2026-08-18, 15:30:24
Author Topic: Need help with electronics  (Read 2472 times)
Hi
I need advice from electronic guru. I have done symmetrical powerr supply for my sinewave generator needed to test TPU kind device. I dislike however the idea of stepping down from 230V from power grid to -15V 0V +15V. Is that possible to get the voltages from single power supply for example -6V 0V +6V from single car battery ?
You can use the trick of creating an "artificial ground" at the +6V level, then run your circuit on pseudo +/- 6V.
Keep in mind that you are reducing the supply voltage quite a bit, and some of your IC's may not function properly.
Here are some examples of how to achieve the pseudo ground.
http://forum.allaboutcircuits.com/showthread.php?p=84026
LOL i was a bit slower  :)
Virtual ground is what you need
http://tangentsoft.net/elec/vgrounds.html
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-18, 15:30:24
