hello friends
I've created my own interpretation of the functioning of kapagen, and wanted
share it with you, to see what you think about it.
I believe that the operation of the coil is created by four coils
different wound on a ferrite core, the first coil L1, is the first coil
is linked to land and enrorrada ferrtita the same core of both ends of the coil
are attached to land, forming a short 'circuit
the second coil L2 is blue in the sr winding 193, this coil is
connected to the gap, only one end of winding, the other end is open, no connection, by
that reason the spark is not much power, that is open one end, coil L2
L1 is wound on the wound that has all appreciate the extra length, and is in
short 'circuit has ground chuck
the third coil L3 is connected to the thyristors to create a
THROUGH variable frequency pulsed circuit with the 555 (the third coil is
first to be seen in the wound on the left side of SR 193, this, is wrapped
L2 coil on blue)
the fourth coil L4 is to feed the 120 V/12 V transformer
Which is powered by 12 volt secondary feedback to the circuit, Flik
frecuencimetro.la flap and the lamp socket of the transformer primary voltage and the union
of the grounded wire
The question is to create a short circuit with the coil L1, throw to earth, and
with the coil L2 and L3 control the short circuit, L2 or create resonance amplitude
wave, and L3 create frequency, and thus controls the short circuit, which
absorb the energy of the earth
is only a theory, based on the idea of being able to control lightning, which
out of the ground to the clouds
chauuuu
