2025-03-21, 10:51:36
Pages: 1 [2]
Author Topic: The Alexkor Device  (Read 11405 times)
I agree.
Thanks to you too for doing all these projects.
I cannot help but; given the preponderance of material I have witnessed supporting the notion, and the lack of palpable evidence against it; believe that it does happen and people keep it hush hush because of the money that could be made.
In my perspective - that's shameful
And a sore loss to not only the scientific world but Humanity as a species
Meanwhile the rest of us are scrabbling around for answers
Realizing the implications thereof
Thankyou for helping me understand all of this a little better.
Hi
Alexkor has a new more advanced device. Are there any video tutorials explaining any of his newer battery charging systems?
Can Inductors with Ferrite Cores be pulsed instead of making a new coil, this would be more accurate?
Also there was a link to Jeg's HV Circuit. Is this an Over Unity Device that can be used to power AC appliances?
Hi Excelsior
I would like to to get setup to start building these circuits. There are different versions of Alexkor pdf's going around and I will attach the most recent one that I have. There second last is an Input of 1.5V and the last has an Input of 12V-36V. I would like to build the last circuit in the pdf (Input 12V 36V)
Which one are you working on at the moment?
In both of these Alexkor uses a Choke but the link does not work. Does anyone know what part this is or have other part numbers which will work? Will the same Choke work for both circuits with Inputs of 1.5V and Inputs of 12V-36V ?
The circuit with the 1.5V input works at 200Mhz - 300Mhz and other circuits work at high voltages like jegs at 3kV. I would like to buy an good Oscilloscope without breaking the bank, even a really good second hand one, any suggestions?
« Last Edit: 2024-01-17, 21:15:38 by MPJ »
Just a note for those experimenting with battery swapping or “ other”
Here a recent topic with a replication?
Many of the persons involved are quite familiar with batteries and attempts at gain mechanisms .
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/512668-reactive-power-generator-rpg-replication-project/page8
 Sorry if too off topic ( please remove if ?
MPJ:
The choke type given in the non-working link of the pdf file may have become obsolote, here is a very similar type:
  https://uk.farnell.com/kemet/sshb10hs-r30015/common-mode-choke-1-5mh-3a-th/dp/2860686
          (i.e. 2x 1.5mH 3A 250VAC rated)
Yes, the choke should work for both circuits you asked,  use only one coil out of the two on the choke for the 12V-36V circuit you fancy.
However, never use a supply voltage higher than 30VDC for the last circuit because the gate - source voltage rating of the MOSFET type given is specified as max +/- 30V  https://www.st.com/resource/en/datasheet/stw12nk90z.pdf  and the gate is tied up to the 12V-36V rail via the choke + the 4 turn coil.  And do not operate the circuit when there is no any charging battery hooked up at the output.  Start with say 15 VDC input maximum to explore circuit behaviour.
One more issue: the 200MHz-300MHz operating frequency should be a typo, it must be kHz, not MHz.
If you use the Search feature within this forum (third icon top left), then you can find posts from member jeg on his HV circuits, and also search for "which oscilloscope to buy", this was already a topic too.
Pages: 1 [2]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-21, 10:51:36
