2026-08-15, 03:36:45
Pages: 1 2 3 [4] 5 6 7 8
Author Topic: Quantum Field Fabric  (Read 39681 times)
The WW2 Philadelphia Experiment was using the Electron shell frequencies, it was a bad concept.
NMR shows us the frequency spectrum of the Nuclear bundle in the Mhz ranges of EM.
The ESR electron shell levels are in the Ghz ranges.
We need to work our way up from the bottom, the lower frequencies first.
I have been able to convert the cones down to audio frequencies where they form layers of fields that are smaller then 1 mm and very safe to experiment with.
These tiny fields will self power from the field fabric as atoms do, since these kind of experiments seem small and unimpressive, they are ignored by the researchers of free energy as well. However we need to understand them before we start adding lots of power, we must be able to control them first.
I have made all the mistakes here, and others do not have to now if they can catch up.
All the warnings are there in the documents where I had success with these kind of fields.
SSF [self sustaining field]
TDF [ take down frequency]
These must both be provided to establish control of a free energy powering system from the Quantum Field Fabric.
Conical Field Menu
I have not successfully gotten any PHD to even read this, let alone believe it works!
I do have one geologist with a strong interest now, but he has fought me at every step with his "magical thinking." Every now and gain he writes to say something I wrote works and then asked another question! Rather humorous to me.
Everyone discovers something and thinks they were the only one to make that discovery, can then own it, and even name it. It has all been done already. Max Planck already figured it out!
Dave L
Copper wire and the concept of torsion - tension - and time flow rates for the ego mind
In the early work with sensitives that had found "toxic" energy from copper wire medium, it was good to do an exploration of what they were all talking about. Here was a strong force of some kind that became radiant from winding a copper wire to a specific length, and then scaring them all so much they labeled the coil toxic, and stated it had to be destroyed. I had to face these people who wanted to contain it as a secret, to protect others from it's exposure. They made me jump through hoops to even get the information, and to control how large I made it, to protect myself.
Once built this coil could not be shut off. If one end is connected to an earth ground, the energy became unbearable to work around it. They made all sorts of rules about wire size, and such, to keep the energy low enough to be around it, but two things would happen that caught my interest.
In one of their experiments a voltage had developed on a multi coil system with 90 degree coils, a charge of 15 vdc, and in another, things would disappear, then return later in another location. The main creator of this coil, also stated there were these grey beings that would mess with him, trying to deceive him, pranksters as I recall. So this information was considered something that should only be shared with caution and great care to ensure it was always made with very small wire. Like 30 gauge or so to be safe.
I got the pdf, and the secret code to unlock it, and decided to violate all the rules right off to see for myself what this powerful nasty energy was all about, and why it was causing them so much fear. I went into my karate mode to face the fear head on, decided to keep accurate notes on the experience, and approach it as a true science, observing both the experiment and myself simultaneously.
In the back of my mind the warning, that everyone who had ever made one of these ended up destroying it to control it. All they could say was it is not compatible with our human body or awareness, and once you feel it you will understand.
Curious yet?
This was now one man, working with the nature of a very secret copper wire coil, and ready for anything to happen, me observing IT's nature and no one else present to make judgments. A very personal thing to do.
30 gauge wire was only creating confusion for all these others, and they still ended up destroying the coil. As I recall only one person lasted a couple weeks with one of these before destroying it.
My notes indicate, I obtained lengths of bare number 6 wire, lots of copper mass, and I wound two of these coils on an acrylic tube several feet long.
I wound one CW and one CCW to study the difference as they had stated there is a great difference. All the statements from Orgonite people were emotional sorts of reports, and then the phenomena they had no clue about with the gray ones, and the 15 vdc intermittently appearing.
I unwound the heavy wire in a warehouse on the floor and carefully measured it out to 44 feet 6 inches marking it with tape every so far. Cut the two pieces off, then began winding them on the tubes, using hot glue dabs along each turn on about 6 different location so the wires would stay formed when removed from the tubes. The directions were to wind 44 feet on the coil form, with 3 inches free on each end for connections. I followed the direction perfectly.
Expectation is always different then reality when we face the unknown, and this was the ultimate I had ever faced working alone. No one locally had a clue what I was doing. The document I wrote then shows my expectations right after making them and setting them both up on a small table next to my desk with computer on it. Torsion Basics Near the bottom of this document is a photo of the two coils.
I was of course seeking the 15 vdc, as any pure scientist would be, what I got was far different.
I had been connecting clip leads in various ways to the coils, and noting how they felt, feeling this power, and as I worked with them the tension in my head started to go up. This is the mental acceleration of frequency in the physical brain mass that is experienced with Proton compression energy.
I do not remember how long this lasted, maybe two or three days, and what happened next was totally shocking to my experience in a human form body! Best explanation I can offer.
The tension in my head was so strong, and almost painful to endure, and then suddenly, a hole appeared in the fabric of my reality just above these two coils near the celling, and a ring of little gray heads popped into it peering down at me. Maybe 8 to 10 feet over head, this was a large metal building with high celling and it is hard to describe the spatial effect or determine exactly how high up they were.
You know how fear either causes one to freeze or to go into a heightened state of perception. Time changes, as in an accident in a car where you are flying through the air and it seems like forever before you hit the ground again. I was experiencing more time then normal in the moment.
I now refer to this as a different "time flow rate." Our perception is accelerated, and more memories can be stored in our consciousness in far less real time.
Psi people refer to a "download of information" that comes in so fast it may take days for all that information to be realize after we come back to 3rd density time flow rate. Some call it a "psychic flash." This was that on steroids, and so much happened there so fast I have to agree with them and the descriptions of what I had experienced.
Telepathic message was so clear, destroy these coils now! But what I did not realize is that with this came a lot more information that would begin to manifest over the next weeks of designing the RM 1 system, almost intuitively, at each step it felt right, and I was remembering it, rather then designing it myself. I knew things. The form of this device had to be perfectly spherical for it to be tolerable to the human form head and body system.
Many other aspects of these devices "came in" now that I had a real platform of science to fit this over, the limits were removed in what I would be allowed to do in the physical.
I had managed to overcome the fear [emotional charge] and keep the mind working as a technical process, without reacting emotionally, and that is the qualification to be allowed in. I was able to observe both my reaction of the body, and still store accurate memory of what was happening in the "now moment."
This was truly an experience involving consciousness, and the acceleration of the physical ego mind system, without being distracted too much with my personal safety. If I was to die in this experiment, it would be to advance the knowledge of all mankind, and this was the only thing that motivated me to master this comprehension and endure it to the end of the process. Recording as I went, that a record survive me for others to benefit from.
This is the set up of the conscious state that allowed me to remain a scientist through this and gain the respect of the Gray ones of the lower 4th density. Mind over emotions, was the requirement.
I now had my personal proof, there are other realities overlaid on this one, and beings do exist in these other realms, and from their perceptions, this is normal, and it is not metaphysical or a projection of our imaginations at all. They sent me a telepathic message that I could instantly understand!
So much was then realized in the weeks to follow, why people had trouble observing and interacting with saucers as they passed through these levels.
Lower 4th density is so scary on the first visit, most would flee from the room and deem it evil, it all made sense.
Visions of demons, because the vibration frequency is seen as fear by us on the first experiences with it.
I had years of asking to see only what is real, and not allow any changes to fit my personal taste, as others do see their demons in these sort of experiences, and turn to mysticism to explain it to the small ego mind. I saw the grays as they are, in their 4th density level and received an accurate communication with them at their time flow rate of perception. I also recorded it most accurately, with no personal extrapolation of fantasy based on fear.
Like looking over a cliff that is miles down, and your body wants to move away from the edge so bad it almost freezes. And yet you stand there and study the canyon below, driven by the desire to know for sure absolutely the truth of what is real, and what is not real.
After this there is no more need for faith at all, there is only knowing, and that is also expressed in the deeper meditations, the state of the knowing, which is so fast, it is like instant knowing, all at once. This is due to the accelerated time flow rate of the lower 4th density reality.
Most important, I understood the Grays are a very natural part of the creation of the physical hierarchy that constructed and maintains our physics on 3rd density. They have a very valid function and it goes far deeper then we could ever realize, they should be respected for what they do and what they know in maintaining order of the structure of our universe. If we get into a problem with control of our experiments, they are there to assist or to neutralize our mistakes until we eventually learn enough to do it right!
We can use spiritual language to describe this, a lower 4th density attunement experience.
Or we can use a scientific explanation, I punched a hole into another reality that exists along side and just above this one in frequency. A portal.
I not only survived this experience, which was not clear during the experience, but I brought back accurate information to solve many of the technical problems with my mental models of the physics of our reality.
I also "knew" that Tesla, had the same communication with these beings during his development period.
He also worked alone most of the time and had made coils far larger then mine.
Now after this experience knowing that 4th density is real, opened a door for me, that others had been blocked from by fear.
The path of the warrior is to master the self. I had new meaning for the phrase "mind over matter."
While the Orgonite people were playing with their emotions as tastes like recipes for desired emotional states, I had breeched the scientific part and penetrated the 4th density reality as a scientist. Enduring my own emotions and seeing them as less important then truth.
This becomes a different sort of "mental high" the accelerated mind, which can grasp an entire field bubble of information instantly as a comprehension that comes in all at once.
I am relating this experience, because what many are seeking is the "power" from the Quantum Field Fabric, and they will face the same if they choose to explore it personally. there are rules on 4th density to limit this knowledge and power from those who are subject to the emotions which will always result in conflict situations. People are judged as animal or civilized being in this test period as to how they react to this kind of experience.
The danger humans pose to the other civilizations, is that of fast emotional reactions when facing what they do not understand.
Shoot first, from a state of startled fear is not allowed, period.
Every civilization out there in the 3rd density physical has the same directives from 4th density to honor their life form and preserve it. No being wants to die, no matter how different they appear to us, and all of them have a protocol system they use to preserve life of their species.
We should never approach another species without first study of them from the 4th density protocols that preserve their civilizations.
Consciousness
Tempic Field Patterns and frequencies
These can all be studied and recorded before ever facing them in the physical to avoid the shoot first reaction of the emotional overlay.
The determination of animal or civilized being is essential to know how to respond to facing them on the first meeting.
Animal reactions, are confined usually to one world. Civilized beings with the sight of 4th density can learn to go and interface with other civilizations and will be allowed. Mankind is still in its infancy in this conflict inside themselves, at the ego mind level.
Until we open this door of the frequency of our conscious ability, and begin to be able to manipulate the Tempic field, we are pretty much confined to the space very near our solar system, at a time flow rate that is far too slow to go anywhere out there.
The time flow rate of our conscious field, is paramount to understanding gravity and manipulating it, as we discovered in the very large Joe Cells in cars.
Personally I do not know if anyone still trapped inside the emotional levels a slave to the emotions, can master this experiment to take a car to the point of disconnect of the gravity field of the earth. I did these things working alone, and never exposed anyone else to these intense fields of energy. But with only one or two layers of the field others do not notice it right off. I still have one layer of the 89/50 on my car, and no one has ever stated they noticed it. However the car still accelerates much faster then it did before the field was added.
Light Activation of a Car
One can now take a very much easier journey through these experiences in just knowing what to expect may happen as we enter the realms of more "power." Because with more power comes more responsibility and greater need for control of the power. These issues must be resolved early on to avoid major mistakes with the energy of creation. Where this power must be controlled using mental means, as no physical body motion can shut it off.
Thus a display of the skill in geometry and math is essential to entry into the levels of 4th density science.
The local ego mind system must have these abilities to cipher its way out of a problem that it created.
Reliance on the 4th density body is also essential. It is very real, and all of us have one.
The creation manifests from the higher frequency realms downwards, and all of us entered this physical realm through them, leaving a part of ourselves on each of the three levels. 5th 4th 3rd.
This is the root of all religions where they began with the three in one knowledge.
The lie we face is to expose the fact that all of us have a unique and different being we may see as our God.
Our own 5th density body. This is why mankind must come to an agreement in how to run our physical world, and stop fighting one another.
It should be self evident the physical creation did not come into existence from its own level, or we would all know how it was done.
There is far too much order in this physical universe to ever believe it just happened from a big bang and some random program of numbers.
As we get deeper and deeper into the 4th density science, we realize we are being handed our reality, and ability to create and destroy as we would choose to. If these decisions are not made with sanity and love of the creation, then we will destroy it ourselves.
The magic of consciousness, and being able to observe ourselves, to be a sentient being is a universal quality of this physical universe.
This consciousness that is present everywhere, also contains all the information to create and to use the Quantum Field Fabric to power the manifestations for us once we create them.
To become the creator beings, of our maximum potential. But the science is also a necessary part of this, more then only the higher emotions we will encounter in the higher light.
I can only teach what I know, and for all I do not know I must avoid speculation, as all that I reveal must be true for everyone.
That is the only perspective an advanced race needs to move forwards towards a self sustaining civilization.
Speculation always includes desire to be right, as an emotional charge, and one must totally be malleable to changing the mental models as we progress to only include accuracy.
The emotional side of the incarnation cycle, has different laws then the scientific side of the wheel of incarnation.
We must learn the difference.
http://www.resonantfractals.org/Doc/Lessons/Frequency_Bands.html
One takes us back out of the physical the other delivers us back into it as creators.
As long as our focus remain on creating emotional experiences we will remain blind to the method of creation we use to come here.
Dave L
12 - 15 - 2021
Deception
After these experiences, and again study of my own experiences with emotions, I came to realize that nearly all intense conflict is based on the miss perception of others emotions and our reactions to this. We generate our own emotions, and thus only we can be responsible for them.
This is taught now in what has been termed co - dependence in relationships, where we tend to make others responsible for our emotions.
It is usually in the state of heightened emotion where we choose to enter into conflict to hurt others physically.
As we tend to blame others for our nasty emotional state, and lose ability of the logic function of the higher mind, to observe and see corrections that will benefit everyone simultaneously.
For the highest good of all involved becomes a mantra, that will release one from feeling responsible for others emotions.
Emotions are contagious for those who are unaware of this reality.
A person new to spirituality will try to take on others emotions and fix them with higher frequency meditations, and deem the lower frequency emotions are to be avoided at all costs.
A person seasoned over years of experience, will realize all emotions are temporary states, and will pass if given their due time to be felt internally.
They will stop entering into situations of conflict by choice and watch other go through this process, and simply allow them the space to do it.
7 years at each level was the normal process for the human form body to begin to wake up and become bored at each level.
This means that to end our emotional development we have to feel all of them most intensely! Suppressing the emotions will lead to disease that can become chronic.
One would not think of this in our society as a technical process, but that needs to change, because it is a very technical process for the human form body to reach a state of freedom and love for the creation.
The wars come to mind right now, as we chopped one other up with swords, then hardly felt it as the others sword passed through our heart.
We fell to the ground not really feeling it yet, and as we were lifted back out towards our higher bodies, the first thought at looking back down, what a waste. How much better life could all be then this, over and over!
Entering into a war with swords and shields, changes ones mental frequency to a point of not even feeling when we are the one being slaughtered. The mental acceleration in real time, and the courage of facing death head on , not knowing who will live and who will die. Thousands of years of living through these kind of endings with emotions running wild. Few ever lived to become as old as today, to reach that level of emotional maturity, and stop following the emotions of the moment, to later resolve all inner conflict we project onto others we do not understand.
This is the same with other cultures out there, we can make emotional judgments about, without knowing them from the inside 4th density protocol level.
If you really want to know why mankind does not have these advanced tools of free energy, this will be revealed from your own experiences of past lives. Our own experiences with emotion reveals it most accurately even if we become aware in this lifetime. Longer lives are necessary to advance beyond this level of comprehension.
This is not a prison planet for anyone who can raise above the level of animal reactions. That is key to exploration of space beyond our civilizations reach in the physical.
After the 7 years of mental work, above the heart level, we can enter into the realms outside the physical body with accurate perceptions.
We can see and understand the larger picture of an entire race of people, a civilization we can know at all it's level of consciousness, and have the freedom to take this knowledge with us anywhere we go, there are no possible secrets from a 4th density aware being right down to the construction of the physical body to the level of the atoms. There is no where we cannot examine and cipher. This cannot be released to anyone who is not fully ready.
There are no prison keepers out there limiting us, we have to be controlled as animals on one world until we have progressed beyond that desire of experience.
If you encounter teachers who think they are awake and favor emotional theories of conspiracy or bliss in the light, are not actually accurately awake.
They have to get through the emotional levels first to begin to see clearly.
When and if they can then move into the mental part and start to create machines that actually work, is an indication of mastery. Power will be the last thing they are allowed to work with, and the conflict is between their own physical body and their own higher bodies.
The astral 4th density body will keep the physical body veiled, and in a state of deception, to fully experience the emotions as very real.
Dave L
Working on the gravity coil
My attention was drawn to a device created by Bill Jensen some years back. I have been working on this off an on ever since to attempt to quantify why it works, and how to improve it. Many people mess with this and never get it to work, but Bill did and we have seen plenty of photos showing it working.
What really caught my attention was the frequency he used to start it working 3.72477 Mhz.
This caught my eye because it is 1/2 the gravity fractal I measured from the distance between the earth and the moon, as a field with power that holds the moon in its orbit. 7.45 cm / 2 = 3.725  which is his frequency rounded off. The diameter of his primary coil at the bottom is related to this frequency also as a pi/2 extension of it, which would make the field spin up.
He posted the pic below in public forums for our information, so I will post it here also. Along with a diagram I am working on to create a possible Gravity coil system.
He noted gravity anomalies when it was working, as well as strange things happening with a drill bit bending at an angle without breaking off.
Dave L
Gravity Coil
Here is what Bill wrote recently.
In the third picture, the circuit has 3 chips. The PIC 16f84a [16F84A] just measures a frequency and displays it on the liquid crystal display.
The other 2 chips create the electrical signal. These are both hex schmidt triggers with a total of 12 inverting gates from these 74hc14's [74HC14]. One gate is an RC oscillator, one gate buffers that, and all other gates are tied in parallel to raise up the output current.
I supply 6vdc to them from either the 6v battery or the black ac dc transformer and the onboard 2 diodes make that about 5vdc to power the PIC and liquid crystal display.
The TTL output is 6v pulsed and is set for 4.8 MHz here usually, but its variable by the blue pot.
The large copper coil primary should get the TTL 6v MHz signal by two wires. [One to the heavy coil base and one to the ground wire?]
The tall coil [secondary] has one common ground to primary coil base, and a 6" typical 120v type fluorescent tube on top for the HV indicator. This is basically a higher power version than the Konstantine Meyl system.
You can light leds and run a tiny dc motor this way, even with just 1 wire and even if it has that pictured RF choke inline [in the ground wire.]
The PIC and LCD display are optional.
The secondary length must be nearly: MHz x Secondary Feet [meters?] Length equals about 300 [c velocity] empirical.
This pucture shows after the free energy point is reached. All works on that 1 ground wire and the gravitational anomalies in g are seen. Need to zoom in. Hope this helps !
bill jensen8400
Photo below of his circuit board described above.
Here is what I wrote over a year back when observing this system.
9/8/2020
Summary:
Top Coil - Resonates the "copper ringing wave form" as EM on relaxation of the square wave. Generates 5 Mhz 1/2 wave resonance EM on the coil.
Bottom coil - Pulse at 3.725 Mhz is 1/2 Gravity fractal frequency 7.45 Mhz. This creates a split in real time cutting the 3.725 Mhz wave into two segments of high tension at 7.45 Mhz.
Oscillator - Changes DC level of Gravity wave at 7.45 Mhz, splitting it into two DC voltages generating a 3.725 Mhz AC EM wave in sync with Gravity fractal wave.
Each time the Oscillator goes to zero volts, the top coil rings at 5 Mhz positive pulses.
Each time the Oscillator goes to +6 volts, the top coil rings at 5 Mhz in the negative direction.
I believe this fully describes the effect.
Ok I found a Tempic Field resonance length from the Bottom coil.
195.5 cm must be the distance of the copper tube length coil at the bottom between the two 90 degree bends.
Set a caliper to 195.5 mm and you can feel what this does at 1/10x, turn it vertical then horizontal.
Set a razor knife on a tape measure at 195.5 cm, place hand on the tape and feel the pulse he is describbing.
EM resonance approx 150 Mhz at 2 meters tube length.
If we look now at the gravity fractal 7.45 cm operating in the horizontal direction, we can generate a circle in the air by holding the pi/2 harmonic horizontally.
7.45 cm x Pi/2 = 11.702 cm  = 4.6 inch = diameter of lower coil 3/8" thick copper wound on a 4" diameter tube. Creates Proton spin CCW.
Set calipers to 117.02 mm  and run a sensitive finger around to discover it generates a curve between the inner gap edges forming a complete circle of energy, a boundary layer.
This is a gravity powered form, and the pi/2 ratio converts it into a circular form of CCW spin.
It would thus be interesting to study a coil with diameter of 117.02 mm.
Wind the coil to a resonance of 7.45 mhz / 2 = 3.725 Mhz and see what it does?
Set up a small load on the coil, energize it at 3.725 Mhz with a sine wave, and see if it self sustains the load.
The coil may have to be oriented vertically, as the turns will set horizontally.
We could also look at derriving an E/P ratio to assit the self sustaining mode as we tap into the G wave using copper coils.
There are many ways to approach this, and experiment is in order to find the best ones.
This was speculation from other things I have done.
Basically however the gravity fractal coil can be constructed and then studied, to see if it accelerates the Protons EM field as expected.
When the Electrons spinning in the CW direction takes the energy in the upper coil system with smaller diameter, we should get a winding of the spin at smaller diameter. The coil at the bottom will control the Proton or cold energy of the system all the way up the through the top coil, since it is resonant with gravity and operating on the Proton mass vibration. The top coil however is calculated to an EM resonance using light velocity as normal EM responds.
The vibration on the lower coil will self sustain. Then the upper coil can be stimulated at a different Mhz frequency that it is resonant at. Best guess.
He indicates 1.2 mhz 2.4 and 4.8 mhz are frequencies he also uses in another post. While we know that copper medium has a square wave resonance at about 5 Mhz, which was my first guess for the upper coil resonance.
Dave L
Hierarchy of creation is unavoidable
All things that are, spring from Consciousness operating on the Tempic Vibration field. If they are brought up with precise frequencies, and ratios, they power from the field fabric.
The Quantum Field Fabric is there constantly, everywhere all around us, we are never without energy.
Awaking to the conscious level that offers control, is a personal advancement, not based on our culture or how nasty our military is to aliens.
It is our own 4th density body that tests us for qualification of comprehension. It is our own 4th density body that opens the door for our physical ego mind to start to use the Quantum Field Fabric directly. For our astral body to stop deceiving us, to create stronger emotions.
The Protocols to receive comprehension
1 - Resolve all conflict both inside us and outside in our dealings with others
2 - Seek Comprehension, do not attempt to just duplicate blindly
3 -"We cannot teach you, we can only assist your learning process." The Grey Ones - boys top side"
I do not know why, but comprehension is more important then any amount of blind duplication, to them.
This is what raises us up above the classification of animal, to civilized being. When we pass this test, the 4th density beings stop trying to scare us back out of their frequency bands.
Consciousness
Tempic Field
Electric Field
Magnetic Field
The foundation of creation, and none could exist without intelligence.
It is all too perfectly designed to ever just happen from a big bang and a blind evolution of random chance.
This is the path I have found that works in practice, and leads to the mastery of gravity and free energy.
Stepping stones
Max Planck - all things that can exist can be reduced to a frequency, or set of frequencies. These energy levels can be calculated with enough perseverance to realize how to expand the various energy packets using fractal coupling techniques.
These techniques can be proven to one personally.
Wilbert Smith - The New Science - With support of "The Boys Topside."
They will intervene to assist, if we get into trouble with the creative forces of nature.
We have so much help out there, if we choose the mental opening, over our person emotional desires.
When the mental building blocks of creation start to fall into line from a real foundation that works, it becomes an experience of enlightenment that changes us internally to a state of love of the creation, as we start to become involved in creation, rather then destruction.
This is the most satisfying path I can express so poorly in words. To understand how the creation process works, is a true mental acceleration experience. When we get it right, and our experiments start to work, and we have full comprehension of how they work, this is an achievement better then any emotional high one can every experience.
The emotions are temporary and always have two sides, the mind is "forever on" and is present through all time we experience, nothing is ever lost.
As with any personal achievement, we then have the power to use it as we determine is necessary to preserve our race on this world, or to apply it to evil. The more personal power, the greater the responsibility to have perfect control.
A higher science always appears first as magic, to ones without comprehension.
If you were in my area for only a couple days, you may witness things that do not make any sense, but blow your mind and change everything you ever thought was true about entropy. You would then need a mental model for your ego mind to overcome the fear of what you experienced.
We can build from the field fabric upwards, once we have breeched how it is done.
Interaction with the Field is personal. Everything that veils this off from our awareness is inside us.
It cannot be used widely on our world by anyone who has not experienced it first hand and come to a level of comprehension.
The progression is simple at each step of discovery, but very hard in that to maintain the mental focus over the emotions only comes later in life.
Our life times are very short.
Once the mind wakes up, it will never go back to an emotional goal, always the "purity of knowing" is the better state of our personal consciousness, for it is the one thing that does not change and records everything. Emotions come and go, but the mind is forever.
Mankind has the potential, to become a self sustaining civilization, as we learn how the atoms are also self sustaining forms of the Field that is everywhere.
These are my personal observations, only from what I have personally experienced, between me and the universe we find ourselves inside of.
This is the true science, and nothing is beyond our sincere questioning, and thus our final comprehension.
We must continue to test our ego mind mental models against what actually works in real experiments. The mind can then make the changes and reprogram itself. This is the human being potential that does not exist in the animal worlds.
We have capability of changing ourselves to live in different ways as a civilization. To become responsible for the state of mankind.
As humans, we must all begin to agree, and "choose" to act as one, as on 5th density we are not one, we are all separate beings.
Dave L
Science has no limits
Do you believe Max Planck actually ciphered the Zero Point Field? Is it real? And what experiment would you need to observe this and then realize is proves itself?
There is no existence that is not technical in our 3rd density reality of heavy matter.
4th density is where the programs can be openly read and comprehended that operate the physical universe we can see and observe.
The notion that a true science can breech right into what we used to hold as spiritual realities, is a hard one to accept at first.
As we note even in altered states of consciousness, with this access to 4th and 5th, there is definitely change and thus time is present there.
As well there is frequency of consciousness that is different, at different time flow rates, then in 3rd.
In the Light Activation of a car, we experience the 4th density time flow rates, and at first it may be very hard to make sense of.
We see the higher light in the tuning process, a previously spiritual experience filled with imagination and wonder at present, which causes us to not see it's truth as another physical reality with different physics that it is. We must then start to notice there is time present, there is space present, and there is form present also, at each of the other levels.
Many will say there is no time, while in that state because they are not using their logic mind to get there.
It is very easy to dispel this when the logic mind comes back online and the memory of the experience is examined.
In the same sentence they will say, there is no time, but something there changes and moves, and not even realize how impossible that is.
These statements are not logical or true, but they are blinded by the bliss of the higher light experience, and then logic is not yet present there.
To become fully awake, one must have the entire brain mass present in one coherent vibration field bubble. But the opening is slow and uses first only 1/2 the brain mass. The logic side must be brought in by calling on it to be useful to record and reflect on the truth after the experiences but never given full control as it will limit all things to what is already known.
The logic mind is then ever present to record all that happens at higher rates of frequency. It is a tool of the physical side, and must not be abandoned with the bliss of the higher light. To have this dual awareness, of the higher energy of the field fabric, and at the same time have the logic mind present to serve the science, is a mastery of the physical minds parts or functions all working as one.
Do you believe your own science, the Strong force field bubble that binds every atom into this reality is 137 times more powerful then any EM field can become.
Do you believe that?
Yet when people step into the psi reality of direct experience they tend to toss out all the knowledge of the physics and do not remember they are inside this experiment! They turn into small children with amazingly vivid creations of imagination, rather then using the Ego mind properly as the tool of logic that it has potential for.
For the science of mankind to the atomic level is now complete, as to the physics.
Even the secrets of the A bomb have been released, and without realizing it, we can all attain the knowledge of how it works, and the geometric forms of the three field forces. We only need look at the real data and then ask ourselves the correct questions. From where is the power for all this coming from, and why do the atoms not wind down as current science would have us falsely believe. Everything from about Bismuth down is given a half life that can never be measured as the times given are so long they may as well be infinite to us. A tiny atomic particle, that never stops working to correct both its frequency and form repeatedly no matter what we throw at it short of a nuclear destruction.
The atom can only be destroyed using a shock wave of vibration that overpowers the nuclear strong force, 137 times stronger then any EM field.
That was of course the first discovery, and now they have unstable atoms that will do this when the mass is increased. They set up two spheres, and when they touch we have a total nuclear release. Thus the nuclear reactor is now possible, but very dangerous if the rods melt down that keep the reactions under control.
The destruction of atoms is very dangerous for human exposure, where in we can instead set up mock atoms at larger fractal dimensions, that do not have to be destroyed to provide useful power. This may be a mind blower for most of formal education, but it is ever self evident, to anyone who has seen it work.
Instead we have to have take down frequencies to shut it back off, and this is the new danger we face with free energy.
When we cut off the source of energy to an atom, it will vanish, rather then spay us with nuclear particles.
Just as when we cut off the Source of gravity, we also loose all inertial restrictions to motion. All the Newtonian laws of motion change.
We need only look to the skies to realize others have ciphered this already, to turn at 90 degree with no inertial restrictions, is beyond most peoples  mental comprehension.
Now we can experience these phenomena in a car with an internal combustion engine, because spin is a universal property of everything, and the engines crank is spinning in a circle of high mass. It could not be any other way. This is the same as the mass of the atoms. They spin under a power, causing the E and P interactions to oppose in direction of spin, and it takes power to generate this opposition of forces, to create mass.
We do know where this power comes from, and Max Planck ciphered this a long time ago.
So why did they suppress the "zero point field" understanding that Max Planck ciphered, must be real to explain all we see in direct experiments?
Fortunately this knowledge is controlled from a higher level of consciousness, we cannot access until we become personally civilized, and with it comes the love of the creation experience, the reverence of all conscious life forms, as we recognize that is also what we are. There is no living beings that wants to destroy itself, and thus a reverence for life in the experience of other life forms is a natural result.
No life form can thus be judged as evil, as they would then enter of state of self destruction as well.
To experience an atom, setting on the bench that both self powers and self corrects at larger dimension we can directly experiment with, changes all we ever thought we knew about our world. Then to take it back down using a TDF, is the ultimate in realizing how fragile our world is to the advanced races.
They have stated they could take down our entire world and then the field it occupies would have to start over with a new process of creation of form.
From what I now know, they could do this from well outside the boundaries of our planet, by shutting down the convergent vibrational force that sustains it from moment to moment. This is the 4th density knowledge, and imagine how that could be abused if the Grey were not there to ensure it does not happen.
The conscious awareness of men only fully becomes coherent when facing the fear of death.
It does not become coherent as of yet from the Love of the creation experience, as we have not yet perfected this to be good for all people present on this world.
911 is one example of an event that captured all mankind's focus with a state of fear.
The CV disease is another.
The Love of healing has not had such an effect as of yet, but it is the ultimate experience for the emotions just the same.
This is a very technical process of consciousness, and existence in physical bodies as individuals disconnected from one another in purpose and desire by personal choice.
A mankind that truly seeks comprehension, will ultimately see all humans as the same value of life form, and desire no conflict every arise between them, but for now we are experiencing the heightened states of fear, to learn that physical life is not the end.
It is only on 5th density where no one can be destroyed by another, and so we do not even attempt it there.
For the Awareness was there at the beginning, and divided itself into what we might call souls, to have interactions of different perceptions in relationships, exactly as atoms do.
The experience from the outer boundary of this universe, is the same for all. Everyone of 5th density opening says the same things, and the NDE experiences prove it to anyone with an opened mind. Once we grow accustomed to the intensity of the light on 5th, we realize, we are all the same in this existence, and choosing all we do to incarnate into the lower time flow rates of the physical. In these lower layers we can have conflict and war, and death seems very real, and things move very slowly compared to the "knowing all at once" we have on 5th. The lower emotions are a great focus for most, and create never ending conflicts in the physical, over belief systems that are all different, and none are correct or accurate.
"Sliding" the frequency spectrum is not to be left to accidental discoveries. It is also a true science of perception of the higher self, which can send the information into the physical brain if that is the choice of the individual in a lifetime here.
We must however achieve accuracy with this ability, and test it locally on our world for the proof.
This process begins with an opened mind and the desire to find only what is true, and then filter out all that is the lie we use to heighten the emotions.
It is a technical process, as much as a spiritual opening.
We can test ourselves for accuracy at every level of perceptions, both locally and at distance.
This begins with the small scale experiments in perception, and the ability to feel the tempic field energy and measure it accurately.
Lesson Menue
It culminates with accuracy, locally and at distance.
Identification of the Elements using feel felt techniques and measurements
These are technical functions that can be fully tested and measured for accuracy. When we achieve accuracy with remote scanning at 100 percent, only then are we ready to approach the advanced races and expect accurate communications.
This information comes from them, not from me.
Know that any one of the advanced races could take down this world in a millisecond, no explosions, and no vortexes, only the pure Quantum Field Fabric would remain and a new start for the consciousness to develop a new system of life.
Ask yourself why they have not already done this?
They will not interfere with our Grey Protocols, as the Grey ones are the reason they cannot intervene at this time.
They have shown up for me at times to isolate my exposure to these other cultures, and when they do, the other cultures respect this and back off immediately. These protocols are honored everywhere, as far as I know.
The Grey that protect this world, are the only reason we are sill here.
Any one of us can leave this world on the next cycle to the higher light at our death, we come here by personal desire to participate at this level of awareness. It offers challenges, that cannot exist on the higher planes of immortality as consciousness that we each are, separated from the oneness until the end of this universe, if there is an end.
Awareness is universal, in this universe. It is the beginning and will be present at the end. "The boys topside."
We can learn all of this in study of how the atom works, and discovering ways to emulate it.
All the information is available.
I was very sad to learn that Nissam Harrimen, who first came up with the concept of fractals, does not even know how to use them correctly as of yet.
If he does he is not telling in his presentations. How could someone be so right and yet not able to apply his own theories to the data?
Maybe it simply is not self evident to someone of extreme ego programming, with no sliding ability as of yet.
Public figureheads have a different purpose, then nuts and bolts experimenters. They do not want information from outside, near as I can tell, when they have a large audience relying only on them for guidance. They are no longer searching, only attempting to prove what they already believe is the truth. They have their place in society, but still need to have real exposure to things that work. Experiences outside what they already believe, without worry of how they appear to others.
I took data directly from his online site to cipher the planck length fractals, and they work! Why would he be blind to that?
Application of this data is missing from his teachings.
So maybe we all have a different path to present, a different perception, and between all of us the solutions are already there.
Planck Length Fractals
Dave L
Probability
Is the Quantum level really based on probabilities?
From the Planck Length fractals I can state absolutely not.
The problem here is in the measurement of electron positions and velocities. For how can devices that use electric fields ever be used to detect something smaller then individual electrons? They are caught up in EM measurements, and thus have no ability to see or measure any smaller.
As there is no way to use an electron circuit to detect the Planck length level of our reality, and when they do get hits, they are a probability of observing something, current science has a blindness limited to EM detections. This is where all the theories of chaos and probability originate, in the false notion that they can observe something smaller then an electron using electrons to detect it. Even if light is used the wavelengths are the limit of resolution and the photons are discrete.
We then use vibration techniques to bring up a field of energy from the Quantum level to our bench level of dimension and discover it is most stable and always present everywhere we do this. There is nothing of probability about this, it always works, and always produces the same forms as we would desire to calculate them. This using the fractal system we can observe anything anywhere at any level of dimension using simple geometric calculations and the laws of vibration.
Just as the atoms are always present and always stable, we can raise up cones and spheres that operate in that same way, using absolutely no functions of probability!
Probability theory, is a mistaken notion of the limits of resolution of electron detection, where in the first field force does not contain spin at all and lies well below the dimensions of the electron, a 2D form of energy of the second order of manifestation in the quadrature field fabric and not the prime level of the Tempic field operation level.
With the Planck Length fractal evidence, it becomes self evident, we can indeed prove this level of reality not only exists but likely is the source of energy of the atom as well, at least in part. It is ever present, consistent, and repeatable in experiment.
That we can deal with something so small and yet make it appear for us at our dimension of consciousness, is truly amazing, and without the knowledge of vibration and fractals, we could have no other hope of observing it directly.
Once we have our proof personally we can then begin to use this knowledge to power different forms of energy directly, and they will never wind down or run out of power.
This information was all given in our current science, but hidden in it's teaching methods and erroneous assumptions.
An electron society, can never reach a level of comprehension of a Quantum Field Fabric or how it operates even to create electrons and protons.
While the muon may exist, its life is very short as a transient spin motion as matter is either created or destroyed.
Physics is deceiving itself, as they belief they are always right, and interpreting things correctly and yet can not see anything other then what an EM field can detect.
The spherical vibration sense is only limited by the reach of the ability of the 4th density body to sense and measure, then send this back to the physical brain to be used in the creation of new mental models that always work consistently at levels well below what our EM instruments can reach down to.
It is the stability of an electron that limits seeing below this level. To construct a two dimensions spin system, as the electric field, takes far more time then to construct a one dimensional vibration flux in the Quantum Field Fabric. The Tempic field is operated on by consciousness only, and is used to construct the electron with more complex motions.
Once the electron is constructed, it can then be used to create the atom, in combination with the Proton construct, which contain the mass vibration binding force of the Strong Force field bubble.
Working only at the level of EM one is lost to understand the anomalies of the fast pulsing wave forms of short and powerful transition intervals.
If one cannot feel and detect the vibration fields as they arise, and equate them to technical data for verification, they are lost in a realm of mysteries which can never be solved at that level of detection.
Using the vibration sense, one can breech this limit, and with fractal expansion prove to oneself the calculations of Max Planck were right on and accurate. We can also detect the Isotope level of atoms and learn to control them using vibration rather then EM techniques.
Are people going to choose to take this further? I do not know, but it can be taken much further.
Gravity manipulation and free energy lie in the choice to move further down below the level of the electron science, and start to have comprehension of the Quantum Field Fabric in real experiments that work.
The irony, is that sensitives have always been working at the Quantum Field Fabric level, and Isotope vibration field level. They just never applied the science to it, to make machines that work consistently. They work off the intuition which always has an emotional reasoning behind it and they cannot and will not measure or quantify what they are sensing.
The furthest science has taken it is to the body meridians of the Chinese systems of healing that go back thousands of years. They did create a science of the bodies fields of chi flows. As one become sensitive to these flows of energy in their own body, they can start to feel the heat and electricity of these flows become much stronger. Enough to feel the fingers are on fire, or going cold, or any other possible sensation that may result in the flow of energy from the field fabric that is always there and ready to power anything we can comprehend and learn to feel.
Consciousness always trumps the higher field forces of EM, and even as the strong force can contain the electron shells, some of our devices can stop the flow of electric fields down a wire. They are more powerful then EM can become, when we raise them up correctly.
Some of our experiments with the earths core fields have knocked down EM devices all around the points of experiment.
These events are real, and I was there in the center of doing them, and experienced the phenomena first hand with a group of several others operating world wide to the same center of gravity of this planet.
The irony is that the people working with consciousness have the ultimate power in the development of our sciences, if they will just embrace them as a true science, and get past the playing with their own emotions.
The roller coaster ride of the emotions amplified is never ending and never stable. When that is finally realized from doing it over and over, then one is ready move beyond that level of awareness, into the levels of creation of form. To see both the yin and yang simultaneously in the dance that is never ending in this universe.
So many of the sensitives are overwhelmed with the bliss states that are not permanent, and thus a constant effort to generate more and more higher states for longer periods, at the cost of local interactions and the life they came here to experience, for all that will be handed us on our death bed.
Dave L
The Photon
Here is where Max Planck shined. In proof of the phenomena of a photon and its path through space.
Max was able to prove without a doubt that as a photon of energy traverses any distance in space it neither looses or gains energy.
It's frequency is the same from the point where it was transmitted to the point where it is received, and its frequency alone determines its energy level.
This is important for the Quantum Field Fabric Experimenter to understand. As a photon moves through space at light velocity, both its frequency and its energy level is preserved without any losses.
Then this carries over onto what happens when it hits the electron shells or proton shells of atoms, and transfers this energy into and then back out of atoms layered shells. Electrons change energy states as they hoop to different orbital position, and again no energy is lost at this level of physics.
This is quantum level operations, and there is no entropy present at all in this level of the system where atoms work!
This has not been hidden from anyone of higher learning, yet they still do not see what is right there under their noses.
They continue to use EM technology for observations, and continue to see losses in the circuits of detection and still do not realize what they are doing, and how Planck revealed what is just underneath their measurement systems.
No one seems to realize that through the use of fractal manipulation of these no loss systems we can bring them up to bench level for experiments, without an intermediate EM circuit in between.
This is absolutely stupid to me at this point, in that they will not even consider such a thing is possible, they are so hooked to EM as a method of detection, there is nothing else that exists to them.
Yet ones like Planck were able to calculate it accurately, and indicated there is no problem with probability at all. It always works the same.
Every photon has a frequency indicating its energy level and that value is never lost in its travel through space at light velocity!
Thus we can come to view light velocity as a no loss resting state of energy.
It is only in the Electron Proton fight of opposite spin fields, we start to see a small drop in the velocity of these fields creating the mass interactions with space. Resistance to a change of velocity or direction as a gyro will show us. The term is acceleration, of either velocity or direction of motion. These require power to operate as they do. The Isotope is where this power is displayed in its resistance to a change of directional tilt of its spin fields.
The atomic motions are all slightly lower then light velocity, and with this lowering comes the mass of the atoms in the Field Fabric. Everything that moves with c velocity requires no external power to maintain itself, and experiences no losses.
We can reduce the drag of inertial changes by alignment of the Isotopes in a mass that is consistently the same element structure, buy cutting it to specific length of the sum of all the isotopes present. We can use the height or the base of the cones fractal to accomplish this manipulations and create the frisbee effect in the mass of the atoms.
The only reason this can even work is that for any distance in the field fabric there is a resonant frequency, if we find the Isotopes frequency, it will then identify a length or set of fractal lengths that can be used to entrain it. [Max Planck]
The Isotope cone spins at 90 degrees to its height length, and thus when we align them all, we get a flat plane of spin at the level of it's mass.
We then experiment with accelerating it, say in a car, and we realize that if we turn the spin plane to the direction of travel it stops resisting acceleration as much. We turn down the inertial drag as if taking off the brakes in a car.
We have accomplished a nuclear manipulation, at the Isotope level of the atoms and changed the way it responds to acceleration.
If one never tries this, and sees it work, they would never realize the power of nuclear manipulations!
All you need is the ability to calculate it, and to understand the Isotope structure, and how it is powered from the field fabric by the lateral surface area of the cones.
You also need the data I have handed you, mm = khz for equating the Isotope frequency structure with its vibration frequency, as Max already stated is the way it works.
If we set up a correct gap length in space, an Isotope will form inside that gap distance, because that is how the field fabric works.
At the Quantum field level of atoms, it is generated using a conscious focus of the distance, but at our level with fractals we can use two wires with a gap distance between them to manifest it at much larger dimensions. This hands us the proof that the math is correct.
There are multiple ways to manifest a conical system from atomic models, some are dangerous, and some are very much self contained and easy to control. We can change the angle on the tip of the cones, using calculation to preserve the lateral surface area, and generate self powering cones that are very stable. The 30 degree cones of the actual atoms are not stable without the electron shells to isolate them, and they will attach to other forms of energy around the experimental area and may grow without limits just as it is very easy to manifest elements in a Joe Cell that are very complex forms of nuclear construction and will attach instantly to the H1 atoms with diamagnetic field exposed.
The diamagnetic field exposure hands us the nuclear forces. We can then tap into them very easily. ABCH elements are prime for this.
Aluminum Bismuth Copper Hydrogen are the main ones, but ones like chromium can also be accessed with very low level diamagnetic fields.
We can even tap into iron with an extremely low abundance and manipulate the isotopes if that is desired, which it is usually avoided due to the resulting stress fields it sets up that can cause headaches.
The presence of the diamagnetic field is what stops electrons from crashing into the nuclear center of the atoms, and this should become self evident in dispelling the lie that we do not understand why this happens.
Dave L
What did we then find from our exploration of the Quantum Field Level?
There are no loss energy particles that travel at light velocity, which are non entropic.
We can manipulate inertia from the level of the mass of an atom using the Isotope structure alignment of spin.
Electron and proton spin, fight and cause a drop below light velocity that begins to create heavy matter and inertia.
They also precess in opposite directions as they fight. Light velocity is the rest state, and dropping this down with resistance creates mass and inertia.
At this point we still do not perceive entropy present at all.
We have not yet even approached gravity, or the gravity disconnect that is possible using correct calculation, that will work in experiment with vibration techniques. A complete and total disconnect which comes about from outside the atoms.
It then becomes self evident, entropy is not present at the level of photons and atoms.
Dave L
How can we raise up a field of vibration that is stable and will neither increase or decrease over time, perfectly maintaining it's energy state?
This is immediately possible using vibration energy.
In the first case we discovered that using phi is dangerous, as it may start to grow without limits.
In the second case we discovered that a pi/2 ratio will in fact do this and provides a very stable system that self maintains its field over time, seemingly infinitely through time. We can do this with a water cell, and two SS tubes, and draw energy from it also as it maintains its vibration power level perfectly. The water will start to go down much more rapidly then with normal evaporation and never stop working.
This is also nice to feel as it seems to be a perfect harmony state to the human body. A perfect musical 5th as I recall, but using fractal methods we do not normally hear with our ears. We instead feel it with the bodies nervous system and brain mass directly. We apply either caliper distances, or vibration coils with F gen.
Once the pi/2 was discovered to work seemingly forever without degradation of entropy present, this became a whole field of investigation.
The very mass of the stainless steel tubes could hold this vibration ratio and never stop vibrating at whatever frequency set we chose to install on them.
The two frequencies interact to produce an infinite string of numbers past the decimal point to seemingly infinitely small dimensions, in the mixing of the two fields.
This fracturing of our reality down to atomic dimensions, where there is no entropy present, seems to work very well.
This causes more change to be present in less space then it normally would be, and creates more density or tension in the field fabric.
The irrational fracturing ratios, causes the Source field to have to spend more time making changes in smaller areas of the space.
It feels as if we are accessing God and causing him to spend more time in our local area of space. A sensation description only, but it does have a conscious effect on us operating very near it.
As we progressed we discovered many more of the ratios of nature that can be used in device calculations, and probably the most important one for EM extraction the E/P ratio. This may set up an underlying coherent field vibration that does not decay and is not entropic, but can assist EM power at the  circuit level, as it does at the atomic levels. These circuits rely on a load being present to maintain the vibration path between source and load, as it is the load that produces the vibration needed to increase the input side in a non entropic circuit path. EM does not work this way at all.
Nuclear mass vibration, from the atoms level, is the only system I have found which can operate without entropy stopping it or making it decay over time in energy level. Although it may also be possible from the level of photons of light as these are non entropic as well.
Vibration is the easiest to prove, and takes very little effort or complexity to demonstrate.
The use of non entropic energy forms is essential to free energy devices that have internal control, as atoms have internal controls.
To regulate both frequency and form no matter what we do to load down the electron shells from outside interferences.
We can set this up for a room full of sensitives and they go crazy with it right off, as they can all feel it very powerfully.
We set this up for a room full of scientists who think they know a lot and want it all explained first in technical jargon, and few can even feel it working!
It is truly a self mastery to get both working as they should, the ego mind only to record what the feel felt is receiving, and then to calculate and understand it after the experience is done. If the feel felt can remember how something feels then it can duplicate it and project it accurately.
One can actually learn to install a pi/2 field on a Joe Cell with the finger tips, or even just using the mind, when it becomes second nature.
The danger is that then the person will stop doing the calculations and measurements that work, and can no longer share the data with anyone else.
This is a new age of renaissance activity, where we must develop and coordinate two parts of our mental operations to work together as one goal.
The feel felt vibration sensory ability, and the mental ego mind that can then comprehend and amplify using calculations that work.
While it starts out with simple exercises with vibration and feel felt work, the end path is what we have all been searching for, the free energy and the gravity control systems that work. I do not have a short cut path to perfecting both avenues of advance they must both develop together as one system, and our human form body has full access to both.
http://www.resonantfractals.org/Doc/1index.html
Dave L
Mankind's Resistance
The posts I put up are where I am at, and the result exposes the fact that mankind is absolutely resistant to respond to what actually works at this time.
Even when one person responds back that something did work, they then seem to abandon it, which is interesting.
Rather then dig to begin to have comprehension of how it was done, so they can advance it further.
I am also convinced that the ones of higher education that do have comprehension are not at all attempting to share it with the public.
Resistance to humans understanding how to use the Quantum Field Fabric to power their world is great.
Ones like Bashar are getting audiences, to work on their emotions. That comes first. The technical will come after that work is finished.
The resonantfractals.org site will likely vanish from the net in this coming year.
My part is almost done.
The seeds were planted in the human collective consciousness and that is enough.
I will put up this experience from my face-book site.
The main people who seem to be impressed are the sensitives or martial artists, and these generally have little interest in the science of how it works at this time.
"Dave opened his caliper to a specific distance. We all palmed the energy around it and felt the sphere. Then he set it on the table and we all moved our palms in and out to ask for the same sphere, and boom, it came up between our palms. It was so perfectly formed and smooth, and we could tell the energy was not coming from us. He said the universe sends us this energy if we only know the diameter and know how to ask correctly."
"You can read about this technique in Interactive Lesson 4 found at the top of Dave's Site."
This is a typical response from sensitives I have worked with. People need to have proof placed in front of them, to be motivated to take on the math and physics discipline to make this possible.
http://www.resonantfractals.org/Doc/Lessons/Lesson_4.html
If the sphere manifesting experiment does not work for you, go back to Lesson one and proceed through them one at a time.
The information is all there, necessary to succeed.
Since the electron is much larger then the Quantum Field Fabric, this cannot be achieved using electrical systems.
EM however can be converted to pure vibration with the hardware I have found works, but it must also be combined with ability to sense and feel what you are asking for. Thus there is no way to avoid working with your own 4th density body [astral body].
That level is more real then this one is.
Organizational Unity Concept may happen in the future, when mankind is ready to advance technically.
http://www.resonantfractals.org/Doc/Magnetism/Organization.htm
This document exposes the two sides of the 4th density frequency bands that humans experience. The emotional interpretation and the mental interpretation of the same bandwidth.
Frequency bands of the human incarnation cycle.
While most now cannot relate to this as an accurate experiment, that is what it is, using tools of measurement and 4th density awareness.
All conflict is resolved inside us. Realizing that is empowerment.
On a purely scientific level, we can have 100 percent accuracy on remote scanning, when we are ready to stop feeling everything as an emotion.
This document is the proof for those who are clear enough to get it working, they will then be ready to advance levitation craft.
http://www.resonantfractals.org/Doc/Lessons/Advanced/Lesson_1.html
30 years ago when we had experiences with these craft the human responses were either angelic or demonic.
This is because the vibration frequencies landed in our emotional overlay responses.
We are now seeing a change in this response. A positive note at least for some.
I have documented and explained this very accurately if one is seeking comprehension and is asking the right questions.
As we start to operate on the Field Fabric, we are now inside the experiment and must start to also observe our own reactions to the experiments.
To realize our emotions are also technical frequencies. This is what you will learn first hand with the F gen and scalar coils by scanning yourself.
Orgonite people are still working the emotional side of this for the most part and tossing them the Isotope frequency of a metal is appreciated by a few of them now and then. As we discovered Niobium and Quartz Crystals activate one another quite well. LOL! That is, it feels good, to create the bliss they seek to feel.
Dave L
Power Supply Phenomena
In the early design of power supplies for electronics, they had taught of a cancelling coil being used to filter out the 120 Hz ripple resulting from the tube rectifiers. This is a small linear ferrite bar, with a wire turned back on itself then wound down the ferrite. This comes right out of my electronics course materials [CIE Cleveland Institute of Electronics] in the 70's, back when we were taught both tube and transistor electronics. This is before desk top computers existed.
Much of the older equipment, F gens and old tube radios used this arrangement, as it reduced the weight of the older large heavy filter choke that was used originally.
Back in these days their was more psi phenomena being experienced with these early units.
One sensitive in Europe spoke to the dead through an old tube radio.
The way it worked was when the person was fully tuned into the radio they discovered it could still power itself if the tubes were removed.
The connection being made by the sensitive, could make the speaker still work with the tubes removed after he had worked the radio for some time and got the vibration field working, connecting him up into the 4th density, and still able to tune through the tuning knob.
They claimed they could hear the dead speak through the radios speaker.
Everyone of course who witnessed this believed it at the time, but few would realize it had any merit who read about it.
I certainly did not, until it happened to me.
I had purchased an older used F gen from the early transistor era, when transistors were new, because it had a nice analog dial on it. I could tune it smoothly across the frequency bands up to about 2 Mhz, and got this old unit to use with my newly designed scalar coils.
The Phillips PM5132  [0.1Hz - 2Mhz right on the front panel.] It could put out about 35 volt signals, although I never turned it up that high.
Pictured here in Experiment 4 down the page: Experiments
This was great for sensitivity tuning as I could connect it to the scalar coil and then smoothly slide up and down the bands. It could not hit NMR frequencies up around 10 Mhz but it was able to find lots of mass vibrational resonant peaks in different things.
This opened me to a new world of scanning the universe as well, using my own mind and finding all the blocks where I could not feel it and needed work.
So one day I come in and set down to the unit push the power button and start tuning the scalar coil, and feeling it working just fine again as it did the day before. Then after a time of working with it and having all the same vibration responses from it, I happened to gaze across the room and noticed the power plug to the unit laying on the floor, it was not plugged into the wall anymore, but the scalar energy tuning of the knob was working just as it had over the past weeks. The maid who vacuumed the room had unplugged it, near as I can tell.
The cord on this unit was about 15 feet, so not surprising really.
A shot of fear ran through me, as I realized the unit was still working to tune across the frequency bands but with only the scalar coil attached to power it. My expecting it to work as normal may have been one of the reason that it did???
My newer integrated 15 Mhz F gen did not have this response at all, when I attempted to see if it would work the same, so I tore into the circuit diagram of the unit to discover the filter choke I had been taught existed in my CIE training.
That unit always felt nice to me and touching the Aluminum ring around front panel was nice, having a feel about it missing in other test gear.
Without realizing it, I had connected to that vibration energy, and coupled it somehow through the tuning capacitor system of the unit into my scalar coil outside the unit and between these two coils I had a flow of the conscious vibration energy, and it was still tunable with the power button on or off.
When I started to feel this new kind of energy, and connect with it, I had some new phenomena happen that totally blew my mind.
Now I understood why in the olden days this was far more common.
While this gave credence to the old stories, now for me it was real, would anyone even believe me?
I remember finding that F gen on ebay, and paying an arm and leg for it to be delivered by ups from Florida to Alaska. I just knew that was the one I wanted, and so I payed the high price for it, probably much more then it was valued at if you found one locally or at a garage sale.
As it turned out, it may have been a nudge from spirit, to hand me what I had been asking for. The secrets to gravity control and saucer technology.
All this totally fit into the work of Wilbert Smith and his descriptions that at the roots of the Quantum Field Fabric was awareness. Awareness had to be present at the beginning or starting point for a universe to exist as we observe it today. Asking any questions as to how or why this existed is obviously something we cannot answer from our level of observation so it is not productive to ask that question. We are aware, and we know that we are, and that must be enough to define the starting point of the physical reality and the field forces.
I was hitting on the primary field force of the universe, and experiencing it directly. Somehow it was connected to our conscious awareness.
Through that document I then began to desire to have a field bubble I could set inside of completely.
This became like a desire that was present but I did not really understand why, or needed to know why.
With experiment 7 I found the correct method, to construct the field bubble I could then set inside of with spheres of energy reaching out to fill the room completely. It felt really good to be inside a spherical field bubble like this and have control of it's frequency directly from the F gen.
Experiment 7
I could now begin to log real data, and quantify this field that responds to conscious interaction. I was passing by the ones of feel felt emotional euphoria they all sought, and maintaining my logic mind presence to record results and make observations that could be calibrated and shared with others.
I also by now had an experience with the Grey protectors of lower 4th density, if I got into trouble I knew they could appear and send me telepathic assistance, but alas using this device reduced that need greatly as full comprehensions come in as complete spheres of information already.
I could now tune this field bubbles size and frequency for myself, with correct geometry to get real answers and data as well.
The unit, in a big way, was teaching me how to use my pineal system which I did not yet fully realize, and that someday I would be able to do all this stuff without the unit present at all, once my 4th density body could communicate with my physical body through it's methods used on 4th density.
The scalar coil was now set inside the base of the RM unit, and its vibration hit the crystal sphere and could be tuned to any frequency and become radiant into the room around the sphere as platonic form vibration fields. The various magnet rings on the ferrite base at angle created more tension on the bismuth core, increasing the output of the field bubble.
I was now finished with the basic design of the RM-1 unit, and could begin using it to "slide" the earth, to any point on the earth and read any frequency I encountered remotely. I used to place the left hand on the sphere during these slides out, but later learned to feel it without the touch.
I also witnessed some phenomena with the camera, showing that light balls would often appear in the photos. I assumed to be dust particles in orbits around the unit. Others however were finding faces in these light ball photos, and to me they did feel conscious.
Light balls would then appear in photos of me, and for a long time after this I would opt to be the one taking the photo so that the balls would not be present in the family pictures. Even then however some would appear every other time.
When my youngest son graduated high school, the photos of us with me in them always had light balls present.
I attest this effect to a direct result of using the RM-1 to train my body to using the spherical field bubbles, which are conscious fields of vibration energy that can reach through density to make things visible we do not normally see.
Measurements using a compass exposed that the configuration for mass vibration from Bismuth and Aluminum, was to point one magnetic pole inwards all the way around the device, and it turns out the scalar coil wind I used, does the same thing modulating this tension to hit the nuclear mass of the atoms in the Bismuth and Aluminum, the diamagnetic field that is already exposed in these specific metals.
It now also became "self evident" that the diamagnetic field is why the electron shells do not crash into the nucleus of the atom, and the diamagnetic field come from the nuclear center or the mass of the atom.
Over the years my vocabulary changed, to better fit current science, as I started to understand how NMR technology added the numbers for frequencies that could then hit things I would desire to target more accurately. I developed a system of measurement I labeled NVR [nuclear vibration resonance] and established tables of data to accurately hit these, and then begin to set up larger Isotope cone fields as well as spherical mass fields that mirror the atoms themselves at larger dimensions.
I was eventually able to tell how the Isotope fields draw in energy from the Field Fabric on the lateral surface area of the cones, but are controlled by the height of the cones, which hands us how to rout energy through a conical system that powers from the Field Fabric.
COnical Tensor Field Menu
This is the crux of power from the Field Fabric! And it becomes very dangerous as it must be controlled with comprehension to utilize.
Atoms do not just shut themselves back off when we start them working, and the natural form is a 30 degree cone with two other inside it at smaller diameter and angle.
Next with the correct geometric calculations of the Quantum Field Fabric, we finally see EM arising from these cones.
The 33 degree mod, tames them. The 45 degree cones are yet to be explored.
I had then found the desired goal to create energy from the Quantum Field Fabric that is everywhere, and it is not random at all, it is very consistent everywhere we have brought these fields up on the earth. Now that we can determine all the interacting frequencies accurately, they can be constructed by anyone with vibration sensory ability.
Randomness only enters the picture when we come up to the level of EM fields, as they tend to shoot outwards all over the universe.
If we set up a resonant EM circuit in the radio spectrum, bringing hand near the field coil will change its frequency!
This is not the case with the Quantum Fields Vibration energy form. The vibration energy is so stable it can work under the strongest EM fields and not be effected at all as to bending its frequency. This is because the EM field are built on top of the Tempic field vibration base as their foundation.
To alter the tension of the field fabric, all we have to do is to converge vibration frequencies inwards to one center, and it will change the tension on the field, altering light velocity through that area of the field fabric. Basically this is platonic form vibration. It vibrates inwards to outwards, and generates the field we know as gravity, or in the atom the field we know as the strong force. It always works as a spherical field bubble in this case.
These kind of fields can now be constructed by us, at larger dimension then the atoms, but when they are they work the same as the atoms and have no losses as they work at the atomic levels also. This is through the use of fractal calculation of octaves.
In an electrical system energy flows outwards towards the larger element, but with vibration energy it flows towards the smaller octave in harmonic coupling with it. This is why the strong force of the atom is so much more powerful then EM can become.
Now some people have been trying to access the Quantum Field in other ways, using plasma and such, and this is a major fallacy in logic.
The creation of plasmas as we are familiar with are generally very hot and constructed of electron motions or proton emitted photons.
The electron however is a higher level of the structure of the Quantum Field Fabric that is purely a Tempic field system having at its roots no spin.
Wilbert Smith pointed this out early on with his Quadrature Field Mental model.
If we want to take energy from the root level of the Quantum Field, we have to start with straight line forms of vibration, then to make them spin we must add a correct frequency shift so they go out of sync with the background field at the 1D level and connect with it at the 2D level, with the same area that couples to the Fabrics base frequency set. This causes the form to spin up, and makes the electric field possible. Now it is possible from here to create plasmas, but if we do not start with the bottom level, there is no real control offered for a shutdown of the field under frequency control.
The fields come up, self power, then can be taken back down, using only vibration frequency access.
Because we know the actual structure of them!
I do not believe Nissam Harrmen has discovered this as of yet, as he is trying to deal at the plasma level from what he is preaching to his followers.
This math is not complex but it may be a bit hard to grasp, or reach comprehension of.
If we have two circles that have a ratio between their areas, they will have a different ratio between their diameters. The 1D and the 2D couplings to these fields operate differently but also simultaneously.
That is, the area of the circle of the electric field spin, is powering it, but it is controlled by the tempic field on the diameter!
That Tempic field is a straight line with no curve. Thus the Pi / 2 ratio arises with the electric field appearance and is the ratio between the diameter and the curve around 1/2 the circumference of the spin field.
This is why we can set up a caliper to pull up a circular form field around it, a cone, or even a spherical one. The linear field controls everything.
This is why the caliper is the perfect tool for Quantum Field Work, for measurements and for testing purposes to design devices that will work.
One correct linear distance in space, can be used to manifest any primary form that is possible to pull up.
Once that field manifests, we can then rout its energy into a secondary level that will then attach to it and feed off of it.
Or as we say in magic, its all done with wires and mirrors. Straight line [wires], and resulting fabric reactions [mirrors] the Fabrics internal intelligence or programming.
The result of all this, is that it is far more simple then we ever imagined, to manifest fields of energy from what seems to be nothing at all.
Dave L
Quantum Level Creation
From the roots of the Field Fabric all the way up through photons, and the entire table of elements, there is no such a thing as entropy, or randomness of how things actually work.
How would one ever realize that if not asking the right questions during the study of these?
Appearance of muons however is very erratic and very short intervals of existence, thus while they have frequency they are not stable units of self recovering energy levels as atoms are.
The atom is obviously the best mental model of a free energy system, and since they do exist, we have our base of free energy now fully defined for us already by current science. Well defined and even quantified.
This is a realization one must come to on their own, I have no desire to convince anyone, as the data is "self evident."
Few if any sensitives realize that their talent for feel felt energy work can take them all the way down to the Quantum Field Fabric Level and hand them techniques to both measure and duplicate fields that will create atoms. As well atoms of larger dimension to use as powering systems.
HyperPhysics
Ask the right question then search for the answers in this database, when you come to a level of comprehension on electrons, protons, and experimental proofs, things will become more clear. This may take some time, and the right question must be asked to advance.
"How do I chase the power through an atom?"
The Basics of NMR
Look at the gifs showing how the nuclear mass moves, and try to comprehend and feel the forces present.
Also note the frequency ranges of nuclear magnetic resonance, and how external magnetic fields effect it.
Answer every question that comes up in your mind, do not assume anything.
This is where we find the conical motions present for the nuclear mass of the atoms.
Remember the atom is the best well known engine of the free energy system!
Wilbert Smith The New Science
Seek to understand the Tempic Field Fabric, and to realize from the mental experiment, awareness is universal to our universe. Connect with that thought deeply, as that awareness that constructs it all, is the same as our awareness at a smaller fractal dimension. That this intelligence can also flow down to the smaller fractal inside our own mind from the entire universe.
Our consciousness is a part of the entire universe in it's same image.
This is the knowing state that comes directly from the spherical field vibration bubble geometry, pure telepathy of comprehension.
Dave L
Dave,
I wonder whether you've yet seen this fascinating video?
It is quite long, nearly two hours, and it covers a lot of territory concerning Free Energy.
In several areas it touches on things which are quite similar to what you've been teaching us.
Your thoughts please.
Dave,
Yes, most is pretty accurate there but the reasons are not presented well.
Mankind is so far off where they could be now, I did not even want to respond to this! LOL!
It is one thing to expose what is possible, another to make it work in a society bent on conflict and competition.
I do not like where this world is heading, building robotic soldiers and drones, with the only intention to kill and maim.
So much money wasted, on destruction, when the universe is actually all about creation.
Dave L
Thanks Dave for your precis on what the video presents.
Yes, it is very unfortunate that in our present World nearly all positions of power and control are in the hands of megalomaniacs.
Perhaps the ongoing great awakening will catalyze the "change" which will turn off the greed driven conflict and war.
I have had a good run this lifetime.
Our generation had the best music, and the best scientific methods.
We learned how to think and reason, and had access to the widest level of information of any before it.
Our mental blocks and blinders were removed, and we learned how to ask the right questions.
I lived through the end of the draft, the peace protests, and massive social changes.
I have seen the greatest expansion of humanity on this world for thousands of years, and the possibilities of even greater advance made.
I could not have asked for more!
The highest reward in old age is to have that comprehension, and the history to reflect on.
We are now closer then ever to the greatest possible mental acceleration in history.
I have personally witnessed gravity and inertia control, as well as free energy systems, and been allowed to cipher them technically!
If we can make the right choices, this world is ready to step into the light.
If those still in the dark remain in power, they will not make the right choices.
Each step of technology is logical, in general only one conclusion is possible, and when we include our own Awareness as part of it, we get all the right answers.
Re-discovery of the Quantum Field Fabric is happening again after about 100 years of groping in the dark.
Maybe this time it will take!
Dave L
Reflections of a meditation that is reality.
Standing on the earth, it is the earths core where the greatest light comes from, and from above only the vacuum of "sweet space."
Awakening involves many surprises, when the awareness becomes more informed through direct experience, and actually touching what is, without judgment present.
The term "Sweet Space" is what the astral traveler can feel and experience, when they finally break free of the ego mind programs that are mostly backwards of the reality. For in the un-manifest Fabric of Space, is all possible forms of manifestation waiting to be accessed, as creation.
We may speak of the "other side" and in the early work get glimpses that frighten us, because the reality is in general opposite of what we think.
The darkness is not to be feared, just because the physical body cannot see it. It is the hidden part of our reality, hidden from the physical eye, but very visible form the "other side." It is filled with energy beyond anything we can dream from the physical.
Tesla stated that light velocity is like a solid wall. It actually seems it is the presence of being everywhere simultaneously, and seeing anything and everything that is. The rest state of energy that seeks to always be everywhere, and maybe it is not the light that moves, but the observer. For me still a mysterious experience. To ride the light beam, and realize it is actually at rest. When we tug on it so hard it creates mass, and only slows it to 0.9999999999999999.....5 * C in the atoms at the electron shells, by making it fight with itself on two layers of spherical manifestation, this is the creation of the lower realms of matter. The E/P ratio battle to sustain physical form that never ends it's dance.
Even in death we see the backwards perception we have, as it was stated by some of spiritual awareness. When we are born everyone celebrates and we cry, and when we die everyone cries and we receive the highest light on our ascension back home, our greatest joy.
These things all sound upside down and backwards, but the Quantum Field seems, it is consciousness forever unending.
We are prepared in the realization that all emotions are cyclic and repeating, as is the very thing we call life and death, and the pattern is the same in all things.
For me now science and spirituality have merged into one truth, that is provable only to the self. All things are resolved into the perfection that they are, and must be.
If everyone could see it all, would anything really change? I believe it would.
Our petty fights over stupidity would end in a heartbeat.
When we realize we have nothing to prove to the universe, as it teaches us what is real and what is illusion of our own making, and still there is no end because from the depths of this universe we are all Loved beyond anything we can understand. And that truth is the Light of awakening.
The universe does not destroy a single part of it's own awareness, it only allows that awareness to shift into other forms.
That same awareness is in all of us.
One has no concept of how powerful an emotion can become until they touch that Source Light, and everyone eventually does.
We could compare the mental awakening, to the greatest emotion possible, to see clearly and to know, an over powering awareness that is what we are.
For the heart can hold but one emotion at a time, however in the opening of the mind, we can see all things all at once simultaneously, and understand everything. This is the path back to where we all come from.
These are the beginning and the ending boundaries of technology. Nothing is restricted as to our examination of it.
In the experience we realize our own awareness can surpass anything and then look back to observe it.
Mind has no limits other then what we create and seemingly it has no ending, it is ever present through our entire lifetime, and so many lifetimes of the past and future we have yet to create.
The opening of the mental centers are the highest ones of the human form body, the last to be developed in the spiritual progression of enlightenment.
When the mind finally accepts and makes peace with itself, there is nothing it cannot achieve.
Whatever is the next step will become "self evident."
The scalar coil that can manipulate mass vibration opens the door to examination of the entire bandwidth of human consciousness, in a way we can then quantify it, explore it directly from inside the physical bodies natural sensory channels, and become aware of the other levels of our reality while still inside a physical body.
Dave L
A Bashar Experiment 136.1 Hz
Bashar states this is the resonance frequency of the earth.
My measurement comes out slightly different at 131.8359...
I measured the earth grid nodes at 135,000 Hz, or 135 khz resonating at 135 mm in a copper pipe.
This is how we can locate earth grid nodal points.
We now want to make this length smaller into the lower audio range to see what vibrates up, so we use geometric contraction.
We can divide the length/frequency by 2,4,or 8 repeatedly to find lower octaves that will couple.
135000 / 1024  =  131.8359375...
This is then closer to 132 Hz then Bashar's 136 [ C sharp ]
Lets try this, here is an online tone generator and if we have a good audio system on our computer we will be able to feel it for our self, short of making a scalar coil and accurate F gen system as would be better as we would not have to listen to the tone, only feel it.
https://onlinetonegenerator.com/
First plug in Bashar's frequency 136 Hz, to me it warbles just a little indicating it is out of sync by a few Hz causing it to beat with the real frequency.
Now plug in 132 Hz and record what you feel.
In seconds I feel my feet start to vibrate, it feels pretty good.
The vibration in the feet is very constant and pure, and does not move around or warble.
Consider this is a resonant length in space of 0.132 mm vibrating through the physical body, and resonating something at foot level for me.
This is how the physics of mass vibration works.
Regardless, Bashar handed us another piece of data, and it is not really about whether he is right or I am right, it is about what works, and learning to feel and measure it for yourself. When we then begin to compare these measurements around the planet at various locations, we can then get a better picture of the truth. [Both of us are within about 4 Hz. = 0.004 mm]
If you type 132 Hz into a search engine, it becomes obvious that a great many other people have found this frequency already.
Dave L
Psi Experiment 101
The first level of experiment using the body apparatus must be done in such a way there can be no cheating with imagination, all things must be verifiable. We use the physical head of our own body for this experiment, and then we engage the awareness to set up the field bubble around it that will see everything in the room all at once simultaneously.
If we have found even one of the resonant fractals we can indeed feel, then it will be more natural to accomplish this experiment in accuracy of perception. Of course if we are a martial artist, being attached from all direction while blindfolded adds a sense of urgency that will assist one to accomplish this result.
We set in a room with little distractions present and move to the center of the brain mass. From here we project out in all directions simultaneously finding a point that brings up a complete sphere to our senses. We then ask to start to "feel" what is in the room, and as we then scan inside this sphere we are projecting, we start to feel reflections, and objects, and discover we can even "see" behind an object.
This vibration sense will travel directly through anything, any object and reveal its pattern and form, and even the vibration of what is inside.
The form of the field is "all at once," it is not a single point focus. Feel the entire room all at once, and out in every direction even overhead.
Just become aware, that is all that is necessary, become aware of the field of perception and the new ability to change it's diameter from the center of mass of the brain.
As the brain has two hemispheres, with different function on each side, there will be an inner conflict at first, that each side will attempt to take full control and pull it out of balance. However the lower brain that sets at the top of the spinal cord is one. So first we silence the higher brains thoughts of duality, and move down to the lower Lizard brain that has direct access to the spinal cord with no delay.
This is like a computer that speaks cobal or fortran or basic, and instead we start to write the program in binary bytes and words which run much faster.
To actually "feel" we do not need to access the higher functions of the brain at first, but later they will be brought in all "as one" to become the servant of the will, and all will then be present on both sides of the brain, with the senses fully turned on simultaneously.
An exploration of the brain function is in order, as we progress and seek out what is the cause of slowing it down.
The ultimate goal is to then keep the sensory level active as we again engage the higher brain logical mind to assist IT.
The higher brain can always see both sides of every conflict, and it tends to want to suppress one of them, making the sensory ability blinded again.
We will then discover our own "resistance to truth". Our unwillingness to consider all sides of all conflicts equally. To create an opened mind which can achieve a "field coherence" of vibration all the way across it.
In life there will be a balance of compassion versus logic in dealing with others. Both hemispheres of the higher brain.
We will then learn to keep all of this present in making the one decision necessary and no part of our self will then be in internal conflict.
The spherical awareness is the beginning of the spiritual path, in the realization that all conscious life forms must claim their space.
With this the higher laws start to come in, that everyone has space whether they hold it, or hand it to others to hold.
Within the awareness of the space we hold, comes the ways to control and protect it.
The choice what to allow to enter our space, and to instantly recognize what that is.
The Lizard knows when you try to sneak up on it from behind, as it suns itself on the rock in the dessert of Sedona Arizona.
It's Pineal system is more sensitive then ours, which we do not often use anymore, because we rarely feel threatened by the presence of other people or animals.
After about 13 to 15 weeks the martial artist is ready to spar with a blindfold, realizing they feel a person enter the dojo without turning their head. They feel the space, and thus what is inside that space is revealed in the greatest of detail. If they worked with that person they will even know who it was that just came in.
Because the field is generated as a platonic vibration system from one center, we see and feel all at once in all direction at once.
As the frequency rises with practice the resolution increases, as the sphere naturally gets larger in radius outwards from us.
In the martial artist this awareness can be tested. For the person working alone, they must go to places where they do not know where everything is and test them self. You must be able to then walk around and verify what you sensed. And do not start using imagination at all, it will deceive you relentlessly by moving out of the present moment.
I used to crab on the weekends for Dungeness, and could feel and scan the bottom for where they were congregated. It always worked.
Developing this spherical sensory ability, will change your life.
Remember however that if emotions come up, we will not see what we do not want to see, period.
All judgment must be dropped away to get accuracy.
Once the sensory ability begins to work, even a little, we can then start to measure these frequencies using a caliper in one hand as we scan.
If you can feel the vibration, then you can measure it. The caliper gap distance will vibrate up and peak at the exact frequency of what you are scanning. It will vibrate up exactly like a resonant rod, or a crystal, because stainless steel is fortified using chromium which is a diamagnetic element, and the steel has a high tension in it's bonds.
When we learn to pass our field outwards through another person, we get everything including emotions and intentions. However if we have not purified our focus to stop judging, and allowing imagination in, it will loose accuracy almost instantly.
The desire to judge someone as bad because they are having a bad emotion is common.
And thus the first level of attaining accuracy in psi sensing is to clean and clear all our own emotions, such that none of them are resisted, but allowed to pass on through. They are temporary states and will pass if we do not feed them.
Better judgment of action will be made by keeping the full brain function all turned on, as the emotions pass through.
If we loose control and then polarize to one side of the polarity, our brain will slow down and stop seeing all that is present in our space.
In the end we come to realize the sensory system of the body, is more accurate then all our devices we have built to measure things for us. It's resolution and accuracy is much better, and it works much faster.
A funny story, for about a year I was having problems with my two front tires on the RAV, and had to watch them, as one winter they both went flat.
Many trips to the tire shop and a lot of frustration that year. I then started to visit the service station and keep filling them when they would drop a little. I got a tire gage as well.
At some point, of feel felt work, while using the tire gage, I realized I could feel the tire pressure, and eventually read the air pressure in the tires using a SS caliper and my feel felt extension into the tire where the pressure is.
After this great realization my tires stopped going flat! Like spirit finally saying, ok kid you finally got it! LOL!
That seems to be how Spirit works, for some reason, when we ask for something and then we get an answer we did not expect but is the solution.
If I had stayed in my anger mode at the tires, I would never have discovered I can "feel" the air pressure inside them with a scan.
Anyway, developing the spherical sensory ability is very natural once one stays in the present moment and learns to use the animal Lizard brain system we all have inside us. When used at the center of mass between the two hemispheres of the brain, we start to have all the function of both sides of the brain at our immediate access in real time, and the frequency rate of our conscious field can then reach higher and higher, as we ascend in frequency and learn to scan the bands. Platonic form vibration fields were the study we were handed in the early days, and had no idea why that was important.
The atomic mass data, expanded geometrically will produce spheres at any fractal size we desire them to come up.
This is how far this can be taken going inwards using accurate data from science to find these fractals of vibration.
Once we get our physical sensory abilities working as our 4th density body works, then it can begin to teach us what we are seeking to understand.
We discover that full comprehension can enter the physical brain, using the spherical field bubble we hold around it.
This result is no accident, and if used scientifically can become totally accurate, measurable, and predictable.
Dave L
Addressing Excuses
I like hearing my wife complain, honey you have done this all your life, it just will never work for me. Then off to her church to fill her with the emotions she needs to get by better. Her method works for her, most of the time, and she is a pretty good companion to live with.
My karate teacher said to me when I was a young guy and he was much older doing this magical stuff, "the next 7 years will pass whether you study this or not. Where do you want to be in 7 years?"  Ok so it took me 18 years, and I loved every minute of it. To really learn something well one should then teach it also.
Kind of put that in perspective, and gave me a longer vision of time then most today ever have.
However being around someone with these supposed "gifts" really helps, as seeing is believing, and feeling is even better.
Doing a Reiki energy balancing, after a 2 hour workout with martial arts, is the best! No doubt remains if it is real or not.
Vibrating up the muscles and realize they no longer fatigue at all, is an amazing discovery of how the body can work more when it is fully relaxed.
The paradox of "relaxed power" is very evident in the advanced martial artist. Even the breathing changes. As you progress it is all very natural.
To release extreme levels of power instantly, then recover with one correct breath. Increase the air pressure in the lungs and the recovery is almost instant. So one exhale with a little resistance at the mouth will do it. This becomes so natural, it is hard to believe, and while watching another go over and have to breath for a time gasping to recover, is rather humorous.
There is so much to learn of the physical body, and so little time in one lifetime to master only some of it.
After the basic training, the people then segment themselves off to different paths, and seem to all know what that path will be.
Many embrace the healing arts, Herbs, Foods, Vitamins, Acupressure, Reiki, levitation, very few stay with the fighting arts so as to take it further.
The body sensitivity, can take one into nearly any other path and add focus and power to how far they take it.
Body discipline teaches mental discipline and control of the self. The art of relaxed power, the paradox, never leaves one who has learned it well.
Focus on fighting as a defense, is not really a higher level because it works from a level of fear, to conquer that fear that we never freeze up, and keep the mind seeking new targets constantly. The weakest woman with this ability can escape the strongest man, just knowing all the targets, and being able to fake giving up. The rest is timing and frequency. There are so many targets and techniques that can disable a person almost instantly with one correct hit, no one could learn them all. The feeling of personal security in your own space is essential to advance in any endeavor.
Becoming fully aware of what is in your space, is essential to increased awareness in real time, and there seems to be no limit then on how high the frequency can go in scanning remotely, because we can also find a smaller fractal of the resonance we find anywhere out there.
This is technical.
If we limit our technology to outside the physical body then we miss so much.
Dave L
Numerology
We may have noticed that even Tesla was using some level of numerology, and that the concept is not totally void of logic.
3 - 6 - 9 has been around for a long time as the universal octave for manifesting power or change.
In numerology we add up all the digit in a string of number and when we hit 9 we reduce back to zero. 9 is considered completion of the energy flow.
Thus we look at the past year, and now the current year to see if there may be clues to how things may be changing.
2021 = 5   The pentagram is a radiance and growth number. Energy reaching outwards.
2022 = 6  The hex form is a crystallin system of stability, where internal change is then possible looking inwards.
Some perspective on the pentagon, a system based in constant expansion or growth. We find this present in our stock market, as a state of economic health. If the growth of a corporation stops, investors abandon it. This cannot be maintained forever, and thus we have seen crashes and adjustments in the markets over the years, making a very unstable system. With computer access to trading it became all the more volatile, they soon realized they had to build in delays to stabilize the markets, so some people had to loose money while waiting for the trades to go through.
In work with resonant fractal fields, that will self power from the Field Fabric, we discover the 9 being used a bit differently as a divisor, or a fracture that will take down a self powering vibration field, it will vanish and stop vibrating totally.
If we create a self standing sphere of energy at diameter X using a gap distance to bring it up, then we apply X/9 a smaller distance with lower frequency, the field crashes and is then gone again.
1/9 is literally the termination of the manifestation, the ending point of a circuit that flows energy from the Field Fabric.
It is also then worth mention that when we bring up a dual cone system in a gap, the system powers from the lateral surface area and not the height frequency. However it is controlled by the height frequency, and if we divide that by 3, the lateral surface area of the result is 1/9 and that is how you crash an isotope field. Disintegration of the manifested form.
It is not only possible to create an atoms energetic form at larger size, it is possible to destroy it. This is why it is possible make a powering system from this technology and be able to control it. To shut it back off. At bench level it is not hard to manage an accurate distance at 1/3 the gap distance of the form of the energy created from the Field Fabric directly. Also of note a lower frequency of less energy can manipulate and higher one with greater energy!
The very last step of this learning process is to add the electric field potential to the cone system, after one has learned to set up and take down cones that have only tensor fields in them. They will not shock you! Until one learn how to control them, they will not want to be bringing up a field with electricity and loose control of it.
So here the 9 is a necessity, as a fracturing form of calculation for absolute control of the fields.
In numerology the 9 is the ending point of the count, where the value of the count returns to zero. One past the octave which is the 3 dimensions or 8x geometric expansion of the octave.
1/8x will transfer vibration power downwards in frequency. 1/9x of that value will shut it off.
This is how entropy is defeated, yet controlled.
After one can feel this energy it will become self evident in small experiments at bench level dimensions.
With the understanding of fractals then and larger volumes of space has more energy, resulting in higher frequency, we can add power simply by accessing larger volumes of space. We can then access the space using only scalar coil frequencies, well beyond the size of our calipers and pull up monstrous fields of energy, using very low levels of power into the scalar coil system.
The saucer flies over and all the electronics goes dead 100 feet under it. A worst case scenario with a very real explanation.
A strong force field bubble to protect the ship out in space. All high energy EM fields will be bent around it, thus the circuits in any electrical devices will stop flowing EM against it's bending angle. If a circuit happens to match that angle of bend for enough distance it will be fried.
David Hamels cones went shooting off into the sky and all the cars in the neighborhood died instantly. Magnets and Aluminum with large vibration field bubbles of the nature of the strong force of the atom. This will easily overpower all electron propagation paths in the area. The noise floor will drop up to 300 feet out from a strong Joe Cell in a car.
Where is the power in the atom? The nuclear bundle with it's strong force surrounding the location of the mass.
What is the form of the power? Vibration in the field fabric with a greater reach then any magnet or electric charge could ever achieve.
At this point he had no ability to control what he had achieved! Later he states it is controlled using telepathy.
Hamel also described the motion of the Isotopes he was very familiar with.
In the diamagnetic metals they connect between atoms and rotate together as one larger field.
We can align them in various ways based on the frequencies of the height, the side frequency, or the base frequency.
These various methods produce different overall results.
In Aluminum materials we can end up with very high voltages being generated on a cone with 90 degree tip angle.
All these past masters of free energy and their devices start to become comprehensible.
This knowledge and feel felt sensory ability used together reveals it all in a very personal way.
Dave L
My perception of higher mathematics
It seems one must make a study of things to realize what they are not.
We may examine a paper on Electro Gravity, which does not even work, and all one will see are formulas with almost no description of the variables offered. The assumption is that Gravity originates from EM fields, and the formulas seems to make it seem possible. They are simply too complex to have meaning for the average person, let alone any sort of comprehension offered. As if an electric field will operate the same in any material, which is nonsense. Every element has a different frequency base! If gravity was electrical we could measure it using meters and see how it falls off with distance between earth and moon, etc... Gravity has acceleration all the way along this distance and at 1 foot it changes enough to power something from the phi ratio of vibration pointing straight down.
As gravity is a result of all the elements on our world mixing their radiant fields to eventually generate a phi function causing them to all reverse and pull inwards at smaller fractal level then the radiant side had.
Gravity pulls towards a center of mass and Electric field is a surface charge that tries to spread out, there is really no comparison.
Anyway, I did learn the advanced mathematics, and because I did I have no fear of it, and most of it is not necessary for anything but theory that has never been proven.
We can conceive of infinity in our mind, with no ability to ever feel it as a feel felt reality in any way. No way to even touch it, personally.
Infinity is a pretend construct, and there is nothing possible to create a boundary layer from an infinity with no boundary.
With infinity it is impossible to create form.
In electronics we seem to believe that all frequencies are the same and none of them are special in any way. We tune the dial of the radio and pass across various stations and all of them can deliver the same songs to us at remote locations.
In electronics we are blind to the value of frequencies found in nature. "Metrics" of our world that do not change with very specific frequencies.
While it is necessary to deal with very tiny values, we do not need to use higher math to bring up a fractal of a very tiny resonance from the field fabric.
The math is simple to accomplish this. The most difficult part is probably the dual cones, and all the formulas are available online anyway.
What we need to add is the ability to scan the form that comes up and identify it accurately so we then can calculate correctly!
So much of higher math is complete short hand nonsense, I have only used calculus one time in my life where it actually mattered.
I have used solving simultaneous equations a few times for fractal work, and a lot of analytical geometry as to calculate volume, area, and length of sides of the basic forms as of yet, and already moved beyond our present sciences as to power from the Field Fabric.
Then they take us down into the atoms and change all the units of measure so we must then learn the conversion formulas for sizes and mass. That is about it.
"Physics people" have no patience for ones who do not have the higher math down with a host of variables with letters they never have to explain, this makes it a sort of secret known only to them, and the public remains ignorant of even what they are doing or how it might actually matter to anyone.
Someone like me then comes along and grabs the Planck distance for you, and then uses fractal expansion to experiment with it on the bench! LOL!
You can then see what it actually is and feel it with a finger for yourself, without even having to know the conversions I went through to generate the spreadsheet of distances that resonate with it. You can then make it personal to yourself and know what you are tapping into.
I have no doubt, everyone whom ever wrote a formula in physics thought they knew what they were representing, however Wilbert Smith puts this into perspective for us. We cannot use existing formulas to work out something new, any new phenomena will need a correct mathematics to fully describe it, and if we get it right it will lead to real results of manipulation that work. The math comes second to observing the phenomena which is real.
When a physicist gets so far into theory and then attempts to prove it using mathematics, this is backwards. The formula must be made after the phenomena is experimented with and proven to work as the math described it, the math of the field forces is not complicated if we embrace the triune thinking ability. TEM is all we need. And for the conscious explorer we add that to manipulate the T field. Mind.
However the ability of mind to produce vibration from the field, is a talent we are not taught in formal schools of science.
That is if you understand the derivation of a phenomena from the Field Fabric then when you call on it to manifest it will!
If you get the frequency wrong from an error in the math it will not manifest for you!
There is then comprehension present when it works every time the same, and it does if you get it right.
The map of the universe is one of frequencies and fractals and they all have different meaning and results due to resonance.
This is what manifests all the forms that exist as matter and flows of energy.
This whole thing has already been simplified at the very tiny levels of dimension which Planck already ciphered long ago.
His logic is self evident. The higher math applied to theory in physics has now clouded this so badly no one realizes what he actually found to be true.
It has produced so many numbers with "correction factors" because they do not work as expected in every case. Physics is an absolute mess of complex calculations. Max realized the entire thing is based on a Field Fabric that is everywhere the same, and it could not function as it does if this were not the case. This field must have tension on it to remain powerful enough to pass cosmic rays, and to hold the strong force present in all atoms.
As Wilbert stated so many years ago, as we get closer to the one true concept that is under all things it should get simpler, and not more complex.
This is the truth as I have experienced it following his lead, all the way down to the Quantum Field Fabric, and the originating point of all matter and energy in this universe.
Panck Length Fractals
Dave L
« Last Edit: 2022-01-05, 01:32:53 by DaveL »
Pages: 1 2 3 [4] 5 6 7 8
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 03:36:45
