2026-08-24, 00:02:34
Pages: 1 2 [3]
Author Topic: Zero Point Energy  (Read 12707 times)
This was found in my archives. Maybe it will be interesting. :)
This was found in my archives. Maybe it will be interesting. :) Casimir chemistry
In general, according to the article, it is necessary to carefully select the reaction conditions. The system must satisfy the boundary conditions of the reaction in a normal environment without using the Casimir effect, so that when using the Casimir effect, a small quantitative addition of energy in the nanocavities leads to a qualitative change in the chemical composition.
IV. APPLICATIONS
A. Casimir Catalysts
Catalysts form the backbone of the world’s chemical industry, contributing to the manufacture of roughly 90% of commercial chemical products. As enzymes, abzymes, and ribozymes, they render life possible. Hallmarks of traditional catalysts are the abilities to lower activation energies, modify
transition states and reaction rates, while not being consumed in the reactions. The Casimir systems considered thus far satisfy these criteria; however, they can also apparently change reaction energies and equilibrium constants, setting them apart in fundamental ways. For this discussion they
will be called Casimir catalysts. On a purely academic level, it might be argued that Casimir catalysts are not possible because they shift chemical equilibria, whereas it is normally understood that a catalytic shifting of equilibrium can lead to a violation of the second law of thermodynamics. This objection is not valid here because any exess in chemical energy resulting from a Casimir cycle e.g., Figs. 2 and 3 can be traced to net work
performed against Casimir force, not supplied by a heat bath; thus, the second law is not challenged
In order to avoid being banned by grandfathers with a pure academic level, we need to somehow get out of the difficulty that has arisen.  :)
When I first heard about the Casimir effect I remembered reading about some Russian inventor working with honeycomb type natural structures.
https://www.rexresearch.com/grebenn/grebenn.htm
It seems like quackery until we correlate this with the newest RF cavity massless propulsion claims.
https://newatlas.com/cannae-reactionless-drive-space-propulsion/33210/
Apparently the old has become new again.
It also seemed to relate to microwave cavities and some older VHF vacuum tubes. Stories of imploding televisions pulling the nails out of the walls in the room. Could some kind of bizarre cavity based self-resonance taken place?.
Ergo, it shouldn't take a rocket scientist to put two and two together and we have countless instances where strange things tend to happen in geometric structures with shaped cavities.
In 2021, interesting information appeared on the Internet, which added facts.
Let's start in order:
Viktor Grebennikov is generally an expert on insects, he did not really understand theoretical physics.
Grebennikov is an artist, writer, sculptor, popularizer, dreamer, but not a techie.
Serious scientific theories were put forward by his companion, professional physicist Valentin Zolotarev.
Together with Grebennikov, he wrote 2 scientific articles. I assume that Zolotarev included Grebennikov as a co-author only because it was necessary to popularize his theories. If you try to download and translate, there is very professional physics text, you should be prepared for this.
1. "Theory of field radiation of multicavity structures" 1988
Influence of De Broglie waves on the formation of elementary particles. Close to quantum physics.
the EPS field consists of displayed de Broglie standing waves, i.e. these waves are not emitted if there is no radiation from material particles.
https://greencapitalcity-narod-ru.translate.goog/unknown/Data/Anomal/Html/tech/eps_theory.html?_x_tr_sch=http&_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
2. "Fast processes in the environment of physical vacuum as a source of physical phenomena" 1988–1991
Quantum physics, structure of physical vacuum, quantum basis of gravity.
https://ru.djvu.online/file/LFwzw48MlQ2mT
Nothing more was known about Zolotarev until recently.
In 2021, the daughter of Valentin Zolotarev posted a biography of her father on the Internet, which lists numerous scientific articles.
https://habr-com.translate.goog/ru/post/566074/?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
Original:
https://habr.com/ru/post/566074/
Based on this, it became clear that Zolotarev worked at the main university of the USSR, engaged in nanotechnology in the 70s of the 20th century.
"F.V. Lukin State Research Institute of Physical Problems". At that time, this university was studying the possibility of using biological microstructures or creating synthetic analogues. Therefore, Zolotarev was probably attracted to the insect science that Grebennikov was studying.
Probably Zolotarev developed photomatrices for first special cameras. This is clear from reading the list of his works.
These photo matrices were very primitive. They were a line of 1000x1 photocells, only 1000 pixels. Nonsense by today's standards, when mobile phone cameras have tens and even hundreds of millions of pixels.
https://www-155la3-ru.translate.goog/k1200.htm?_x_tr_sch=http&_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=ru&_x_tr_pto=wapp
The pixel lines were probably installed on satellites that photographed the Earth's surface. Scanning was carried out by the satellite's movement in orbit, while the Earth's surface was constantly shifting. It wasn't only the USSR that created such things; the US also made, I think, even more advanced devices.
The elements of such a first matrix are probably relatively large, micrometers.
Of course, in those ancient times, they could not have technologies that allow the creation of structures measuring several nanometers, as now in processors from AMD or Intel.
But the vertical structure of the photocells layers could probably have been very small.
A list of works by Zolotarev, in which, it seems to me, he could observe the influence of De Broglie waves, Casimir forces and other quantum effects, and even anti-gravity effects:
33. Method for studying adhesion levels in photosensitive translucent films
49. Method for determining the parameters of sticking levels
56. Method for determining adhesion levels in translucent films
92. Parameters of sticking levels in amorphous selenium
127. Method for studying adhesion levels in photosensitive translucent films
Why can adhesion in microstructures be related to the Casimir effect? ​​- probably because Casimir discovered this effect when he was creating colloidal solutions to coat magnetic tapes at Phillips, where he worked at the time, and he was having trouble with it because of particle agglomeration. So he discovered the law of why this was impossible. Metal particles stuck together under the action of the Casimir force.
The numbering corresponds to the list in the article:
Conclusions:
- probably Grebennikov's anti-gravity structures had very, very small dimensions, nanometers.
- Larger structures Grebennikov demonstrated as a model, and as a way of influencing the biostructures of humans and insects, which, in his opinion, are very sensitive.
- could Zolotarev somehow secretly manufacture nanostructures at his place of work at the research institute? Some kind of hidden technology?
- could Grebennikov obtain such structures, in the range of nanometers and less, from natural materials?
I think that Grebennikov presented his fantasies as reality, and his friend Zolotarev dreamed that his theoretical works would be accepted sometime in the future.
« Last Edit: 2025-09-01, 15:05:07 by sergh »
Sergh
Conclusions:
It's debatable, I did extensive research on Viktor Schauberger and his work who was a humble Austrian naturalist and forester.
So how can a naturalist/forester become an expert in advanced energy and EM propulsion systems in the 1950's?. It's easy to understand and these people were studying and replicating how nature works first hand not simply following the often misguided opinions of other people. I found this to be true as well.
As Schauberger said, consider a simple tree. It can lift hundreds of gallons of water hundreds of feet per day. It is a syntropic, self-organizing, self-healing system which concentrates energy and material to grow larger and replicate itself from a seed. It makes all of mankind's technology look grossly amateur and primitive by comparison. Nobody is even remotely intelligent enough to build this kind of system such as a seed from scratch. So this notion that everything is known is comical verging on absolute delusion.
As well I think you may be mistaken about the work of Grebennikov. Nature always interacts on multiple levels simultaneously which confuses most people who can only think in singular terms. They can grasp a single cavity oscillating at one frequency but don't have the capacity to imagine hundreds of different cavities interacting through physical and electrical oscillations on multiple levels.
The answer to why so many people fail to understand these complex concepts and systems may relate to this phenomena...
https://dignotech.com/why-some-people-cant-picture-images-and-might-dream-in-words-instead/
Aphantasia is the term used to describe the inability to form mental images. Ergo, if you cannot imagine or form a mental image of these complex systems in your head the odds of failure increase by magnitudes. My research suggests the majority of the most brilliant people, like Einstein and Tesla, all had hyperphantasia. As Tesla claimed, he could constantly build something in his head in every detail and determine if it works or not. Einstein believed that "imagination is more important than knowledge," suggesting that while knowledge is limited, imagination allows for endless possibilities and creativity.
Ergo, if a person cannot imagine how nature and advanced technology works then it may be time to take up another hobby.
Well, I posted new exclusive real information about Grebennikov and his friend, physicist Zolotarev, I was accused of lack of imagination. Should I have fantasized? Would they have been happy then?  :D
Ok, let's fantasize, a little. If Zolotarev was developing primitive photo matrices for early military satellites, and then found an antigravity effect in such structures, then we could probably find the same or a stronger effect in modern photo matrices in cameras and, of course, ... mobile phones.  :)
 Weigh your mobile phones in different positions and camera states, on super-precise scales! Antigravity should be there, if Grebennikov or Zolotarev are not just dreamers!  ;)
Sergh
Well, I posted new exclusive real information about Grebennikov and his physicist friend Zolotarev, I was accused of lack of imagination. Should I have fantasized? Would they have been happy then?
No, I simply pointed out that-
1)Many brilliant people like Viktor Schauberger had no technical background or training. They learned from nature.
2)The majority of all the most brilliant men like Einstein and Tesla had a very active imagination.
Pages: 1 2 [3]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-24, 00:02:34
