension. I see so many people with a lack of the knowledge that is freely available, which would save them years of work on dead ends, with concepts that will go nowhere as they do not make the connection to real world physics.
We then begin to chase the power backwards from something like a copper pipe that is somehow vibrating on its own, and can thus make all the right connections all the way down to the Quantum Field Fabric, the Zero Point Field that powers everything.
This is a process of self learning, and becoming more aware, while at each step we can set up resonance fields to prove it works, and our calculations are correct.
However the current science has not yet reached this level of comprehension, that an atom can be created in a Joe Cell or even how that can work! They do not believe in the first two field forces. Consciousness and Tempic field, which seem beyond their laboratory experiments.Many prefer to leave creation to the pretenders of Religions, and only God can ever grasp it, so they do not search for that goal.
An accurate sensitive can easily master creating atoms if they have only a little accurate science to add to their sensitivity abilities, and a correct experimental platform. The fact that collecting gas from a Joe Cell produces the H1 atom, which is the first atom on our table of elements, is a fact that few would even attempt to prove is real. It also explain why there is so much Hydrogen found in the universe, as it must be present for the higher elements to form from it.
The other thing they need is the frequency to be accurate of the element they wish to produce in the Joe Cell. And to be able to recognize what they are observing when it happens. It happens to almost everyone who has a Joe Cell and works with it, but most do not understand what they are doing, or what it is doing. They do not have the science foundation to recognize it. Many prefer to believe in magic, because that is most sensational, and then they are free to make up any theories they desire to be true, adding all the flavor of emotions to be experienced along with the preferred mystery of the experience.
One of the side effects of working with vibrational devices is an acceleration of the mind, and if that is not used correctly they can generate thousands of words of verbiage of their new discoveries, most of them total fantasy. I assure you it all conforms to the New Science of Smith, with the assistance of the Grey ones whom guard the 4th density creation system that manifests this universe.
As many today realize it is our own consciousness that must be raised up in frequency in order to attain a heightened awareness of things we do not yet know how to experience, this is a side effect of the vibration technology, but if the current scientific understanding is not there as a base to start with, they all go far out into imagination creating their own worlds of fantasy which do not apply to anyone but them. At this point it will then all be ignored and not believed, as no one can even understand what they are trying to say.
To pass this on and advance it, we have to master a new vocabulary along with the new discoveries, and we must all begin to agree as to how to express it best, with the phenomena that always works when we get it right. It must blend into current science and take it one step further, or it will be ignored and lost again.
Now as you may have noted you can read my experiments, but may not fathom the magnitude of each one if you started in the middle of the 20 year long process I have put myself through. I did discover how gravity works and then proved it to myself, and experienced inertia reduction for myself based on these scientific explanations I presented early on. They did not come from me, I could never have done the whole thing working alone.
My very first documents were what is known, and what was theorized to be possible. At first I did not grasp it at all.
I was fantasizing the 3SD was going to hand us gravity control I was very wrong, it was a device to wake us up to remote communication with 100 percent accuracy, with cultures all over the universe who use it already. 15 years later I can now tell you how to identify the elements in a sample of anything on earth faster then a scientific lab can.
The early work began to develop the New Science of Wilbert B. Smith, but one step at a time, I had to learn its truths by experimenting.
The scalar coil was going to hand us free energy and antigravity, but we had no clue just how that could work. So many people turned to sensational goals, rather then keep the science present all the way along the path. To my knowledge I stand totally alone at this point where each colleague has abandons this path for some spiritual meaning of the higher emotions they began to feel during these experiments, and their lack of wanting to calculate any of it for themselves.
For a time of several years I would do calculations for them that would blow them away, because they worked, but none saw this as a talent they needed to develop on their own. The calculations will be lost when I pass, if no one can grasp them.
There is a series I like to watch now and then as it describes exactly how I feel. The world of mankind is blind, and no one but me can see that! LOL!
The series on Netflicks is called "Manifest". It is a lonely feeling to have no one able to comprehend how to light up a car with the higher light and have it approach levitation, disconnecting from the earths gravity field, due to a linear hop in the space between the car and the earth which blocks the natural mixing of the frequencies of radiance between them. This disconnects the gravity field of the earth from the mass of the car! One would think this should be center focus for all mankind reaching from the stars, but yet there is no one to hand it to, who is ready for this reality to be given.
If the collective Spirit of mankind was ready, they would find it.
It is like jumping off a cliff, to ask for these comprehensions and be granted access to them.
The other part is to be able to observe others fantasy work, and know it is not correct, a curse, and yet I have to be positive with them or they will shut down to anything I say or post.
If one has no clue where gravity originates, they will be shooting blind as to how to manipulate it!
There is a Hierarchy to creation, and when we can trace the flow all the way through the atom, it then becomes self evident, where to make the adjustments that will work. One must recognize there is a Source of energy present that runs it all, put this to the test and prove it to the self, observing the self learning it well.
Current science then lights up, and all kinds of experiments are now possible to take it further, but Sensitivity and ability to measure these frequencies can not be bypassed with theories.
Consciousness is the first step and the last to learn.
All science is a result of one man having the ability to observe accurately what is happening in an experiment, and then make the connection to current science.If one believes they can advance current science without knowledge of it they are very much mistaken.
All new phenomena is ignored if it does not fit in at some level of current knowledge, and this is because the current models work.
My posts are intended to save you years of time with hands on, or with theories you cannot prove, and phenomena you may hit on by accident as well as I also did several times before reaching comprehension. I have strived to make that connection with current science, and as well offer new techniques of measurement that work. You do not have to waste time redoing this, if you simple follow it accurately at each step.
However consciousness cannot be avoided if gravity control is your goal, there is no way to disconnect this from flying saucers that power from the Field Fabric using accurate frequencies of vibration.
The monk levitates with no batteries or EM power systems, and the original Saucer craft are the same. Gravity is a vibration system.
While EM can be used to create anti gravity or gravity disconnect effects, very little is necessary to make the mass vibration systems rout correctly.
Gravity is a function of the mass. The mass is located in the Protons at the center of the atoms. This is not complicated, but getting a feel for it may be the greatest hinderance. The calculations have all been done for us already if we ask the right questions.
GravityDave L
