Testing Gabriel's friction heater: Results and Questions
Started by PhysicsProf, 2013.03.08, 18:41:54
ION
Yes there are many factors to consider,I did speak a bit with Steve About the Control runs I did to simulate
Gabriel's  device last Month [pryor to shipping]
I had done many tests over several days with resistive heaters in Oil [as per his spec and volume ]
at 500 watt 750 watt and 1000 watt inputs ,static tests and stirring.
I put 30 ilbs of steel inside the stainless test vessel to simulate his steel mass as well.
all tests did fall short of Gabriels Marks [not by much].
I am out of town for a few,when I get back I'll pull the data ,Steve was most interested in the Time to Heat vrs input Curve  [oil]
Thx
PhysicsProf
Thanks, Chet.
I did one more quick control test today, room air still 16.8 C.  I switched the resistive heater to 1500 W; wanted to see what it would equilibrate to.  Actually pulled 1358W per the KAWatt meter, and the temp reached in the tent was 94.4 degC = 202F.
With 634 W, the same device reached (equilibrated at) 54.4 degC = 130F.  So, yes, the equilibrium temp rises markedly with input power, as expected.
PhysicsProf
DUT was tested once more before sending for repairs.  Gabriel had noted that the oil had to be about 80 F before the electric motor could handle it.  (Viscosity down as temp up).  I found it would not start (keep the electric motor going before auto-shutoff) until 101F!  Suggests internal problems.  Further, At that temp, the max heating was about 3.4 deg-f, dropping to about 1.5 deg-F/min around 200F (oil temp).  Much less than Gabriel's 6-7degF/min heating at roughly the same input watts.
So it needs repairing; hope Gabriel is not getting discouraged!    Will get another chance near future, let us hope.
