2026-08-14, 21:02:14
Author Topic: PM Motor + Alternator Build - Think Outside the Box - wpgenligten 4Truth  (Read 1989 times)
Canadian YouTube posting Energy Builder, Gerald, over at Winnipeg Enlighten For Truth aka "wpgenligten 4Truth"
YouTube Channel:
https://www.youtube.com/channel/UC-zoUnW9-nK6qwYfGUfppiw/videos
Thank you Gerald for sharing and making your designs "open source"!   :)
He shows some of his interesting design builds on, 3 to 4 different PM Motor and Alternator combinations, which shows overunity, more electrical energy output than input.
It looks like several different key ways are available to achieve the extra net electrical output.
This Blog is my build attempt progress.
Parts Needed:
- Permanent Magnet (PM) Motor
Leeson 90VDC 15 AMPS 1.5HP Treadmill PM Motor
- 110A to 220A , 2-Pin regulator input control, Alternators for Input and Output controls.
Note 4-Pin alternators will NOT work, only 2-pin according to last video update.
Fun With Alternators...THE FOUR PIN PROBLEM
https://www.youtube.com/watch?v=2UQldK9Ad_A
Parts Needed:
Some photos, note the 2-pin alternator 10si type
Caution - spinning magnetic field
The inventor at wpgenligten 4Truth  posted a video today to issue a caution to anyone building this system,
Having Fun With Alternators .....A Quick Update
https://www.youtube.com/watch?v=9DF1NRqf_dI
Please understand its a spinning magnetic field and it may affect you by standing beside it.
"Two people in the middle of a test already felt sick to their stomach standing beside it.
So put it in a metal box and ground it and there won't be any issues what so ever."
How to Excite the One Wire - Self Exciting Alternator.
https://www.youtube.com/watch?v=QPl7CTb685I
Good video on the 2-pin 10si self exciting alternator description, used in this wpgenligten 4Truth build design.
Fun With Alternators.....A Quick Minute and an Upgrade
Jan 30, 2022
https://www.youtube.com/watch?v=0tr72rk6XaE
3- alternator setup for total output of 360A at 12V DC
- 2- 100 amp
- 1- 160 amp
Alternator Spec's
The 2-pin, 10si, self excited, alternator needs to be modified as follows:
- rewiring from the 2-pin connector directly to the rotor brushes.
Gerald will show a YouTube video on how to do this in the coming days.
Two Types of Voltage Regulator Design:
- Internal regulator (IR) as in the 10si
- Exterior regulator  (ER)
He found some 220A (ER) alternators that worked, as in the 220A Dodge unit demonstrated , and will post the info.
His design is based on regulating the rotor voltage to create more net electrical output.
Having Fun With Alternators .....Update
Jun 17, 2022
https://www.youtube.com/watch?v=KymdwX7Oxeo
Photo of:
220A ER/IF, Dodge Alternator, - 1.54VDC at 0.8A to Rotor Bushing, Input from CC PS
Are you using lead acit batterys ? only arn't they rather wastfull ? when we tested them they were only about 50 percent eficient
Rotor Bushing Input Current Adjustment Power Supply
It looks like a DC Constant Current CC type adjustable power supply
Video demo LED PS Output to Rotor Bushings:
1.45VDC + 0.55A LED CC PS
Jun 17, 2022
https://www.youtube.com/watch?v=Wnkt-UttSIA
DC DC Buck Boost Converter Variable Voltage Regulator CC CV 0.5-30V 4A 5V 6V 12V 24V Power Module
https://www.amazon.com/gp/product/B0978T3JKH/ref=ox_sc_saved_title_1?smid=AYY4I0D4PZJ0T&psc=1
Yes, lead acid batteries.
So far that is what Gerald is using.
Car Battery type for first battery input from alternator/ 4 Farad super-capacitor
Then 2-100 Amp 12VDC Deep Cycle lead acid batteries for main storage
3.5 Farad Super-Capacitor
Sound Storm Laboratories C352 3.5 Farad Car Capacitor for Energy Storage to Enhance Bass Demand from Audio System
https://www.amazon.com/gp/product/B00FU8O4NQ/ref=ox_sc_saved_image_1?smid=ABO907060G8YG&th=1
Video Demo:
Jun 17, 2022
wpgenligten 4Truth  update:
- No OU in this alternator setup.
- His latest videos show how to modify the internal regulator to make it an external regulator
Fun With Alternators ...The Last in the Voltage Regulator Series
https://www.youtube.com/watch?v=aYLGiWOs3Yo
Back to the drawing board!
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-14, 21:02:14
