2026-09-04, 06:31:53
Pages: 1 2 3 4 5 [6]
Author Topic: Georgia Shop Technicians Ran Briggs Mower Engine ONLY Water In Carburetor 2008  (Read 45887 times)
Superimposed Voltage / Current passes Through!
Pulsing DC 40 volts, 15 amps, about 60 cycles, passing through 13Turn coil over steel core, going to separate load resistor, that has one line wire UNDERNEATH coil also, that is from different circuit of higher voltage, milliamps pulsing, at lower 15 cycles. This 2nd wire acts as a full loop circuit flux secondary side of STEP DOWN transformer of 13 to 1 ratio. Am I to assume this "automatic" secondary #12 gauge single line side has somewhat of an increased current passing through it also , to it's separate low ohms load resistance? (S1R9A9M9 Electromagnet as also being transformer means same time by induction )
Give me please circuit Bobcat excavator instrument panel. Because it’s impossible to find it here. :(
But it needs repairs.  Or at least a diagram of the cabin's electrical equipment.  :)
What's the model of the excavator ?
335
p.s. The excavator is used exclusively for peaceful purposes. (municipal economy)  :)
« Last Edit: 2026-06-04, 15:49:59 by chief kolbacict »
Water powered 1 cyl riding mower engine has alternators, and electric start starter. You tube 2008 2 videos by S1R9A9M9 . About 7 peak amps current (not average amps,) at about 15 % duty cycle , and requiring about 110v DC to zero ohms resistance spark plug . Water flow slowly into carb, with choke. MUST BE APPLIED THROUGH CARB VACUUM TO WORK. Georgia technicians converted several car engines back in 2005-2008. Spark plug electrolysis, without separate cell. There is also some water vapor creating pressure to push piston , of polarized charge ions separating from each other during piston movement, along with small amount Hydrogen gas. . Timing must be changed ATDC to about -34 degrees. Must be magnetic field applied to plug cable, and electromagnet with current .Web site shut down. I copied tech data so as could review later. Nathren got himself in trouble with other's accidents of reproducing, and won't talk any more. He either used Inverter box with series inductors + diodes, or just hand wound electromagnet with separate hand wound step up pulse transformer for the 110v. Alternators together with one diode for pulsing on+ off DC as about 8 amps dc at idle speed after starting. To start, without alternator on, vibrating relay used to get vibrating contacts for the 12v battery. After the Briggs 18hp engine running, him and son disconnected the car battery, so as self running on the 12 magnets alternators. Flywheel goes around 360 degrees. On time POWER only about 15-34% of the time. Electromagnet called the S1R9A9M9 triple coils assembly. See photos on internet. The shop technicians did not publish report, since the car engines were slightly rough running, and the special commercial relays were no longer available to purchase. I had figured out , they were using the wrong inverter type box. There are 3 types of inverters to change to DC. Square wave, modified square wave, and pure sine wave. The modified one does not deal properly with INDUCTORS , as inside their relay. They should have used the more expensive pure sine wave box inverter. Alliexpress china is cheaper than Ebay/ Amazon.
Video 1 only SPECULATION.  ;  tank disconnected from carb. Carb has gasoline. Engine removed from lawn mower. Chassis white plug connector end open. For carb to work , the solenoid valve at bottom of carb requires 12v on gray wire. Looks like Shut down black tab wire probably disconnected from Magnetron and hooked to small 12v hidden battery in hole of cement block.  The black and other gray wires on left side engine hook to separate holes of white connector. Jumper wire put on white plug. Carb solenoid now on, opens hole for gas to go through to engine. Person knows engine will run, but NOW, has no method  to shut down later. Loose extra wire is placed on spark plug top so as flopping end in air. That end is to touch casting to shut down engine. In the Smack video, there is no black wire near the Magnetron ignition coil where it should be. . There should be no reason to disconnect the original shut down method and change method, as ignition switch is not there. . At idle speed, the alternator to dc, has 12v available. The large main battery was disconnected at idle speed, during the successful test of engine running on "water".
Video 2 Speculation only:  No carb float bowl. Fuel has to enter top of carb. Plastic bottle needs, solution of gasoline, or 70% alcohol, or screen is placed on carb top with Carbide stones. Just water drops added will form acetylene gas vapors and instantly start engine. ( I already tried these) This does not prove engine not running on Hydrogen gas from spark plug electrolysis, and water vapor pressure, at lower power level.
The 2nd S1R9A9M9 Transformer/Electromagnet (Not Shown) 2008
That S1R9A9M9 coil assembly was the first made and tested with inverter box. Not compatible as having interference. The second one built, as source of extra current was used in deli tub, but found to form required magnetic field also. The first was discarded . Successful engine running s  of engine on water vapor pressure were shown. Actual new hand wound transformer/ electromagnet not shown. Step up transformer made from modified quality Kawasaki ATV  KLF185 ignition coil. Wire  removed to get 2 piece core set. Set fits with other parts in plastic deli tub.  Mower engine too low high volts. Tesla Patented circuit Inductor added to magneto to raise up voltage 24-30ktz. The videos about just 1st coils probably wrong, as about 2% efficient.  Take apart video was wrong coil probably on purpose.  Timing from Ignition tab terminal used for proper ignition and extension to late timing. Variable resistor vary s magnetic field, over cable, and vary s timing.  Can superimpose small current from wound secondary coils as actual main line ignition. Full loop circuit from extra ground wire through series diodes bank, back to wires joint .  Dual alternators output run only with engine at idle speed. Battery temporary only for starter + and removed. Wire on starter terminal transfers 12v temporally to conversion circuit. Relay high ohms coil operates about 15 cycles, from tab terminal to open + close extra contacts to get square waves on/off DC from battery. as power source, then alternators  half wave DC one diode. Talking about repulsion of over charged high voltage ions water vapor pushing down piston.
I made up another time line sheet regarding the S1R coils, but you are not that interested. Just suffice that it also allows for the ORIGINAL connected S1r coils and new coils same time in deli tub. The first was removed as not needed any more SAME TIME, as transformer has the required magnetic field also. There is also now the reason for the cut off stub frayed wires on the S1r coils. That point is the 12v source power for the 2nd transformer input. Then, it was cut with dull knife, not proper tool, so as copper stranded wires are shown. The web forum showed only the 1st coils assembly. The laminations core type with also full circle loop magnetics is superior as about 70-85% efficiency. Ai said the other was 2% efficient.
Please write back so I know you read my messages.
From original 2008 documents, the S1r electromagnet field in tub, forces the ignition cable to slow and pulse forward, greatly increasing the CURRENT through water vapor. Another wire coil is added to Briggs Magnetron ignition for way higher voltage that ionizes the vapor ions at same polarity to repulse, and form useful pressure, running engine on water in carburetor ! Minimum 24kv. So now we know! New revelation never heard of before! Shop final report was never released.  S1R9A9M9 You tube videos and the now shut down web site. The shop all previous engine conversions in Georgia were of Hydrogen gas as from spark plug electrolysis. The Briggs mower engine conversion of 2008 is now known as of from different method.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-09-04, 06:31:53
