F6FLT
It is crazy to see that the thread "A true OU Breakthrough...? Holcomb scientific research" made to study Holcomb's system, is in decline, while the thread "Re: Holcomb and other FE technology debate" is at the top of the "activity". An activity of course without any interest or outlet, since it's about linking to Holcomb old outdated free energy stories from which nothing ever came out.
I agree to some extent, I think most realize they can read through all the technical chatter but it seldom amounts to much. Not unlike the Ruslan/Kapanadze thread where 95% of the debate is on circuitry and electronics not a working premise for FE. It just gets old after a while...
Now, on to something new from Figuera...
Because we all know that the effects that are manifested when a closed circuit approaches and moves away from a magnetic center are the same as when, this circuit being still and motionless, the magnetic field is increased and reduced in intensity; since any variation , occurring in the flow traversing a circuit is producing electrical induced current. It was considered the possibility of building a machine that would work, not in the principle of movement, as do the current dynamos, but using the principle of increase and decrease, this is the variation of the power of the magnetic field, or the electrical current which produces it.
Most FE inventors used this basic kind of language and we can see it is devoid of the standard terminology we tend to use. The bulk technical terms like inductance, reactance, impedance, phase angles, inverters, converters, lines of force, reluctance and so forth. Many also criticized Holcomb for using the same kind of non-technical but descriptive language.
Here Figuera is describing how a moving magnet is no different than the principle of increase and decrease or variation of the power of the magnetic
field with an electromagnet. Faraday agreed when he said it does not matter how the magnetic field changes only that it does. So we can see these
inventors generally approached the problem from a conceptual/descriptive perspective rather than a mathematical/technical one. I'm not saying either approach is right or wrong, only that all these inventors seem to see and describe what's going on differently than most do.
Figuera then goes on to say...
The voltage from the total current of the current dynamos is the sum of partial induced currents born in each one of the turns of the induced.
Therefore it matters little to these induced currents if they were obtained by the turning of the induced, or by the variation of the magnetic flux that runs through them;
Here we can begin to see a divergence in the inventors perspective and descriptions from our own. First he describes how the magnetic field changes in intensity and the total current is born as partial currents in each one of the turns of the induced. This could suggest that he was aware that the magnetic field is like an onion having many different layers of varying intensity. Likewise, each one of the turns of a coil could feel this variation in intensity to a different degree as a partial force per unit length but adding to the whole.
Obviously this is very different than a simple magnet field acting on some coils of wire as a bulk or generalized description. Many dispense with any description at all and simply call it induction. What I'm trying to get at is that many tend to use non-descriptive terms and a lumped sum perspective unlike these inventors.
So what does all this mean?, if we were to use infinite element rather than lumped sum analysis we find Figuera and many other inventors were correct.
At any given point in any section of one turn of a conductor all the partial induced currents should produce a greater output than we measure. However normally were only concerned with the average or lumped sum values and ignore all the smaller details.
This is similar to the flawed premise of temperature which is only a mean or average of the actual molecular motion present. It does not account for any individual energy states which could be magnitudes lower or higher than the average. It only looks at the average and "pretends" the higher/lower states do not exist which is not real science in my opinion, it's absurd. It's absurd because it doesn't take a rocket scientist to figure out that if we could use some mechanism to separate the individual energy states then all bets are off. Most of the equations we know become meaningless because they are based on averages and lumping many things together and pretending the individual states do not exist.
I take comfort in the fact there are people magnitudes more intelligent than I could ever be developing new technology I will probably never understand. It proves evolution works...
