img Maxolous Re: Akula, Ruslan, Stalker, device discussion and replications. « Reply #484 on: 2023-08-13, 08:18:06 »
Sr. Member ****
Posts: 325 Quote from: Excelsior on 2023-08-13, 01:41:21 Can someone please elucidate the shared attributes between these 3 devices? (What are the fundamental similarities?)
Akula, Ruslan and Stalker's device if that is what you're referring to, have the same mode of operation and of course they're same device not actually attributed to one person as above because they all replicated it also.
The original owner of this device is Nikola Tesla of blessed memory. Other foremost persons who built a working devices on this principles are Donald L Smith and Teriel KAPANADZE both of blessed memory.
The principle is based on "resonance and synchronization" through this, power can be harvested from the ambient or Aether. This had been proven many times that , there is excess energy in resonance and back EMF when the ambient is disturbed.
In this case we are creating voltage levels, thus ; the high voltage and the low voltage. Impinging the low voltage side with the high one. Both are already in resonance and in proportion to each others in term of frequencies ,then synced.
And why does it seem that one cannot be said to be "better" than the others?
The three named above are doing the same thing, one, namely Ruslan seems to have edge over the others on the media because he built a 4kVA unit of it and more current. Mind you he copied from Akula.
Or, is one of the three devices indeed more worthy of R&D than the others? If so why? Thoughts appreciated
No, we only have enthusiast like; Itsu, NickZ, Aliengrey, Geofusion, Maxolous, Apecore,Vasik042,Verpies just to mention few who are willing to take up the challenge and to build which ever version of this device on their work bence, also seeing it as real because there is sufficient evidence of the existence of this device as an over unity device , hence a " self runner"
Maxolous « Last Edit: 2023-08-13, 16:58:31 by Maxolous »
« Last Edit: 2023-09-01, 15:38:46 by AlienGrey »
