Where's Ed.L.?
Started by giantkiller, 2010.01.26, 17:11:37
0 Members and 17 Guests are viewing this topic.
giantkiller
It is seriously disfunctional to think that the common propaganda is true.
He was from Latvia which has microwave antenna designs in their ancient buildings and floors.
Grumpy
Quote from: giantkiller on 2022.10.20, 03:07:36
you are also not from here, nor am I.
We are many, and we serve the One.
O0 O0 O0 O0
giantkiller
What skills do you bring to the table and why should we hire for this job?
My reply is simple...
giantkiller
I posit that the substrate layer of the park was set up as a resonator to produce Chladni pattern of the Star of David as carved into one rock by ED L.
The resonant pillars were positioned at nodes/antinodes to further interface the substrate resonance to the auditory layer.
giantkiller
There are massive numbers of posters that all try to explain how Ed built the park. But none of them know or can answer the why.
The answer is in the movie Prometheus where the pilot engineer operates the console.
giantkiller
Quote from: Grumpy on 2022.10.20, 01:01:58
Most likely he went back to the Pleiades.
On the 1941 date the Coral castle points directly to the Pleiades constellation.
giantkiller
I mapped out the resonant columns in the park. They position to cymatic nodes. I posit that Ed used a hose to turn the 'Blow here' turret and to sweep the park with different tones to find the nodes.
He then placed the resonating columns in those positions. The rocking chair mount is also one. And no doubt the arcs over the moon pond.
Once the whole layout is set up the park would create a resonant chamber over the park.
This finding then exposes the 'Why?' into a bigger realm of beyond the last realization. He waits till the park points to the Pleiades  then turns this whole hydro-magneto-acoustic crystal based orchestra on.
There are astral penabulims on the chair and at the end on top of the west point wall. Draping a string across them shows an exact planetary position of the year.
But again, why? This little guy from nowhere has knowledge that academia didnt have full scale of. And he moved tons of crystals to set this monstrosity up to point to the Pleiades at a certain time in his life.
When one stands on the step of the North tower and looks south, the grooves in the walls become a celestial graticle.
Sm0ky2
Interesting thing about the 'blow horn',
If you listen through it you can hear every voice and bird in the park.
(the aperture was broken last i saw it so be careful not to cut your ear)
Anyone seeking to understand some of Ed's secrets
I advise watching giantkilleroverunity's videos:
I do not believe he knows what exactly he filmed....
But when you combine Ed's 3 writings:
(Magnetic current, animal veg min, and the advertisement pamphlet)
While walking through the monuments in the park
You learn the most important secret in human history.
Ed encoded it in stones, in the exact same manner the Egyptians did.
The story is told in words (the the lesser educated population)
Then the story is related to math, physics, and science in the stones.
You cannot see it looking at the stones,
Nor can you see it by reading the stories.
They both are used hand in hand, like a textbook and a laboratory.
And just like in Egypt, the stories come in 3's
Ed has taught us how to 'touch' the planets using a sensitive compass needle.
The moon being the strongest of these.
this is your first lesson and the one that will open the door for you to walk through.
