Tesla electric car ?
Started by forest, 2015.04.08, 04:52:15
Duncan
Hi Aking Benitez very reminiscent of the Tesla switch thing that was the latest muse a few years ago. That there is substance to it I personally have little doubt. Still as with all things not fully understood the first faltering steps it seems all you get is a glimmer of the effect,
In the case of 'free energy' Its things which are not understood by most of us despite the fact its the very same most of us who have paid for the research, tptb of course muddy the water and hold that status quo  >:( .
These flash arrestors/spark gaps I guess you can view as pretty similar to a neon bulb in that they 'flash' at a certain voltage depending on the gas . In the case of neon 70 or 80 volts here's a few oscillators and other circuits using neon's for your interest
http://www.bristolwatch.com/ele/neon.htm
how long do they last ? In their comfort zone years and years I guess. Anyway I probably have quite a lot of what you seek Aking as I bought a box of Russian surplus some time ago
if you want to email or pm me an address your welcome to half a dozen.
Regarding Benitiez  I would respectfully suggest Aking that you have a long hard think about the system then compare common points with for instance the 3BGS as I recall we both wrestled with that. Whichever system your forced to conclude that at some stage one way or another more energy is being asked from a battery than it possibly has to offer , (be it from the ground or elsewhere) That being the case focus on the battery. Regard this webpage not particularly the Tesla switch ( which was the genesis for the 3BGS by the way) but rather the scalar battery charger .. I wouldn't bother building that circuit however it won't work like that but the idea's clear.
http://www.icehouse.net/john1/tesla.html
Some time later J L Naudin re-hashed the circuit of the 'scalar battery charger' so it would at least perform . The result can be seen here
http://jnaudin.free.fr/html/scalchrg.htm
keeping in mind Aking that the battery in question could be in the 3BGS, Benitez,Tesla switch, or  Clemente Figuera's machine the same thing is being asked of it ergo the same thing is probably being done to it .
I would suggest even the rabid measurists that breed in a swamp somewhere and then slither out and infest forums would have difficulty with motors turning and lamps lit, all with no measurable supply voltage as Naudin  shows ..wouldn't you?
Kind Regards Duncan
D. Erasmus
TinselKoala
QuoteI would suggest even the rabid measurists that breed in a swamp somewhere and then slither out and infest forums would have difficulty with motors turning and lamps lit, all with no measurable supply voltage as Naudin  shows ..wouldn't you?
Kind Regards Duncan
Preserved for the record. Your hypocrisy and insults are once again noted.
Duncan
 insulting who? hypocrisy about What exactly ? as for preserved I don't erase my posts so I would hope so  O0
D. Erasmus
Aking.21
I think Duncan is wazzed off about some naysayers.
Let us keep a civilized tone please:  life's too short...
Re Ne2s:  In my opinion they do not operate the same as a spark gap/ gas discharge tube.
A spark gap can create oscillations in the Mhz range whereas an ne2 can "short" across, and loose those oscillations.
Farmhand
TK if the voltage and the current were to remain at exactly 90 degrees out of phase with each other than wouldn't the input drop to zero + losses, the losses being real power would mean that the phase could not possibly remain at exactly 90 degrees wouldn't it ? If it did the input of real power would stop.
Theoretically it should be impossible for a real world system to operate with no real power input. The losses are the real power and so the phase must be not exactly 90 logically.
So in reality even if we see 90 degrees phase difference on the scope real power and energy are being consumed, as indicated by the input power measurements.
In my experiments I see always a changing phase even when it varies from less than 90 to more than 90 degrees.
The real power input when the circuit shows 90 degrees phase difference has be be explained or explainable.
