Magluvin 3D printers are pretty cool and I use FreeCAd and Repetier-Host for render-printing. I use mine to print PLA coil formers in some pretty complex geometries then pack the core center with a powdered metal/epoxy. I can print coil formers which are darn near impossible to produce any other way. Note the segmented form of the former below and I print off each half then glue them together then each whole form can be stacked in series if needed. Which begs the question why this exact form for a coil former. The segmented former dates back to the early 19th century and was used for HV Ruhmkorff Induction Coils. If you google "Induction coil" the picture most likely to be depicted is a Ruhmkorff Coil including the interrupter. https://en.wikipedia.org/wiki/Induction_coilThis was the precursor to many other variations including what many call a "Tesla Coil". As well many other inventors started noting anomalies with this setup which then spawned many of the most well known FE devices. Many would do well to go back and research the older technologies which were the basis for many of the devices we see today. These devices did not need electronics to produce the desired effects and in fact electronics become problematic when experimenting. P.S. I have the STL files however it would not let me upload them here. Good luck and good printing
« Last Edit: 2019-07-25, 09:15:47 by Allcanadian »
