Here a File shared by another open source associate regarding Neon appearing in the TGen Snip from PDF
OPEN Water can trigger nuclear reaction to produce energy and isotope gases Bin‑Juine Huang 1,2,6*, Yu‑Hsiang Pan 2, Po‑Hsien Wu 2, Jong‑Fu Yeh 2, Ming‑Li Tso 2 , Ying‑Hung Liu 2, Litu Wu 2, Ching‑Kang Huang 2, I‑Fee Chen 2, Che‑Hao Lin 2, T. R. Tseng 3 , Fang‑Wei Kang 3, Tan‑Feng Tsai 3, Kuan‑Che Lan 4, Yi‑Tung Chen 5, Mou‑Yung Liao 2,6, Li Xu 6 , Sih‑Li Chen 6 & Robert William Greenyer 7 This paper reports the discovery that water can trigger a peculiar nuclear reaction and produce energy. Cavitation may induce unusual reactions through implosion of water vapor bubbles. Many of this research has been published formally or informally. We have conducted experiments using two reactor types made from multiple-pipe heat exchanger and found that the heat exchange process of water produces peculiar excess heat and abnormally high pressure leading to rupture of the reactor. Recently, we have tested another eight reactors. Interestingly, these reactors produce non-condensable gas. We suspected that they include 22Ne and CO2. We used a mass spectrometer (MS) to analyze 14 gas samples collected from 8 reactors, including ten samples showing a coefficient of performance COPx > 1.05 (with excess heat) and four having COPx < 1.05 (without excess heat). Several methods were adopted to identify the gas content. For CO2 identification, two methods are employed. For 22Ne identification, three methods are employed. All the results confirm that isotope 22Ne and regular CO2 really exist in the output gas from reactors determined to have excess heat. We conjecture a possible mechanism to produce 22Ne and CO2 and find out that 12C and isotope 17O are the intermediate. They finally form isotope gases containing 17O, including H2O-17 (heavy-oxygen water), isotope O2 (16O–17O), and isotope CO2 (12C–16O–17O). In the excess heat producing reactors, all these gasses were detected by MS in the absence of 20Ne and 21Ne. The observed isotope gases produced from reactors having excess heat verifies that water can trigger a peculiar nuclear reaction and produce energy. Review of peculiar phenomena observed in heat exchange process of water Possible energy production via water cavitation has been noted for a long time. It was occasionally reported formally or informally that cavitation of water may induce some form of reaction by way of implosion of water vapor bubbles which produces excess energy1–10 . We have conducted experiments using two reactors made from concentric multiple-pipe heat exchanger and found that, when water is flowing through a tiny space and heated, it produces peculiar excess heat probably by cavitation and dynamic implosion of nanobubbles11. Water used in the experiments is the city water filtered by reverse osmosis (RO) filter. The first reactor (VCS)11 is a triple-pipe heat exchanger (THX) (about 30 meter long) using R22 vapor from a freon compressor (3 kW input) as the heat source to heat the pressurized water (about 21 bar) flowing through a tiny channel of THX, about 2 mm gap. The water flow can be controlled as a pulse flow, about 2 to 10 cycles per minute, through a control valve. VCS was developed for 2 years with several modifications11. The inlet water temperature varied between 10 and 55 °C at average flowrate around 1.2 liter/min. The compressor outlet tem- perature varied around 150–160 °C. Modification of VCS-1, VCS-2a, VCS-2b, VCS-2c, VCS-3 includes the change 1ChairIn End snip
Respectfully submitted Chet
