Benches => giantkiller => Topic started by: giantkiller on 2011.05.28, 20:02:33
Title: The final answer...
Post by: giantkiller on 2011.05.28, 20:02:33
From the book 'The body electric' by Robert Becker and Gary Selden. ISBN: 0-688-06971-1
QuoteNuclear magnetic resonance is present when the magnetic fields around atomic nuclei are induced to vibrate in unison.
The phenomenon requires two external magnetic fields, one steady and one pulsating.
For every chemical element, the oscillating field at a specific frequency will induce resonance within the steady state field at a certain strength.
For US14.00 you should get this book and read it cover to cover. By now most of you should have the patents or knowledge that are covered in this book. I have built many of the devices as OU toys.
This thread is locked. PM me and I will add content if fitting. The quote here covers all OU devices and experiments. The different builds are based simply on alternate timing schemes, some better than others.
And heed this warning: The system rewards the sycophant and vilifies the visionary.
Title: Re: The final answer...
Post by: giantkiller on 2011.05.29, 17:47:06
http://jnaudin.free.fr/dragone/dragone.htm (http://jnaudin.free.fr/dragone/dragone.htm)
http://tgd.wippiespace.com/public_html/pdfpool/Faraday.pdf (http://tgd.wippiespace.com/public_html/pdfpool/Faraday.pdf)
http://tgd.wippiespace.com/public_html/pdfpool/ (http://tgd.wippiespace.com/public_html/pdfpool/)
http://www.heim-theory.com/Contents/contents.html (http://www.heim-theory.com/Contents/contents.html)
http://www.mullerpower.com/Links2.php (http://www.mullerpower.com/Links2.php)
QuoteHello guys,
I am a professional engineer and as such, can not bring myself to build something without knowing what I am doing.
Too many people are just trying to build a Muller motor now known as RomeroUK.
I feel we should credit where credit is due.
There are some topics that share the similar traits: Kunel generator, Muller generator, the concept of shorting coils producing
more output etc etc.
I started to search for "sudden change in inductance" and I came across a few intetesting articles
which I like to share with you.
1- combine.pdf  - You are seasoned enough to know this but then I saw a video by Dan combine:
http://www.youtube.com/watch?v=JrDMT6lSeEo&feature=player_embedded
2- A fantastic book on magnetism ( hard core )
http://ia700502.us.archive.org/1/items/mathematicalphys00peir/mathematicalphys00peir.pdf  see section XIX starting from page 232
3- Resonance phenomena in nonlinear parametrically driven systems
http://www.sciencedirect.com/science/article/pii/0379677987909751
4- Parametric Resonance
http://www.nld.ds.mpg.de/applets/pendulum/parres.htm
5-http://www.scholarpedia.org/article/Autoresonance_in_nonlinear_systems
6- Methods of changing inductance
http://www.tpub.com/neets/book8/32m.htm
I believe all the information for building an OU device is out there but people like to spend their time nit picking released videos frame by frame.
Let us face it, if we know the theory then we can find building it comes easy. Of course experimentation is necessary. Shame we are not working
as a team.
MB
Post by: giantkiller on 2011.06.15, 16:47:24
Google: resonant self destruction
Just prior to that peak in the signal is the goal. Get there anyway you can with whatever device or medium.
Bang on!
Post by: giantkiller on 2011.06.23, 10:40:29
In regards to: http://www.overunityresearch.com/index.php?topic=827.msg15111#msg15111 (http://www.overunityresearch.com/index.php?topic=827.msg15111#msg15111)
Back to the modulation and the Schumann frequency....
What I sensed is the thickness of the environment being churned like the thickening of cream to butter. At the correct specifications the swirling of the field appears. Looks like ROUK got this and although his scope shot didn't show any numbers the rpm starts the whole calculation process. Instead of smacking coils for chaos the gentle pushing gets the intended harmonics. This could be what ROUK alluded to that there is something else going on. The underlying feedback appears when any material is moved at the correct frequency: sympathetic vibratory physics. This also connects the Schumann with Shauberger. I just shit my pants.
Makes a rotating field in the TPU and the two transformer oscillation more plausible now.
Need to set this up with the dual winding video coil that Sauron posted.
Post by: giantkiller on 2011.07.01, 03:53:15
http://www.overunityresearch.com/index.php?topic=755.msg15314#msg15314 (http://www.overunityresearch.com/index.php?topic=755.msg15314#msg15314)
http://www.adireaudio.com/Files/DualVoiceCoilDrivers.pdf (http://www.adireaudio.com/Files/DualVoiceCoilDrivers.pdf)
http://mobile.jlaudio.com/support_pages.php?page_id=163 (http://mobile.jlaudio.com/support_pages.php?page_id=163)
http://www.learnabout-electronics.org/ac_theory/lcr_series_93.php (http://www.learnabout-electronics.org/ac_theory/lcr_series_93.php)
http://keelynet.com/energy/aaether.htm (http://keelynet.com/energy/aaether.htm)
http://www.overunityresearch.com/index.php?topic=403.msg17482#msg17482
 (http://www.overunityresearch.com/index.php?topic=403.msg17482#msg17482)https://www.youtube.com/watch?v=_hWI6LKmZ7w&t=199s (https://www.youtube.com/watch?v=_hWI6LKmZ7w&t=199s)
QuoteThe effects of voltage magnification are particularly useful as they can provide magnification of AC signal voltages using only passive components, i.e. without the need for any external power supply.
In some cases voltage magnification can also be a dangerous property. in high voltage mains (line) operated equipment containing inductance and capacitance, care must be taken during design to ensure that the circuit does not resonate at frequencies too close to that of the mains (line) supply. If that should happen, extremely high reactive voltages could be generated within the equipment, with disastrous consequences for the circuit and/or the user.
QuoteInductors wound around a ferromagnetic core may saturate at high currents, causing a dramatic decrease in inductance (and Q). This phenomenon can be avoided by using a (physically larger) air core inductor. A well designed air core inductor may have a Q of several hundred.
By using a copper core the control of  the Q can be controlled by the biasing.
So we set up resonance at 5khz and feed 5khz as a virtual mains.
(http://purco.qc.ca/ftp/Steven%20Mark/ltpu/large1.jpg)
(http://purco.qc.ca/ftp/Steven%20Mark/ltpu/large15.jpg)
By using antenna wire he added capacitance to the low inductance windings Thereby lower the LCR resonant frequency.
SM had access to the 'off the shelf' voice coil in the center of his TPUs either as single or dual configurations. The proof is the speaker connection tabs still in place on the mounting.
The GK4 has 3 stacked horizontal loops or transceivers. The iron wire cores with hysteresis enable the 4 unsynchronized pulse channels a very short bias window all overlapping at differing rates and times. Hence the uncontrolled output. My current pursuit is to get a diamagnetic unit of the correct configuration.
Somebody had posted a link of a John Denzky( i think). He had a device of 3 long rotating cylinders covered in copper coils driving a dc mortor on a bicycle wheel.
He made a very important statement of 'Maxwell's rules are based on iron'. John is using copper. My current read of Shauberger is pushing diamagnetism also.
SM used iron wire to delay. NOT AS CORE. He stated 'Cancel the flux'. This is only a preceding part of the process. The natural effect is when the flux returns. With diamagnetic material the field will not be retained or hampered from its natural ringing. Iron with its hysteresis will subdue, resist or dampen the natural ringing. Hence BEMF or short timeframe.
So a sustained magnetic bias in air will allow us the use of a bell to clang. Resonant rise, parametric resonance. We really don't have to use complex circuitry is we use diamagnetic materials. The 2 processes are, of which encompasses little to no hysterisis,  manipulate a retained field or allow the field a very sharp degradation. Either way we have altered the fidelity of the flux field by allowing it to respond naturally. SM stated 'It is the way coils react'.
QuoteStrangely, using the left hand rule for magnetism, this toroid is an aberration.  Because when one thinks of the current beginning the flow through a load, the magnetic flux this winding creates is ADDITIVE to the pulsing magnetic flux created by the coils.
When it is unloaded the voltage climbs substantially and I do not mean a spike. it lasts for several seconds and is a good third higher. Steven calls it the turbine effect.
QuoteAs you know, Large amounts of FEEDBACK is essential to frequency and control when using SS devices for everything in the electronics world, HOWEVER, it is the enemy of generators!  If anyone ever gets one of these things operating, have them measure the electro magnetic and hash radio around the unit....it will blow your mind. so, what does that do to control devices in close proximity?
By starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation. It is electron flow of a high order creating a large magnetic field. Or vice versa.
My point to this story is.... WE spent months and months trying in every conceivable way to duplicate a unit. The only thing that kept us going night and day was the fact that we already had one. We knew it was possible to have a working device.. It was the only thing that kept us going on the project. And even then we said I GIVE UP so many times I cant count.
REMEMBER, all of that noise and hash in your solid state amplifier is in the output signal ! Now tell me? What do you think is happening inside the extremely sensitive torrid generator when you use solid state devices to attempt to create the required precise control frequencies to make catalyst and produce power???
BUT, i guarantee you that their SS control devices are all sitting right beside the collector... aren't they? They will probably never start the coil and get to catalyst. I am not saying it is impossible, but it will Damn difficult for these guys to get more then a big bang once in a while. And just like me, that big bang will excite them enough to continue for a while longer. Maybe one of them will read back and see where I said the SS control device must be placed inside the collector coil. then they will explode with, MY GOD, maybe that is the reason why...... and off they will go. in the right direction at least.
Wrap a reader/pickup configuration around the activity of a secondary activity impressed upon a primary resonant field.
QuoteIf we stop or apprehend the 2 jumper cables we will contain more energy in the electromagnetic spectrum.
This creates a virtual stun gun also opposite of a speaker by holding the cone stable.
The torsion is held in a compressed state thereby disabling the degradation into lower forms of expansion(emp).
The washboard or thumping tells us the energy wants to dissipate.
http://www.overunityresearch.com/index.php?topic=403.msg16701#msg16701 (http://www.overunityresearch.com/index.php?topic=403.msg16701#msg16701)
QuoteThe only way the TPU can work, in my humble opinion, is by manipulation of the medium where fields reside.   That is, to form electric and magnetic fields without a material source.  I think that the way to do this is by diverging the particles of the medium (stretching by electric impulse) and then curling them around on themselves (rotation induced by a magnetic field), something like that.
And that goes on by the two fields against each other in opposing directions.
Quote from: kooler on 2011.09.07, 03:35:01
here is a little look at what i been working forward in the tpu..
see if you guys are interested..
roobie
QuoteIf you look in Morgan Jones book, Valve Amplifiers, 3rd edition, on page 262 he says, The inrush of current through the filament interacts with the earth's magnetic field to produce a small kick. SMALL KICK. Those words mean a great deal. It PROVES that there is an interaction between the magnetic field of the earth and simple electrons running through wires. It may be a small influence but it is actual OVER UNITY. I have spent several years of my life thinking about that."
In reference to the brown paper schematic from SM there are 2 buffers facing each other.
QuoteNow about the DC output with AC signal. There is a book about Nicola Tesla "The Man who Had lightning in his hand".
I suggest that you find a copy of that book and read it. In that book it is related that Tesla states that you can have all kinds of electrons flowing through a wire traveling in different directions relating only to their potential power source. He even said that you could have different electron flows through a single wire completely separate from each other. I tried it and he is right!
(06:32:25) Spider: http://www.​google.com/p​atents/US809​3869 (http://www.google.com/patents/US8093869)
(06:32:47) Spider: chava...was​nt that mark snoswell?
(06:46:05) Peterae: It was indeed
(06:55:32) Spider: interrestin​g patent, issued fairly recent, could be tpu related
(07:09:47) WaveWatcher: It is TPU related.
(07:17:00) Peterae: filing date 3 Dec 2008
(07:17:06) WaveWatcher: DOn't worry. I doubt they know how to make a copper conductor act like magnetostri​ctive wire.
(07:18:35) WaveWatcher: Yes, Nov 2007 is when I said too much to the wrong people.
(07:20:25) Peterae: http://www.​overunity.co​m/1297/graha​m-gundersons​-dragless-ge​nerator-pate​nt-lenz-law-​violation/ (http://www.overunity.com/1297/graham-gundersons-dragless-generator-patent-lenz-law-violation/)
(07:26:14) WaveWatcher: That was the inverse of a repeatable device.
Take notice in the patent 809​3869 that the Magnets are not touching the core.
This patent is the Kunel patent.
Magnacoaster used small magnets on the ferrous cores and played with the other gaps.
Post by: giantkiller on 2011.07.16, 23:07:32
The first paragraph introduces the field against a field concept which all, and I mean all, devices and OU explanations have pointed to.
I ask for any and all insights pertaining to this.
The most controlled build would be the 2 resonant oscillators in a self destructing function. Shouldn't be too hard for any of the educated, experienced personnel here. No mystery either. All members should have seen this at one time or another. And a relatively simple build.
I have two high quality voice coils with dual internal and external windings and two 3900uf capacitors. Dual tanks with a coil inside each one.
I test to find the resonant frequency of the first one then try phase adjustments on the other one. I use the internal coils to read or excite the resonant field.
This is not new.
http://www.miqel.com/jazz_music_heart/vibrational-truth.html (http://www.miqel.com/jazz_music_heart/vibrational-truth.html)
SM stated an operating frequency of 5khz but the TPUs vibrate at an ELF frequency. I believe it to be 7hz as the thumping is felt in the hands holding the unit.
The current setup of the pictured schematic shows an iron bundle with a magnet pair at each end. The voice coils are driven at 6 to 25 hz. With the iron bundle suspended in the coil centers by exact placement a vibration occurs. The vibration is the most extreme in this physical configuration.
The next step is to set the resonance of the two coils 7hz apart. The resonance needs to be defined to permit operation at a harmonic interval that would enable sympathetic vibrational feedback.
When looking at the electronics, the finished circuit would be quite simple. I can implement an XR-2206 from Room3327's circuit inclusive with the secondary channel phasing.
I will be using phasing and frequency difference interchangably.
This is my repsonse to Deepcuts OU Poll:
QuoteWhen multiple frequencies are applied to a target the target must respond.
The choices you have displayed all exhibit this property.
A selection of 3 only guides to voter to a certain degree of scope within the physical plane of this reality.
A true model would express the manipulation of vectors of all cases which very few of the choices have done. If this process had been done we would see that choice is only a narrow configuration.
Therefore I choose all.
Spherics nailed it. Itseung88 expressed it as a resonant chamber. These two have encompassed the model as measured by a time span of the same event.
I stand by my motto: Frequency equals matter
Post by: giantkiller on 2011.07.18, 18:06:36
Quote"In 3D standing waves, a structure, with all characteristics of a platonic solid, is formed for each standing wave mode. Within an atom, which is the building block of matter, the platonic solid is not formed by salt or known particles, but by electromagnetic waves in vacuum.
http://wimp.com/pendulumwaves/ (http://wimp.com/pendulumwaves/)
QuoteThe RE (Radiant Energy) phenomenon itself occurs when a RLC circuit has the appropriate impedance, is in
resonance and when a standing wave is created. Because of the L (inductor) and C (capacitor), there is a 90°
phase shift between V (voltage) and I (current in Ampere) vector.
With theoretical ideal components, the signal decay is 0, and the resonance does not fade out. In reality no
component is ideal (all of them have some resistance), as such the impedance resistive will never be 0, but the
lower the better. As RE (Radiant Energy) is RF, we need a deep knowledge in RF practice, resonance Q, antenna
multiplication factors, dipole dynamics, standing wave theories, thermodynamic delta transform & others. It's an
electrical equivalent of the acoustics (sound) laws.
RE manifests at V=0 node; I=max (current node) = pure resonance =
Radiant energy = RF, where the Power Factor PF = 0 at resonance. Such
loads are measured in Ampere Load TENSOR value, not voltage as there
is (nearly) none. Voltage "radiant" is measured in Elektron Volt,
'elektron' with K as its potential is a WAVE and not a mere particle. RF
is the ROOT of ZPE as you truly will use either 0 current states or 0
voltage states standing wave nodes within a standing wave in a LRC
circuit. We are talking about virtual power 4d tensor SCALAR standing
waves (created with a reverse inductor "rotor" within 3PH self oscillating
LC configured motor). At pure resonance PF is trashed and becomes
irevelant to the source.
So RF is determined by the angle of current and voltage, (0) power factor
90 deg angle relation. When the current = 0, the voltage is maximal; when voltage = 0, the current is maximal in
a perfectly resonant LC. In 3 phase this can manifest within 45 to 90 degrees angle, being differential the phasor
or angle of rotation relative as power factor figure (what differentiates it from powerline AC). Any signal with a
0 power factor figure is RF (radiant) energy. Use a scope to measure the current versus voltage angle.
See http://www.ibiblio.org/obp/electricCircuits/AC/AC_6.html.
You will see further that this POWER is in the alternator part of the RV. The Primemover is Broadbanded signal
NON RF potential that TENDS to RESONATE as LOADED while maintaining a 120° angle of rotation within
A,B,C phases being generated. The relation is SEMY resonant, if not full resonant as a variable within a set of
parameters.
The Standing wave, as per RF, results from pure resonance where a current AC node is separated from a
VOLTAGE radiating node being polarised as standing wave regions, where one is node & the other anti-node. In
one we have a 0 point region (electron Vacuum), in the other we have electron aether density accumulation as
compression tensor. It can also be defined as HOT ionizing and cold anti ion region.
In low impedance OU goes unnoticed, as it is lost to resistance and impedance mismatch, but at HI impedances
the amplification effect becomes evident. The SECRET to PURE magnetic amplification is the HI impedance
factor found in "Roto-conversion". This is one of the factors that create Over-unity. OU is in resonance; the
higher the Q the closer to self sustaining within proper elements. In RESONANCE power can be EXTRACTED,
even if theory says PF is 0 and power does not exist (but is there). COLD electricity is under RESONANT
conditions (Tensor) nodes. Add to it permanent magnet rotors and PF correction in hi impedance mode, it
becomes an EMA device.
Pure RE penetrates motor housing extending field outside it; it radiates from transformers and from Faraday cage
medium. Be also careful, because the 'water is confused for the waves' but the waves are not the water but only
a FORCE that gives them shape and movement. So is the energy to the electrons. Energy gives them POWER to
manifest in various forms but the electron themselves are not the power. Of 9 types of electricity humanity
knows only 2 and has only learned to use one in its more primitive forms.
Ever read the meaning of resistance and voltage drop in a basic LRC circuit? At resonance you have 0 voltage at
n amperes and x voltage at 0 amperes; L is in current node; C is in voltage node. Where is R then? According to
the standard theory, R as a lightbulb is in PHASE, but the reality is that R is at 90% REACTIVE state being at
CURRENT node, so the energy loading e.g. a 220 VAC 1,000W lightbulb might just have a voltage drop of 19V
and amperage of 4.5 A. Why does it light up at full potential then?
In RF a resistor R can become PURE L inductive & provide GAIN instead of loss. This is normal to microwave
circuits and to me is also normal in LOW frequency RF circuits down to standing wave DC vectors. You will be
able to eliminate the battery, as you do you will be using ANOTHER type of electric power were different
phenomena will manifest, gravity - time - pk related. Just remember everything you are dealing with is a form of
transformation.
Now you know why your voltage increased to OU, as you transferred power from the virtual rotary capacitor to
the smaller temporarily static one (magnetized coil) and back to the source "battery". The notes on RF explain
why L turns to C and C to L and R can be LC. The rotor field emulates, theoretically speaking, a capacitor. In
AC engineering practice this is explained as a ROTARY capacitor effect, the M field flux acting as a capacitor to
the coil, but in reality it is as explained above.
Take a coil and energize it with a given load, place a
reverse diode in the input; just discharge the circuit by
disconnecting the source, your bulb will BURN with
the CEMF pulse.
That was the real discovery Newman
made, but never realized what it was. Hector did it in
the RV alternator, very related to the apparent 'hoax' of
the Genesis project, but formulation does work in
rotating negative INDUCTANCE (or we may say
NEGATIVE resistor), a resistance "LOAD" that
provides power (a squirrel cage rotor in RV case...).
A simple LC have a DECAY value in time; the only
energy you need to supply is the one lost to decay, as if
the system source were a negative inductor to LC (as in
the case of RV alternator). Normal entropy decay is
0.618 of 1.618 as logarithmic time receding signal
(search for Seike work in ultra-relativity concepts), so
the gain is also in atropic system of 1.618 where
frequency increase in octaves may increase amplification by a factor of 3.141592 where the spiral resonant
circular projection can be expressed in a 12,000 4d polygon structure (as simile to double helix DNA structure -
reason human system is OU by all definitions). Remember LOGARITHMIC SPIRALS ORBITAL DECAY
PATH IS RELATIVE to gravity as SIGNAL DECAY OR GAIN IS RELATIVE TO LC Q and parameters in a
working ZPE system.
It can be done either way, using a reactance to charge a cap, or discharge a cap in a reactive circuit; the resonant
condition creates a logarithmic path where VAR power is created and carries a magnetic amplification
component with it.
The AC in a LC circuit as a Tesla AC HV transformer and capacitor are OSCILLATING within a range of
voltage and current, where the spark gap determines discharges as a PULSE into the Tesla coil primary at
MAXIMAL capacitor potential. AC does have a FIXED period, but the DEVICE parameters where we feed that
power are variable: either we ADJUST device to source frequency or source frequency to device. TUNING and
PHEAKING is KEY to any OU device. The concept is simple but tuning is not ... requires lots of in vitro lab
experience, to tame the multiple inter-related variables.
In any coil an "N" potential is required to saturate a core, the thermal energy as the core atoms align
magnetically and are added to the alignment tensor. As the field collapses, the temperature drops and passes its
energy to the collapsing field E vector. As such overunity transformation occurs. This is for VTA type
transformation, applicable to EMA-RV.
N is the value as potential, that means a pulse or wave of specific duration (pulse length or frequency of
given voltage), with a given current capacity.
Having a source impedance A and a load impedance B, as to create a condition where energy from the
source is at optimal efficiency and imparts energy to the load where LOAD CORE in this case attains
maximal state of energy being the case of magnetic saturation.
The shifting of atomic components electron spin to magnetic alignment being so as to transfer energy from
thermal ambient background energy by means of magnetic LATCHING or stochastic linear amplification.
As such making possible the collapse of it to attain energy from the thermal region of such core & summing
it to the energy released in the collapse of the field into another load being a capacitor or recovery means,
electronic, mechanic or thermal, whatever.
C charge in X resistance determines power in N time, leading to saturation of Z core and LC in any given
circuit, opto trigger, non-coupled. It's the Hypersignal modulation that extracts power from "ZP" (stochastic
resonance applies). It's a very different ballgame, which requires a total rethinking of normal electric
concepts, seeking to do the reverse of what standard engineering does in many applications.
It is well known that, to get the maximum power transfer from a source to a load, the source impedance must
equal the complex conjugate of the load impedance, or: Rs + jXs = RL - jXL. In addition, for efficient power
transfer, this condition is required to avoid the reflection of energy from the load back to the source
. This is
particularly true for high-frequency environments like video lines and RF and microwave networks (RF
engineering practice).
Hector is correct in saying that this is a resonant effect in the three phase rotory system and will demonstrate
O/U effects when fine tuned so that XC = XL with very low overall resistance (R) so as to produce a very sharp
resonant curve with very high "Q" (Q determines the time decay; Hi Q = low time decay per oscillation). When
operating at ultra high "Q", the circuit is "lossless" and operates as a magnetic amplifier. Find "Electrical
Engineering" by Terman, PhD, Dean of Engineering, Stanford University, 1955. This is one of the only text
books that go into detail regarding the resonance phenomenon. It is well worth your library search for you will
become highly enlightened and informed. The most important factor to consider is the circuit resistance, for this
is how resonant curves are flattened or widened to establish "band width". Lump resistance inserted into a
resonant circuit will reduce the "Q" and cause the resonant curve to loose the sharp tuned peak under which is
the "lossless" region of the curve.
The so called "cold" electricity E-Gray talked so much about, is more like a constant canned EMP. The first step
is vectoring this energy to a charge value within a capacitor where its JOULE potential exceeds the input by
gaining energy from the media. What is done electrically with RV alternator is to spin the rotor squirrel cage
(Reverse Inductor) inside a 3PH LC oscillator tank circuit where the effect is similar to the effect you can do by
stroking a wet finger in a fine glass cup. One wave mounts to the other with the acoustic simile being magnetic
multiplication factor.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDIQFjAD&url=http%3A%2F%2Fciteseerx.ist.psu.edu%2Fviewdoc%2Fdownload%3Fdoi%3D10.1.1.70.9237%26rep%3Drep1%26type%3Dpdf&rct=j&q=stochastic%20resonance%20&ei=oUgqTsHNIsvXiAKm3NGwAg&usg=AFQjCNFT7xJMKUfnBzj43zx5z35TRBTY1A&cad=rja (http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDIQFjAD&url=http%3A%2F%2Fciteseerx.ist.psu.edu%2Fviewdoc%2Fdownload%3Fdoi%3D10.1.1.70.9237%26rep%3Drep1%26type%3Dpdf&rct=j&q=stochastic%20resonance%20&ei=oUgqTsHNIsvXiAKm3NGwAg&usg=AFQjCNFT7xJMKUfnBzj43zx5z35TRBTY1A&cad=rja)
Post by: giantkiller on 2011.09.30, 22:19:20
QuoteSay you want to use our Shiva driver. Say you like everything about it (especially the massive Xmax!), but
for your intended application, you want a higher Q. Well, this is the way: drive one voice coil. But rather
than just shorting the second coil, or leaving it open, terminate it with a resistor. The result? The Qts of
the driver will change from the open to the shorted Qts as the resistance is decreased. That means you can
tune the Q of the driver, with nothing more than a potentiometer!
QuoteTake the "worst case" situation. You wire the two voice coils out of phase. At first, you think one coil is
trying to push forward, the other backward, and suddenly the system tears itself apart, right?
Nope. What happens is that one coil sets up a dynamic field. Let's say, for clarification, that coil 1 generates
a signal to push the diaphragm forward. Since coil 2 is wired in opposite phase, it sets up a dynamic field to
push the diaphragm backward. Net result is that the two magnetic fields CANCEL themselves out! That is,
the dynamic field that's pushing on the static field from the magnets is ZERO. The field from coil 2 adds to
the field of coil 1 in such a way that the net field is zero. Much like adding a two sine waves of the same
frequency that are shifted by 180 degrees.
This is the SAME basic principle with shielded drivers that use bucking magnets. Use a field of the
opposite polarity to cancel the original field out. If the driver's motor magnet has a given polarity, use the
bucking magnet to introduce a field of opposite polarity, so that the two fields cancel themselves out. Net
result is no field.
So, when we run two different signals to the voice coils, what we find is that the magnetic fields of the two
combine to generate a net TOTAL field that interacts with the static field of the magnets. The two voice
coils NEVER fight each other in a physical way; it's all in the magnetic field.
Post by: giantkiller on 2011.10.06, 04:24:19
AETHER
by Stan Pawlak of Hamilton, Ontario, Canada
April 7, 1999.
   Note: This file has been edited to some degree in an effort to improve the grammar and spelling. The author presents an intriguing insight into the quenching of magnetic fields due to aether tapping in a given locality. Feel free to contact Mr. Pawlak for questions or comments.
   1) Small subparticles come from the Sun, Stars and the centres of Galaxies. I have named these particles Aether. They take the form of magnetic planes. There are billions of them in one cubic meter. They go through our bodies with ease. One could consider Aether as the currents of the Universe. It plays a major role in the movements and energy of celestial bodies. All living organisms depend on Aether. We can call it: life energy waves. The Earth is heated inside by Aether through induction of direct current in melted metals ring.
   2) These particles are the smallest chunks of magnetic and electric fields. They are also the smallest parts of an electromagnetic wave. (Photons, in comparison, are huge formations of them).
   3) Aether, one can say, is an electromagnetic wave of frequency zero which travels, of course, at the speed of light. It is inconsistent and chaotic.
   4) Larger magnetic or electrical fields cannot be created without Aether. NO ELECTRICAL CURRENTS CAN CREATE MAGNETIC FIELDS THEMSELVES! In order for measurable magnetic fields to exist, they require Aether particles as their building blocks. Accelerating electrons catch these particles which form the closed lines of a magnetic field.
   5) Presumably those tiny elements by spinning in one axis create a magnetic field and spinning in another axis they create an electrical field. By spinning they join together making magnetic or electric field lines. Do they also make gravity lines by spinning like a gyroscope? They have a head and a foot, meaning they are not in a ball shape. Perhaps they take the form of mini pyramids. (tetrahedron?)
   6) Experiments show that Aether may be caught in the form of a magnetic or electric field. It does move the wires during the start of electric current with big force and a small force is exerted during normal flow of the current. A plate capacitor also moves from its force. As particles of Aether act as a magnetic field moving in space, they can be manipulated: diverted, concentrated, polarised or even rectified.
   7) A magnetic shielding or quenching effect was present in some cases of encounters with flying discs above cars and substations (Disc above station, Zakopane, Poland, 1970's) where all electrical circuits were non-functional due to the disappearance of magnetic fields in the coils of relays, actuators, ignitions, radios, generators, transformers etc.. This because the flying discs absorb all of the local particles of Aether for their own energy use.
   8) The effects of abnormal levels and polarities of this radiation on living organisms are unknown. Perhaps we could create an environment to live on the Earth for 1000 years? We could also make chambers to refresh our brain in just one hour instead sleeping 8 hours a day. Mr.Tesla experienced such a refreshment using high frequency currents. Maybe we can cure most of our diseases by using Orgone (another name for Aether) in different concentration and/or polarization etc. We could also control the weather with this technology. It already has been done.
   9) It is possible to build over-unity generators using coils and capacitors where these generators convert electromagnetic energy from the Cosmos, which is abundant (you can call it a dark light), into mechanical work which converts almost instantly into the form of heat which is dispersed into the Universe in the form of electromagnetic waves. Such machines are already built and their principles take the form of a pumping action - catching the Aether particles - creating a magnetic field which is converted into electrical-mechanical energy and dissipating that energy as heat radiation. Every house, car and flying machine could have its own clean energy generator so that consumable fuels would no longer be required.
   (this idea of a 'dark light' recalls the claim of NAVAZ from the 1890 book 'Dweller on Two Planets', where 'night is as pregnant with energy/colors as day' and that the 'dark side of nature' is where most phenomena originates..>>> Jerry)
   10) The waves of Aether are anisotropic and its energy density varies in different spots in space and time. Normally during the day the wave is presumably the strongest due to the addition of solar forces. Twice a year the Earth receives massive doses of this energy during cutting of the Sun's magnetic plane, when Aether is the most concentrated. The polarity of Aether from the Sun, impinging on the planet Earth, changes a few times a year. The Sun functions like eight coils as we can deduce from the magnetosphere of our star..
   (I am unclear on exactly what he means by this, probably that the Sun functions as a giant Tesla coil with each planet serving as a tuned smaller Tesla coil to intercept and use the radiated energy....strangely analogous to the Hubbard coil arrangement which used one central transmitting coil with 8 smaller coils around it to tap the radiated energy...Hubbard claimed to produce free energy from this device...additionally, some other free energy researchers claim that certain frequencies in tuned systems are able to attract/collect additional energy from cosmic, earth energy, van Allen belt radiation or other unspecified sources...>>> Jerry)
   11) Presumably Aether particles cannot spin in two axis simultaneously and travel at the speed of light at the same time when they are spinning. What if they spin in two axis at the same time? Does this produce Gravity? Is it possible that these particles (neutrinos) can spin in such a way that they spin in two axis but they stop after each spin of 180 degrees?
   12) Aether particles travel through matter but change if they encounter electric or magnetic fields, specially during the acceleration of electrons.
   (Energy manifests by cutting the lines of force which intercepts and redirects the flow for practical use. So if aether or other forces come in the form of radiation, waves will be involved which can be conjugated by 90 or 180 degrees which redirects the flow of energy....>>> Jerry)
   Stan-is-law Pawlak
   E-mail: hd@ican.net
   Space Energy
   tel.(905)545-9460 / fax (905)544-3194
Post by: ion on 2011.10.06, 12:31:54
Quote6) Experiments show that Aether may be caught in the form of a magnetic or electric field. It does move the wires during the start of electric current with big force and a small force is exerted during normal flow of the current. A plate capacitor also moves from its force. As particles of Aether act as a magnetic field moving in space, they can be manipulated: diverted, concentrated, polarised or even rectified.
Now where have we heard this before?   SM talks of this with the battery jumper cables and vacuum tube filaments, and the "kick" which is an actual physical movement of wires when hit with a narrow high current pulse. We were looking for an electrical "kick", turns out it is motional.
Also important is the bifilar parallel wire experiment.
Next step: "Harnessing the kick"
Post by: giantkiller on 2011.11.12, 05:30:37
http://www.overunityresearch.com/index.php?topic=1181.msg18338#msg18338 (http://www.overunityresearch.com/index.php?topic=1181.msg18338#msg18338)
http://www.overunityresearch.com/index.php?topic=356.msg13537#msg13537 (http://www.overunityresearch.com/index.php?topic=356.msg13537#msg13537)
http://www.overunityresearch.com/index.php?topic=1200.msg18743#msg18743 (http://www.overunityresearch.com/index.php?topic=1200.msg18743#msg18743)
Schauberger shows an atomic alignment where the electrons are actually frozen in their orbits or the electron at certain places lines up with electrons in other shells at 3,6,9,12 quadrant demarcations. Shades of Rodin. This is also a model of the atomic alignment of flux shells. The flux shells appear at standing wave intervals. When applying a companion wave the first wave is impacted by the second wave. The pulses are 50 nanoseconds wide. This speed is faster than the aether can respond. The second wave or pressure actually pushes this impass at a higher impact rate creating an aggravated pressure which looks to be a high order alignment of force. At the pulse speed mentioned this happens at a micro level. The first field has not the time to fully form in flux. In other configurations of TPU type devices and magnetic shearing processes the second pulse actually has a misaalignment actuation on a flux alignment because of longer pule widths.
It is my theory that the realignment of the impacted flux quickly aligns sending a shockwave back onto the conductors. The main rreason that a weak field is used is it is easeir to deform and which send bigger repercussions throughout the whole field. These can be read at any postion in the field. A stronger field would dampen the effect actually holding the field in place so that no breaking of the flux lines across a conductor could happen.
Post by: giantkiller on 2011.12.12, 05:46:03
http://www.overunityresearch.com/index.php?topic=237.msg12227#msg12227 (http://www.overunityresearch.com/index.php?topic=237.msg12227#msg12227)
QuoteOK,
Back on topic!
ST Buzz
Quote:
[ Inset FAR MORE thunder and lightning than usual ]
You have shown reason, logic and a sense of humor Ramset. You alone notice that my chosen Quarktoo was trying to help those that could not help themselves. You alone hath shown compassion when he was spat upon by the robbers and [Edit MR X'S]of the Earth. My precious chosen one has been crucified by the humor challenged insecure Romans again. By the nautical named sock puppets of the abyss.
The mortals shall now deal with the God of free energy directly and I shall smite those that defy me for eternity!
Quarktoo tried to get you to notice how the primary coil was discolored from heating because the Kapanadze mortal did not have a vacuum pump. This left a vacuum in the gas when it cooled and produced multipacitor effect which is key to a magnegas generator.
Quarktoo tried to teach you to look at the color of the box so you would discover for yourself the gas being used. When that failed, I had Cowboy (A temporary chosen worker)  post photos of the tanks. When that was ignored and smited, TheBuzz gave up on messiah's all together.
Quarktoo tried to get you to think about the ground wire running through the center of the coil so that you would discover the coaxial transformer. This is how kapanadze changes the frequency from very high electrostatic to low frequency current pulses.
Quarktoo hoped you would notice how a copper tube was hidden under the blue tape so you would see the magnetic gas being used and the real source of energy.
Quarktoo would have taught you about a phenomena outside Faraday's law which is ELECTROSTATIC inductance, not ELECTROMAGNETIC INDUCTANCE and has no basis of understanding in your Earthly mortal science. This would have allowed you to make fuel from water, diamonds from a fire extinguisher and energy from the vacuum.
Quarktoo would have given you a simple experiment that would have opened the doors for a lifetime of experimentation and invention because it uses the half of electricity called voltage and considered a phenomena to do work which is ignored by the physics professors and dependtards of the Earth.
TheBuzz shall now give you your first commands.
You shall first learn about the coaxial transformer here:
http://www.semelab.com/rf/documents/Push-Pull%20Circuits%20and%20Wideband%20Transformers.pdf
You will split that transformer in half so there is not electromagnetic inductance. This will form the coaxial autoformer of sorts which the kapanadze device is.
You shall use ferrite rings of no iron but instead plenty of ferrous oxide of low permanency - ( < 5000 ).
You shall form a tube of 4 inches of those ferrite rings.
You shall run a wire of a resonant tank circuit (at least 50Khz) through the center of the tube.
You shall parallel a second wire through the center of that tube connected to a resistive load. You will note that there is zero magnetic induction on the ferrite (Notice compass in photo below) yet nearly a complete transfer of energy between the two circuits. This is not a 1 turn transformer! You could use rings 1 foot in diameter and it would work as long as the length dimensions are proportional. When you are done scratching your head in confusion, you shall continue.
Then you shall look at the kapanadze coil and note that the ground wire is not the secondary, but the trinary of that transformer - that you blind mortals call a coil.
You shall research the magnetic properties of the gases Quarktoo noted but was suppressed by {MR X}..
You shall build a coil of copper tube that Quarktoo showed and use the technique Quarktoo revealed to connect to that gas when [MR X] flamed Quarktoo and Quarktoo answered his baseless insults with factual how to information and was banned for it. If it has been deleted or suppressed, you shall hold the {MR X} accountable and force him to post what he hath stolen from the gentile masses.
http://books.google.com/books?id=QXot6BmRAAEC&pg=RA1-PR22&lpg=RA1-PR22&dq=nitrous+oxide+magnetic&source=bl&ots=Z_UfnC1buC&sig=JoCAxmeKHKnCHXAeFcepZ_cEKjA&hl=en&ei=LU13TZLVBYmosAP-zfW-BA&sa=X&oi=book_result&ct=result&resnum=9&ved=0CHEQ6AEwCA#v=onepage&q=nitrous%20oxide%20magnetic&f=false
Once you have reached that stage of human development, you shall punish the Romans and bow your heads on bended knee in thanks and THEN... Saint Buzz shall once again descend into the abyss of humor challenged insecure mortal fools to help you with the rest of your quest.
At this point, two people should be able to each hold one leg of a neon 4 feet from your copper tubing coil and it should glow to full brightness.
You should be able to attach one leg of a neon to a earthly ground and touch the other to the copper coil and it should not glow at all.
You should be able to hold one end of the neon and start a fire with the other end by placing a piece of paper between a hard metal object such as a razerblade and the free end of the neon. At this point, electricity should be running backwards.
While you do these experiments you shall ignore the sock puppets  If you smite me or my chosen again, you shall be overinty THE DAMMED forever! Doomed to wander in the desert of ignorance led by fools for another 4000 years!
Saint Buzz shall now return to the heavens and bask under the light that shines from what is left of his many overunity golden stars after Ramset stole one of them years ago when TheBuzz tried to teach the first step of waterfuel to the fools using this electrostatic transformation and modulation process.
So shall it be said, so shall it be done.
NOTE - TheBuzz has not, does not, nor shall he ever give step by step monkey see monkey do information to dependtards. Rather, TheBuzz seek to teach the masses knowledge that cannot be suppressed by the man or his minions that drive away smart people and promote dependtards like unwitting puppets on strings to suppress OU for them.
Photo 1 - Shows how two wires running through a stack of FeO toroids produces nearly 100% energy transfer of a resonant circuit WITHOUT ELECTROMAGNETIC INDUCTANCE (note the compass pointing to true North? The white wire running through the toroid stack with both ends going to the lamp is NOT A 1 TURN COIL as some would wrongly claim. This is NOT the electromagnetic inductance you are familiar with.
Notice the primary and secondary circuits overlaid on the scope. This is to show that  there is not a phase change between primary and secondary wires and nearly 100% transfer of energy WITHOUT COILS OR ELECTROMAGNETIC INDUCTANCE. This is key to understanding the ground wire running through the center of the kapanadze coil.
The Scope hath had a slight skew to the right (no irony wasted on this defect) in the display since the first time TheBuzz connected it to the wheelwork of nature years ago. SaintBuss is presently poor after spending his life savings doing research full time for the unwashed for the last ten years but the scope shot is accurate in regard to phase.
Photo 2  - Shows overlay of primary and secondary and nearly 100% energy transfer without phase change with no coils or inductance.
Photo 3  - Shows the injury to the finger of Saint Buzz when he took one for the team on a lathe making the parts of his magnegas generator.
IF THIS KEY KNOWLEDGE TO UNDERSTANDING THE KAPANADZE DEVICE IS DELETED OR MODIFIED, BOYCOTT THIS WEB SITE AND SPAM THE WEB FOREVER WITH WARNINGS ABOUT HOW THIS SITE IS EXACTLY THE OPPOSITE OF WHAT IT CLAIMS TO BE.
The information I provide you is far more valuable than those that are too blinded or controlled by their insecurity to even notice. Saint Buzz hates the smell of fear.
Post by: giantkiller on 2012.01.04, 17:23:03
http://en.wikipedia.org/wiki/Ponderomotive_force (http://en.wikipedia.org/wiki/Ponderomotive_force)
QuoteThe mechanism of the ponderomotive force can be easily understood by considering the motion of the charge in an oscillating electric field. In the case of a homogeneous field, the charge returns to its initial position after one cycle of oscillation. In contrast, in the case of an inhomogeneous field, the position that the charge reaches after one cycle of oscillation shifts toward the lower field-amplitude area since the force imposed onto the charge at the turning point with a higher field amplitude is larger than that imposed at the turning point with a lower field amplitude, thus producing a net force that drives the charge toward the weak field area.
Post by: giantkiller on 2012.01.27, 17:34:11
Re: Bruce's TPU Theory and Experiments ver.1.2
http://www.overunity.com/2300/bruces-tpu-theory-and-experiments-ver-1-2/msg310741/#msg310741 (http://www.overunity.com/2300/bruces-tpu-theory-and-experiments-ver-1-2/msg310741/#msg310741)
http://video.google.com/videoplay?docid=-1944827568401901581
Post by: giantkiller on 2012.02.02, 05:43:38
Quote from: e2matrix on 2012.02.01, 17:14:49
I'm posting this as copied from OU since it may have some new thoughts of interest here (GK?) .  Might or might not be something new here but when I see someone's JAW hit the floor I start listening ;)   From pauldude000:
It has been over a year (I think), since I retired from the TPU research. I started hitting dead end after dead end, yet the
results of various experiments were promising enough to keep me going. I instinctively knew that Tesla tied into the
matter (not surprising really), but I could not quite figure out how..... I had to clear my head and take a break.
Only SM knows for sure, but I wonder of the TPU was an accident..... I am not joking. Say you are looking at a patent
for a Tesla device employing a rotational field toroidal transformer, but in replication you try to use copper wires instead
of soft iron wires?
More guesses than facts circulate around the device (of which I was as guilty as anyone). Prejudices based upon pet
hypothesis and following theory make for a nasty mix. They cloud your judgement and wreck your ability for emotionally
detached logical thought and evaluation. After my head cleared..... I started over, tossing out most every assumption I
had previously held, or had been told by others. I re-read all of SM's posts carefully to see exactly what HE said and
meant, not what interpretations I or anyone else placed upon his words.
I found that he was actually quite clear, and that someone else was occasionally posing as him. (People have a distinct
writing style, grammar, word usage etc.... like a written fingerprint.) Some matched, others were 180 degrees out of
phase so to speak.
facts:
SM stated plainly that the fields were rotating, and that the rotation was necessary to the operation
SM stated there was a kick, then specifically pointed out the inrush current from the book he cited as the stated "kick"
SM pointed out TAO had the overall key (And he does I believe, through the winding pattern he developed and through
his initial presentation of his thoughts about Tesla.)
NOWHERE did SM agree with the statement TAO made about Tesla's wireless transmission of power tech being
involved. THAT was assumed.
SM stated that the unit worked by making as many kicks (inrush current) as possible as fast as possible.
Out of nowhere an EE posts an anonymous letter to Mannix. To which SM (the real SM by writing style) agrees almost
whole heartedly with every deduction the man makes, then points out several 'points of interest'.
What was a point of interest to me was that from the style of writing, I think SM himself may well be the hypothetical
myterious EE as well.
After watching ALL the movies again, slowly, pausing and rewinding and paying as close an examination as possible.
I noticed a few interesting things off of the good quality vid I received from JDO300 way back..... exactly two sets of
matched components in the center of the large TPU. Two large black caps with resistors in parallel on the inside
periphery of the coil (very clear, I could almost ready the values) and in the very center two matching inductance coils
with two matching caps close by......
I wondered why he would need two pairs each of matched RC and  LC tanks, then it hit me. More than one signal out
of one input signal....
Q: How can you make AC out of DC?
A: Charge a capacitor in series with an inductance, then open the switch and shut the power off. The capacitor will
discharge through the inductor to equalize charge across its plates as soon as the  forward voltage either reverses
(AC)... or ceases (DC). The pair will resonate at a frequency governed by the values of the given components.
A nagging suspicion ate at me for awhile, then I loaded up the Tesla patent again, and examined the diagram closely,
tracing the wires through the circuit on the transformer, then back to the generator in the circuit, asking the question
"exactly what is the ELECTRICITY doing when this generator rotates through a cycle", not merely what the current was
doing. I wanted to examine both current and voltage together.
My jaw hit the floor. The device in the patent is a rotating field transformer. Four coils make and rotate the field, and the
outer coils 'generate the juice' so to speak.
Now, understand that the picture in the patent is only CLOSE to a TPU, but it is NOT the TPU.... (I will explain why,
please be patient with me at this point.)
Why two different type matching sets of resonance devices?
VOLTAGE PHASING.... 90 degree voltage phasing to be exact as the tesla patent demonstrated, using a single
CLEAN dc square wave signal.  I was actually right about one thing, go figure. Transistors are a really noisy device that
tend to amplify any abnormalities in the applied signal. The signal HAS to be as free of parasitic AC signals as possible,
that is why tube rectifiers  REALLY are easier as SM said.
Tesla didn't need caps, as he treated every inductor as it should be treated, as a resonant device. Capacitance can be
made by wire placement and spacing relationships. An EE views resonance as either a phase relationship, or as a purely
mechanical function.  Telsa's concept of resonance was a little different, incorporating the 1/4 wave relationship between
the propagating wave and its voltage. The classic case of two people referencing the same term, but using differing
definitions. Tesla desired a relationship where the voltage was highest possible at one end of the wire coupled with an
overall Z (impedance) as close to zero as possible allowing maximum current to flow.... When this condition is achieved,
you see a LOT of energy available in the circuit.
Voltage, remember, is not energy. Neither is current. BOTH must be in motion for a state of usable electrical energy to
exist. We have all seen the resonant phantom signal pushing hundreds of volts, yet would not light a fart, let alone a light
bulb. The current was out of phase with the voltage, therefore little or no usable energy.
Tesla didn't need caps, but I DO.... and so did SM. you have four coils, one DC square wave signal at a given desired
frequency, how do you rotate the field? Hint 90 180 270 360... you phase each of the voltages 90 degrees further from
zero as the previous coil, using equal reactance components to achieve resonance at the input frequency, into a wire
wound into a coil, the length of each wire being 1/4 wavelwength long..........
Anyone see what I see?
By the way..... you can generate juice using the "A" field in a toroidal unit.......... doesn't have to be magnetism doing the
work you know, that is assumed. Interesting how coils 90 degrees out from each other can induce voltage and current in
each other. (Collector to control amplification.)
I don't know enough about the "A" field to speak much about it. If someone is an expert, please give us all a heads up.
Paul Andrulis
P.S. I am using public wi-fi for this, and am not "online" right at the moment. I will read your thoughts as posted as soon
as I can get back online.
Paul Andrulis
Post by: giantkiller on 2012.02.02, 05:45:00
http://www.overunityresearch.com/index.php?topic=1241.msg20407#msg20407 (http://www.overunityresearch.com/index.php?topic=1241.msg20407#msg20407)
(http://www.overunityresearch.com/index.php?action=dlattach;topic=834.0;attach=6937;image)
I was running at 14.x khz and noticed this bump at that later part of the ring down. I conversed with JDO300 and guessed it might the diode junction capacitance.
I do not have any capacitors in the circuit except to couple the scope probe to the drive line, 4.9nf.
So I measure out where this bump occurs and it happens at ~103khz. I increase the span frequency(between the dual drive pulses) so the next dual pulse hits at the bump. The signal then shakes back and forth. The scope looses it syncing. I lower the voltage to 100vdc and things calm down, the signal stabilizes and the scope locks back on.
I noticed that the bump occurs sooner so the next dual drive pulse does not hit at the bump point in time.
Post by: giantkiller on 2012.02.17, 16:12:25
http://www.erowid.org/culture/references/other/1997_turmel_resproject_1.shtml (http://www.erowid.org/culture/references/other/1997_turmel_resproject_1.shtml)
http://sharp.bu.edu/~slehar/HRezBook/HRezBook.html (http://sharp.bu.edu/~slehar/HRezBook/HRezBook.html)
Post by: giantkiller on 2012.04.20, 15:30:51
Currently the 2 models I am working on are:
The TPU as an arced or semicircular Tesla coil (the snake bites its tail). The gap between the starting point and the ending point is similar to the Kunel patent to be exercised accordingly. This motion mimics the self destructive resonant transformer but with the added safety of the gap that acts as a shock absorbtion or suppression device. The activity at this point can be read or siphoned.
The TTBrown model can be reproduce very easily by making a domed shape capacitor of 2 aluminum plates with a Tesla coil under this with the discharge going in to the center to the bottom plate. What is needed is HV and sharp pulsing with a shape reflective echo impacting back to the aether. The aether becomes noticable when the very high speed and potential are shot to a reflective scattering which creates more surface of impact instead of just a stream breaking through the space looking for a sink.
The spark gap for both of these experiments is the low inductance primary driven by the comp wave / dual pulse protocol that Spherics mentioned.
This mimics the spark gap normally on the primary. TTBrown used HV transformers.
This picture is a mix of Tesla, Deyo, Hutchison, TTBrown.
The secondaries are made of 3 concentric coils. They are shown extended as an example. Normally they do not move. The three secondaries perform as a pancake type operation also.
Post by: giantkiller on 2012.06.18, 18:12:17
I have bypassed the internal sparkgap with a neon start bulb from a fluorescent ballast. This reduces the external Ee-Em-Pee. I am setting up a resistor ladder to enable the circuit to run off of 12v ATV batteries. The ckt needs a 9vdc bat. The Osc transistor has a base current of 3.5 amps but the emitter-base voltage max is 7v so at 12v supply it breaks.
With the sparkgap bypassed I can now run this circuit in stealth mode into a coil. The scope shows a constant small level wave form and every 1-3 seconds an Ee-Em-Pee shows up. I believe the neon I use permits this. The electrode gap is wide but this is usable in a start up protocol assessment.
I have tapped off the final stungun stage to a low impedance coil. I will move the tap point to prior this stage replacing the factory supplied discharge stage with my coils to analyze the difference. This effectively makes a TPU - circlular Tesla type coil as the discharge stage. High & Low impedance coils with be instituted.
Based upon events in 1996 Muller started it with his aluminum rotor(This beat Juan Be dinin by years), then Don Smith did his with sparkgaps. Then SM did his with the gaps hidden. I believe SM used hidden neons. These are all brute force. The delicate way is to use the dual pulse protocol that Spherics showed. But then this makes it geometry specific. Sm showed a number of different formats all in a simple geometry.
Post by: giantkiller on 2012.06.19, 15:46:46
I did get the ATV batteries in place by using a 2.7 ohm resistor in series. With the Base to Emitter of 7v the ATV 12v damages the Osc transistor. In replacing the 9volt snap in batteries with the ATV batteries I noticed some things:
Now that I have a high current source to drive the stungunckt I can run tests more freely. This allows more focus on the ckt operation than trying to procure batteries for the ckt. The next step is to replace the normally open momentary switch with a relay or foot switch.
My experience with a HV flyback or ignition did not perform the switching fast enough for the high transients. In an automobile points were added to accomplish, which is a rotary Tesla coil switch.
Premise:
The sequence is this:
Automobile ignition and point system, Tesla coil rotary switching, Muller rotor, Kapandze radial Ee-Em-Pee, Don Smith NST based sparkgap, Steven Mark TPU driver.
Onward:
The idea here is to change parameters on the stungunckt stages keeping the TPU as a third stage discharge of a Teslal coil setup. The TPU looks like the flexible dryer hose top but is a mobius wired configuration.
So:
The last stungun stage is still connected to the coil.
The bulb ionization shuts off by itself. This creates a very fast transient. The neon is a more conductive gap than the internal screw gap. If I make the screw gap too wide the internal gap sparks to the board and the neon doesn't fire.  I am trying to see if SM hid this stage through replacing the internal sparkgap with a neon configuration. I am following a hunch.
The main goal overall is to see if I can magnify the spark discharge to a higher vibratory action. We know by experience that the sparkgap produces a thumping in the magnetic range. The eye can see and in the bigger stunguns the thumping is very slight from the operators end. From the victim's end the thumping is very revealing to the action that is posible with a 9v battery.
On the scope output the the fast transient appears at a certain interval. What I want to control is that interval to match the action of the circumferal discharge coil. Right now the interval is longer than the circumference. This will let me see things at a slower pace.
Damage report:
In the stungunckt one side of the the large mylar capacitor coating was ejected into space. There was no heat. The ckt still works as normal. The correct frequency at the correct place produces cataclysmic results.
Title: Re: The final answer...
Post by: giantkiller on 2012.06.20, 04:44:13
http://www.youtube.com/watch?v=pdrzBL2dHMI&feature=related (http://www.youtube.com/watch?v=pdrzBL2dHMI&feature=related)
Post by: giantkiller on 2012.07.16, 17:21:46
http://www.overunityresearch.com/index.php?topic=1484.msg23990#msg23990 (http://www.overunityresearch.com/index.php?topic=1484.msg23990#msg23990)
When ever a greater pressure falls to a lower pressure we get a vortex.
Link to Viktor Shauberger and Walter Russel.
Fluid Dynamics http://www.evert.de/eft724e.htm
Walter's Periodic table of elements fits nicely onto Rodin's coil field array. Which by no streatch of the imagination fits into the Alchemical Manual.
http://www.bing.com/images/search?q=walter+russell+periodic+table&id=E6C972649665FE5A31C0667010BDA9676E88B342&FORM=IQFRBA
How does everything flow?
(http://www.meta-synthesis.com/webbook/35_pt/magetosfera.jpg)
QuoteA possible example of two equal sized offspring may be the binary pair called Y Cygni.  This is a pair of giant O or B type stars that orbit each other in a period of 2.99 days. Each star is some 5 million miles in diameter and 5000 times as luminous as our Sun - absolute magnitudes about -4.5.  They are some 12 million miles apart (less than 2.5 times their diameters!).  Their masses are 17.3 and 17.1 times the mass of our Sun.
Post by: giantkiller on 2012.11.26, 23:06:32
In regards to the TPU, Hutchison, Otto, and the GK4.
The bias produced by the iron wire enables a resonant field captured within the device so there is no need for a grounding connection(Like an iron ball or virtual iron molecule). The large reservoir is within the device itself(SM showed this with an ampmeter held in the center of the tpu). As can be seen that the primary can be loosely or tightly coupled. Because of the bias the device can achieve a resonant structure easily without any attempt to physically connect with the ambient structure to produce a discharge, which is lost energy. Take note that if the secondaries are formed into a loop formation what can be seen is the tpu. With an activation placed within the vesica pisces area a Hutchison device can be achieved which oddly enough is the configuration of most of Steven Mark's TPUs. In the diagram shown it can be seen that as the device is driven the resonant bias can be agitated within each secondary itself. The more Tesla coils added creates a stronger vesica pisces within the same physical area. We therefore have a achieved the virtual ambient structure to manipulate. Like Don Smith's multiple coil configuration.
This is the process shown by the explanation of the Ark or the Covenant. When ever a major Holy meeting is going on there are angels on each side. These represent two resonant magnetic fields. The vesica pisces is the symbol of Christianity also known as the IKTHUS or fish. The greater powers are trying to convey onto us the process and devices to achieve the use of the wheelworks of nature. This process has been hidden in the context of love because it is very dangerous. The use of this process will foretell our future. The use of agitation in the vesica pisces can be harmonic or chaotic. When a harmonic additive is applied matter can be made to perform at our command. When a chaotic addition is applied the event is uncontrolled like a rogue wave. Or, using Hutchison's demonstrations you can produce new atomic lattices or make little figurines jump about randomly. Whether he knows it or not he has a produced a virtual Ark of the Covenant.
All of the overunity attempts are an attempt to manipulate the bias field. EMDevices showed the iron wire running through the larger tpus. The smaller tpus had magnets placed on them. These are basically Bearden MEGS with removable magnets. The Johnson, Smith, Muller and EVgray  motors are basically manipulating a bias charge or bias field.
The Ark of the Covenant is two magnetic fields overlapping with an agitation in the center in the box itself. When the walls of Jericho fell at that time there had been marching and trumpets blown. Two sources of harmonic agitation.
Tesla's pancake coil is another model of this bias manipulation.
Who so ever reads this and understands have become a very serious threat to the powers that be...
Attached is an iron wire core Tesla coil. It is not 'Tuned' to the standard for an ambient discharge but to produce a high potential resonant field.
The scope of interferometry of the area of the vesica pisces is not yet fully mapped from what I have been able to research.
OU'ers have seen the most abundant breadth of the process. But I have noticed that this elite set of thinkers are segmented by their education, experiences and views of how things operate.
For instance: some try to quantify by their known physics law, others by a device's mechanical view, others by their electronic process knowledge. The process of the manipulation of matter by the Ark of the Covenant, Coral Castle, and ancient megaliths is viewed from the ground up by minds trained from their center. This limits the acceptance of the ability to accept an outside view.
Current is a mere byproduct of this controlled manipulation. The control potential in this overlap area has banded areas of operation. Some between to resonant magnetic fields with an interjection of white noise i.e. Hutchison, some an interjection of pure audio, crystal vibrations and magnetics i.e. Coral Castle, Ark of the Covenant, some are pure vibrations from compressed gas in spherical chambers i.e. Keely's work, while some are just magnetics with physical vibration i.e. Steven Mark and the Canadian with the spinning magnet layers in a steel drum.
As with Hutchison's attempts we have seen new matter lattices form. Keely executed the opposite of this by performing molecular association to disassociation. Actually Hutchison did this too with the material ripping.
So as in this thread with the usage of iron wire there is creation of a bias by a weak magnetic field. The low amount of iron used saturates at a very fast rate thereby producing a magnetic field for the process. And as we know a magnetic field is moved in the vicinity of copper windings. In the tpu there is an outer field/ a bias and an inner smaller cirumferral generator(those smaller spools with vertical windings). The inner speed is faster.
Resonated at 81khz with a 20vp2p sine to the secondary. Next I switch from a loosely coupled pancake to a loosely coupled parallel winding.
Post by: giantkiller on 2012.12.04, 20:12:39
On this, OverunityResearch site I see no mention of intersecting magnetic fields inside a medium. This is the function that generates the friction to cause an impact to be managed. The energy created at that point can be generated to perform with or against matter at the sub atomic layer and further down or across the Planck layer.
So I find this blatant science exposure. We, on this site talk like ants in the ant farm while the owner spins the glass cage around to occupy us.
Riddle me this, Batman?
http://www.youtube.com/watch?v=LzjGseA6Mq8 (http://www.youtube.com/watch?v=LzjGseA6Mq8)
If the choices are outside of your reality you will be easily modified against your will without your even knowing.
Can anyone see past their imprinting? Without Truth we mimic our deceptions.
Post by: giantkiller on 2012.12.05, 05:45:24
Maybe we can agree on this hyper-reality?
http://www.youtube.com/watch?v=RqbcsU0_RjU (http://www.youtube.com/watch?v=RqbcsU0_RjU)
Post by: giantkiller on 2012.12.20, 00:09:00
http://www.mojvideo.com/video-soviet-weather-engineering-over-north-america-by-tom-bearden/0d7a5d3c68f508fe6588 (http://www.mojvideo.com/video-soviet-weather-engineering-over-north-america-by-tom-bearden/0d7a5d3c68f508fe6588)
http://www.spacedaily.com/reports/MIT_researchers_discover_a_new_kind_of_magnetism_999.html (http://www.spacedaily.com/reports/MIT_researchers_discover_a_new_kind_of_magnetism_999.html)
Post by: giantkiller on 2013.01.06, 23:57:51
Incorrect coupling frequency.
Runs at 77 degrees f, 26,950hz. Need lower cap in spark gap stage to raise the freq to 68741 of the output stage.
Lowered signal to 1257hz. Odd symmetrical wave appearing at end of off time.
Post by: giantkiller on 2013.03.30, 15:57:32
We know Steven applied and swiped magnets to the TPU.
We know the TPU became warm.
We know Steven stated DC with hash.
We know Steven mentioned audio equipment.
We know the circuitry was simple.
We know the phase locked looping was mentioned.
We know that the units thumped.
We know iron wire was mentioned. It was pointed out by EMD that the horizontals could be iron wire. I have many tests doing this. I have seen nobody else try this? We are not talking cores here, but a low saturation configuration to couple the fields at 90 degrees. This presents a bias for pulsing or squeezing. We see this in  Hutchison tests and in MRI processes. The magnetic flux will exit from the horizontals and not be seen by the center toroids because of the winding angle being parallel with the those fluxes. The pumping action will cause movement in a circumferal fashion there by cutting across the center windings, hence the labeling of [pickups].
We know that Steven mentioned squeezing.
We know Steven mentioned conductor jumping, attracting or repelling.
We know there was outer wrappings on all TPUs. This facilitates squeezing or the implication of adding extra flux to the core then letting that flux spread out across the core. I call it a core because of its placement.
We know Steven mentioned [A different kind of induction].
We know the horizontals were 2 to 6 loops/windings. This enables the ring configuration of flux coupling so the whole ring becomes magnetized and any action will appear around the whole field. What is being addressed here is a wave guide.
We know Steven mentioned ramp up time. Did anybody see the vids where there was none? There were. These were the TPUs were Steven primed the units with magnets. Swiping a bias copper core with a magnet will add excitation to the field thereby triggering the feedback loop.
We know Steven mentioned simple parts acquisition from Radio shack.
We know Steven mentioned field rotation. How about this being a reference to the pumping action around the ring? I posted many animations about this.
We know that most of the units had the extra toroid pickup in the middle. I equate this to the trigger pickup for the phased lock looping.
We know that there was one unit that did not have a center toroid. I refer to the attached pic which addresses all the afore mentioned specifications...
Happy Easter and may He find you loving others beyond all reason.
Post by: giantkiller on 2013.04.27, 21:07:57
http://www.youtube.com/watch?v=IWGOpuca7cs&feature=endscreen&NR=1 (http://www.youtube.com/watch?v=IWGOpuca7cs&feature=endscreen&NR=1)
Post by: giantkiller on 2013.12.07, 22:55:02
@EM your L C values are right on. My L is 64mh and the C is .2uf.
@Grumpy, SM commented on Spherics in that he wasnt even close. This is obfuscation. He was dead on and he also showed the setup for a single kick event. The spark gap affords the stream.
@Wavewatcher, the center toroid is a Tesla coil internal primary.
I have done many combinations with this setup. The simplicity is staggering. There is also the 'Effective aperture' involved here by putting large loops in that connect the inductor and the capacitor together. The LC tank is comprised of a tank circuit with 2 large antennas imbedded.
Just by switching leads around I can swap the configuration into any permutation that I would think produce something.
I drive the center, the outside, read from anywhere.
I have another mechanical modification to this that is going to take sometime. I am adding a magnetic waveguide to the outside.
My theory is if I keep this to myself and it is announced then there is a single point of failure. So here ya go. CFL starter neons as sparkgaps. The CFL runs at 37khz, 2kv, 6amps.
I am basing this current on the simplest of what has been previously stated in public and private. There had become a huge amount of overlapping and repetitive quotes. Having produced a large amount of events concerning the TPU it was inevitable that the next combinations would have to be an accumulation of the smaller tests into bigger sets. The last thing I will do is to switch from the input power parameters to an internally generated set. The feedback mechanism is the space between the center toroids and the outer vertical windings. SM showed this.
Merry Christmas.
Take no money for your findings. Remember to be safe. The only prairie dogs that get shot are the ones who stick up. I was very hesitant about releasing this. Every day I sit with it, things just fall into place.
Post by: EMdevices on 2013.12.08, 10:48:54
Thanks, looks great!  Im currious if DC can be induced into a toroidal winding, but once you put that on you cant modify it anylonger.
So the small toroid in the center picks up and resonated the mag field to 500 V and above?  Sweet!
Post by: giantkiller on 2013.12.08, 23:08:29
Quote from: EMdevices on 2013.12.08, 10:48:54
The CFL injects 2kv. What I was showing again is the usage of electrostatics and how that transfers in all directions.
I tracked the energy going inward and outward. Any metal becomes an antenna and absorbs the discharge. I don't think losses are detrimental. The main point is not only capturing but then using that as a trigger,  feedback, or excitation in another part of the circuit. This is elemental and fundamental. Also the 'Effective Aperture' in a horizontal plain can work in an up and down fashion, pumping and receiving.
Now what if the input voltage is 300kv? We tune the tanks to sidebands and not dead on. Once again, like SM said, 'There is no complex circuitry.' and the next conglomeration of sets will prove if the TPU is real. I know that is a bold statement but this build incorporates everything that has been discussed in the past 6 years. And my employer just stated potential downsizing and the employees were just offered a 'Resume Writing' class. I do well when I am tormented and squeezed...
I will not have a problem once the wrapped toroid is on. I will test the large open and the closed loops separately but in the same build.
http://www.overunity.com/8185/understanding-electricity-in-the-tpu/msg254189/#msg254189 (http://www.overunity.com/8185/understanding-electricity-in-the-tpu/msg254189/#msg254189)
http://www.bibliotecapleyades.net/ufo_aleman/rfz/schappellerchapter4b.htm (http://www.bibliotecapleyades.net/ufo_aleman/rfz/schappellerchapter4b.htm)
Searle said 'The electron follows the magnetic field.'
The positive DC bias serves two functions. One is to provide a destination or attraction for the electrons and two to contain the compression on the collectors.
Magnetic containment:
Post by: giantkiller on 2014.01.05, 23:42:54
http://www.youtube.com/watch?v=36RGonC_Zgs&feature=youtu.be (http://www.youtube.com/watch?v=36RGonC_Zgs&feature=youtu.be)
Post by: giantkiller on 2014.01.07, 20:30:01
Previous vid had copyright problems....
http://www.youtube.com/watch?v=epRcSjATULA&feature=youtube_gdata_player (http://www.youtube.com/watch?v=epRcSjATULA&feature=youtube_gdata_player)
Post by: Rosphere on 2014.01.08, 02:16:30
Thank you, GK.
Post by: giantkiller on 2014.01.18, 04:01:42
Next: A jump into the configuration:
http://www.youtube.com/watch?v=3H3qZ2YQ-UQ&list=PLRMAWXyCH-CVjuZ3HY10HnOBGxcFA3jjB&index=8 (http://www.youtube.com/watch?v=3H3qZ2YQ-UQ&list=PLRMAWXyCH-CVjuZ3HY10HnOBGxcFA3jjB&index=8)
Attached schematic.
Post by: wings on 2014.01.18, 21:56:28
have you seen this video?
http://www.youtube.com/watch?feature=player_detailpage&v=_ze8cVIqSkQ
Post by: giantkiller on 2014.01.19, 02:10:39
Months ago. Been conversing with him a long time. As stated in my last 2 vids I produced the kick many ways. After seeing it I placed it in everyday operations of consumer products. The logic is the kick is the return by the collapsing field. It is very fast so why not use whats free? Ignition coils perform this. That is a Tesla coil.
The argument is about the BEMF which many state that is not the answer. Well is it easy to perform, achieve and stream. Automobiles do it all the time.
I was stuck on the feedback mechanism. That is an apparent control in the stun gun which also fires from a collapse because the feedback shuts off the coil. Same thing here again. Collapse.
SM stated simple. I believe this is it. If not then Akula is the alternative, which adds complexity. Because the other alternatives don't pan out. We have all seen years of a myriad of attempts and burn outs.
With what Akula has produced it again points to the collapse type energy. He is focusing on the eclipsing of high speed frequencies. I covered this in my first three years in OU. This process lights bulbs.
The next step I am on is the switching of the CFL outputs into complimentary sides of the coils pairs. This produces HV bursts in a see saw type activity into 2 coils.
Change the view of operation and the kick becomes the collapse.
Post by: giantkiller on 2014.01.19, 06:03:12
http://www.youtube.com/watch?v=8ML6cBuk3ug&feature=c4-overview&list=UUasw7-7Lz9H9cwozzAhrmYQ (http://www.youtube.com/watch?v=8ML6cBuk3ug&feature=c4-overview&list=UUasw7-7Lz9H9cwozzAhrmYQ)
Post by: giantkiller on 2014.01.20, 04:24:49
As can be seen there are kicks occurring randomly.
http://www.youtube.com/watch?v=zbypRYyrlHE&feature=youtu.be (http://www.youtube.com/watch?v=zbypRYyrlHE&feature=youtu.be)
Post by: wattsup on 2014.01.27, 17:55:48
@GK
Always a pleasure seeing and learning about the effects of your works.
As a side note, I have started to migrate stuff from my house to my newly built garage.
This will clear up some great space in the house for a bigger OU lab right beside my existing office/lab.
For guys that would like to see my garage build on time lapse (hahaha) you can go here...
http://www.youtube.com/channel/UCA6T7xOfANBi-onm-9IX8Ow
Can't wait to get started again. But while I catch up I wanted to share with you (and other OUphites) some of my "thinkings" about SMs TPUs which I have had the last few months to ponder about and muddle over all the devices, functionings, parallels of each, etc, etc, as we all have done for years now.
So let's just start.
Regarding the SM-LTPU (I'm saying SM because now we have a GK-LTPU hehehe), I think that if you looked very closely to the videos and also the LTPU wiring diagram I produced way back, it is very evident that on each of the ltpu center toroids, the two halves are connected in parallel. Seems like because the center toroids are wound in bucking mode style with the four wires coming out individually and only in the ltpu we see the two halves are paralleled from each end of their windings, that maintains a uni-directionality of the field in one toroid and this could be turning energy or the field in one direction each. The second toroid is the same but if it is connected in the reverse direction this would equate to the two fields going in opposite directions.
If two half toroid coils were wound on a standard ferrite core, the vast majority of the field impressed towards the coil would be stuck inside the core as we all know such toroids do not readily cause remote static unless you find the right frequency, width and amplitude to pulse the toroid that would be sympathetic to any specific remote outer rings or coils that would catch the transmission. I had shown this many times in my Pulsing Coils youtubes. This could then mean that the toroid cores are not ferrite type. One option is what if they were enamelled aluminium cores. Each coil pulse would draw in the ether field that could not enter the alu core but be reflected back outwards and available to the outer rings.  Like calling in the ether brigade without a landing site. It will just  leave but with a good reflector the leaving may be more dramatic then your standard air coil dissipation of the field back from where the ether came. Since we are always in motion, the ether dissipation is left behind as we move ahead and ahead into what the ether sees as us moving through it so fast that anything dissipated would leave the origin. The capture time would be very small.
Put it this way. If I was working at Big Bang Central Station and Universal Observatory and was asked, "where is @GK", while I am looking and pointing outwards from the very point of the BB, I would maybe say something like, "he's just grazing around in the milky way galaxy that is moving at xxx xxx xxx miles per hour".  That movement is real and even our solar system does not feel it but it also means when a coil is pulsed while it is moving through space at high speed, the ether lands on the object like a bird lands on a sea going vessel (pulse on) that is caught in high winds. If the ship sinks in the next second (pulse off), the bird just flies with the wind and is taken away until it sees another ship (if ever again).  The same ether will never be, always renewed and always there.
Sorry for veering off... hahaha.
One center toroid was in the ftpu, otpu, stpu, 6tpu's and mtpu. In those SM must have used each of the two toroid coils individually but one half pulsed at 0 and the other at 180 degrees off. In the ltpu he is using two toriods, each one with the two coils paralleled then each full toroid was pulsed one at 0 the other at 180 degrees off. What does that do. Consider that the ltpu outer vertical wind(s) (receivers) is or are obviously stationary. The verticals do not move. But curiously, if the 2 toroids are at a small enough  distance apart but far enough for each field to end in a different position around the fixed outer rings, then you now have two opposing fields each one hitting the outer rings at 180 offset and at different physical locations. There is the physical movement of the fields. It is toroid one pulses then off then toroid two pulses then off and so on. This will MOVE  two opposing fields over the outer vertical rings. The pulsing frequency is to be discovered of course but if the logic holds in the mind it has a much better chance of working on the bench. hehehe
So...let's go a little further.
Also, regarding SMs statement of the consequences of two fields moving in opposite directions, myself and I guess everyone else that has delved in the SM devices have always thought that the two field directions are relative to the outer rings having two coil winds that are pulsed in opposite directions, but, what if this is partially the case. What if the toroids are the ones initiating the two field dance. It would be like a dual blade food blender creating some great wiped cream ether energy available inside the LTPU verticals where the outer coils catch this and transfer it into the output.
That would explain why the sliced MTPU pie showed so few wires. The MTPU ran with one center toroid and was producing around 400 volts with all its outer coils, so in the LTPU catching 600-800 volts would not be a problem but then the question of amperage arises. This is where we should start to think about paralleling the outer vertical rings to increase amperage. Two halves or four quads on vertical would be a first suggestion. Even eight depending on how much voltage each could produce. It could even be each vertical is only one or two turns then all of them are paralleled. That would hold with SM statement of "one wire pulsed over 1000 wires". This can all be worked out once the main system is functional. But there is more.......
I would like to now relate to your last build of the GK-LTPU as specified above. From what I can understand from your videos and posts, this build incorporates the following but please correct me if I am wrong.
1) Two toroids with two coils each wound in bucking mode (140 degrees around each) with their four wires coming out of each. Core or not is not important right now to just see the minimal effect.
2) One vertical wind going 360 degrees around the outer periphery.
3) Three horizontal rings top, center and bottom of one turn consisting of dual conductor speaker wire.
So now I have these observations and recommendations to try with your build if you can.
A) If your center toroid coils are wound in bucking mode, put them coils in parallel. If you look at the toroid from the top with the coils going left to right, one over the top half and one over the bottom half of the core, put the left wires together and put the right wires together to get your parallel.
B) Make two outer vertical winds with your existing one wind and put a dioded cap on each one. Put a volt meter across each dioded cap.
C) Now about the three vertical rings of two conductors and of one turn only. This is not good to have only one turn since half of that is doing nothing thus you would not be able to cover 360 degrees of pulse activity with only one turn. So just put the two conductors in series to make one ring of two turns instead of two rings with one turn per top, center and bottom horizontal ring.
D) Connect one of the top horizontal ring (H-ring) wires in series to one of the paralleled toroids and do the same with the bottom horizontal ring in series to the other toroid but make sure that one is opposite the other. You will have one wire free from each toroid and each H-ring. Now when a toroid pulses it will also pulses one of the top or bottom rings. Think of it like the toroids provide + and - potentials and extends these pulses into the outer ring system via the top and bottom horizontal rings.
E) Leave the modified center H-ring alone for now as I will be getting to that soon enough.  hehehe
D) Ok let's find out the best frequency of operation. If you have just two frequency generators even with their small output capacity, connect one fg to the free wires of the first toroid/H-rings pair. Now it's time to play with the FG frequency, width, amplitude etc to find the settings that produces the highest gain in the outer vertical winds that are dioded and capped. Try again with the diode on the other cap end and see if one is better then the other and keep the best.
E) Now take your second FG and do the same with the other toroid/H-ring pair while the first FG is still active. If you ever see the voltage rising very high in the verticals, you will need to add a load on each cap/diode and whatever you do, do not turn off the FG if the vertical outputs are full of juice as this could create a back spike and ruin the fg.
F) OK once you have identified a good frequency range, it's time to build two solo circuits that can be battery driven and provide the same pulsing effect as the FGs. The criteria for the circuit is that is must start with only 1.5 volts but it must be able to then increase its voltage throughput and control. You can do this by testing it with one 1.5 volts battery then adding more batteries in series.
G) Try the two circuits and make sure they are providing the same function as the FGs with comparable results in your vertical output coils.
H) Now you need to make a small radiant energy circuit (REC). The well known circuit with caps and diodes that we have all used before. You probably have one lying around already.
I) Now remove the batteries from your pulse circuits and connect the REC + and - to the battery input of your circuits.
J) Now connect the REC antenna side to the center H-ring.
K) Now if the antenna can produce 1.5 volts that device should start up on its own or with some help via a moving magnet. When the 1.5 volts is available to the pulse circuits and they start pulsing, this will increase the radiant energy available in the outer rings thus increase what the centre H-ring antenna can send back to the input of the circuits so this would be a very simple method of looping the energy back to the source.
This would be a good place to then continue on the R&D. With the above build strategy, what are the energies involved since this is much more then your regular two coils on a core coupling?
a) The toroids will pulse to a frequency that is sympathetic to the outer vertical coils and reach them via air to air coupling.
b) The top and bottom H-rings will also extend the toroid air to air with a more direct proximity pulsing.
c) All the activity in the outer coils and rings will create more and more radiant energy available to the center H-ring that resupplies the toroid drive with energy.
d) As the energy increases in the outer coils and rings, the resupply to the source also increases and the total system should now function with gain.
It may be a good idea to put a 1 amp fuse on the REC antenna just in case you get a runaway.
Sorry for such a long post. I just had to give you this input although I do realize it is rather redneck theory derived from ether impress and spin conveyance. I will talk more about this in my older thread. If both exist, then the above should show some interesting results.
I would say the frequency will be in the audio band where we know feed back but this is just a very educated guess when considering all the times some rock band feed back forced everyone to cover their ears in horror, feed back is a nasty b&t$h wait'in to crush your ears. (Ouuuu that was bad.)
I will have to build this and try it myself in smaller scale then your LTPU to see the effects. I'll try the ftpu format again because it is the first tpu and hopefully any runaways will be minimal and the build is easy. Hmmmm.
In the control circuit, it has to be simple and I am inclined to think that he was using zenor diode breakdown to make or could I say engage the pulse. I don't know how yet but I do know the ftpu had diodes and I am sure radio shack sold identical looking zenors as well. hahaha
One last thing. Try to keep your classical hand held ammeter like SM tried around the ltpu to see if you can maybe play around with the toroid placement in the ring. When positioning the toroids into place, I don't think this was randomly placed but rather a well thought out affair, This could explain why he had that amprobe handy. He did not place the two toroids in perfect center but rather offset from there. I am sure he had a reason to lock it there. Sometimes when I was pulsing coils,  just a small change in distance would make a world of difference in results. I think SM was using his ammeter not only to measure the ambiant discharges around the toroids and rings as the system is running in demo, but more importantly, to best position the toroids as well. Just hold the probe above the toroids as you move both around in the ring and see where it plays louder. hehehe
Have a good one man.
PS1: I'll be back soon enough.
PS2: For all other OU developers, I think that while a TPU is developed, maybe consider the radiant energy circuit to be all you have to start up the tpu. Put the antenna of that circuit inside your coils and see what happens. Is it possible that Tesla was not kidding. Who said the receiving plate (or antenna) has to be in open air 200 feet high. I think he would have used a very big version of this to energize his Wardencliffe and send electricity around the world for free. Basically, imagine having your antenna inside the transmitter.
Post by: giantkiller on 2014.02.04, 20:13:36
Current schematic...
Post by: wattsup on 2014.02.08, 15:26:52
Hi @GK,
Sorry for late reply.
Yes your wattsup-LTPU.jpg (top one) depicts very well what I had indicated as a simple and real point of starting experimentation bucking toroids. Your second image is good as well since you mentioned your toroids were not in bucking mode so inversing may be better. You would of course need to play with the variables such as the FG polarities applied but the first stage is so simple and is only to find what frequency to pulse the FG1 and FG2 to obtain the maximum possible gain in the two verticals and their cap banks. Even if the output is reactive, it does not matter at this first stage. If by chance that frequency winds up being the best in the 5k range then this would be again a good indication that the orientation is at least plausible.
Now let's talk about zener diodes. What happens when you put a 9v zener diode across a 9v battery. Nothing should happen. If the 9v zener received 10 volts it will pass 1 volt so not very useful plus it will eat up 9v and create heat. But if the zener was a 1v rated and received 9v, it will pass 8v. Aha. There is a potential pulse right there. The zener would only eat up 1 volt and pass the rest but how.
If the 1v zener receives 9v, the voltage across the battery should short and the battery voltage should then drop to zero and open the diode until it gets again to 9v. Has anyone ever tried it?
Now if the 9 volt battery was also connected across a cap bank where the voltage return could grow and grow, the higher the voltage the higher the pulse voltage going through the zener and this would equate to running with gain. hehehe
Maybe too simple, maybe not.
(gee)
Post by: giantkiller on 2014.02.10, 05:16:24
http://www.youtube.com/watch?v=hdfo7dRiJ64 (http://www.youtube.com/watch?v=hdfo7dRiJ64)
http://www.youtube.com/watch?v=5HZGBzIJMV4 (http://www.youtube.com/watch?v=5HZGBzIJMV4)
Post by: wattsup on 2014.02.14, 15:22:08
@GK
Super good work man. Snow day today so I am working again getting my space set-up. Still lots of work but one day at a time.
Anyone interested in my garage build, you can see it on youtube as time lapse here;
https://www.youtube.com/channel/UCA6T7xOfANBi-onm-9IX8Ow
OK, you are showing exactly what we would expect to see when driving one or other toroid and one ring and scooping from one half of the verticals. The fun will start when both toroids are driven and you should then start to see higher spikes. Again don't worry about the energy produced since you are driving this with your FG amplitude which is really nothing compared to when this same set-up would be driven in gain mode via that center H-ring.
Does your FG enable you to adjust the pulse width because sometimes pulsing at 10% to 35% can give you better results then 50%.
The small circuit for the radiant energy capture is very simple as shown below. You can leave one end of the center H-ring open and connect the other to the antenna input and use the two outputs on a dioded cap to see how it produces for now. In the circuit they are showing germanium diodes for their lower breakdown values but once the system matures, those diodes should be replaced with regular diodes, but again, at that point I am sure even SM had to try many diode types like I have shown with my Diode Carousel video that the right diode for the right condition makes all the difference when harvesting outputs. This would also apply to the diode type you are using for your vertical coil tanks. Imagine if with the right diode those spikes went off the screen. More on the Diode Carousel here;
https://www.youtube.com/watch?v=nj0ShZV6bhY
I was hoping that someone else on the forum would have taken up the zener question as this will be another factor for finding a decent and robust enough pulsing scheme that is as unobtrusive as possible to enabling and maintaining a gain and loop condition. That will be a big step to solve later on.
Slowly but surely.
(gig)
Post by: giantkiller on 2014.02.17, 12:18:42
I researched the diode speed and am wondering why I would want to use a diode that gives the highest output at at a certain frequency?
It seems that would constitute an incorrect operation. Even with lower frequency coming in, the biasing from the higher frequencies would cause the diode to allow all to pass.
So why have a diode at all? Just wondering.
Shown here:
I do have some germaniums from an old Denver mainframe.
In the GK-LPTU I have found the optimal operating frequency of 69,165hz(U.S. thousands) 50% duty cycle of both verticals. The 90 degree coupling might have some effect but the toroids are parallel with the vertical. The highest voltage I get is 1.6 with both function generators running. With just channel A I get 2.6v. There is also a slow signal signature of 2.5 seconds in the background. I am curious about this. One thing I need to do is move the toroids around the inside to effect any change.
The duty cycle doesn't seem to make much difference at this point yet. The input signals to the solid state relay boards are +12vdc with +12vdc driving the coils. This could be premature as Wattsup stated putting the signal generator directly on the serial toroid/horizontal pairs.
But wait this just in:
I am using hvr-1x fast recovery diodes that have 50ns recovery time. I would not see high voltage on the verticals since a signal side would be dampened.
Post by: giantkiller on 2014.02.18, 04:00:20
Switched out HVR-1x 50ns diodes to 6A10 300ms diodes. Reactive frequency changed but no change in the Vertical voltages. Still ~2.00vpp.
Will switch in the oscillator circuits and build the Radiant Energy receiver circuit.
Will apply the Radiant Energy receiver to the middle horizontal before the new oscillator circuit applied.
Post by: wattsup on 2014.02.18, 14:46:07
Hi @GK
I'll answer your PM here because there is no option to attach an image on the PM.
See photo of a coil I made a good while ago with bucking mode winds. Notice the primaries E and G on left side both start by going over the core and where F and H finish coming out from the bottom of the core. Then you put E and G together and F and H together. Look you can also try putting E and H together and G and F together as well, but based on the wires coming out of SMs LTPU toroids, I expect the former to prevail.
QUOTE fro @GK
UNQUOTE
Output of 1.6 with both gens and 2.6 with one gen. Hmmmmm. It may be possible that from one of the toroids you need to go to the other end of that toroids H-ring. All variables have to be checked as maybe the way it is connected now from toroid to H-ring it may be causing some cancellation effect on the vertical outputs. Do you have an "offset" control on your FGs that could put one slightly off phase from the other meaning that the top H-Ring would pulse off phase from the bottom H-ring? If not that does not matter much since changing the pulse frequency on one of the FGs would equate to a simulated off phase which is better then nothing just to try. These are all little things that can be checked with the low power FG before trying to go into a looping condition.
Great work man.
Post by: wattsup on 2014.02.18, 20:45:09
@GK
I forgot to mention another thing based on your last post.
It may be a good idea to wind a few more verticals over what you already have. I would add at least two more verticals.
AWG between 14 and 18 multi-strand.
One of just 4 turns.
One of 10 turns.
They are not wound one over the other but side by side
Then when you do pulsing tests on the toroid/H-ring and find something interesting on your regular verticals, you can then read off the 4 and 10 turn winds as well to make a comparison. If you are getting less then the regular verticals, that would be considered normal but if you are getting more, then at least we will know and can consider breaking up the verticals later on. This too make sure that maybe you get more output on the verticals with shorter winds but all in parallel. The thing is at this stage everything will be discovery and you may need to have these two extra verticals as a base comparison. This will cover much more R&D ground with each test.
Post by: giantkiller on 2014.02.19, 16:42:47
Thanks for the reply. Yep. I knew the flexibility in this latest design would facilitate quick additions.
I will reverse the connections on the B & C toroids. As a side note the A, B, C, D toroid halves are all wound in the same direction. The halves of each toroid are just cut to add the B & D sides instead of them being reverse or opposite wound from A & C.
Another note is: if the two twin lead verticals are running at 2 different frequencies how will the phase shift enact any event? I mean they are out of synchronization to start with. Kapeesh? or νόημα?
100 x 1n34a ordered for $10.00 and on the way.
Post by: wattsup on 2014.02.20, 22:57:05
Quote from: giantkiller on 2014.02.19, 16:42:47
@GK
I think you meant the two H-Rings are running at 2 different frequencies and how will the phase shift enact any event.
The "ideal" situation would be for the two H-rings to run at the same optimal frequency but 180 degrees off phase. That is the ideal where the pulse would hit the top then the bottom then the top and so on, creating enough spin in the vertical copper wire atoms to produce output. Lacking that capability, slightly changing one of the frequencies would create a simulated off phase but it will also create many crossover points or points of cancellation and all that is impossible to know about before actually trying it.
Man I wish my lab set-up was already done and was just working on OU builds right now. I am getting tired of construction and renovating, but am almost there via cutting some things out of the renovation just to speed things up. No fancy walls or anything that would be considered cosmetic. Just sticking to the essentials.
I am putting here four photos of the work so far just to show you what is involved.
Lab1.jpg is a shot taken from my office/lab desk looking through my closet opening to the next room where I will be making the lab. My son loves it because it looks like a secret room. hahaha
Lab2.jpg is a shot inside the new part showing a fresh electric feed on its own breaker in case things get hairy. Also you see a frequency generator there so I can try and figure out the best experimentation table depth and set-up since I would like to have the FGs and scopes visible in videos of experiments. The experimentation table is the one giving me the most grief. I am thinking off maybe having the FGs come out of the table at a slant to save table space and have them as accessible as possible but I am also thinking that this may give fodder to the skeptics thinking I am hiding things under the table so you see the fight I have with my set-up logic.
Lab3.jpg shows the wall I made to section off this part and now covered with shelving.
Lab4.jpg shows my new work bench area where I will be able to make coils and other builds.
So it's all coming together but I still got a ways to to go. The reason I am putting these photos up is because I feel so bad that I am trying to guide you through some testing and stuff without me doing the same on my end. Maybe I should open a new thread called, Building my OU Lab so others could chime in on some recommendations or show what they have as a set-up. I'll see about that.
Post by: giantkiller on 2014.02.22, 00:01:42
My stumbling point is the operational frequency of such low inductance horizontal loops. Right now it looks like quarter wave is 43mhz. Is running at a lower harmonic like 118x slower going to be that detrimental? The freq i see now is 91.8khz. This means that the coils stay on for longer period than their wave length. So is a quarter wave length at a lower harmonic going to suffice? Looks good on paper but...
Post by: wattsup on 2014.02.23, 19:10:35
@GK
Here is a progress photo. hahaha
Decided to put the FGs and scopes on top and at a slant. Put up a main switch and plugs all along the bench. Set-up all my wire types, finally I can actually distinguish what I have on hand. hehehe Still lots more to do but it is taking shape.
Post by: giantkiller on 2014.02.23, 20:48:53
Nice setup!
Post by: wings on 2014.02.25, 13:36:41
 :) I don't find the MEG tread I post here
MEG resurrection ?
http://www.youtube.com/watch?v=no50_5iSr2Y
http://magengltd.webs.com/
Post by: giantkiller on 2014.03.13, 21:13:25
Got cooling fan in today. Can get laptop back on line.
Also have REC circuit on a board. Have to solder parts in place. Have the 4 and 10 windings saddled on. Will post pics. I have two further steps on these additions.
Post by: giantkiller on 2014.03.18, 03:49:56
Radiant Energy Collector circuit soldered and hooked onto middle horizontal loop collector antenna.
11 & 4 turn outer winding on sliding collar. Collar can be moved around to find node.
If I add another 4 turn winding on another collar @ 90 degrees to the left I will have a rendition of Don Smith's large coil.
These were simple additions. Just had to make time and analyze the best way to place onto larger coil to maintain flexibility in configuration.
The REC circuit was placed on a circuit board with extra room for additional circuitry.
One additional circuit will be to add a 74c04 hex inverter/buffer to accommodate an inverted 50% duty cycle at 1Mhz to 20Mhz using channel A as the channel B only goes to 1Mhz.
Next will be to measure the REC output when device fired up.
The schematic is a rendition of a magnetic flip-flop using this current device build.
Post by: wattsup on 2014.03.18, 12:46:07
@GK
Great advance on your build and good thing to keep components as flexible as possible. I was hoping you would.
While you are doing that, I am going to build a simple grid on a 6 inch high thin plywood that I put some wire conduit on each end as a wind guide. On this 26" long board I will wind 4 vertical coils of 6 inches wide each, then put them all in parallel. This will permit me to slide the horizontals under the wind and test to see if there is a specific position that imparts best to the verticals.
If you read my post in the Interesting Reading thread, you may see that the LTPU may in fact be a collection of up to eight individual TPU sections. So being in a circle may not be fully required. But since your build is already done with the top and bottom H-rings already fixed into place, I need to know if this is a detriment as we must ask the question, "should the H-Ring position first be optimized before fixing them in place". You never know. Maybe just a 1/2" higher or lower may make the world of difference. I need to see that myself and report back.
Under the multi-section scenario, if the LTPU produced 800 volts at 1 amp, this means if all eight sections are parallel, each has to produce 800 volts, but if we take our cue from the MTPU cut away where after he cut the pieces he reconnected again and found a lower output voltage, this means not all sections are parallel because if they were, you would have the same voltage but less amperage as output after he re-wired the MTPU cut away.
So this confirms even more that the LTPU may be in 2 sets of 4 sections, (that ties in well when SM didd his hand pantomime of the two sections coming together) each set producing 400 volts at 1 amp then these are put in series to get the 800 volts 1 amp output we have seen in his videos. This would explain why he has two on/off toggle switches to turn the LTPU on. One per 4 section set. Also, two toroids, one per 4 section set. The 4 section set would equal the MTPU that had only one center toroid.
The other observation that is now really bugging me is "Why did he use his magnet around the outer sidewall?" If he had two toggle switches to turn each 4 section on or off, why would he need the magnet.
I don't think the magnet was ever used to turn something on in the LTPU. I think he uses the magnet as his only means of feeling a vibration from each of the eight sections to make sure they are on. If one or two of the eight were not working properly as evidenced by the vibration he feels when he approaches a magnet, he would already know his output will not be full force and stop the demo to fix something without divulging why to his visitors. Imagine if he was testing the output of each section to see why 1 or 2 of them were not working. This would give away to much of the build spec so of course he needed a way to test they are working without creating any situation where he risked divulging the function.
But we all know that if you pulse a copper wound coil on a plastic bobbin, regardless of how you pulse it, you will never feel the pulse if you put a magnet next to the coil, and the magnet will never stick to the coil. You absolutely need a metal core around our inside the coil to then bring your magnet and feel the pulses or to have your magnet stick to in. It will stick to the metal and not the copper.
So this brings up a whole new confirmation that each of the eight sections must have some metal inside for it to create both any vibration felt by the magnet swipe and the ability for SM to stick the magnet on the side wall.
You can appreciate the quandary this presents and also why I am planning this simple test grid where I can vary the H-Ring position plus slide in straight lengths of bailing wire to see their effects as I know the magnet can stick to bailing wire easy.
The magnet can also stick to a 9 vdc battery if the sidewalls were loaded with batteries but that is just responsible me accepting that both types of scenarios are always a possibility.
As another potential observation, in the cut away video, SM first explains that the MTPU in hand did not produce the speculated output and this is his reason for accepting to cut some parts off the unit to show the investors. I don't think SM's character would permit him to make such a move unplanned. It is therefore possible that the cutaway MTPU was specifically made with two sections missing, hence his lower output problem and hence he can then cut out those parts since they are duds. He knew exactly where and why he was cutting those two pieces. He made it look like a random act but I would not be surprised to learn he had planned the whole thing. That's why what we see in the cut away close up is more or less nothing save some wires that were passing through those dud sections to get to the next working section.
More soon enough. hehehe
Post by: giantkiller on 2014.03.18, 18:13:39
I had posted this over the years all over the place:
The 2 paragraphs before [NOT CRACKPOTTY AFTER ALL]
http://amasci.com/tesla/tesceive.html (http://amasci.com/tesla/tesceive.html)
After all, SM stated "Operation like a radio..."
Integrate that with this:
Post by: wattsup on 2014.03.20, 05:30:25
@GK
I had prepared a post but I lost it before posting. So I start again.
That page you referred to, exactly, I agree at the sub heading. We are always reading between the lines.
So maybe slight ac on the center H-Ring might be suitable if this ring is going to be among two other pulsing rings, it will need to transmit to receive. hehehe The good thing is they should all be talking the same language.
Anyways, I will do some tests with this LTPU side wall grid I made to see if H-Ring positions make a difference. I am using 4 types of wire 47 turns each for 6" except the fourth which is 23 turns of Litz 1650 conductors. That's all I had in a one piece.
"Antenna size of a plate" would fit very well inside a 6" by 6" LTPU section. I will try both types shot ones in each section or long ones going through them all.
Basically, if you bring the TPU down to radio, the collector vertical is the big coil, and the top and bottom H-Rings are tickler coils and the center ring is the antenna stick'in its nose smack dad in the action and looking to rejuice the drive end.
For now, I will simply put an LED on each vertical coil since I am not looking for big pulse right now. Just to see some visual of any gain from fishing for resonance frequencies versus positioning. I'd be very happy to see a few LEDs fizz up. That would be a good catch. hahaha
My HP 8116A blew, it was going slowly and now its gone. That makes two of these 50 MHZ units I have that don't work. One shows Error A21 and the other error A31. I'll probably sell them on eBay for the parts, or maybe try to make one working out of the two since the errors are not the same. Hmmmmmm.
I still have one HP 8111A to 20MHZ. Had this one for ages now. Most effects will be in this range anyways. These FG prices have gone up man. I had an HP 214B beast that blew. Cost me $240. Now they are $800 and way more. The 8111As are a grand easy now.
Post by: wattsup on 2014.03.23, 17:22:22
@GK
We all should have just taken a 6" high panel and wound a couple of coil over it to see all the dynamics of this and the ways it can accept impress. I am trying many ways and keeping track to then hone in on the most plausible, plus I am always going back to the LTPU vids for comparison. Saw a few new things, one of concern that I will mention further down.
You know when you have taken a few steps back, sometimes you can get a better perspective always keeping in mind......
1) parts of the side wall can be cut away and will only decrease total output
2) include the canon-to-canon analogy
3) compare to other SM models except the OPTU which I am sure he half tricked with his big lamps.
Picture this.
What would happen if you had 4 or 8 tesla coils. Pulse first primary 1, connect that secondary 1 to the next primary 2, connect that secondary 2 to primary 3, connect that secondary 3 to primary 4 and take output from secondary 4. That's one half of the ltpu. Do the same on the other half and connect both secondary 4 outputs in series.
Now this is not your regular tesla coil producing 25000 volts or more. These are heavier wound Tesla coils that would produce maybe 100 volts per level to get total 800 volts. All DC for it to be additive.
So far, just 2 1/2 turns of a primary wire at the end of one section works well. Also a one turn copper strip primary also worked slightly better. Frequency range was 1,2 MHz.
I put a metal strip on the start of the beige coil, then put that beige coil to the copper strip of the red coil then put a small 4 LED load on that red coil. See below. Happens at 11.7MHZ. So pretty high frequencies. At the 5K levels totally deadsville with my scope but I am not saying there won't be interesting things when driven harder with other ancillaries (hic hic).
I need to start simulating the antenna as well. Just to get some more insight into the limitations to more realistically look at those LTPU winds.
About the magnet swipe, He was using a rather weak Alnico magnet so I did some tests by putting three lengths bailing wire and paper. With just one layer of paper the magnet stick just barely, fold the paper in two and the magnet no longer sticks. Tried it on metal as well and same thing. This means the metal had to be immediately behind the outer cover. If there was a copper wire outer vertical coil there, it would never have stuck. So this is one more head scratcher.
My biggest quandary now is the next photo. When I saw this it was like seeing a Platypus play a banjo. Was not expecting it at all.
What the hell is that. Looks like there is no vertical wind on that part of the LTPU. Just those horizontals that are pretty fat gauge wire that coincides with the MTPU cut away wires that sprang free when he removed the pie.
This could mean back to the drawing board or at least part of that outer wind is made another way.
Probably another look at the ftpu is required to make a link.
Post by: giantkiller on 2014.03.25, 01:50:32
As is shown this version has a split at the middle. More can be added at other circumferal positions.
I had posted years ago the tpus were horizontal Tesla coils connected in series. The discharge head is loop that goes into the next primary by way of going thru the centers of the secondaries. In my case I use iron wire to enable a weak field storage. This facilitates not having to achieve any resonance to attain a field. This is still in regards to the Kunel patent.
Post by: wattsup on 2014.03.28, 13:14:52
@GK
Are you around these days to do a few other tests on your LTPU.
The main point is we might wind up realizing that the verticals cannot work with two pulsing H-rings located inside the verticals at top and bottom because you have a very long wire vertical and that H-ring will be creating so many inversing nodes that energy will just not be able to escape a long wind.
To test this, you would need to put a tap like your center tap but lets say on 10 more to the left and 10 more to the right of that center tap and parallel the 21 taps, tank it and pulse sweep the H-rings while the two other vertical ends are left open. This will give you 21 straight turns to try and get the same mix to move juice short distance but with greater amperage. From my own tests on my LTPU board, the rings on the inside of a fully wound vertical if ever it worked will be working maybe in the 200 or more MHZ range and output will be highly reactive. It would be impractical to count on that to produce the desired effect.
But I have done some testing with my FTPU mock up and now really see how the TPUs were built or the closest match since this works for all of them except the OTPU which I am not considering as a viable example.
I did a big post for you that wound up being much to complicated but I thought it will be better to make a youtube and show you exactly first then post what I think you need to do with your LTPU. I think this will be a great boon to advance our understanding. So I made the youtube and it is here. We' ll see if the power to be decide to remove it. hahaha
Understanding the SM TPU #1
https://www.youtube.com/watch?v=9chncFlT3KQ
Tesla made many patents and he never said to not put them all together, hehehe. There is the ozone patent that teaches damped inductive discharge, radiant energy method for but who said you can only use a plate in the air, Tesla coil to ramp it up and the world of parallel and series to mix it up. Pulsed side, coupling return side plus  radiant return side. DC with slight hash. All Litz "Wire is very important". I don't think regular wire will cut it.
Gotta leave for work and am jamming on Saturday, so maybe tonight I'll post you some written info's.
It's been such long six months with the Garage and New Lab and all, just need to unwind. hehehe
I think I'll start a jam on the TPU.
Wizzing,  wizzing were will it take me.
Pulsing, pulsing gain and control.
Post by: wattsup on 2014.04.04, 12:26:23
@GK
Son of a gun. I did something last night with my FTPU on the bench and I am trying to recreate it but no luck till now.  Shit I am sure I saw the kick action and will try again tonight. I won't get into the details because it would take one complete page.
I think by now you have realized that your build will not work with the verticals winds going over the two H-rings. It will be very difficult to produce the perfect nodal impress on those verticals to create a fluent and directional energy transfer. Let's say you have 300 winds of the verticals with two H-Rings (top-bottom) that makes 600 nodes to coordinate but actually it makes 1200 nodes because the vertical is hit on both sides. It won't work and will just create loading, cancellation and very little output.
So what I foresee is some changes to your build that I can explain if you want, but if you keep your unit as is, try this type of testing.
1) Use your FG as follows, Connect to one of the top H-rings, at half bring it down to one of the bottom H-rings and continue in the same direction then out. So the FG  will be on one half ring top and other half ring bottom.
2) Then you can experiment by connecting the verticals and the free H-Ring (top/bottom) all in series in all the ways you can think of, full circle, half circle then change level, etc, etc., until with all the verticals and free H-Ring you are left with two free wires that you will tank.
Forget the toroid for now. Just try this in as many ways as you can until you find a connection method that will start a kicking action. When you set the FG at an interesting frequency, leave it there for a good 2-3 minutes because at this learning stage it may take time for the kick to show up.
I was brainstorming on that kick and realized that the kick cannot be produced by all the TPU but only in part of the TPU configuration so I went and started to work again only with the rings and outer winds on my FTPU.
Then I saw this post I made long ago.....hehehe.
http://www.overunity.com/8141/steven-marks-secret/msg213907/#msg213907
Your main challenge is to make it work with your vertical covering both H-rings as mentioned above. That will be the Achilles heel of your present build.
You see, in the SM videos we do see on the top of the ring that there is wire there that is wound vertically yes but we never see those wires on the side wall. That means the verticals are like on my FTPU. Each H-ring has its own vertical wind so there is only one ring pulsing inside the verticals so that the nodal cancellation cannot occur. The other H-ring in the ring pair is used to pass what the verticals have collected back through the center of that set.
This is very similar to ottos' 20 turns with wire going through except that what was missing in ottos' idea  is the extra wire going through that creates the seed pulse. hehehe
The ideal method that I will have to try again to build another FTPU with two ring levels, each level having one of two turns, and one of one turn making three turns. The two turns carries the pulse, the one turn goes in series with the verticals. The ring that carries the seed pulse needs two turns to at least have one complete turn active. The other of only one turn does not need two turns because it is just reseeding the ring area.
Basically the TPu is a set of complimentary winds and rings that are in series, one feeding the other then put in a loop to output via a tank.
More to come during this weekend. When I get the kick again I will stop and make a video.
Title: Re: The final answer...
Post by: giantkiller on 2014.04.08, 17:11:33
 http://www.dxzone.com/dx3676/magnetic-loop-antenna.html  (http://www.dxzone.com/dx3676/magnetic-loop-antenna.html)
Post by: giantkiller on 2014.04.09, 04:13:30
@Wattsup,
If this is too small I can make a larger loop type build. My suspicion is this here has too many windings per horizontal.
The low turn count of the verticals on my horizontals match up with the loops you have in the youtube. This configuration has appeared very few times. The OU-ers never took ahold of this.
http://www.youtube.com/watch?v=9chncFlT3KQ (http://www.youtube.com/watch?v=9chncFlT3KQ)
Post by: wattsup on 2014.04.10, 12:46:43
@GK
I'll answer your PM and post tonight when I get back from work. Just a small note for now....
While you have this small build GK-STPU, try to find another plastic tube of smaller diameter onto which you wind a Tesla Secondary (TS) (horizontal wound) that can slip inside your tpu. Thin insulated wire will be best as this will be a center pick up coil (analog of my center coil in my video but more directly related to a possible TS inside a 6TPU) and if possible put a center tap so you can test bifilar or parallel of two halves.  The other testing possibility with your STPU for LTPU analoging is to make four small bifilar pan cakes in the center as output and just pulse them outer rings. If the pancakes can produce a nice enough capacitor coil, they could be discharged back into the source for looping. So far there are three energies involved and present in the rings and the center Tesla to play around with in looping schemes.
In the FTPU rings, there may be a relationship with the Otto mobius. My past tests of the mobius showed that the applied frequency and the produced frequency are not the same as the mobius has a tendency to create a runaway condition where if you apply let's say 5kHz or 6kHz the actual frequency generated is in the 100 MHz, above the capability of my scope to freeze the waveform as it is just overlaying itself. This may be a desired effect in the rings under a mobius scheme and may also be the reason why SM related to the "inherent frequency" as 5 or 6 kHz. Yes it can be 5 or 6 but as inherent but the produced "working frequency" could be in the MHz level were I have seen all the effects of the FTPU.
It is only these days that I realize all those years of experimenting enable us to consider so many effects in order to try and find the common denominator in all the TPUs.
I am doing some ring side tests to figure out the relation between the rings. So I put an outer wind on a 3/8" polytube and this permits me to change the wires inside the tube as testing may require. (see image below)
Post by: wattsup on 2014.04.11, 13:10:57
@GK (or other OU brainers)
Thanks for your PMs, I understand what you are saying.
Let's play brain drain for a second here.  Do you have any comment on these side observations/questions.
On the LTPU the two black caps had a bleed resistor across each of them. If those caps were used to stabilize the final output of 800 vdc, do the resistors on the caps mean that the LTPU had to produce even more output to overcome the constant bleeding on those caps. How can that be possible as an OU device to waste energy in bleed resistors? What is the advantage?
OK, then in the FTPU, SM starts the device by placing his magnet (probably reed switch on/off control) then when he removes the magnet the 62 vdc starts falling in 0.1 volt increments. If the capacitor was dioded, this should not happen unless he had a small bleed resistor on that capacitor as well, otherwise what is consuming 0.1 volts to decrease the output.
I have been taking a much closer look at the SM FTPU video again and again. The more I look and figure out the wire scheme, the more it is becoming easier to see the whole device.
There is one thing though that is really confusing me about the FTPU. Why is the FTPU toroid so difficult to see the winding in the video?  See image below.
When you look at the  LTPU toroids, the windings are well defined as I have already mapped those a long time ago. You already know that and I trust that LTPU toroid is well etched in our minds so no need to post it again. But the FTPU toroid definitely does not have the same windings. There are what seems to be a pair of finely wound wire and one set of courser wound wire on the FTPU toroid. See the image below. If the windings were exactly like in the LTPU we would not be seeing this image but a well defined winding even if the image quality is the shits.
Is it possible that in the FTPU SM needed finer and more winds on the toroid to feed some inductance into the system. He used it again in the OTPU since the systems where very close match. But in the SM STPU or 6TPU, there is no room for that size of a toroid so he must have found another smaller toroid or even a standard high inductance transformer that he fit inside the wall, or, maybe he simply used  lot's of wire to create an inductance.
So what we need to know is if I have a transformer primary with an decent inductance of let's say 250mH, how much standard wire would be required to produce the same thing? Could this be a reason SM may have wound outer full height verticals because we know the ring to full verticals impress will be way to difficult to achieve, he may have been using them for simple added inductance. Maybe I would ask you to measure the inductance of the vertical winds in your GK STPU to see if they could be used as a such a source.
Post by: giantkiller on 2014.04.12, 00:36:18
I need to know if all members can see this post.
The center toroids are Tesla coils and or Don Smith cart coil.
Attached pic is a looped shortwave antenna. The same winding exists on the SM-ftpu outer edge.
Post by: Grumpy on 2014.04.12, 03:59:10
Quote from: giantkiller on 2014.04.12, 00:36:18
What's inside the SM-ftpu coils, under the coil that you show here?
I never had any faith in Don Smith, but I would buy a car from him, and get a good deal too, or least think that I did.
Post by: giantkiller on 2014.04.12, 04:18:28
I am only going by the type of wire gauge and windings that are shown. Anytime there is a fine gauge secondary and low gauge primary I see a Tesla or high step up transformer.
Glad you could see my posts. This probably means all members can. Thanks.
Post by: giantkiller on 2014.04.28, 19:45:29
The last build pic that i posted looks like a looped CB antenna. Going down this route opens a whole new paradigm.
Post by: giantkiller on 2014.04.28, 23:10:09
 http://www.techlib.com/electronics/spherics.htm  (http://www.techlib.com/electronics/spherics.htm)
Post by: giantkiller on 2014.04.29, 21:01:46
The LTPU has 2 potentiometers.
http://www.youtube.com/watch?v=w1eE13UXAKs (http://www.youtube.com/watch?v=w1eE13UXAKs)
Post by: wattsup on 2014.04.29, 23:30:10
Quote from: giantkiller on 2014.04.28, 19:45:29
You will notice that if you pulse through the ring of one or two turns before it goes in series to another coil, the pulse will multiply and overlay onto itself. That is pretty incredible just by using rings. It will be near impossible to catch a steady waveform on the scope because of the overlaying is so tight.
@GK I will be back to that soon as I finish some experiments with the Akula device since it is considered OU and there are some good cues to go by once you remove all the fat and keep to the basic principle. Maybe such a principle could be used in the TPU but I will let you know more soon enough.
Post by: giantkiller on 2014.04.30, 03:07:23
The shortest cycle I can achieve is 10ns which equals  9.8357 feet. This is 4.91785 feet of on time @ 50% duty cylce = .1 gigahertz.
Post by: wattsup on 2014.04.30, 13:45:04
@GK
Please take a read of this post;
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg400521/#msg400521
Makes sense to me.
Let's say you have two rings A and C onto which you wind over each one (not over both) two outer coils B over A and D over C. You will have two ring/coils as follows.....
A = Ring
B = Coil over A
C = Ring
D = Coil over C
I already know that if you pulse A, the incredible thing is B will pick up almost all of the energy from A when pulsed at the right frequency because the coupling becomes so efficient.
But in this case let's say the lengths of the rings A and C are slightly different. Also, coil B has a length that is sensitive to the pulsing of ring C, and coil D has a length that is sensitive to the pulsing of ring A.
This type of cross coupling would be very difficult to accomplish and would required some time to perfect via trial and error before an effect pattern is realized but the resulting effect would be as follows.
Ring A pulses, imparts directly (skin-to-skin) to B and the A pulse also resonates D.
Ring C pulses, imparts directly (skin-to-skin) to D and the C pulse also resonates B.
Each ring pulses to its cover coil and also resonates the cover coil of the other ring. The energy imparted from the rings to the coils would be double (or near) and this could explain the output as DC with slight hash and it could also explain the canon effect.
Taking it a step further, at the same time, we know that when using a small ring antenna, an applied pulse will increase the antennas strength so maybe with that increase in sensitivity, it can pick up pulses also produced from the toroid itself. If the toroid was not a ferrite type core, then the toroid pulses could increase with gain that impart to the rings that impart to the coils that feed back more to the toroid in a loop.
But any increase in impulse gain would need to always be kept at the same frequencies so as all the outer coils increase in output, they provide more to the two toroid coils that impart more to the rings to pulse with, but always keeping the same frequency. Maybe an inherent frequency of 5-6KHZ. hahaha
This would also explain in the FTPU why SM had such lazy winds of rings and coils because it is not a question of coil turns but more a question of wire length and not circumference or ring diameter. The mutual sympathetic frequency would change with differing wire lengths hence differing circumference.
Then the pulse frequency could not be controlled by the time required to fill a particular load capacitor since at increasing gain, filling the capacitor would take less and less time thus changing the pulse frequency. This is why it would require the output capacitor to be isolated from the pulse capacitor(s) (or other timing system). Larger holding tank feeding smaller pulse caps.
Just more food for thought. The actual mechanics of this could vary from the above description but it does provide another angle for testing. I think more and more we need to look at the interplay of effects leading to a loop condition. The more we look at it this way, the more we will be able to play around and find the desired effect.
But imagine if such a simple method could function with gain, then making TPUs would be so easy and cost peanuts to produce all over the world, with low level technical skills. Some wire, a toroid core and few components and bingo, the loop is set and running. This would be a perfect simple system that would have the main required criteria, easy tech to pass on to others.
Post by: wattsup on 2014.04.30, 20:18:45
@GK
Off topic - You have to take a look at these beauties. I just flipped when I saw these pancake coils which are used for wireless charging. Expensive though.
http://www.digikey.ca/product-search/en/inductors-coils-chokes/wireless-charging-coils/197928
Just put your cursor on the images to blow them up.
Added: Notice the wire type. hahaha
I guess the guy making them spent a pretty penny getting to standardize these with the best wire type possible.
Post by: giantkiller on 2014.04.30, 20:53:17
Nice...
http://media.digikey.com/Photos/TDK%20Photos/TMX-66-2M7.JPG (http://media.digikey.com/Photos/TDK%20Photos/TMX-66-2M7.JPG)
Post by: giantkiller on 2014.04.30, 21:49:49
http://themindunleashed.org/2014/04/soon-censored-korean-scientists-successfully-kill-cancer-magnets.html (http://themindunleashed.org/2014/04/soon-censored-korean-scientists-successfully-kill-cancer-magnets.html)
Post by: giantkiller on 2014.05.01, 04:34:41
I will fix the winding spacing at 1-1/8"
Post by: giantkiller on 2014.05.09, 04:05:31
http://www.youtube.com/watch?v=6R20LUD3oIs&feature=youtu.be (http://www.youtube.com/watch?v=6R20LUD3oIs&feature=youtu.be)
Post by: giantkiller on 2014.05.16, 04:04:39
http://www.youtube.com/watch?v=Bj0U7qvmtjA&feature=youtu.be (http://www.youtube.com/watch?v=Bj0U7qvmtjA&feature=youtu.be)
Post by: giantkiller on 2014.05.16, 04:24:48
http://www.youtube.com/watch?v=4VWWCuYoMB8&feature=youtu.be (http://www.youtube.com/watch?v=4VWWCuYoMB8&feature=youtu.be)
Post by: wattsup on 2014.05.17, 14:11:58
@GK
Sorry for late reply. Fantastic that you see this. The coupling from an already coupled vertical. Not bad at all. The efficiency is crazy.
But it is not only that. The pulsed ring also imparts to the other ring as well. Then when you put a distance between the top and bottom that whole area inside the rings becomes delineated for even more coupling.
Also, I am using the plastic tube to enable changing out the ring conductors to try other types but in general the VCoil is wound right over the Hrings so in practical terms, the real coupling will be much better then what you see now.
So now you have this as a baseline.
Next, maybe consider putting the Hrings (top and bottom in various mobius modes - there are several) and keep checking the VCoils as you are. Those verticals should show much higher frequency (maybe higher then your scope will go) and higher vpp. lol
The idea is to produce a multiple of effects from that one pulse medium and it will all depend on how the frequency imparts to the others.
As an example, the way I see the FTPU.... Hrings pulse to the toroid resonance, the toroid starts a directional flow "spin" and the toroid is in series with the VCoils that are also being fed by the Hrings. So the Hrings feed the resonance frequency of the toroid halves and the halves are in series with the VCoils. That would be a plausible usage. There is a load capacitor inline somewhere in there and a diode (1n5819, 1n5817 or UF104 are always winners) or if the output point is sine waved, then make a full bridge rectifier with one of the diode types mentioned or use 4 similar fast diodes you may have. Don't use those ready made pre-cast FWBRs. They are just junk when it comes to resonance work.
It has to be played with through the variables and polarities (no free lunch - hahaha). Two toroid halves, two Hrings and two VCoils plus I am sure there was a Tesla secondary but most likely two at half height each under the toroid around the center of the spool between the top and bottom rings. The FTPU produced only 68 or so volts. Forget amperage for now since the FTPU only showed voltage because that's all he could show in such a small device.  He could not light a bulb with it otherwise he would have put it on the FTPU demo for sure instead of just showing a voltage reading.
I think SM, during his own experimentation to develop the TPU must have also used a simple coil tuning rule. He had to require some basic rules to keep track of his experimentation parameters. As an example in the FTPU there may be a relationship between the length of wire in each toroid half and the length of wire in each VCoil. If these two are nearly the same lengths (FTPU) or a multiple like they may be in the other TPUs, then when the Hring pulses to the resonance of the toroid half, it will also be near the resonance (or sub-resonance) of the Vcoils. Hope I am not confusing you (too much).
This is all based on simple tests, theory and observation but could always be totally left field from actual SM workings but at least it is in a plausible direction. We cannot ask for more then that at this stage. The main idea is to always keep a multi-effect viewpoint. We want more activity from the same pulse. This is not simple pri/sec that we see all over the place. No core to lock everything up. The action is between the wires, the attracted ether fields, their resonances and trying configurations that will favour a combining effect of all of these to produce bigger kicks.
I'll be back soon enough. I just wanted to take another day or so to try some more experiments with my Akula stuff just to be complete and see if I can learn at least one damn thing with this guys set-up after endless hours on the bench with dead ends or standard results.
So we keep moving forward.
Post by: giantkiller on 2014.05.18, 01:58:38
One thing: the wire length of the toroid could not be the same length as the rim in the ftpu or could be a harmonic length.
Post by: giantkiller on 2014.05.18, 19:34:54
Arg... The wire lengths in my toroids are 9 feet 6 inches and in the Vcoils are 5 feet 8 inches.
Post by: giantkiller on 2014.05.19, 18:05:55
The configuration i currently came up with is reticent of the stun gun circuit. I posted this before because it makes so much sense. It this ckt, instead of using a ferrous core it uses an air resonant core. The vcoils have already shown activity. The RE circuit attached shows 2 volts at times.
Post by: giantkiller on 2014.05.20, 21:09:58
Another circuit upload attempt on android phone
Post by: giantkiller on 2014.05.23, 04:13:32
This a test using a variation of the previous post ckt. Only I have both Hrings in the one circuit path in series and the Vcoils are connected in series to the scope and not used as feedback at the moment.
http://www.youtube.com/watch?v=JZoDym1hEq4&feature=youtu.be (http://www.youtube.com/watch?v=JZoDym1hEq4&feature=youtu.be)
Post by: giantkiller on 2014.05.30, 02:21:27
http://www.youtube.com/watch?v=Cf63-qjWYKQ&list=UUasw7-7Lz9H9cwozzAhrmYQ (http://www.youtube.com/watch?v=Cf63-qjWYKQ&list=UUasw7-7Lz9H9cwozzAhrmYQ)
Post by: giantkiller on 2014.06.04, 20:34:02
I wanted to capture and keep this statement.
IT IS where the next step of my endeavor is.
Quote from: WaveWatcher on 2014.06.04, 16:44:19
I had forgotten about gimmick loops & caps  O0
Some FYI...
1. 'Alterations', in this case, may be referring to the method to introduce phase shift between each conductor of the bifilar windings. Controlling this with gimmick caps would work but trimming one of the conductors also works. Of course, none of this makes sense to most as making a low turn count coil resonant at low frequencies is impossible unless you use huge capacitance. Unfortunately, when you use a capacitor and coil with good performance in-mind the impedance of the cap and inductor should balance at the intended freek. (I know the books say otherwise but they are wrong.)
2. There are ways to make a single or two turn loop have an electrical length magnitudes larger than the actual circumference/length. Some of the text makes me think he knows about this (also not found in the 'books' according to my searches but the method was used to lower the operating frequency of loop antennas in the early part of the last century).
Post by: giantkiller on 2014.06.21, 20:09:48
http://www.youtube.com/watch?v=Y1xDVzQFrnU&feature=youtu.be (http://www.overunityresearch.com/ttp://www.youtube.com/watch?v=Y1xDVzQFrnU&feature=youtu.be)
Post by: wattsup on 2014.07.12, 16:28:04
@GK @GK @GK
Hope things are going OK with you and your family and your works. Regarding your last two posts around June 21st and I have not yet responded and am very sorry for that.
I am so damn mixed up these last few weeks. I have been doing side experiments in other angles as well as continuing looking at SM stuff, trying to balance the importance of my new perspective of electricity (Ether Impress, Spin Conveyance) and advancing that, and the importance of figuring out the SMTPUs, but the more I advance, the more I realize SM was a real joker.
I have gone all the way back to step one of SM devices, re-looking again, re-reading his letters to @Mannix, re-looking at the vids, thinking about the SM tirade when he called Jack Durban, thinking about all the posts I have done on SM devices, all the sleuthing, all the possible ways I put up that SM could have faked his demos and taking all the flack for that, all the freebie baseless comments SM made that amount to nothing more then a second rate TV technician pretending to be on top of the OU world. My local tech guy is best TV technician anyone could ask for, but you know something, when I talk to him about OU experiments his technical prowess starts to dwindle, his explanations are so SMish that it is really freaky.
The chances that after all the documentation and vids available on the SMTPUs, all the comments by SM, when you put this all on the wall it is like a complete jungle of information but in this particular jungle you can find not one shred of life. How is it possible that a jungle full of docs can amount to nothing. Zero, nadda, zilch. After all this, after all the  guys that have worked parallel to us on the TPUs, after all these years of SM silence, and especially after all I have learned about electricity and how it really works, I can only derive one possible explanation for the SMTPUs.
They were all a fake. SM does not have, never did have and never will have the logic, technical patience, technical knowledge as well as the humanitarian instinct to produce a truly working SMTPU. His orientation was 100% trickery, and his TPUs simply display his ability to build anything without any precision is shown in his devices that are all half-hazardously concocted widgets.
I have not come to this conclusion lightly or by chance or only after 1 minute of consideration. I think I have paid my dues concerning the SM conundrum and so have you and so have many others. Any one of us, even myself, could quash SM on any work bench because we have been involved in the real effort, the real intent, the real learning curves, the real and varied experimentations and have all accumulated a vast knowledge base of cause and effect. We have actually done the work and all of us have never lied, overstated results, faked results, faked devices (except EM who really brought the 6TPU point home at the time).
This is really not an easy post for me because I know the amount of effort all of us have invested in SM and I also know that as fully responsible and honest OUers, we all accept the fact that while we do all this, there is this main portion in the back of our minds that says SM could have been a total fake and despite all those internal qualms, we all continued onwards. How is it possible that after all the docs SM put out that it all amounts to nothing. How can it be that when SM says something or gives an analogy that it all amounts to nothing. Nothing concrete has ever been had by his information. NOTHING. We all know that only nothing can come from nothing. If all his info produces nothing, then it has to be derived that the source information was nothing, The guy was a fake. Nothing on our benches can prove otherwise and has been proving this since day one. It is only our own, call it "senseless hard headed and high degree of stamina" that has pushed all of this to the limits, and at this point, not even a smidgen of workable results could be tabled to directly attribute anything to SM.
The results we have seen are yours, are mine, are others based on our own knowledge base, effort and openness to share with our fellow man. Basically SM was a figurehead that gave nothing and you can read it in his level of proficiency and use of the English language when put into context of that time, that SM was just feeding what we already knew and what was already known in the day. We just could not see it then because we were all taken in by the grand foray of it all, the OU adrenalin circulating in our veins and giving us a TPU high that is very very addictive to any intelligent mind that is looking to help this damn world of ours move on to the next level of existence on this fuck-rock we call home.
We have rationalized everything around us to agree with a lie, many lies, not just SM, but there are so many more that we see re-surging today, all now playing the same SM money model. I won't name them but there are several recent benefactors of our OU community already being conditioned by SM to accept openly, without proof, without any plausible explanation of true function or coiling theory, we see these guys showing us and the world these coils that are one more fabulous then the other. None of them are real man. All these guys that show but do not tell are all frauds and these guys use the same modus operandi with slight variations. It has gotten to the point that we are so blinded by junk that it is hard for the normal OUer to see through all the fog of fakery.
Man, I am so sorry to put this down on a post. I am so sorry to say that we are on the wrong track man. OU is possible but not in the way we are trying right now. Not by following anyone, NOT EVEN TESLA.
Tesla, what a man, what a mind, what an inspiration to all. Tesla took DC, saw how DC motors would burn out their windings and realized there had to be a better way, then conjuring up AC was a stroke of genius that has served us well to this day. But Tesla was limited in his time and we see his inventions as a normal progression from one device to the other always keeping in mind that devices had to be useful to the day. For any normal man, just that one invention of AC should have been enough to offer him a life revolving around that one greatest accomplishment, but no, he continued, he went into many directions always looking to produce something that would better or beat his AC accomplishment. But everything else was a simple progression that did not meet even the heel of the AC mountaintop, but still he was not satisfied. Now why would that be that such a guy with such a list of technical medals, feel unsatisfied. That is one of the questions that I have been haunted by for so long.
It is only during the last few years of my own studies and tests and realizations of all the illogical premises of EE that has given me the answer to why Tesla did not fully enjoy the satisfaction of birthing AC, it is because he knew what the DC problem was but could not put it into words because the standard methods at the time, same as today, did not have the base perspective of electricity to understand exactly why our coils eventually burn up. Tesla invented AC to drive our coils and this did in fact provide the world with a better mouse trap, but he also knew all this was making man rely on the electrical grid more and more, regardless of how efficient our devices have become, our reliance on the grid has not changed and the big brother money model has remained intact. But in general, humanity has not advanced very far from the days of Tesla.
If advancement is only based on the measure at which humanity can overcome a major worldwide calamity, where everything we know today is wiped off the map and no more electric grid, then we have not advanced one bit. Our demise is just as precarious as it was 150 years ago, probably even worst because at least then society was already geared around the natural forces. Overunity is not only the answer to our present needs but it is the only real answer to the survival of man on this spherical cesspool, should it all come tumbling down.
Tesla made AC but he did not know about Half Coil Syndrome (HCS) and how pervasive it is in any coil being driven by DC or AC, The simple fact is AC has the same problems but at least it is swinging the problem from a positive peek to a negative peek and not holding the problem at maximum peek like DC. I know what the answer is now and if Tesla was alive today, I am sure he would agree with me that the solution to increase efficiency is not DC or AC but what I call Dual AC (has nothing to do with 110 to 220). hahaha
I am telling you all this because I really honor all the efforts you have made in your experimentation and honest approach never over embellishing your results, never overstating, always having a positive OU attitude that I think I also have displayed. But for me, at 56 years of age, seeing childhood buddies of mine falling left, right and center to never wake up, realizing my own demise is possible at any instance, realizing that we are in such a fucked up world with so many fucked up people running the controls with so much lies, lies and lies, how can we move forward when you are stuck and sinking in this lobotomizing quicksand we call modernity. We are in so much shit, it is amazing that anyone is still alive on this planet that itself is existing on borrowed time.
So all this is to portray somewhat my present level of anxieties because life has a way of focusing us when the time is right. Do I continue pushing onto the horseless carriage called SM Junction, or, do I drop SM and concentrate on my own present works and start to finalize my drafts on electricity. I wanted to tell you all this because I respect you and if I should decide to move on new works that have no relation to anyone, my time for SM will be resolved. Maybe one day when SM is on his death bed, he will experience some level of compassion for mankind and dish out the truth of his TPUs, but don't hold your breath on that one. Well at least we (or I) can say "I gave it my best shot". Maybe all this is me doing a grand rationalization to release myself from the TPU grip and the promises this would have afforded mankind. But in reality, I am more and more convinced that spending my time on new works will be better then working on a phantom device with no real advance leads. I am now convinced more then ever that Electricity, how it works, why coils never produce OU and how our future devices should be oriented in order to take advantage of the true effect of electricity and not continuously fall into the traps of our wrongly based perspective of electricity, that I have now come to the point that putting this information out there, regardless of how it will be received, is the only thing I should do today. What would you do if you had a choice between SMTPUs and the real bench work and a real workable theory of electricity?
I am just tired of staying on the sidelines. I have a good 20 posts that I never posted in this thread, 100s of posts that I made but never posted in so many other threads, always holding back because the information or perspective would then have to be defended, cross-examined, cross-compared and I am always afraid that I do not have the technical wherewithal to do these perspectives justice.  I am also always self-conscious with a level of fear of maybe steering someone in the wrong direction that could be minutes away from making a grand discovery. I am so conscious of how  a post may affect someone out there to toss out their current works and concentrate on this perspective, always being haunted by being a possible cause of time, effort and money wastage that I have been holding back.
I am sure there are many others like me with these type of concerns, call it a phobia, call it ultra-realism, call it exaggerated compassion, call it whatever, all I know is this is how I feel these days. I feel the great urge to just get out of all forums because reading is one thing but posting these days is very difficult. What if I am wrong? What if I waste someones time. What if I redirect OUers into a dead end? What if someone gets hurt? What if I start this new perspective and before it is all out there, die off leaving a half polished idea that could waste years and years for others to figure out the rest. There are so many what ifs that you can become paralysed with apprehensions.
So, I need a safe place to put this information out there. A place where I will not be bombarded by mindless naysayers who only make a sport of negating everything that is not standard methods. A place where I can invite only those that will advance the cause without being a zombie agreeing mouse-head. A place where I can ask for help where I know I lack the proficiency, math, chemistry, metallurgy, EE, and more, but where I can provide the basic guidance to others to further one mutual and global cause. That place has been quiet since July 3rd, 2011, not a sound has been heard, not a post has been posted, just waiting, now for a tad over three years, I think it is time. There will never be any more time or any better conditions so I have made a decision to leave all forums, migrate to EI and use it as my medium of choice. I will still read the forums but I will only answer, from now on, to post on other forums, via EI. I will also copy some threads to EI to keep things tight.
If I had the bucks, I would spend it all on building a research facility. Instead, with my limited means, I built a garage, to then make a bigger lab for myself in the home. This is done, the lab is open, the works are ongoing so now I think it is really time to move off of SM and onto reality where I feel our true efforts deserve to be oriented.
I'll see you there. I'll start posting there in a few days and we will see where it goes.
Keep well and thanks in advance for ready this post.
PS: Just know that I will always follow your works and post parallel to them at EI and if you want to partake in some new ways, the door will always be open for you.
Post by: forest on 2014.07.12, 19:54:54
Wow! Wattsup..that was ULTRA..long  ;D sorry, but my point of view is different. SM TPU is real one, but much easier probably then you and I think. maybe Tito L.Oracion would describe it the best ,but I think Steven Mark tried hard to let us understood it.
Maybe some day somebody will replicate it and put video on youtube, who knows ?
Post by: giantkiller on 2014.07.12, 20:03:29
@WU and all,
Great post. I feel your pain. I have not been ignoring any of the OU aspects. I have taken on the Tesla mindset of covering it in [you build it in your mind many times before you touch reality]. With that said I have been making strides in the TPU arena. I have found the kick no matter what configuration I attempt. This lets me move forward in what SM had physically built. I am constantly haunted by the stun gun circuit and Tesla coil configurations. SM could not have moved too far from this. SM showed safe huge sparks, EMD showed output, Grumpy harped on resonance and transmission, Wattsup showed physical and electrical configurations.
Now I will state from my view. As can be seen in the attached there is a coil marked vertical winding. I realized this IS a vertical winding because it IS an antenna and it IS modelled after a spiral wound CB antenna. What SM did was create a magnetic flip flop as termed by Allcanadian. The attached schematic shows a view of this. Sm mentioned 5khz. Each side of the TPU operates in single side band. The FE is tuned to the middle peak. The device jogs back and forth to each loop. The bottom loop is reading the top antenna transmission and vice versa.
Now if you notice the coil configuration picture the OSC section is a stun gun driver circuit. In case no one has noticed this lends the ferrite core to be as a chassis and not a standard shaped transformer core. All of Wattsups' site vids and pictures point this out. SM actually put magnets on the device to point this out. Also the beauty of using iron wire enables the device to pull off the magnetic current into electircal current like Leedskalnin's PMH.
SM added really large caps to bring the low inductance loops down to 5kz range tuning.
Also as can be seen in the schematic the circuit described can fit in the area of any TPU. The center toroid coupler also fits nicely.
I spent a month reverse engineering the stun gun circuit following how to tune a Tesla coil by placing dummy loads at all spark gaps. Then the pieces all feel into place.
The vertical winding of only a single layer loop points out the CB antenna, Thanks Wattsup. Nothing folded back on itself.
SM stated radio, the way transfomers work, connecting with the Earth's field, etc. Pretty simple.
But the important secret is the way SM used iron wire to create chassis cores to direct the flux through the units. Pure genius.
When Otto posted that there was no iron in the TPUs he was actually redirecting the viewer to a different configuration other than normal. SM showed this with magnet prestidigitation. He was very slick in getting around the NDAs. In the open TPU the magnet is a keeper across the core top. This acts as a switch. Hehehe.
I installed Falstad's simulator in my webpage to be able to access it at work. Work routers firewall his site for me. Doing this I was to simulate circuit parts to verify my analysis.
So after reading the last post I though I would chime in and update.
Now lets go over board here.
This technology is not allowed because it would stop the flow of money into Arab nations via oil purchases. This would inturn stop the funding of Muslim population into other countries. This would stop the infiltration and growth of Islam around the world.
We don't have time left here. All categories of failure are intersecting into the final scene. In 2009 Israelis vacated the Gaza strip. In Gaza, Hamas can now reach Israel nuclear power generation facilites with their rockets. Hamas doesn't need any fissionable material. Boom.
The Chinese have been caught performing parallel recollaterallization transactions of commodites and precious metals across the globe. This means that they sold paper of commodities to a number of contracts before fulfulling the old contracts. As oil prices rise a shift in global commodity shipments transpires causing contracts to come due out of contract. The house of cards fall as recipients call to collect before commodity prices rise. Total collapse.
The planet Earth is a housing facility much like a petri dish. As the target subject grows it is culled off before any bacteria can permiate. Eventually the culture is overrun with bacteria and the dish is thrown into the fire. This is our near future.
Attached is a series of slides I made concerning the Coronal mass ejection of 2011. It fried Mercury, altered the magnetic signature of Venus, and had we been in that place in orbit Earth would not exist as we know it. We would have been annihilated by microwave energy. It was the largest CME ever recorded.
Large animal colony collapses and die offs. Large radiations releases
Not a bright picture and progressing to the finality in a couple of months. I carry on in daily duties knowing full well that nothing can be done. This nexus of events is foretold in the Bible. Choose to believe or not is up to you. I find that most are unwilling.
In 2012 I tried to tell friends and family members about the debris field entering Earth's orbit in 2014. Typical ignorance. The evidence speaks for itself.
These things always happen. Right...
Post by: giantkiller on 2014.07.14, 05:02:48
In regards to the schematic:
(http://www.overunityresearch.com/index.php?action=dlattach;topic=860.0;attach=14309)
Post by: ion on 2014.07.14, 11:33:38
Nice work, GK....will be interesting to see where it leads.
Post by: giantkiller on 2014.07.15, 03:47:52
we know this for a fact. The large and the open TPU had horizontal loops with vertical windings wrapped around them. On the tpus those vertical windings were not side by side. They were wrapped in the spiral fashion like a CB antenna. I will bias the bifilar loops with dc. This field should encompass the spiral windings. This increases and magnifies the loop's effective aperture.
Post by: giantkiller on 2014.07.19, 04:26:35
http://www.youtube.com/watch?v=nQokx-KAZXI&index=12&list=PLRMAWXyCH-CWQufIqRcXBTypK_mjmNq0u (http://www.youtube.com/watch?v=nQokx-KAZXI&index=12&list=PLRMAWXyCH-CWQufIqRcXBTypK_mjmNq0u)
Post by: ion on 2014.07.19, 13:15:49
Quote from: giantkiller on 2014.07.15, 03:47:52
Regarding the large open TPU's, while true for later of the large devices, not so for this device (photo attached) No vertical windings visible, but magnet swiping required. Note lower left corner of image showing only horizontal loops. If there are vertical windings, they do not cover the horizontal loops. "All encompassing" vertical winds on this large devices came later. Any proposed theory of operation needs to address this.
Post by: giantkiller on 2014.07.19, 16:59:21
@ION, I agree.
I highlighted in yellow the top edge. Looks like spiral wound just like the open tpu.
When you look at the inside you see vertical runs from top to bottom. To me this seems to be the pulled plastic covering. There are no vertical wires from top to bottom.
Now SM swiped and stuck the magnet to the middle horizontal winding I believe to show iron wire.
Post by: giantkiller on 2014.07.27, 06:32:08
http://www.youtube.com/watch?v=JigkIxfM76E&list=PLRMAWXyCH-CWQufIqRcXBTypK_mjmNq0u&index=12http:// (http://www.youtube.com/watch?v=JigkIxfM76E&list=PLRMAWXyCH-CWQufIqRcXBTypK_mjmNq0u&index=12http://)
Post by: giantkiller on 2014.08.02, 22:57:51
Interacitor:
Yep. Right here!
Post by: giantkiller on 2014.10.01, 16:26:20
https://archive.org/stream/onincreasingeffe58macp/onincreasingeffe58macp_djvu.txt (https://archive.org/stream/onincreasingeffe58macp/onincreasingeffe58macp_djvu.txt)
Post by: giantkiller on 2014.10.09, 03:09:00
Early Christmas:
QuoteA floating oscillator wrapped in its own trigger antenna...Isolation coupled to draw power.
Post by: giantkiller on 2014.10.14, 01:47:02
I C T P U
The 3 overlapping windings were in reference to the Armstrong oscillator of the Stun gun circuit.
The reference to the 3 frequencies were in reference to the 3 inductive pathways of the Armstrong oscillator circuit.
We never saw 3 frequencies.
'A new type of inductance' was in regard to the iron wire accepting flux waves at any angle.
In all these years I had yet to see any antenna engineers on this. Why? It has only been clocking and power people.
The Armstrong oscillator creates very symmetrical sine waves. Just the best signals for antennas, transmission, reception.
The TPU is two transformers oscillating in space rocking back and forth in sync out of phase like motioning water out of a tub.
Prototyping a device with a bench supply will never produce anything. This is a noise reception antenna. It has to float. A floating oscillator sings unto itself.
Post by: bte on 2014.10.14, 02:58:51
You're making things too complicated. You have the effect, build upon that, rotate the field manually. 3 coils ala a motor stator. Pulse sequentially.
Post by: Allcanadian on 2014.10.15, 05:24:40
@GK
QuoteThe TPU is two transformers oscillating in space rocking back and forth in sync out of phase like motioning water out of a tub.
I would agree, a long time ago I learned to "ping" circuits when prototyping and most won't get this but I think you will. When we ping a circuit we connect a source then disconnect it, we disconnect it completely and listen for a response. In fact when everyone told me I should not let a circuit float that's the first thing I did, lol, best thing I ever did.
I think the most important thing to remember with circuits is that all energy relates directly to force and all forces relate directly to fields. So is seems obvious to me that if we do not understand fields then we will continually be running in circles chasing smoke and mirrors. I started measuring the fields indirectly with hall effect sensors and electrometers, second best thing I ever did.
Post by: giantkiller on 2017.05.19, 03:14:13
Here's the bomb:
The TPU is a current day technology version of the ark of the covenant. I was expressly told to not pursue it anymore. There is no way to get it to market without a dire cost or changing ongoing world future/history. The weight of unsurpassed and unmet curiosity has weighed heavy on me for the last 3 years. To see something with so much potential go unachieved yet not uncharted is mind wrecking. Things still sit on my bench unattended. I know how Tesla felt now. I will dabble with it.
Let me drop some names here for reference: T.T.Brown, E.V Gray, William Cooper, Stanley Meyers. Steven Mark was pretty slick in his presentations. The visual clues spell out everything. Really. Watch the slight of hand with the magnet swiping. It says more than anything else and tells all, especially the amp meter trick in the middle. Count all the connector lead connections. Surprise, surprise, surprise! The exposure of the cut coils is only a small part of the internal makeup. For instance: Coils were were cut show three wire leads but the LTPU has a magnet stuck to its side. See what I mean? Building the LPTU was an eye opener. Forget the operation and myriad of explanations by those who weren't there.
The reality of everyday was a mere dream of an achiever. They chose to pursue and commit.
Post by: Verpies on 2017.05.19, 21:19:24
Quote from: bte on 2014.10.14, 02:58:51
With the resultant field vector reversal every 180º or without?
Post by: giantkiller on 2017.05.19, 23:23:17
This is but a mere test of understanding. There is no field reversal, per se. The field bubble at each resonant ring is flexed into a compression. Then let go. At the other ring, the pressure is applied to help flex the companion ring into its new forward motion. The device wobbles up and down. The relation between the upper and lower ring is balanced in a resonant companionship. The middle ring catches the oscillations. The rotation is but an expression of the flux direction. It circumvents its own path around each ring, left hand rule.
Don't try to bend the spoon. There is no spoon.
Post by: Allcanadian on 2017.05.26, 20:17:00
Philosopher, Ayn Rand, said. "In reality, there are no contradictions. Things are what they are irrespective as to whether we know it or not. Check your premises." If the term "energy" is only a convenient abstraction, then it does not exist in physical form, and really describes the potential to perform work as a by-product of matter and electromagnetic radiation in perpetual motion, some of the force of which has been diverted through a path where it performs the desired work, as it goes on its merry way through the universe. Every change of form of either matter or radiation involves the "work" which induces the change, or the "work" which is induced by the change. Without work there is no change, but all work is ultimately the product of the universe in perpetual, self-sustaining motion, as a rule and not an exception."
I found this to be a very elegant description. What is energy when everything represents energy in one form or another?. Thus we could simply replace the terms energy and work with the ability to change or transform. We are then left with the notion that nothing is consumed, wasted, created or destroyed if we are to believe the conservation of energy holds true.
Thus the construct of energy simply becomes the ability to have some means of control as to where and how one thing is transformed into something else and how it relates to it's surroundings. When we control the nature of the transform we control the flow of energy. Which always comes back to my favorite question... can anyone describe any place in the known universe devoid of energy?. Well no, nobody can thus this notion of a shortage of energy which cannot be created or destroyed or consumed or wasted is false. How can one be short of something which cannot be destroyed and exists everywhere in everything in the know universe?.
Post by: Allcanadian on 2017.05.31, 18:25:10
QuoteHere's the bomb:
Here's the bomb... if as SM said we understand all the possible field interactions between two single lengths of wire then the solution becomes obvious. Obviously most do not understand or care to understand or they would see the solution.
QuoteThere is no way to get it to market without a dire cost or changing ongoing world future/history.
That's the whole point is it not? ... changing world future/history or were hooped?. You don't get it to market that's a pipe dream you give it away to establish a new norm then compete like everyone else. That's the way a truly free market should operate. The real problem is that supposedly responsible grown men tend to lose their sheet at the prospect of a FE device and start acting stupid. At which point I start thinking what's the problem? ... it's just a machine, nothing more nothing less.
QuoteThe weight of unsurpassed and unmet curiosity has weighed heavy on me for the last 3 years. To see something with so much potential go unachieved yet not uncharted is mind wrecking. Things still sit on my bench unattended. I know how Tesla felt now. I will dabble with it.
I see it a little different ... this technology is as natural as the sun rising and setting or the wind blowing. I don't know most other people on this planet nor do I really care what they think. Their problems are not my problems and progress waits for no man. I stopped making excuses for other people as well as myself a long time ago. You do not need them to succeed my friend you only need you. This is yours for the taking, leave your baggage at the terminal, own it and never look back.
Post by: giantkiller on 2017.06.02, 19:01:38
One side of the TPU.
Post by: giantkiller on 2018.06.12, 20:51:15
What I have seen over the years and experiments is this in a nutshell:
The connecting field of two cabinet magnets has a flux strength value at a given distance. This can be duplicated using two coils. The power needs to be defined to match the gauss value of the magnets. The disrupting opposing gauss value then needs to be matched against the original field strength of the primary magnetic source be it magnets or coils. The secret is in looking at power line harmonics and transmission line reflections. The operator merely needs to pick a harmonic position, kick it lightly and in phase. You wanted to know the TPU secret?
This will cause a pumping operation that will build up in time. Remember SM stated 'too much in phase causes explosions' and 'watch out or you will draw lightning out of the sky'. Think discharge.
Now lets simply change the view point. When SM mentions something in a direction then simply reverse the logic or operation. He was willing to tell us everything but couldn't so he changed the labels and directions. Pretty simple.
Lightning from the sky = discharge from the TPU. Tesla coil, charge pumping.
Rotating magnetic field = the direction of the flux lines and not the moving of them around something. The reflections do that.
Two frequencies in = the resonant base frequency and the kick frequency.
The multiple, multiple, multiple windings around each other = The overlaping flux fields(think magnetic current/ Leedskalnin) that are the base frequency resonant field,  the harmonic itself and the kicker or in phase pulse somewhere in the harmonic overtone. We now have three frequencies.
Forget all the complexities.
Iron wire presents a core with low mass. Why? It is a collector that absorbs all magnetic energy around it from any angle. The wire aspect then turns the magnetic energy into current. The 90 degree coupling law does not apply here. We have an antenna, a core and conductor all in one. Another gold nugget.
Its all about producing destructive power line harmonics from transmission line reflections.
We can have 3 mediums to work with, the weak field from two cabinet magnets, two coils or three like Spherics showed or Otto's ECD, and transmission line reflections.
Transmission line reflections are the same as magnetic fields reconstructing after being broken. Bing, bing, bing. Big clue here!
For the new people, I have gone over this many times over the years. Now every test I do incorporates this. Otherwise you wont see any power. The real simplicity of failure is that our electronics knowledge always implies a ground. The inclusion of this one connection stops all TPU design progress. No grounding and no harmonic dampening equals destructive reflections. SM stated 'You connect ground you lose the operation'. Major insight here. The current design model is to reduce harmonics. This is incorrect. Choose your tank circuits and filters in the range of the harmonics you want to keep and you will destroy components, equipment and body parts without safety precautions. This will happen on your path to thumping. Think transformer vibration.
Go forth and blow shit up.
Post by: Reiyuki on 2018.06.12, 22:53:40
Thank you GK. :) Always nice to get some protips.
So do you generally put a lot of load on your iron-wire coils directly, or do you reflect most of the energy back-and-forth with capacitors and just skim a bit off the top?
Post by: giantkiller on 2018.06.13, 01:23:58
You can take it down to 101% but things peter out.
If you get bursts you know that is way higher than 500% gain. Pretty hard to measure when all hell breaks loose though. But enough tests show the bands of disabling energy, i.e. hot wire to smoldering components. Lighting lights is no real test either as some others have pointed out too.
If you want to take higher percentages above 100% then choose the higher frequency harmonics to pulse. Naturally and obvious. PWM techniques.I have used audio amplifiers too. They show the pressure moving back and forth. But they get hot also. Now the trick in the current tests is keep the temperature down and find the next runtime area. This has taken me away from doing things to step back and view what the failure areas are while devising a better method. The next test has taken me into higher frequencies. This just spatters EMPs all over which I am not aiming for. The nagging claim is Radio shack level purchases. I am using the iron wire as a forward coupling and as the feedback trigger at the moment.
I never leave things setup after these tests. The acrid smell never clears. I am rolling through design after design. Some are great but a small segment of the operation and some time consuming. I like things idiot proof and getting the idiots out of the operation is hard. The tuning seems to shift the failure point from one point to another.The current set up is a mobius wound tanked loops hit with a subdued stun gun. The fuses in the back of the LTPU are spark gaps. The Stun gun supplies the wide high frequency bandwith to the filters and tanks. At this I need to get the pulsing correct. If SM used the stun gun as the ring start and ringing trigger he is a genius.
Getting at the steps correct is one thing. Getting them to play nice together is a whole other effort while you protect your equipment. :o
Post by: giantkiller on 2018.06.13, 17:59:42
The operation across all working devices is the flux disruption and reconnection. And these are all based on the Kunel patent. The base is a flux field in space between two magnetic sources, i.e. weak magnets or coils or a combination of both. Dr. Harold Aspden outlined the field tension of this operation. On page two he also tells of a motor / generator pair. Howard Johnson built this and proved it worked. But then Johnson changed the side by side configuration to a single axle. and things went south. Mueller also built a flux disrupter that he demoed in his back yard. This worked. Nothing came of it except his daughter is doing very well in Canada and is friends with a number of Hollywood stars. I smell money.... SM created the TPU and demoed it. It worked under the view of many people. Then this went south. Magnacoaster made a version of the Kunel. He demoed it. It went south. We have seen numerous motional attempts at this magnet connection. They are frictional. A lot has gone by the wayside.
So what does all this mean? The enemies are friction or losses. Nothing new here...
But there remains the destructive force of reverberation. That reflective energy from harmonic distortion. Bridges, glassware, Tesla's earthquake machine, power transformers, audio equipment, ocean going vessels destroyed by an unwanted(?) resonance. The uncontrolled resonance is the key. Capitalize on the ringing echo of flux density reconnection and there is where one will find the answer to over unity.
SM pointed this out when he said 'Don't ground the device. It wont work'.
A simple tank circuit, just a cap and a coil in parallel will ring when hit by an external stun gun shot. That would be the basic answer but the scope will also see the large amount of noise also. I had to take a leap of faith knowing that the tank was ringing in the noise that obfuscated the scope display. Working in the dark as they say. But the tank ringing is the same as flux reconnection, same as transmission line reflections. Left alone and entropy has its way. Additively spook it at the pre-peak sideband of one of the echo cycles and you send the wave even greater in height. SM stated 'Make the phasing just right and not dead on.' Reverse the emphasis and you see the secret. Not dead on at the peak but in a sideband. How about during a field collapse? SM also stated 'We destroyed hundreds of coils that didn't work.' Let me rephrase that. 'We destroyed hundreds of coils that didn't work anymore.' Because he burned them up in use!
As always statements are backed up: http://www.askamathematician.com/2013/08/q-can-resonance-destroy-anything-is-the-brown-note-possible/ (http://www.askamathematician.com/2013/08/q-can-resonance-destroy-anything-is-the-brown-note-possible/)
SM also gave the analogy of the swing set. I think most OUer's have lost this facet. There are many ways to produce this or see it. With the current set of tests on my LTPU I have surmised that the rheostat is a phase control and the two switches kill the tank circuits.
We want to modify the entropy from a vertical to a long slow horizontal.
Post by: Bob Smith on 2018.06.14, 17:05:42
Quote from: giantkiller on 2018.06.13, 17:59:42
Interesting. Reminds me of Bearden's references to a degenerate semiconductor.
Bob
Post by: Reiyuki on 2018.06.16, 03:59:30
Quote from: giantkillerThe disrupting opposing gauss value then needs to be matched against the original field strength of the primary magnetic source be it magnets or coils. The secret is in looking at power line harmonics and transmission line reflections. The operator merely needs to pick a harmonic position, kick it lightly and in phase.
QuoteThe multiple, multiple, multiple windings around each other = The overlaping flux fields(think magnetic current/ Leedskalnin) that are the base frequency resonant field,  the harmonic itself and the kicker or in phase pulse somewhere in the harmonic overtone. We now have three frequencies.
QuoteThe operation across all working devices is the flux disruption and reconnection. And these are all based on the Kunel patent. The base is a flux field in space between two magnetic sources, i.e. weak magnets or coils or a combination of both. Dr. Harold Aspden outlined the field tension of this operation.
QuoteTransmission line reflections are the same as magnetic fields reconstructing after being broken.
Am I the only one losing sleep pondering over these few lines? C.C C.C ;D ;D    The ramifications are quite staggering and elegant.
No wonder Eric Dollard talks so exhaustively about harmonics and transmission lines.
Post by: szaxx on 2018.06.16, 08:21:20
It's quite an eye opener when you study harmonics and a very poor VSWR in transmission lines. The source voltage seems to get a good kick when those troublesome reflections occur. It can burn the driver if it can't handle the two way flow of energy increasing the voltage it receives from additive reflections due to poor VSWR.
There seems to be a link with the seventh harmonic, if phased correctly it creates a nice voltage spike on top of the fundamental. If this is then studied as a reflection in a poor VSWR set up it becomes more interesting if booted by a cannon one seventh of the fundamentals period before the peak.
I hope my assumptions above are correct, further study of what we have been supplied   may indicate  or dismiss this.
A missing link is the cause of the effective velocity within the rings. This could be component or environmentally derived. I hope the latter as this will help a great deal in comprehending the operational characteristics.
Sleep..., what's that? lol.
Title: Re: The final answer...
Post by: giantkiller on 2018.06.20, 02:54:39
I see a few scabbards are empty and the slashing has begun. Be careful what sails you slash. There are many pirates waiting to run with the TPU booty sundered from the unwary advertiser. I have posted enough gold nuggets to validate my engineering existence. Looks like szaxx any Reiyuki are quite triggered. There will still be the assassinated prairie dog that advertises the booty held. The egotist is the thief not in hiding. I have a long posted history across the globe that substantiates I know what I know. And I know the TPU. But I am not a threat to the status quo because there are no video demonstrations. Oh but there are. I used the time correctly to redundantly promote what SM, Tesla and Dollard have stated. The obvious. I have shown the reader the clues to the new science that the propaganders refuse to understand or admit.
The rogue wave is, my friends, the secret. We create it. O0
Post by: Reiyuki on 2018.06.20, 13:56:56
GiantKiller, the thing that cinched it for me was matching Eric Dollard's versor mathematics on parametric variation and transmission lines with your comment 'Transmission line reflections are the same as magnetic fields reconstructing after being broken.'   I suddenly saw the entire Kunel patent inside a single length of wire. ;D ;D
To synthesize energy:  Discharge a coil while its inductance is falling or a capacitor while its capacitance is falling.  Energy seeks balance and both create a situation where V approaches infinity.  Since EMF results from dV/dT, this can net a larger kick than what you had to put into it.  It's like squeezing on a water balloon while water is shooting out.
In-phase, this harmonic relationship is also equivalent to pushing someone on a swing since magnetic fields are additive and conserved.
From a different perspective, it mimics what occurs in a regular combustion engine.  First the medium is compressed (air), then injecting and catalyzing fuel creates an expanding wave of exhaust gasses.  This reaction would be pitiful in open-air, but since it happens in a region of high compression the reaction goes critical and instantly combusts with a powerful force that slams at the piston.
From another perspective, consider that things like gravity and magnetism are 'free' forces.  There is no 'gravity generator' at the center of the earth making gravity work, and there is no internal generator keeping a permanent magnet magnetized.  If you stick a magnet to the fridge, it will be putting 1lb of force against the fridge, effectively forever.  1lb constant force times eternity equals how much energy now?  The only problem is gating and harnessing this source of energy.  The Kunel patent provides a way to switch the density of objects influenced by this constant magnetic force up and down.  This is a non-linear reaction and if the switching circuit and extraction circuits are efficient enough, it'll get the job done.  Kunel patent, except that switching the field in air is much easier (and faster) than in the core.  Flip it faster than the core can react and recycle everything you can.
Consider the above while reading SM, Don Smith, Floyd 'Sparky' Sweet and Eric Dollard's writings and other posters here and maybe it will click for others too? ;)
Of course, everything I'm posting is armchair theory as I haven't had a chance to properly test these ideas (except the Iron wire thing), so take my words with grains of salt.  But the math and concepts are solid and consistent.
PS: Ferromagnetic wire is amazing to work with but please shield yourself.  Of course you'll probably figure this out on your own once you've wound your first headache generator.
Post by: partzman on 2018.06.20, 14:44:07
Quote from: Reiyuki on 2018.06.20, 13:56:56
This is true as a result of CoE and can be shown with bench experiments to exhibit gain.  The problem is, the energy required to bring about the parametric inductance change equals the gain produced by the change.  At least that has been my experience and I'm certainly open to any suggestions.
Post by: Reiyuki on 2018.06.20, 15:08:35
Quote from: partzman on 2018.06.20, 14:44:07
The energy used to induce the parametric change can also be recycled (as in diode recovery or a tank circuit).
I have had that same problem though (especially with a large core).  It takes a lot of current or thousands of turns to fully saturate some cores.  Saturating in air (or thin iron wire) is much easier.
If solid-state isn't your thing, you can also consider using a rotary system to induce the change in L or C as in the bed1ni machines or the Rotary Electrostatic converter.  Or something new and novel like a vibrator that compresses a series of spongy capacitor plates.
Post by: giantkiller on 2018.06.21, 03:28:46
Tanks and resonance. Do not stray from Tesla.
Post by: Centraflow on 2018.06.21, 11:29:11
Quote from: Reiyuki on 2018.06.20, 15:08:35
Yes I agree with you and still working on this when time permits.
Meanwhile  below is a simplified Janos Vajda paper
Post by: Centraflow on 2018.06.21, 14:17:06
@ PM
The energy required is just a switch plus a LCR circuit. Depending how you connect it you can increase or decrease the charged inductance.
The coils must be wound the same direction on the same core, or it will not work.
If you use an iron core, 3 or more insulated turns, which is also your L2, and wind your L1 over the iron core, like a toroid, you should get some interesting results.
Diagram to follow.
Post by: Centraflow on 2018.06.21, 14:47:46
Diagram.
Top increases inductance and the bottom one decreases inductance on discharge.
Post by: partzman on 2018.06.21, 16:47:44
Quote from: Centraflow on 2018.06.21, 14:47:46
Diagram.
Mike,
Thanks for the info and the schematic.  I will do some bench experiments based on this and will post the results.  I may have some more questions regarding the inductance values but will get started anyway.
regards,
Post by: Centraflow on 2018.06.21, 17:16:38
Quote from: partzman on 2018.06.21, 16:47:44
Mike,
regards,
Hi PM
One thing, the cap across the switch has to be HV. Remember Itsu showed a 500v spike at the drain of his mosfet! a cap will do two things, one it will save the mosfet and two it adds to the tuning of the output.
I have always said in the past, if you really look at this carefully it is a class E output before the diode and should be a sine wave (may have a flat top due to coil saturation).
To bloody hot in my lab atm, 32ºc today.
Post by: giantkiller on 2018.06.21, 18:26:37
The tpu pdf is based on thermal variance. Whats missing is kinetic transference.
Transmission reflections do all the work without the need for amplfication by an implied or inserted circuit.
Its all good but Tesla had no extra amplifiers to read the feedback.
The tpu is a magnetic earth machine. 8)
Post by: Bob Smith on 2018.06.22, 02:07:33
Quote from: giantkiller on 2018.06.21, 18:26:37
GK
I've been thinking back to Eric Dollard and Thomas Brown's Borderlands demo of the separation of magnetism and dielectricity that occurs when their L-C setup reaches resonance (tried to cue it up to where EPD addresses this separation phenomenon here):
https://youtu.be/6BnCUBKgnnc?t=1385
So if magnetism at one end is pulsating at resonance, I'm surmising from what I've read in your posts and infer from others, that the magnetic field (and longtitudinal impulses) is pinging up against the magnetic field of the earth. I would presume that the earth's mag field is going to push back to re-establish equilibrium.
This is where I'm at in trying to get my head around your statement "tpu is a magnetic earth machine".
Kind of like TPU and Earth doing the Cha-Cha-Cha :)
Bob
Post by: Centraflow on 2018.06.22, 09:56:17
No the pdf is based on ALL waves, the electromagnetic is shown, it would also apply to water and ocean waves (how large waves are formed from interference of smaller ones), sound, light and thermal.
SM knew about sound wave interference, that was exactly his forte, he then applied it to electromagnetic as he knew that all waves react the same in destructive or constructive.
Once I had realised the only link between his real work and the TPU, things got clearer. Now it is realising the electronics of the system by substitution of the different magnetic loop configurations and pickup from the same so as to feedback a high current/low voltage to the input capacitor without affecting the performance of the circuit.
IMO, loopback can't be from the output, it has to come isolated from within the circuit, it is a slow buildup and I think that will apply to "all" attempted loopback circuits and why they normally fail.
Post by: ion on 2018.06.22, 15:01:13
QuoteIMO, loopback can't be from the output, it has to come isolated from within the circuit, it is a slow buildup and I think that will apply to "all" attempted loopback circuits and why they normally fail.
It seems you are talking about local regeneration. How would you propose to implement this in your circuit?
Post by: partzman on 2018.06.22, 15:53:47
Mike,
Here is an initial test result of your top schematic shown above which should show an increase in inductance on discharge.  Two tests are shown taken with a 10vdc and 30vdc supply respectively.
The probe IDs are CH1(yel) is gate drive to mosfet switch, CH2(blu) is drain voltage of switching mosfet, CH3(pnk) is output on pin1 side of Schottky diode, CH4(grn) is supply current, and Math(red) is input power consumption.  Not shown is the dc voltage level on C? which is approximately equal to the max level of CH3.
The circuit values used are C1 = 4.07nf, C2 = mosfet output capacitance, L1 = 47.9uH, and L2 = 27.2uH and the frequency is 342kHz which gave the largest peak output voltage on CH3.
I'm not sure what I am supposed to be looking for although I do see a slight change in the rising slope of CH3 at turn off.  Is this the indication of an inductance increase?
Added: The resonant frequency of the CH2 ringing is 3.22MHz.  Considering the parallel inductance of L1 and L2 at 17.33uH, this would equate to an equivalent drain capacitance of 143 pf which is reasonable for the IRF636 mosfet I'm using.
Post by: Centraflow on 2018.06.23, 08:16:45
Hi ION, PM
ION I will get back to you on your question, I want to get PM hopefully in the same area that I am with the changing of inductance in charge and discharge using only a switch (mosfet).
PM, you need to measure the individual inductance of each coil, then measure the inductance of the coils in series. I presume you have wound the L1 and L2 as I have said, L2 is 3 turns of insulated iron  wire (+- 17cm dia: coil),  L1 is a copper wire wound around the L2 like a toroid using L2 as the core. Don't make too many turns, about 20% of the circumference or less and make it so you can move it by sliding around the L2 (not too tight).
Your idea of measuring the drain resonant frequency is good, but you need to put a cap across the source and drain and measure the capacitance.
The combined series inductance of L1 and L2 is not a straight addition, it is a lot more as they are basically two coils in series on a magnetic core and not air coils (that is if you wound them like I have said).
The other thing is to do circuit 1 and test, then change the connections and do to circuit 2, all at the same settings and see the difference.
Back later, getting very hot here, reached 35ºc yesterday.
Great work PM
Post by: partzman on 2018.06.23, 13:16:04
Quote from: Centraflow on 2018.06.23, 08:16:45
Hi ION, PM
Great work PM
Mike,
OK, for my previous post I used an existing coil assembly that I had from previous experiments with the specs- L2(iron) is 8T on 17.2cm diameter with L1(copper) at 282T wound over the top of L2.  L1 = 47.93uH and L2 = 27.16uH.  L1 and L2 in series, aid = 84.05uH and buck = 73.58uH.  I see that I have L1 with too many turns so I will change that and run some more tests.
Post by: Centraflow on 2018.06.23, 14:35:17
Quote from: partzman on 2018.06.23, 13:16:04
Mike,
OK, just curious but is this right what you said before
But L1/L2 in series measure 84.05uH  (type of common core) not 17.33uH!!
It is one reason you need to put a HV cap across the SD of the mosfet and measure the capacitance.
This is quite informative:-
http://www.crarc.ampr.org/uploads/Main/Archives/July%20Class-E%20Transmitters.pdf
Post by: Centraflow on 2018.06.23, 14:57:27
My investigation into the TPU tells me
1.   There is a magnetic core
2.   The core heats up, so eddy currents, the heating problem SM had over time
3.   The core is most probably iron
4.   The core is also a coil or loop which emits magnetic waves
5.   The core vibrates
6.   Excess energy from the magnetic wave reaction around that loop/core (constructive)
7.   The larger TPU's possibly have two ion coils and a second L1 etc which the two circuits are in series to increase power
8.   Loop power comes from a second copper coil wound on the iron loop (high current but low voltage). Takes time to wind up the output
Post by: partzman on 2018.06.23, 16:31:58
Quote from: Centraflow on 2018.06.23, 14:35:17
Yes, this is correct.  Considering the low reactance of C1 at 3.22MHz, this essentially means L1 and L2 are in parallel and therefore calculate to Lp or 17.33uH.  Lp is in series with the drain capacitance of the mosfet and is grounded through the + terminal of the supply  Any added capacitance from the drain to ground will resonate with Lp along with consideration of the reduced reactance of L1.
Edit- Thanks for the Class E amp design article.  O0  I didn't have that one in my file.
Post by: Centraflow on 2018.06.24, 15:50:20
PM
Please do continue with the second circuit, I would like to see what results you come up with!
Post by: partzman on 2018.06.24, 19:54:16
Quote from: Centraflow on 2018.06.24, 15:50:20
PM
Mike,
Here is the 2nd circuit using the same components as in the 1st circuit except I've added a .022uf C2 in one of the tests.  The frequencies are lower for these tests.
The first scope pix is without C2 and the probe id are the same as before.
The last pix is with the .022uf C2 in the circuit from drain to ground.  These waveforms do resemble a class E amp without the output filter.
Post by: partzman on 2018.06.24, 20:17:54
Mike,
This test is with a new coil arrangement where L2 =4.6uH with 3 turns in an 18cm diameter.  L1 = 3.2uH with 62 turns (~20% of L2's circumference) wound over L2 and moved to the positions indicated in the scope pix.  C1 = .022uf and C2 = 6800pf.  With the power supply at 10v dc, the wiring of both L1 and L2 do begin to get warm.
The first scope pix is with L1 positioned near the output of L2.  The next pix is with L1 positioned in the middle of L2 and the last pix is with L1 near the junction of L1 and L2.
Post by: giantkiller on 2018.06.24, 21:51:50
Your circuit is singing. Make it bigger!
Post by: partzman on 2018.06.24, 22:07:19
Quote from: giantkiller on 2018.06.24, 21:51:50
GK,
Could you elaborate on that a little bit more?
PM
Post by: Centraflow on 2018.06.25, 16:18:53
Hi PM
Only seen this today, had visitors all weekend, some interesting results which I need some time to study.
The last test shows that position does not seem to make much difference ATM.
Are you going to do schematic 2 with the new coil setup?
I know all this takes time and I appreciate what you are doing, but I think the results with your equipment are better than mine.
One thing on the last tests you are showing I presume DC mean for CH3 PINK, but it does not seem to equate to the scope shot, or is there something I'm missing?
O0
Post by: partzman on 2018.06.25, 16:30:36
Quote from: Centraflow on 2018.06.25, 16:18:53
Hi PM
O0
Mike,
Yes, the mean value shown on CH3 is the average or dc offset of the output waveform measured at pin1 of the Schottky diode.
I will run the circuit 2 test with the new coil and post the results.
Post by: partzman on 2018.06.25, 16:47:32
Mike,
Here is a test with Circuit 2 running with a 10v dc supply.  Again notice the lower operating frequency verses Circuit 1.  Probe ID's are same as before.
Post by: Centraflow on 2018.06.26, 18:43:15
Quote from: partzman on 2018.06.25, 16:47:32
Mike,
Thanks PM
That is interesting, well I think so.
So we have a step charge of L1+L2 at the parallel LC frequency with C1 when the mosfet is high.
When the mosfet goes low L1 discharges through the diode and L2 and C2 discharge at their LC frequency back to source it seems, hence the negative current oscillation.
Now the discharge to the diode is like a rectified positive pulse with hash. If you could expand that we could see better.
Post by: partzman on 2018.06.28, 12:34:57
Quote from: Centraflow on 2018.06.26, 18:43:15
Thanks PM
Mike,
Sorry to be late in responding but have been taking care of household duties.  I think you may have meant "mosfet gate" in your analysis above because the action you describe is correct.
What would you like to see expanded in the discharge phase of the circuit?
Post by: Reiyuki on 2018.06.28, 14:19:10
Well I have not had much luck with tank circuits yet, but I did get a good handle on 90deg ferromagnetic coupling. ^-^
Several systems of various types and sizes were tested, it should not be hard for anyone here to replicate.  Just wind several turns of insulated Fe/Ni wire in a loop and wind many turns of copper wire over it in a spiral.  Pulse the copper, extract output on the Iron.  Output in these setups is predominantly DC (with a little hash >:-)).
Because of the frequency ranges (~1khz-50khz+) and other factors, it does look to be based on magnetostriction.  This means all flavors of ferromagnetic/paramagnetic metals should work fine.  Nickel battery strip used for chaining LIPO batteries works great.  Just insulate with a layer of Kapton tape before coiling.
https://www.amazon.com/Breynet-18650-Nickel-Welding-Battery/dp/B07CVVZ1Y9
Efficiency is not the best(yet).  I hit a wall at 50-60% efficiency when driving these.  Perhaps I need to let the wire hang more loosely, or add a nickel coating to iron, or maybe add a runner line of copper parallel to the iron wire in order to couple into low-loss copper.  More likely I just need to move on to resonating pairs of these in tank circuits and let the Kunel magic happen.
The neatest feature besides DC output is that within audible frequencies these things literally sing.  Loud.
https://www.youtube.com/watch?v=I2yo-2yFP4g
Post by: Centraflow on 2018.06.28, 15:48:27
Quote from: partzman on 2018.06.28, 12:34:57
Mike,
Hi PM, take your time, my wife and I are a bit under the weather ATM.
The pink trace going to the diode and the mosfet drain.
Have you put a resistor across the output cap to create a load? just wondering what difference there is to the pink trace with and without.
I think we don't quite yet have the iron core/coil right, hence my question about an infinity magnetic current loop on the other thread ;)
Post by: Reiyuki on 2018.06.30, 15:48:35
I'm finally starting to see the different properties for grounded vs ungrounded systems, as it relates to tanks.  Grounded systems simply do not ring as well.  Well, for RC circuits they're fine, but ground seems to snub any radiant/electrostatic impulses.  Too much capacity I reckon. :-\  I suspect that strong HV would overcome that issue, but I've smoked too much equipment to risk diving back into that field quite yet C.C.
Anyway, this has led to a couple questions:
Would it be advantageous to simply float my entire bench (power supply, scope, oscillator, etc) with a large 12v battery bank and an AC sinewave inverter?
or would the battery present so much capacity that you'd lose the benefits of floating?    I do have an off-grid solar rig set up, but relocating it to the lab area would take much effort.
Was looking for some advice before I go break apart and relocate that monstrosity. :P :P
Perhaps it's just better to power devices and oscillators via battery, and use magnetic/dielectric coupling to take indirect scope readings of the tanks?
Post by: partzman on 2018.06.30, 17:53:07
Mike,
OK, I finally got back to the bench and ran the following test on circuit 2 with C1 = .022uf and C2 = 6800pf with the supply at 10v dc.  Probe ID's are same as before with CH3(pnk) alternated between the AC and DC output and CH2(blu) being the supply voltage.  The load resistance used was a non-inductive 50 ohm film resistor which provided the best efficiency at the frequency of 594.1kHz.
Pix 1 shows the output DC voltage of 11.93v mean on CH3 which results in 2.85w output.  The input power seen in the Math channel is 3.865w mean.  Note the gate drive voltage distortion and the high peak current at the mosfet drain.
Pix 2  shows the AC output waveform at pin1 of the Schottky diode on CH3.
The pix 3 Math channel shows the input at 3.069w mean with no load.  The AC output with no load is seen on CH3 .
Post by: Reiyuki on 2018.07.01, 00:40:42
Quote from: partzman on 2018.06.30, 17:53:07
Mike,
Thanks for sharing, Partzman :)
  From your scope-shots it looks like your coils might be ringing closer to 10Mhz, which might be too high to efficiently switch with your setup.  Maybe adding some core material (ferrite/iron/nickel) will help bring that number down, or adding tank caps, or simply scaling the whole thing up to hundreds of turns instead of dozens.
Of course we're about neck-and-neck right now so it's anybody's guess ;D
If you have an LC meter, you can also try measuring the inductance of the copper coil while slowly powering up the iron coil w/ straight DC and slowly increasing the current.  It would give you a good idea how much inductance 'swing' is there, and what your hysteresis curve looks like.
I was thinking about doing this setup instead with a few dozen turns of iron wire, and several hundred turns of copper wire wrapped toroidally around the iron wire core.  That would provide 90deg coupling and make it act more like a mag-amp.
Post by: Centraflow on 2018.07.01, 11:02:35
Mike,
Thank's PM
Yes I did notice, what are you driving the gate with or are you driving straight from the SG (10v)?
Still analysing the  tests so as to alter the circuit accordingly.
mike 8)
Post by: partzman on 2018.07.01, 17:53:39
Quote from: Reiyuki on 2018.07.01, 00:40:42
On this coil arrangement, the inductance change of the copper winding L1 was ~2% with the 3 turn iron winding L2 varied from 0 to 1.5A dc.  The iron wire I'm using is typical bailing wire obtained from a farm supply store.  Very little inductance change.
Post by: partzman on 2018.07.01, 17:58:51
Quote from: Centraflow on 2018.07.01, 11:02:35
Thank's PM
mike 8)
The gate drive is taken from a complementary bipolar half bridge driven by a Cmos 4049 buffer all with a 10v dc supply.  I'm sure the distortion is primarily caused by ground looping in my breadboard layout.  The mosfet used was an IRF14N05L.
Post by: Reiyuki on 2018.07.04, 02:40:42
QuoteOn this coil arrangement, the inductance change of the copper winding L1 was ~2% with the 3 turn iron winding L2 varied from 0 to 1.5A dc.  The iron wire I'm using is typical bailing wire obtained from a farm supply store.  Very little inductance change.
@partzman:
I've had better luck pushing closer to the saturation knee.
Eric Dollard mentions a propagation constant 'Ohm-Siemens' as an energy factor for each verser.  This suggests the amount of change of L or C within each quadrant results in a proportional synthesis/destruction of energy.  2% may simply not be enough to close the loop.
You might try 'paddle wire' used in floral decoration (hobby/craft stores will have it).  Or, insulated garden wire (local hardware stores should have it).  Less core and more turns = easier to saturate.
@GK
Loved your book.  Quite clever and entertaining.
Shields up!  8)
Post by: giantkiller on 2018.08.04, 19:59:35
@ Reiyuki (http://www.overunityresearch.com/index.php?action=profile;u=693) Thanks for the comment about the book. People ask me what its about and I replay "Its a semi true book about a guy who screws with people's minds." That way there is no bias towards sci fi, tech or emo story.
Now...I went to the mountains for 4 days. Didnt bother to tell any one. I was just going to sign a business contract in Salida and BLM camp. No big deal and no Sprint coverage phone service either. I get back into town and stepped into a shat storm of issues. My dad had passed away, my local friends and family could get ahold of me, my distant family was in a complete chaotic mess about my disappearance and my dad's passing, my locals had the 3 day requirement for a missing persons report and were going to file on the 5th day, my laptop died, backups were screwed up and in pieces, taxes were needed to be filed, at home one day and back out the door on a plane for the funeral. All this within a week's time. I hadnt told anybody figuring I would be gone for 4 days. Nobody ever bothers me. I step out of town for few days and the whole world crumbles. Juggling rabid monkeys. All is settled and I am back on board. Just need to redo pieces and parts of my laptops applications. Who would have thought 40 years of I.T. experience would have come in so handy.
But I sidetrack. I posted a comment on the companion wave generator because it is so important. The setup had no circuit to sustain any ringing. The TPUs all apply this to a helical antenna configuration. Now this thread has some pretty interesting comments by Petrae. http://www.overunityresearch.com/index.php?topic=38.msg234#msg234 (http://www.overunityresearch.com/index.php?topic=38.msg234#msg234) In particular about adding magnets to the little transformer. I have been using transformers to increase the length of my helical antennas. The helicals are connected to the primaries and secondaries. I get good ringing returning. The object is to accomplish resonant rise just like in a Tesla coil but with components instead of the ambient capacitance.
Post by: Reiyuki on 2018.08.05, 14:50:59
@GK sorry to hear about all the issues.   Life sure loves to keep us busy.  When I was younger I wouldn't have believed that projects could get sidetracked for months or a year.  Now I do C.C.
Well anyway, I'm quickly realizing that knowing the principles of how an internal combustion engine works is a very different problem from being able to build an engine from scratch.
I still run into issues, but am slowly getting there.  The journey from a conceptual understanding to an engineering one is entertaining.  At least now I have a 'compass' of weird phenomena that I can always return to to keep me oriented.  ...I never thought there would be so much depth and variety and precision in something as simple as a MOSFET.
Thanks again for blowing some more wind into the sails ;D
Post by: giantkiller on 2018.08.05, 19:38:25
Here is what might sound like a stupid statement but MOSFET linear mode operation should be obsolete by the use of Frequency shift keying/ frequency modulation configurations.It happened with audio equipment. Cool runnings at lower cost and longer life runtime.I found this out when building an FSK/FM and a linear mode amplifier. I thought it strange that linear mode has such a strong following. But then it occurred to me it fell upon the geographics of the training which then permeates into careers. With linear mode there is a need for heat sinks and larger current handling mid schematic. With FSK/FM the thermal area is pushed out to the production end of the schematic or operation.In other words we are in the middle of two camps of thought: using current or using frequency.
Post by: Reiyuki on 2018.08.05, 23:26:11
GK, It was more about navigating the internal inductance/capacitance of FETs (and their self-resonance at higher voltages) and discovering that they are nowhere near 'on' until you REALLY start pounding at the gates.  I think my IT history clouded me into thinking 'a switch was basically a switch' even after experiments proved otherwise. C.C
That and being diverted to working on electrotherapy prototypes to help a sick relative (both the Body Electric author's DC setup and a micro Lakovsky MWO.)
Post by: muDped on 2018.08.06, 00:59:55
Quote from: ReiyukiIt was more about navigating the internal inductance/capacitance of
Such is the 'secret' of using MOSFETs as efficient switches.  Of course,
the same was/is true with Bipolar Transistors;  the lowest possible Vce(sat)
for efficient switching requires significant Base drive current with provision
for removal of 'stored charge' to speed up turn-off.  Tricks of the trade.
Post by: giantkiller on 2018.08.06, 05:26:45
QuoteStanding waves are only
present when the line is mismatched.
Does Higher SWR Lead to Lower
Power Being Transmitted?
Not always so dramatically. Believe it or
not, 100 percent of the power is actually transmitted
in both of the previous examples. In the
first case, with a 50 Ω antenna, it's easy to see
how all the power is transferred to the antenna
to be radiated since there are no reflections.
In the second case, the 33 percent voltage
reflection travels back down to the transmitter
where it doesn't stop but is re-reflected from
the transmitter back toward the antenna along
with the forward wave. The energy bounces
back and forth inside the cable until it's all
radiated by the antenna for a lossless transmission
line. An important point to realize
is that with extremely low loss transmission
line, no matter what the SWR, most of the
power can get delivered to the antenna.
Post by: ion on 2018.08.06, 14:12:19
Quote from: giantkiller on 2018.08.06, 05:26:45
Re reply 166. Please provide citations when quoting.
Post by: giantkiller on 2018.08.06, 16:30:13
Quote from: ion on 2018.08.06, 14:12:19
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=2ahUKEwiPvNWswNfcAhXi7oMKHQNuDnMQFjAKegQICRAC&url=https%3A%2F%2Fwww.arrl.org%2Ffiles%2Ffile%2FTechnology%2Ftis%2Finfo%2Fpdf%2Fq1106037.pdf&usg=AOvVaw3UXQaeDbAlSg1tPOEUuz0Z (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=2ahUKEwiPvNWswNfcAhXi7oMKHQNuDnMQFjAKegQICRAC&url=https%3A%2F%2Fwww.arrl.org%2Ffiles%2Ffile%2FTechnology%2Ftis%2Finfo%2Fpdf%2Fq1106037.pdf&usg=AOvVaw3UXQaeDbAlSg1tPOEUuz0Z)
Post by: ion on 2018.08.06, 18:08:03
Quote from: giantkiller on 2018.08.06, 16:30:13
GK thanks for the link and pdf, that is a good paper  O0
Post by: giantkiller on 2018.08.07, 16:54:36
Here is a concept video to show the standing wave where the timing is just a bit off so the wave scrolls past the center toroids.
I use the term 'concept' here loosely because any tests with a ring transformer have produced this.
No Spherics ties validated.
He was involved with nuclear sciences in some way because of the things he articulated.
He posted a picture a nuclear bomb setup at Alamogordo, NM and waited for responses.
I posted I was interested in the coax running all over the bomb itself. He asked me why is this so?
I restated controlled, eclipsing frequencies during the ECD build time. He posted a smiley emoji and I never heard from him again nor did anybody else.
I guess he was satisfied with the seeds he planted. Too bad too. He was a sharp cookie.
From what I can remember is after he communicated with Lindsay he never much communicated with others too much after that. I don't feel too special about his individual response to me for he might have talked with others in their own way too. I was too involved mentally with the addiction to the TPU and found myself getting spread too thin. And that is why to this day I harp on mixing frequencies.
Now it might not be the actually mixing of frequencies that do it but the awareness made of the frequencies themselves and the other parameters of them that he tried to get us to focus on.
Transmission reflections and power distribution failures were my final outcome.
Tesla did this on purpose with his earthquake machine and I associated this magnetically to the TPU.
SM mentioned Radio shack. 555s were available along with lm324s and FETs. As I looked back I always felt like a kid in candy store after that. By paralleling two 555s with a wire length delay between them we can achieve a very high speed switching scheme.
I believe SM was very truthful in a very obscuring way about the TPU. Anybody else that came along with insights that had been involved with D.O.D. technology was not at liberty to teach anybody outright. I believe Spherics to be one of these types.
The other piece of the puzzle was Radio shack did not sell fet drivers as these were way too expensive for their retail model.
As SM was in audio he came from the FET linear operating range. When he switched FETs off and on digitally he must have heard or seen large speakers bust up a room by the high power clicking.
He was in the audio history where the industry change was happening where FET operation went from ac linear to dc frequency scheme of audio transmission.
And each revelation brought ten fold more on.
One of the conspiracy theories is blaming the Rothschilds and Rockefellers for changing the tonal range of public audio frequencies from Solfeggio to Intonation. Nothing really hidden. Solfegios transmitted with power over copper would decimate the analog electronics at the time. Tubes would have busted because of the fascination with audio fidelity. And IC designs surely wouldn't have made it off the prototyping bench.
Just another reason why tubes were mentioned. No particle physics, just fidelity and frequency scheming.
With fidelity comes reverberations or transmission reflections.
A lot of elbow bending over the simplest of things.
Post by: giantkiller on 2018.09.20, 03:15:13
In this next stage I am implementing a 555 as a retriggerable one shot as a driver and feed back implementation.
I want to drive the primary and receive the trigger from the air coupling to the secondary.
Using a very short driver pulse it is my hopes to get the device to self oscillate.
I have implemented the 555 as the heart of the High Q mulitplier: http://www.overunityresearch.com/index.php?topic=860.msg42286#msg42286
 (http://www.overunityresearch.com/index.php?topic=860.msg42286#msg42286)This fits right in the two oscillator section of the last schematic of this post: http://www.overunityresearch.com/index.php?topic=860.msg15322#msg15322
 (http://www.overunityresearch.com/index.php?topic=860.msg15322#msg15322)My aim is to have the 555 act as the control of the loop than a specific filtered frequency. This way the ungrounded, floating circuit can correct itself.
The signal protocol would be that the BEMF collapse is in synch and in phase with the next driver pulse, thereby creating a power line oscillatory feedback loop.
Parametric oscillations without harmonic dampening.
 Free round for the house...
Post by: TinselKoala on 2018.09.20, 05:03:58
What you've described there is essentially how the TinselKoil X wireless power transmitter system works. A 555 timer is used to generate an initial pulsetrain into a mosfet driver chip that is driving the mosfet switching the primary. This causes the floating secondary to ring at its resonant frequency. This ringing is detected by a small antenna which then takes over driving the mosfet driver chip, overriding the weak initial signal from the 555. So the system is self correcting due to the feedback cycle, just as you have said, and remains in resonance as the environment changes or power is extracted, etc. However this isn't a parametric oscillator.
Post by: giantkiller on 2018.09.20, 21:29:10
Quote from: TinselKoala on 2018.09.20, 05:03:58
I couldn't find the post or schematic for this. Can you supply link for our perusal?
I am interested to see if parametrics could be added.
And in return I submit using an antenna of FE wire. This picks up signals from ALL directions.
Thanks.
Post by: giantkiller on 2018.09.21, 19:41:15
I also believe the kick is a transmission reflection.
A parametric oscillator is COP > 1.
A swingset is a parametric oscillator.
SM mentioned a swingset operation.
https://www.youtube.com/watch?v=gY3ymZC6t9M (https://www.youtube.com/watch?v=gY3ymZC6t9M)
The TPU is a parametric oscillator.
Had this been the first understanding of the efforts of OUR's we would be in a different place in history.
https://www.google.com/search?q=parametric+amplifier+circuit&client=firefox-b-1&tbm=isch&source=iu&ictx=1&fir=CCs1XDsbZsNhrM%253A%252C003lAnXypGbm2M%252C_&usg=AI4_-kQSb3FBLnHOA6uS7FoPuN6eCfHpUQ&sa=X&ved=2ahUKEwjUipK3ic3dAhXJ6oMKHbxxDsUQ9QEwBXoECAEQBA#imgrc=FTgRYpbCPaCuOM: (https://www.google.com/search?q=parametric+amplifier+circuit&client=firefox-b-1&tbm=isch&source=iu&ictx=1&fir=CCs1XDsbZsNhrM%253A%252C003lAnXypGbm2M%252C_&usg=AI4_-kQSb3FBLnHOA6uS7FoPuN6eCfHpUQ&sa=X&ved=2ahUKEwjUipK3ic3dAhXJ6oMKHbxxDsUQ9QEwBXoECAEQBA#imgrc=FTgRYpbCPaCuOM:)
A Tesla coil is a parametric oscillator/amplifier.
Googled:
Quoteharmonic problems in power lines
https://www.google.com/search?q=harmonic+problems+in+power+lines&ie=utf-8&oe=utf-8&client=firefox-b-1 (https://www.google.com/search?q=harmonic+problems+in+power+lines&ie=utf-8&oe=utf-8&client=firefox-b-1)
So the TPU converts a third harmonic generation into a grid compatible power signal?
QuoteHarmonics are created by electronic equipment with nonlinear loads drawing in current in abrupt short pulses.
The short pulses cause distorted current waveforms, which in turn cause harmonic currents to flow back into other parts of the power system.
Harmonics are especially prevalent when there are many personal computers, laser printers, fax machines, copiers, or medical test equipment, fluorescent lighting, uninterruptible power supplies (UPSs), and variable speed drives all on the same electrical system.
https://www.grainger.com/content/safety-electrical-power-system-harmonics (https://www.grainger.com/content/safety-electrical-power-system-harmonics)
SM only mentions two frequencies.
Post by: giantkiller on 2018.09.22, 19:33:26
Sounds suspiciously familiar...
What if the TPU collector is a floating ground or neutral wire?
If the neural wire was FE then it would collect everything to the point of saturation then overheat. Because it is a core made of wire we can then collect the current from the conductor.
https://www.electronics-tutorials.ws/accircuits/harmonics.html (https://www.electronics-tutorials.ws/accircuits/harmonics.html)
Post by: Centraflow on 2018.09.22, 22:03:27
Quote from: giantkiller on 2018.09.22, 19:33:26
Yes GK, you more or less have hit it on the head. I don't think frequency makes a lot of difference, we will see :-\
Harmonic current circulation along with a design which is a voltage boost converter, all merged into phase using a CMC, two diodes and a capacitor = DC  higher voltage than input and with at least the same current as input= "OU".
Post by: giantkiller on 2018.09.23, 01:56:23
I need to repeat this:
The only time frequency matters is when the need is to have the SWR wave front vacillating around half of the circumference. This is caused by the time domain variance of the pulsations which happens to be the distance control of the frequency.
The SWR is created by the reflections. This is standard AC electronics. When the SWR passes into the center toroid the pulsing is shut down to the lower frequency thereby causing the SWR to start at the beginning of the circumferal path. This timing can be easily created by using two 555s, XR2206 or a voltage to frequency generator(Think Radio shack circa 1994). The ramp generation is in the physical 1/2 circumference of the TPU. Both sides do this. Thumping.
SM got his TPU diameters from industry standard wire spools. This has been covered in the past. That starts the frequency selection.
Then one simply has to alter the frequency from that point a small amount to cause the SWR to swing towards the center toroids.
Special secret here is the outside vertical winding is in two sections of incorrectly terminated antennas. SM stated radio of sorts.
Its the only way to get a small battery or low power to cause immense damage.
The antenna drive is started at the gap and the SWR is brought from the farthest point out to the gap.SM showed the LTPU/SM17 away from the GAP to hide this fact.
The reflections in an audio system with blow the amp or speakers. SM really lit up on OverUnity.com when I showed the two mikes pointed at a speaker.
My two cents is nobody's change...
http://www.overunityresearch.com/index.php?topic=2897.msg69808#msg69808 (http://www.overunityresearch.com/index.php?topic=2897.msg69808#msg69808)
QuoteThis has been the boon dongle for everyone from beginner to eccentric.
Materials, configuration, power, pulse format and frequency. Most combinations don't do anything of interest. A smaller set do something. And a very slight set does phenomenal things.
Lets focus on the slight set. This would be where the test does a number of things, like where a great high resonance performs wireless power or LEDs glow very brightly and one needs more than one in series. But this is air core primarily. On the other side of the experiment we deal with saturation. This has pros and cons also and some new benefit. But then the experimenter goes off thinking about newer materials and this can get expensive with no further outcome. Ouch.
As I have always taken the high road as in the permanent 30 mile high look down when I see something that could apply I dive in and dissect to the best of my skillsets without becoming stuck too far down in pontification.
Back up to the higher view...
Over the years I have seen that 99.99% of the devices all deal with some portion of the magnetic field whether in air or core. This is obvious. But what is not is the ratios of the field and where they reside.
If we have a saturated core then vibrating the air portion doesn't do much as the core is the main feed. If we minimize the core in proportion to the amount of flux or field we want in air we then have a stepping stone into the next level of resonance. The field can be rung and it will sustain further than normal. We have all seen this.
With this in mind we can start to look at devices as a bipartisan function. Think Howard Johnson motor and Magnacoaster. Disregard the bad vibes. I have talked about these two before.
These devices like others that are promoted to work have something in common. The operator controls the air field flux tenacity, the strength of the flux surrounding the device. This is an incorrect description though. These devices control the status of the surrounding or coupling field. Magnacoaster controls the coupling internal between to items, i.e. a large core with a small neodymium, a field coil with a pickup and an air gap. The Howard Johnson takes another approach with the air gap. He sets the resonance in a wave motion around and between the two items of the device, the motor and the generator. His frequency control is the ratio of the two parallel pulleys.
There has got to be slippage allowance in the mechanical or electrical side to the magnetic field side so that the ringing can control the speed of the driver.
If one looks at any of the devices this way one can easily see the failure or working point of any non working device.
The SEG has inherent slippage also. It is in the mechanical side.
Pulling this all together causes one to step back and re analyze with a greater view. What part is missing or off kilter?
Just like you  did.
SM stated it the best when he was talking about snipping wire at a very small increment to achieve the tightness for operation and not of operation.
Diameter of a ring could be a factor when taken into account with the core amount and power size. This would spell a definite wave length of the mag field wave length which has an inherent power factor of that resonance point.
In any documentation it would only take a small fractional change to create a device that doesn't do anything. But it looks perfectly legit. And it previously worked!
Hope this isn't too far off the beam for any one.
http://www.enigmatic-consulting.com/Communications_articles/EnMnofields/No_time.html (http://www.enigmatic-consulting.com/Communications_articles/EnMnofields/No_time.html)
Post by: giantkiller on 2019.02.06, 20:37:14
Well, well, well.
Since Israel's enemies are all at her feet and they are seething to get their agendas enacted pretty damn fast I have come to the conclusion they we dont have much time left on this planet, believers or otherwise.
I would like to take this time to update the community with ad infinitum pablum:
QuoteEveryone also seems to forget that GK's GK4 device produced some interesting results and was referenced by Spherics.
Let this stick in your mind and I will go back in time and reflect on actions and appearances.
The fix is that no matter what setup one has if the forward transmissions are in synchronization with the wave reflections there will be a resonant rise, a build up, i.e. Tesla coil.
Today's power engineers all know about destructive harmonic reflections and the intense need to avoid these. Really? The TPU answer has been under everyone's noses the whole time. You want proof?
The comp wave is but one cycle of the example.
I thought I would spend a couple of years letting everyone get deep in their own mud. Cruel, huh? Nope. Self preservation. There are people we know of that should not have this technology or are looking to promote themselves. There is no time left for grandious foot stomping or dissertational exhortation to a jury of one's peers.
Every one wants a demo. I gave tons of them, all single cycle. From the minute scope shot to blowing up the neighborhood. Wattsup gave additional suggestions and Dollard proved the actuation through the air and ground. I just happen to be the guy that turned all the nuggets in to a gold bar.
But I was given one word of advice. 'There is and there is only ever going to be one Ark of the Covenant'. Sounds hokey, huh? This technology is not allowed in the hands of the public at this juncture in time. The MIB have it though.
I can assure you this that only a few have the technology under their belts and there is little promotion one can do to Make the world a better place.
I always wanted to change the world and I did. Now you can too. I shut down the Berlin internet for 3 hours with my first demo and left a sluggish internet in it's wake for the next 3 days. Remember that?
I told SM that would like to try a stun gun demo with a 20 foot loop of super conducting silver wire by an airport. He emphatically responded ' No'. Remember that?
The reason I mentioned that action was to flush him out of hiding. And it worked. I also came up with this test because I live in a communication test corridor of super top secret air to ground protocol testing.
I can not go beyond the single cycle or power up tests where I am at.
As long as you have no demos that show powering an infrastructure item you're safe. But some fool reading this will jump on the soapbox and shout glorious parade talk. Good luck with that.
Let me repeat: My demos were
'All single cycle'
capitalizing on harmonic reflections. This is the TPU. Why do think it vibrates?
Post by: Grumpy on 2019.02.06, 22:36:16
Yeah, the events around Israel are very interesting.
Lots of prophecies for WW3:
http://www.alamongordo.com/ezekiel-bible-prophecy-and-world-war-iii/
Post by: Reiyuki on 2019.02.06, 22:52:41
GK is Deadalus, building great machines and warning his Icarus cohorts not to fly too close to the sun. :P
https://www.greekmyths-greekmythology.com/myth-of-daedalus-and-icarus/
Post by: giantkiller on 2019.02.07, 19:24:00
This came across my system...
Post by: giantkiller on 2019.02.07, 21:19:46
One ring to rule them all...
Post by: Magluvin on 2019.02.07, 23:19:28
Quote from: Grumpy on 2019.02.06, 22:36:16
I had written a reply to Brad at OU a bit on this very subject.  Its written that after they get their land back that that would be the last generation before the big war.  So we are probably closer than we might think.
Mags
Post by: TinMan on 2019.02.07, 23:31:05
Quote from: Magluvin on 2019.02.07, 23:19:28
Mags
Probably right Mags
Another war due to religious beliefs
Anther reason i have 0 time for religion
Post by: CITFTA on 2019.02.08, 00:13:56
Quote from: TinMan on 2019.02.07, 23:31:05
Probably right Mags
Sorry Brad,
The next war will be because Russia and her allies want the wealth the Jewish people have gotten by turning a wasteland into a very productive country.  And maybe when you see it happen before your very eyes you will recognize that the Bible is always correct.  When Russia, Turkey, Syria and Iran all attack Israel their armies will be totally destroyed.  And you will probably see that in your lifetime.  I agree with Mags all the signs show we are very close to the end.  And by the way, this prophecy was revealed over 2500 years ago.
Respectfully,
Carroll
Post by: TinMan on 2019.02.08, 00:21:53
Quote from: CITFTA on 2019.02.08, 00:13:56
Sorry Brad,
Respectfully,
Carroll
I totally disagree with that Carroll.
It is America that invades countries-not Russia
America has waged more wars than every other country put together.
Post by: CITFTA on 2019.02.08, 01:57:56
I agree with you Brad, that in the past America has waged many many wars.  But I am not talking about the past.  I am talking about the future.  Time will show you that the Bible was correct with that prophecy.
Carroll
Post by: giantkiller on 2019.02.08, 02:33:13
Quote from: CITFTA on 2019.02.08, 01:57:56
Carroll
Nice way to see the end of history happen. I think so. I am glad to be where I am at with what I have discovered and found with my curiosity.
Jeremiah 33:3
QuoteKing James Version (KJV)
Call unto me, and I will answer thee, and show thee great and mighty things, which thou knowest not.
Not religion, just a promise kept. And a pretty fantastic experience.
Post by: TinMan on 2019.02.08, 02:36:31
Carroll
I am yet to see any prophecy from the bible come true.
Even that big event that was suppose to take place in the year 2000-the return of Jesus.
There would be more truth in the series star gate than the bible.
Post by: Magluvin on 2019.02.08, 03:00:24
Quote from: TinMan on 2019.02.08, 02:36:31
Umm, where in the Bible does it say a specific event was suppose to happen specifically in 2000?
Mags
Post by: giantkiller on 2019.02.08, 03:15:16
Truth is for the mind. Religion is for the ignorant.
Israel became a nation in our life times in the year given by the calculations.  And those that witness this shall not die out before Harpazo. Been gone over ad infinitum.
And now this thread has fallen to conjecture and arrogance. This how the threads are smothered with the milktoast of quackery and hide the apparent nuggets to a solution that is in great need.
These spikes of great strides are always controlled by categories of operation duplication into and array of perceived tasks and answers spewed.
Never argue with a fool as the Bible says.
Zealots abound in every camp. It is the scouts that know fully.
Post by: TinMan on 2019.02.08, 04:39:02
Quote from: Magluvin on 2019.02.08, 03:00:24
Mags
Is it not known as the second coming of christ ? Just type it into google,and all your answers are there. Of course different religious groups have different return dates  C.C
It was the biggest event waiting to happen in 2000,but it never came.
Science simply dose not allow events to take place as quoted by the bible. But now we see the bibles claims starting to be twisted,so as they conform to the laws of physics.
When a believer is asked question about the writtings in the bible that portray things as being wrong and inhumain,they simply turn a blind eye,and ignore the question.
The miricals must stand,GOD is good,and the bible speaks the truth.
Carroll stated that evolution could simply not account for the complexities of the human eye,but we are told that Jesus could heal a blind man with just a touch of his hand.
God flooded the whole planet,even though science says there is simply not enough water to do that.
These are the things we are being told as truths,most of which common sense and science can quickly dismiss.
The guidlines of this forum clearly state that extraordinary claims must be backed up by scientific proof.
I am yet to see any evidence shown that god exists.
There is though, scientific proof that disprooves many stories told in the bible.
I present facts backed by science,while the believers only have presented beliefs.
Are we here to discuss beliefs ?,or are we a group of people that are here to present the unknown,and then back it up with proof ?.
If Mike has what he says he has,and what i think he has,then science and physics is about to get an upgrade.
This also means,despite what i have said above,i must also leave a little room for the unbelievable.
I have nothing against those that believe in a god,i only have an issue with the stories told in the bible.
Post by: giantkiller on 2019.02.08, 06:52:30
QuoteI only have an issue with the stories told in the bible
Most of them are world history as the world confirms it. Jews, Hebrews, Levites, Canaanites, Jordanians, Sodom & Gomarah.
Google Ron Wyatt. He back tracks in the texts and find the ancient sites from 'The stories'.
Look up Polydactyl with L.A. Marzula. and
https://www.youtube.com/watch?v=_-EnQTG5qww (https://www.youtube.com/watch?v=_-EnQTG5qww)
There are forces at work which are hiding historical items knowing that the human can be constantly distracted away from truth.
Post by: rensseak on 2019.02.08, 07:14:36
I agree with you Brad, that in the past America has waged many many wars.  But I am not talking about the past.  I am talking about the future.  Time will show you that the Bible was correct with that prophecy.Carroll
That is the same as with the holocaust.
They do everything that prophecy become true.
Post by: F6FLT on 2019.02.08, 11:43:25
Quote from: giantkiller on 2019.02.08, 03:15:16
I agree. And the worst ignoramuses are those who bring religious issues back into science. Please, spare us your superstitions, believers and preachers, religions have done enough damage to men since the beginning of time to avoid bothering with them here, or show us the power of your ideas by pluggin an angel and praying for current.
(http://www.overunityresearch.com/index.php?action=dlattach;topic=860.0;attach=30996)
Post by: CITFTA on 2019.02.08, 11:53:24
Francois,
I will respectfully ask that you delete your last post.  The rest of us here were having a respectful discussion about why we believe different things.  Your last post was only meant to show disrespect for those that don't believe the same as you.
Respectfully,
Carroll
Post by: F6FLT on 2019.02.08, 12:20:43
It's just sarcastic humour, Carroll, as resistance against the proselytism of those who put the bible or the koran everywhere, including in the field of free energy.
I know that humour is also fought by religion, read "The Name of the Rose" by Umberto Eco to understand it.
I am no less respectful of believers than they were of scientists (http://www.lecrayon.net/var/website/storage/images/media/images/caricature-de-darwin-un-venerable-orang-outang-paru-dans-the-hornet-le-22-mars-1871/4337-1-fre-FR/Caricature-de-Darwin-Un-venerable-orang-outang-paru-dans-The-Hornet-le-22-mars-1871_page.jpg)
Post by: JimBoot on 2019.02.08, 13:21:31
I was brought up catholic and despise everything about that institution. The clergy are a pack of ------   I respect everyone's beliefs though. You want to believe aliens pop out of volcanoes.. whatever. On this forum I respect it's data. Data can come from old stories as detailed in the EU theory, Graham Hancock and to some extent Jordan Petersen.
So if you have a theory about science stemming from some ancient script, I would expect to see data to support it on this forum.
Post by: ion on 2019.02.08, 14:02:51
 I created "The Rant Room" for off topic and irreverent stuff so that main threads would not be disrupted. Anything goes there within the rules of the forum. Use it when you need to vent. If you don't like what is said there, just don't go there.
Here is one of my posts from the "Rant Room" includes a little parable you may or may not enjoy. It was written to poke at the people who act and talk like they already know and have the secret. Crumb droppers that hope others will go on a fishing expedition for them.
http://www.overunityresearch.com/index.php?topic=363.msg5247#msg5247
Post by: Reiyuki on 2019.02.08, 14:07:30
Geopolitics and religion aside, we'll make more progress discussing things we can actually build on the bench.
GK and anyone that's made progress in the field:  Since there are so many distractions and chaff theories floating around online,what posters and papers did you find most useful in guiding your earlier experiments?
(Dollard, Aspden, SM, etc.)
Post by: F6FLT on 2019.02.08, 14:27:39
Quote from: ion on 2019.02.08, 14:02:51
That's a good idea, but here are two problems.
1) "Irreverence" is not assessed in the same way by everyone.
2) an "irreverence" placed on the "rant room" is no longer in the context of the previous "irreverence" that could have motivated it in a particular thread.
What do posts about the "bible" or about "prophecy" have to do in this thread? For me it is irreverence, we're not on a religion forum.
I think that a touch of humour, even a big one, is acceptable everywhere from time to time in response to the context. It can be a more efficient way to show that we were getting off topic and to refocus the debate, than tedious and not funny explanations.
Post by: TinMan on 2019.02.08, 14:38:03
Quote from: F6FLT on 2019.02.08, 11:43:25
Perhaps your post takes it a bit far F6FLT.
You seem to have a little !MileHigh! in you.
Post by: ion on 2019.02.08, 16:15:44
Quote from: F6FLT on 2019.02.08, 14:27:39
Regarding your critique of my post here: http://www.overunityresearch.com/index.php?topic=860.msg72182#msg72182
I agree, taken out of context an irreverent post may loose it's impact.
I was raised Christian and see that religion can have both good and bad interpretation and effects in the world, depending on who is doing the interpreting and applying. Jordan Peterson has a lot to say on this subject.
Humor is good, and if we are offended by a few symbols, maybe it's time to examine why.
"The advanced person is not easily offended"
Post by: F6FLT on 2019.02.08, 16:32:38
I noted. I'll use "The Rant Room" when the opportunity arises.
Post by: F6FLT on 2019.02.08, 16:35:47
Quote from: TinMan on 2019.02.08, 14:38:03
I admit it, Brad. I am exasperated by these believers who come to place the Bible wherever they go, and take advantage of free energy sites to advertise their religion and fight science (for example, there are currently many posts against Darwin and the theory of evolution on ou.com).
Then, I am in a country where we have complete freedom of speech in matters of religion, and no cultural barriers, we are not easily shocked, cartoonists have paid for it with their lives. Blasphemy is legal, as I think in most European countries also, but not in Russia. This freedom serves to combat the religious obscurantism found everywhere, even in the field of free energy.
Many believers demand that their beliefs be respected, so that they can spread religious conditioning without hindrance and enjoy it comfortably.
Should we respect the beliefs of those who would tell us that the best political system would be one based on the principles of the Aryan race, or others, on the Islamic sharia? Of course not.
If we are to respect people, it is important to know that we have not to respect beliefs that we do not share.
For this reason, some believers do not hesitate to identify themselves with their beliefs, so if we criticize their beliefs, it is because we would not respect them. We must not fall into their trap.
Sorry for the digression, but I had to make that clarification.
Thank you, I appreciate knowing that I could share something with him.
I have always seen from him rational contributions that are always very well constructed, pedagogical and clearly based on solid skills, not on beliefs.
Title: Re: The final answer...
Post by: Bob Smith on 2019.02.08, 18:32:28
Quote from: giantkiller on 2019.02.06, 20:37:14
'All single cycle'
I believe you and I had a little exchange last year about heterodyning signals to create standing waves and harvesting (collecting) from these. It would make sense to me that the harmonics would multiply the standing wave effect in terms of voltage.
As far as the TPU's vibration - the one thing that comes to mind for me is the notion of discharging a cap into one end of an open coil. One of the demos I watched of an abrupt discharge into one end of a wire showed the wire jumping with the discharge. What happens after the discharge, when the impulse crosses the zero line?  Does the open ended wire become an atmospheric collector of sorts - a kind of push (pos discharge) - pull (ambient charge push-back) effect?
If one had two of these open ended coils overtop each other pushing and pulling, would you get this heterodyning effect?  I could see something like this vibrating and charging up. What would prevent runaway though?
You guys were on to something back in 2007 on the other forum. Maybe things had to cool down for a while.
Enjoying the posts.
FWIW.
Bob
Post by: giantkiller on 2019.02.08, 18:43:39
Ironic, isn't it?
Quote"Chance favours only the prepared mind."  Louis Pasteur
You victimized yourself.
QuoteWe must not fall into their trap.
A simple trigger word and off go the cannons of dissension, disfavor and vile diatribe.
A reader can truly see the level of wisdom in the posters and their age group.
There are those who respond to trigger words and not to the objectivity.
Now go back and re read the post that started this latest banshee hosting.
There are those who get it and they ain't saying a thing. They take and run.
The nuggets are meant to be piled up and not thrown.
Is nobody sane here anymore? My advisor counseled me on this posting but I heeded not.
Now a post was requested to be withdrawn but the self righteous victims did not comply. So where is the trap(rhetorical)?
I did not guide nor request that you get upset. So then why did you 'bring it on' so to speak? What are you here for?
Do you want the technology or tantrum space?
Keep your powder dry...
Post by: giantkiller on 2019.02.08, 18:46:49
Quote from: Bob Smith on 2019.02.08, 18:32:28
Enjoying the posts.
FWIW.
Bob
And one stands tall among the many...
Post by: ion on 2019.02.08, 19:26:25
SM's devices allegedly produced DC without the use of rectifiers. He claimed that was the natural outcome of the devices operation. He said it is a new way of producing electron flow (not oscillation) in a conductor, and I take that to mean a flow in one direction, so in my world this constitutes a first principle for operation to be sought.
Now I don't pretend to know how this is done, nor do I believe anyone else does, as I said before, most folks are sloshing electrons back and forth at um/sec regardless of frequency or amplitude of charge flow.
If anyone professes or even hints to have the answer, just put it all together in a  technical.pdf document and post it here as the Final "final answer". Right now it seems to be the gift that keeps giving a changing direction.
This is not to imply that there is only one method. There may be methods of oscillating circuits that can produce excess energy.
In discussing TPU operation, however, the DC basic principle should be kept in mind.
Post by: Reiyuki on 2019.02.08, 20:05:21
Quote from: ion on 2019.02.08, 19:26:25
SM's devices allegedly produced DC without the use of rectifiers. He said it is a new way of producing electron flow (not oscillation) in a conductor, and I take that to mean a flow in one direction, so in my world this constitutes a first principle for operation to be sought..
IMHO, the DC effect is the principle behind a Faraday/Unipolar generator.  Two ends of a conductor moving at different relative velocities will develop a DC current between them.
https://en.wikipedia.org/wiki/Homopolar_generator
Systems like the TPU, AVEC, and others create a small change in the density of local space (Thanks to E=MC2 this effectively creates a 'virtual velocity') and extracts energy through the Faraday principle.  Larger gradients = larger DC potentials.   More advanced devices create larger and sustained gradients by spinning the gradient into a vortex or dual-vortices.
If this is the case, then all of these systems should show time, inertia, and gravity distortions inside the field relative to normal space.  Dielectric permittivity and permeability constants will also drop below one (and possibly become negative?).
The question then becomes, how can we pump energy into a region of space faster than it can be dissipated?  To create a compression zone where the total energy of that region is higher or lower than free space.
Post by: giantkiller on 2019.02.08, 20:38:17
The EMP in the resonant field is collected by the 90 degree coupled iron wire. The current can be pulled from that wire easily as long as the core content is kept low compared to the secondaries or driving coil's wire and resonance is kept high.
In other words the low FE content increases permittivity and lowers hysteresis. Leedskalnin permanent magnet holder at the point of removing the breaker bar. The TPU sits in the timespan of resonance and captures the moment of EMP. Remember the broken fuses in the open part of the LTPU? SM commented they make wonderful spark gaps.
Don Smith's energy from the vacuum is really an analogy of 'we apply resonance to empty space and we receive a pressure back'.
It all sounds like quackery until you feel or see the power reflections return. Dollard proved this. I got into a lot of local trouble with this. A lot, to the point that I shut down any further attempts because they were growing in size in build and transmission. This is what stops all the achievers. One can only EMP the neighborhood so many times before the mystery becomes a known public aggravation.
Any more dissertation or demos beyond this and I would follow E.V. Gray to the grave in a similar manner. The human cost of collateral damage is too much to bear. No pity, just truth.
So get a resonant ring, open ended transmission lines with capturing the reflections. Ever wonder why they are all rings?
The resonant ring insures that the forward traveling wave will recirculate into a synched transmission at the beginning of the loop. It also insures that the reflections will be met with the next forward traveling wave. My avatar shows a circular Tesla coil feeding itself. 'Nothing complicated' as SM stated.
QuoteThe question then becomes, how can we pump energy into a region of space faster than it can be dissipated?  To create a compression zone where the total energy of that region is higher or lower than free space.
A ring coil in the stun gun charge pump stage.
One must scale up to get the required charge space to make a difference. All the small attempts have been shown here.
The only variable is the diameter of the ring. This sets in motion the input resonant parameters which can vary per the build configuration/type. The GK4 had too much iron core. Wattsup's builds show that which I duplicated. These little builds were way out of control and I didnt want to pursue the end goal because of the damage they emitted. But they did prove what Don Smith was talking about.
In regards to the movie Contact: ever wonder why Jodee had that look of absolute amazement in the transporter ball? Good luck with all this and don't wreck the nest.
Reality was meant to be a dream come true and not a vacation nightmare.
Post by: ion on 2019.02.08, 20:39:40
Quote from: Reiyuki on 2019.02.08, 20:05:21
Thanks for that input, Reiyuki  :)
Sounds like you might have a handle on a working principle. Spheric's "comp" wave might be close to the compression zone you mention.
I'll bet you are now working on an experimental proof.  O0
Post by: ion on 2019.02.08, 20:51:38
Quote from: giantkiller on 2019.02.08, 20:38:17
The EMP in the resonant field is collected by the 90 degree coupled iron wire. The current can be pulled from that wire easily as long as the core content in compared to the secondaries or driving coil's wire is kept low and resonance is kept high.
It all sounds like quackery until you feel or see the power reflections return. Dollard proved this. I got into a lot of local trouble with this. A lot, to the point that I shut down any further attempts because they were growing is size in build and transmission. This is what stops all the achievers. One can only EMP the neighborhood so many times before the mystery becomes a known public aggravation.
The resonant ring insures that the forward traveling wave will recirculate into a synched transmission at the beginning of the loop. It also insures that the reflections will be met with the next forward traveling wave. My avatar show a circular Tesla coils feeding itself.
In regards to the movie contact: ever wonder why Jodee had that look of absolute amazement in the transporter ball? Good luck with all this and don't wreck the nest.
Hi GK
My suggestion, keep it small,  low powered, if that can be done while keeping within the required minimum operating parameters. Shoot for a device that is easily replicated and that is controllable and safe in the range of a few watts. Publish you work on a private forum here initially until others can replicate. Use doc control rev #'s.
Regards and good luck.
This edit by GK to my post:
Post by: F6FLT on 2019.02.08, 20:54:57
Quote from: giantkiller on 2019.02.08, 18:43:39
Ironic, isn't it? You victimized yourself.
Not at all. It only means that if you are a person ignorant of your subject, even if you have all the elements for a discovery in front of you, you will miss it.
The best example for me is the accidental discovery of penicillin by Fleming. (https://www.pbs.org/newshour/health/the-real-story-behind-the-worlds-first-antibiotic) I doubt that the cleaning staff would have noticed anything, the mind has to be prepared.
That's why those who think that without any basic knowledge of physics or electromagnetism they will become great inventors, fail. But for them, in general, it is rather the opposite, they see the extraordinary everywhere in banal effects that their ignorance prevents them from understanding.
Don't forget that Tesla was a mechanical and electrical engineer. The university is not necessary, but at least you have to train very well, even alone, you have to prepare yourself, if you want to have at least a small chance to remark something new. That's what Pasteur means.
Sorry, I can't translate the rest of your message correctly even with tools, my understanding of English is basic, especially technical. Figurative sense or subtle allusions are out of my reach, and it's not ill will.
Just a word about your story. It's more about dogs than wolves. We don't feed wolves. See the difference in this other tale (https://www.bartleby.com/360/8/68.html). Knowing which side to be on is a matter of debate. Ethically, nothing is fixed in advance. Good and evil are a Manichean concept inherited from the simplism of religions, but in real life, everything is in between.
Post by: ion on 2019.02.08, 21:10:36
GK added this edit to my post   earlier.
QuoteOne must scale up to get the required charge space to make a difference. All the small attempts have been shown here.
Well these are specific directions ("one must") that implies coming from someone who has succeeded and accomplished the task at hand. So now we must decipher if those "small attempts" were successful or not.
Assuming they were unsuccessful, when you say "small attempts" were those "small attempts" unsuccessful because of their size? If so is there a sharp threshold or could one expect small effects from a scaled down device? IOW Were those "attempts" successful to some degree in their OU effects or only shown here to demonstrate the basic configuration.
When you say "the only variable is the diameter of the ring" you must mean that the remainder of the assembly must be fixed at a certain size or circuit. Could you expand on that, as "scaling up" and "the only variable" seem at odds?
How much iron core is the right amount?
The small attempts were all successful. They did not rely on anything special. Either resonance or emp actuation is all. That is the division between the two camps of operation. The Tesla coil emps a huge resonant field.
The variable and the core volume are inextricably twisted together. In the SM LPTU he sets a magnet on the side and it stays there. My LPTU doesnt do this. Which is probably what has kept the operation safer. On my list are a number of future modifications. These have been waylaid by the ongoing High Q multiplier circuit insertion in the circuit. This one step alone incorporates the integral self feeding charge pump stage operation. Get it?
Safe as in no lost equipment or fires, like the past. These two are inescapable.
So I need to up the core volume just enough to achieve the magnet staying. By changing this parameter alter all the others. Back to square one? Not really. But what I have seen the trouble with is natural resonance and LC modification to achieve resonance. There is something there that begs further investigation. Natural resonance can be driven. But adding a capacitor lets us store up the resonance. This creates a huge charge pump that has to disipate some where and that is through the spark gap. Which leads us right back blowing up equipment. I do not mind breaking my own but that is the canary in the purverbial coal mine. The neighbors will be affected.
The tests that Wattsup showed me were a small section of lamp wire attached to a battery with a small magnet wire coil at one end and tapping the smaller driver coil onto a battery. What a frickn bomb that turned out to be. A micro sized EMP generator. The idea was a very quick off pulse in an established magnetic field.
Power extraction is not the difficult problem. The dangerously powerful reflections into a half wave rectifier provide that. The goal is to achieve these accumulative reflections. And it does not take group think to do this. One just has to find out the weaknesses in the surrounding environment and protect them or quell the generation. I have a proclivity to blown stuff up. Tesla charged up all metal objects in his environment. Lucky him. I am on my 5th scope!
Post by: giantkiller on 2019.02.08, 21:40:13
Quotethose "attempts"
Both. Achieve resonance then scale up in diameter, achieve resonance again to create a huge charge pump stage, enough so that the amp clamp on meter shows activity not attached in the center as SM did.
I used a SWR antenna meter to measure the distance outside of the coil. The needle showed I had a magnetically resonant ball six feet across. I then heterodyned that with lower auditory frequency as a test to lower the speed so I see the SWR needle swaying. It dawned on me that this was an interesting addendum to the operation. I could remove the measuring equipment a still see the lower speed effect. The lower frequency was done using audio amps. I found the measuring trick that SM hinted at. The stopping point was how fast is this heterodyning? It is the speed at which the configuration needs for the charge pump operation. At least this is what I surmised from the finding. I also came to the conclusion that the thumping speed was indicative of the build's survival rate. A balance between heat and power out. The 90 degree coupling between the iron collector and the lamp wire is the diode. O0 Like Tesla, I turned the core into a conductor, right off the patent. Thank you, Otto.
One can not achieve power out without the necessary charge pump resonance. I became aware of this as soon as I saw the first TPU in 2006 and it becomes so obvious when the device operates as dangerously as SM stated. Its a fine line. Imagine sitting on this gold mine and working in the D.O.D. I was bustin up inside but had to hold my tongue for ten years. I could not even say the term 'Stun gun' without arousing fears and trepidation.
We all have a lot of builds trying to weed through the elusiveness of the correct build. I pummeled through those previous builds to get to the next stage SM had achieved and was talking about cryptically to get us or some one up to speed without giving away the farm. It truly was trial and error. I didn't and never did want a coil. I wanted to see what SM was talking about. I found a lot of what he had talked about in the smaller builds. But my big 17" proved a great platform to then combine all those effects from the smaller builds. Thats when I decided to buy the Rigol scope with FFT and hacked 100Mhz operation. The 17" LPTU turned out so well that resonance is easily achievable. This had brought down the driving frequency to the range of inexpensive frequency generators. The picture I posted last is one drive line with no ground, 9mhz operation. Look closely. One wire drive into resonance. Really? No shit!, is the revelation I had when I saw that. Another check box checked in a list of too many to list. SM gave away the farm with his demos and factual comments. The 17" LTPU started out as a number of lamp wire turns driven by a fet switch. I then went to two layers. Then went to audio. Then natural resonance. Then iron loops for core attraction. Then the outer twin lead winding like I saw in the LTPU and Don Smith's cart coil. Then built the SWR using magnets instead of FE core rings. Hmmm.
The spark gap EMP is a broadband emission that is channeled into a resonant tank to build the charge pump power level up on the smaller units. That is the only way to get the higher frequencies needed for the small diameter coils. These higher frequencies were not attainable with 1996 radio shack parts in a oscillatory fashion. But could easily build a stun gun from there.
So as the combinations become more and more inclusive one has to put the brakes on and ponder about the ramifications of the next logical step. Why would one stop or at least take more progress in stride?
I would rather be the heckler saying 'I told you so' than the pioneer with arrows in his back. It is much safer this way. But I know I have posted a lot of eye opening tests. Most shocked the hell out me that they were so easy to duplicate. That's why I was posting rogue waves and destructive power reflection videos.
I learned from the greats that became their own best victims. Everybody knows the list.
And it being my turn, I give away the farm. Thanks goes out to Steven Mark who gave us the greatest adventure of a life time.
And to W2aeW: https://www.youtube.com/watch?v=byF1FLdbUiA&list=LL2kUhIngtcxmoT86ahaFLRg&index=28&t=119s (https://www.youtube.com/watch?v=byF1FLdbUiA&list=LL2kUhIngtcxmoT86ahaFLRg&index=28&t=119s)
As the saying goes: 'Pump it up!'
Signed: Lord of the ring...
Post by: Reiyuki on 2019.02.08, 23:49:10
Quote from: ion on 2019.02.08, 20:39:40
A common factor in many, many devices involves applying very sharp, very short, high voltage DC impulses into a coil sitting in a static magnetic field.  Too many to list.
That is likely what generates the 'compression' field.
There should be many ways to detect the field once established.  Crystal oscillators should run faster/slower inside the field.  Tiny changes in mass.  The dielectric constant and permeability of anything inside should change.  Light should travel slightly faster/slower.  Optical dielectric constants should change as well (spectroscopy).  Wires in the field with full 90deg coupling might experience lenz-free induction, or generate a DC bias.  Modulated impulses might create RF that will pass through a Faraday cage. :o
Of course, I'm not speaking from success, I'm just paraphrasing the experiments of dozens of inventors in our field into some simple, testable parameters to work from. O0 O0
Thanks GK ;)
Post by: giantkiller on 2019.02.09, 00:03:29
One of the secrets that I garnered from SM was the cabinet magnet. A controlled volume of mass and field strength. One little, weak magnet, always. Saturates the small core ahead of using current. And he pulled from his pocket, just like a key, and inserted into the device, just like a key.
Post by: ion on 2019.02.09, 00:24:42
Dear Lord of the Ring (I say that respectfully as you seem to know what you are talking about)
I'll throw out a few questions, answer if you are so inclined.
In  SM's demo videos dated March 10, 1997 and another July 3, 1996  we see large diameter presumably iron wires wound horizontally on the 17" device with nothing wrapped over them. Admittedly due to poor video quality, there may be something wrapped behind the wires, but there is nothing in front of them, they are quite observable in these videos
In later devices these wires were wrapped over, and the magnet swiping ritual was no longer needed prior to operation.
Is this explainable from your hypothesis of operation?
When you say you went from audio drive to natural resonance what do you mean by natural?
You said operation between heat and power output is a function of  thumping frequency. Can you clarify?
Also that "90 degree coupling between iron wire and the lamp wire is the diode". I almost get it but a little more explanation would help.
I have more questions but I'll save those for later.
You are a gifted writer, have you ever considered putting this saga into a complete document, instead of bits and pieces cast on many disconnected threads?
Thank you for your patience.
p.s. just saw your post about the weak magnet. I agree in that a stronger magnet would possibly not have given the right amount of saturation to the "knee". Of course some are still shouting "reed switch" without thinking deeper about the whole picture.
Post by: giantkiller on 2019.02.09, 01:13:36
QuoteIs this explainable from your hypothesis of operation?
I do say that SM was switching things all the time to keep the mystery a float. It could be that UEC was driving the boat at the time too.
I use mine as the Tesla coil primary. This propels a high speed emp into the already resonant outer twin lead. Which in turn sends that shock wave around the ring. If there are two then that substantiates drawing current off it. The other test I did was to use that as a tickler into a 'q circuit'.
So the 'Q circuit fits into the ResonantCoupler block drawing,
which makes this look very much like the one wire cannons that Wattsup showed. Only larger. In the shape of my avatar.
 A circular Tesla coil. Match the forward triggering primary with the  previous finishing revolution.
It is at this point I cease to connect the blocks ever further. This turns on the device and I want to take extreme precautions. What controls are really in place to prevent run away? We all can talk about that. But I dont feel particularly safe with this next step having seen what the smaller coils do. Why should the larger platform be any different? I have connected these larger building blocks together in sub fashion in case I want to run this up the wall. This is nothing more than a Tesla coil with a pre-resonant secondary that is powered in addition to receiving EMPs from the primary. And this design eliminates the high level of specification demand on the physical build. Maybe the physical specs we see from the images have already solved that. The circular nature of the build is also a feedback loop. This also creates its own reflections so to speak by using the secondaries at each end to simulate a reflection to each other. Heterodyning. Sounds like a rogue wave to me.
With two primaries the secondary can be driven from both ends to set an impact at 180 degrees out. This squeezing of the resonant field of the secondary makes it also like the Kunel patent.
QuoteWhen you say you went from audio drive to natural resonance what do you mean by natural?
The coil has a natural resonant frequency. Adding a cap we can change that up and down the scale. Thanks for catching that. I didnt finish my thoughts.
QuoteYou said operation between heat and power output is a function of  thumping frequency. Can you clarify?
The thumping is either the reverberation due to reflection or the emp through the device.
QuoteAlso that "90 degree coupling between iron wire and the lamp wire is the diode". I almost get it but a little more explanation would help.
Easy. When you run current through the lamp wire the 90 degree iron wire sees the inductive connection. No different than a core. When you run current through the iron wire the 90 degree lamp wire does not see the activity. Many educated thought I was trying to rewrite the laws of physics. I had the last laugh on that one as I am sure SM did too. Otto showed the one wire configuration that boosted the whole OU scenario.
I did. It is on amazon. Savant by Paul Moore. There are many other books named Savant. At the time Israel was not surrounded by her enemies like it is now so I thought at the time there would be more for time for disclosure. The story is wrapped around clues in a coffee shop where the main character hides out and screws with the public. From the readers that have read it seems very plausible scheme of what could possibly be happening today. The ultimate unstoppable criminal.
QuoteOf course some are still shouting "reed switch" without thinking deeper about the whole picture.
Actually it is like a reed switch only we are talking core biasing. But the mechanical people don't see this. That is why the term 'Energy from the vacuum' sounds like hocus pocus to so many. I love a good twist. It keeps the game a foot.
And actually the postings all over the threads are a self protection scheme. Other wise I would have to act crazy like Dollard, Hutchison, and Manson. Crazy is their game and they play it well. I ain't caught so I can run it different.
Now if and when the TPU specifications are published by some poor unwitting prairie dog, they will take the fall but the design will fly immediately around the world and the facts of operation and design will be known from whom and what was posted. I have posted enough to make the whole thing simple and open source, meaning it can simply be built by any one. I know a few kids in Africa that will topple regimes with this. I plan on building wells in3rd world countries that are self contained and self running, like no pump handle. But this is an action item for a longer time frame. Through the grand management use of time the builder crowd has amassed as a large unstoppable force. The only thing the authorities could do to stop it is make ownership of copper illegal. I see a huge market spike in the world wide iron commodity. :D
It is based on controlled, channeled destructive power reflections. That is: it can not be grounded. Look at the charge pump(middle) stage of the stung gun or Tesla circuit. It floats.
The only tight specification is the resonant charge, the synchronized triggering, the reflections. This needs component values. I like SM's 'No' when I mentioned a 20 foot circumferal loop. While the world heard 'That will get you busted, but I heard 'That, my friend, is a better specification', as in lower frequencies. The impetus is to acquire transmission reflections. 'Just like a radio.' like SM stated.
Here are reference pictures. The long wire pair with the cap on the end is one Mannix sent me privately. He is probably passed away by now so no harm, no foul.The Q multiplier has TPU written in it all over the place. Tickler feedback included.
Everybody cries for a circuit. Well here you go, staring the viewer right in the face. It even has the hidden mysterious 9 volt battery there too. I built that on the 17"LTPU. It became an essential tool for tuning. Looks like this little circuit simplifies and answers alot of needs from the community.
Well it looks like the whole package right here, no? For prosperity's sake.
Post by: ion on 2019.02.09, 02:05:26
Well I did purchase and read your book, but because I am not a savant, I was not able to understand all the cryptic clues.
Thanks for all the explanations, and the pics and drawings. BTW, You forgot to add your most recent to that batch.
I will ponder why the center section needs to float.
In SM's large 17" device the pairs of zipcord terminate their ends in each of the CMC windings. The whole section floats except for one wire which goes somewhere. Trying to understand that. See attachment
Post by: giantkiller on 2019.02.09, 02:41:15
That is the open load termination at the end of the antenna. Impedance mismatching causes reflections.
Do you remember all the talk that was going around the wire being snipped at the correct length for timing?
This fits in real well. But the wire does not have to be cut. The frequency is altered to match the need. And this fits back into the rest of the build. This also is where SM claimed difficulty.
Thanks for buying the book. For the sake of the book history and its social content I can not reveal the answers to the clues. It is an asset to the book's appeal.
Post by: Grumpy on 2019.02.09, 03:55:19
Quote from: Giantkiller on 2019.02.08, 21:10:36
Is there a sketch or picture of this?
Here is one of them.
Post by: Grumpy on 2019.02.09, 04:00:34
Quote from: Reiyuki on 2019.02.08, 23:49:10
Thanks GK ;)
The only thing missing from this summary is "rotation".  Are you having trouble with any of this?
Post by: Grumpy on 2019.02.09, 04:17:01
Quote from: ion on 2019.02.09, 00:24:42
Does putting a magnet to or swiping it across iron wire magnetize the entire length?
Post by: Grumpy on 2019.02.09, 04:33:24
Quote from: ion on 2019.02.09, 02:05:26
Where are these pairs of zip cord in the physical body of the TPU?
This is an interesting find.
Post by: Grumpy on 2019.02.09, 04:35:31
Quote from: Reiyuki on 2019.02.08, 14:07:30
Aspden, spherics, Willie Johnson Jr., Michael Faraday, Elihu Thomson, Rowland, Rontgen
Post by: Reiyuki on 2019.02.09, 04:54:56
Quote from: Grumpy on 2019.02.09, 04:00:34
No problem with the concept, I just think it's important that metaphorically, we properly understand simple reciprocating engines before we start building jet turbines.  :P :P
"what posters and papers did you find most useful in guiding your earlier experiments?"
Quote from: Grumpy
I have not read much into Thomson, Rowland, or Rontgen yet, thanks. :)
Post by: ion on 2019.02.09, 14:07:13
OK things are getting quite mixed up here.
In post #223 by Grumpy, I was quoted, but I did not make that quote.
Also since GK is moderating this thread he is able to edit others posts and add to them without anyone's knowledge,
acknowledgement or permission.
This happened on one of my prior posts #213 so I changed it to red and added his name to the edit.
I believe this also happened in Grumpy's post #223 where an image and text was added.
These edits by GK is going to really confuse things.
Post by: poynt99 on 2019.02.09, 14:11:37
Yes, GK.
Please quote or reply to posts rather than editing them. Editing is for moderating purposes, not for replies.
Thanks.
Post by: TinMan on 2019.02.09, 14:33:55
Quote from: ion on 2019.02.09, 14:07:13
Ah,so it is not just me that didnt know what was going on here.
Been trying to make sense of a couple of posts which made no sense toward previous posts.
Post by: Grumpy on 2019.02.09, 15:45:57
Post by: ion on 2019.02.09, 15:53:17
Quote from: Grumpy on 2019.02.09, 04:33:24
In the later versions of the 17" units they are clearly seen as the vertical toroidal windings. These loop up at the back of the device then go directly entering the center of the CM chokes. One pair on the inside left, one pair on the outside right of the back of the 17" unit (where the unit black  tape has been cut to install the fuse holders but at the top back right and ).
The four wires from the ends of these pairs of zipcord are believed to connect to the four wires of the CMC's, as evidenced from the videos.
I will see if I can find a picture and post it here.
BTW, I see that you made this post twice, #236 at 4:33:24 and again post #232 at 15:45:47.
Did you do that G or is someone playing games?
Also please correct the quote attributed to me in post #223 as I did not make it. Also you can see at the bottom that GK edited your post and added the picture. This should be acknowledged as coming from GK.
Also that picture that GK added in answer to your question seems to have nothing in common with the quote. At least it's not clear to me. Can someone clarify?
The looped up wires from the back of the 17" that enter the CMC's in the attached pic are the pairs of zipcord (lamp cord or speaker wire). These pairs are taped together so look like one fat irregular wire. One pair from the outside, one from the inside shows the pairs are the toroidal overwinding.
Post by: Grumpy on 2019.02.09, 16:41:31
Quote from: ion on 2019.02.09, 15:53:17
I reposted my question because I thought it was overlooked.
I changed that quote to GK.
An open-ended wire from those coils only makes sense to me if there is an inductive mechanism similar to electrostatic induction, inducing current into those 4 wires.  The thought being that current is induced into these coils to create a static magnetic field.
I don't know why there is a single wire end.  Maybe to get rid of charge build-up, transients, etc.
Post by: Grumpy on 2019.02.09, 16:49:17
Is it possible to pull voltage potential up with only a single wire?
Post by: ion on 2019.02.09, 17:39:13
Quote from: Grumpy on 2019.02.09, 16:49:17
Mike (Centraflow) has a single wire to his loop in his latest adventure.
Post by: TinMan on 2019.02.09, 17:53:46
Quote from: ion on 2019.02.09, 17:39:13
I would think capacitive coupling would be the other !wire!
Post by: giantkiller on 2019.02.09, 18:23:23
My humble apologies for editing posts.
Not meant to be subversive. You will notice I only edited to provide positive additions.
I leave the original poster to clean up their own messes should they decide.
Questions were asked and I applied the immediate answers. Threads can be a long list of multiple issues.
I re-edit my own posts quite a bit because of dropped words, mangled sentences, and missed statements.
I have to get my thoughts down as quick as possible and therefore ram text in before losing train of thought.
<div>This can create unintelligible diatribes which I have to fix and usually missing some needed corrections.</div><div>Here is an olive branch for your troubles.
</div>
What is truly interesting though is how all other things are catching attention and not the main gist of the operation.
I reposted pictures in the release post that have garnered no comments that I could find.
The one in particular is the helical transmission picture. The TPU is a helical antenna as is a Tesla coil.
This is the action responsible for retriggering, field rotation and heterodyning.
Field rotation is an interesting one. The energy is following a transmissive path. Only one way to go before arriving to the exit point.
The story about the King's party clearly points this out.
That transmission is the expulsion of energy from the output end of the antenna to the input trigger start of the ring. The feedback.
The accumulative feedback and to a very large degree.
I cant get the HTML to display correctly
Here is the King's story as relayed by Mannix from SM. A very clandestine way to release the design, operation and cautions.
The King's Story
Wunce(<font color="red">So it would show up in Google as a lone document</font>) upon a time in a microsecond far away in a land under the noses of all,
<font color="red">The length of the wire is 1 megahertz or in the megahertz. Under the nose, the mouth emits frequencies.</font>
there were some electrons which were sent on a trip around the world by their king.
<font color="red">Pulsing is the connotation here by the term 'Some'.</font>
&nbsp;Their destination was a place near their home but they were sent the longest way possible.
<font color="red">The 'C' shaped path, like the LTPU where this is the most visible.</font>
&nbsp;Their king told them that it was so that they could meet as many friends as possible on the way.
<font color="red">Forward pulse running into many reflections from the 'Long way around'.</font>
&nbsp;They were told &nbsp;that if they were lucky enough to meet some friends they could have a big party and celebrate with them and invite a few back for a visit.
<font color="red">Reflections into reflections</font>
So their king gave them a big kick
<font color="red">This EMP is from a stun gun or square pulses. We start out with sine waves for tuning then switch to square waves.</font>
&nbsp;to send them on their way and arranged to meet them back where they started,
<font color="red">Pulses in phase with reflections</font>
&nbsp;he showed them the other end of the wire just behind them.
<font color="red">A 'C' shaped loop</font>
&nbsp;"See you at the arranged time, back here" he said and off they went!
<font color="red">Timed pulses.</font>
Some short time later the king sent some more groups of his favourite electrons on a similar journey,down another wire . He did this a few times.
<font color="red">A pulsing stream.</font>
&nbsp;After a while he lost track of how many he had sent
<font color="red">Frequency doesn't matter or free running</font>
&nbsp;and was worried that they all might arrive back at his castle together and crash into each other.
<font color="red">An amplitude greater than the capacity of the path. 'Worried' connotes pulses and reflections being 'in phase'.</font>
&nbsp;The king was worried about this &nbsp;so he disconnected the return wires before any of them arrived home.
<font color="red">Another connotation of square pulses inducing greater 'in phase' reflections. The 2 switches in the 17 inch TPU are kill switches. The potentiometer is a 'Phasing' adjustment'</font>
He wondered whether they might get lost but was more worried about them colliding with each other in his castle on their return home "Oh dear!.. What Have I done?" he said.
<font color="red">Interesting Mannix mentions 'worried' three times in three sequential sentences.</font>
<font color="red">A diode in place somewhere at the start of the pulse stream. This connotes a charge pump similar to the middle stage of a stun gun.</font>
Meanwhile the electrons were still on their merry way twisting and turning. round and round
<font color="red">Rotating magnetic field or flux field and spin conveyance or momentum. Also the in phase amplitude of the transmissions and reflections overlapping each other.</font>
&nbsp;when they noticed that their end connection was somehow ,gone ...What had happened
<font color="red">More phasing alignment with other reflections. Open ended transmission line to increase reflection amplitude.</font>
? they also saw some other electrons nearby
<font color="red">Identified as phasing being just a bit off and or a resonant field.</font>
&nbsp;that they recognizsed
<font color="red">An 'S' instead of a 'Z'. Sine wave perhaps?</font>
and so they met up and had a party.
<font color="red">This is a feedback control implication of self-destructive operation</font>
&nbsp;What big party it was.
<font color="red">Operation is just right.</font>
&nbsp;They all met and danced and sang and in the process many more electrons joined in the party, even ones that were not sent by the king.
<font color="red">Additive feedback and ambient energy.</font>
&nbsp;this created a few fights and some confusion but all the other electrons from all around heard about the party and sent messages to all their friends
<font color="red">Power accumulation greater than the device specifications.</font>
. Obviously the place was not big enough, but as it happened ,just nearby there was a wonderful piece of wire which seemed to have an even better way home and it was a bigger wire with much more room . They told their friends and &nbsp;almost the whole party jumped over to the other piece of wire so that they might get home the short way. The uninvited guests were really getting out of hand at this point so It really was a case of either jump or be pushed so they jumped..the only trouble was that all the uninvited guests followed them and their friends and their friends as well, and they just kept on &nbsp;comming .(<font color="red">mmmmmm many windings</font>)
<font color="red">Power extraction by induction to a larger current capable configuration.</font>
Nobody told anyone that the party was over and not to come.
<font color="red">The device self-oscillates.</font>
&nbsp;When all the kings electrons came rushing home thru the other big wire that was not for his travelers the king was &nbsp;relieved that they had taken the shortcut.
<font color="red">The reflections are a viable source of current. The inductive process is the way to extract energy.</font>
But when he saw all the other uninvited guests he realized that disconnecting the main return wire was a bad mistake.
<font color="red">It is imperative to add a load to clamp down the self-oscillation build up. The disconnection process will cause a large back EMP and cause self-destruction.</font>
He grabbed a few of them and put them to work ...he was able to send some of the &nbsp;others back down the original wire in the hope that they would find another king to annoy
<font color="red">The reflections are controlled or monitored.</font>
But there were too many of them so he quickly found another big wire that led somewhere else and joined them together. He managed to get most other uninvited guest to go down that one, away from his kingdom and told them to tell the others that the party was over but they were having such fun ,weaving and winding ..jumpung(<font color="red">he uses a u instead of an i, a scope signal?</font>) and pushing. &nbsp;It did not take long for the king to have so many electrons passing by
<font color="red">Either there is another circling path or he speaks of feedback into the amplification stage. Also this connotes dual rings</font>.
&nbsp;that he had no way of dealing with them &nbsp;so he would sometimes go down to the big wire and watch all the free loaders whizz(2 'Z's) by . He would tell some of them that the pary(Missing T as in parrying. ward off (a weapon or attack), especially with a countermove) was over but they just kept whizzing by faster and faster. &nbsp;He even sent some of them down the bing weavy wire to let the others know that the party was over, but it didn't work. He gave up after a while and &nbsp;left them to it and went off somewhere else hoping that nobody would notice ..Im told that he went to a power generator where none of this sillynes(missing the second 's') could happen to him again an all the electrons had things to stop them from being so silly. &nbsp; (<font color="red">As in out of control, and grounded</font>)
<font color="red">Power companies have regulation in place. The destructive resonance implied here is very real. The industry avoids this energy build up like the plague.</font>
<font color="red">Fidelity...</font>
<a href="http://overunity.com/712/the-master-of-magnetics-steven-mark/msg50061/#msg50061 (http://overunity.com/712/the-master-of-magnetics-steven-mark/msg50061/#msg50061)" class="bbc_link" target="_blank">http://overunity.com/712/the-master-of-magnetics-steven-mark/msg50061/#msg50061 (http://overunity.com/712/the-master-of-magnetics-steven-mark/msg50061/#msg50061)
Original text with spelling, grammar and punctuation errors. Mannix uses a lot of 3 periods through out the text.
Hi all,
This thread will pause for a little while so that every body has time to get up to speed.
There have been many attempts to recreate the conversion events that occour in the tpu.
The best so far have been GK's GK4 and Otto's E.C.D.
Despite their use of square waves and noisy switching devices there was still interaction happening that may lead to the discovery of the correct parematers to have &nbsp;controllable conversion.
The TPU is a harmonically interactive device that is driven with pure frequencies that interact within the space of the collector circumference. This interaction is an accelerating field that causes high speed electron flow.....a particle accelerator..
Tubes are used to experiment with..because they are easier, especially to begin with!
The clues that have been given could be considered vague by some and there are very few specifics..except for One and that is to use electron tubes to begin to experiment with.
Those of you with out the capacity to use the most rudimentary of electronic devices should really not bother with the tpu at this stage, Most especially refrain form giving advice to others. however perhaps in a few years time your skills might be usefull , right now they are can only be misleading .....any thing that leads any body away from the few specifics is misleading. There are volumes of information on tubes, all of it on the net..they are not hard..they are easier ....And they dont fail!
Please do not take offence but do try to listen to &nbsp;what I am trying to &nbsp;explain here.
So you might have to learn something that you consider old technology. I ask you have you seen an electron? There have been some fantastic theories and some great work that have &nbsp;proven that ss devices are not what is required at first....just like the inventor said 2 years ago!
Thanks to many for helping to prove that even though the is a very,very slim chance of success if other guidance is followed which it is mostly not (centre mounted electronics)
The moment any thing unusual happens with your silicone devices...they will fail as explained to you ...in so many ways. &nbsp;It is not unlike a nuclear reaction in that way...go figure. If you think that you are experimenting with something safe....again don't bother.
I was hoping for some assistance with this quest but it seems that people will only pick out some of "their" &nbsp;easy bits and expand on those to fit their own ideas.
Im guilty if this as well in that I thought that by providing this information it would be followed as close as possible by some at least, and some of the work and all of the information would be come well known by all and open sourced.
All the information is here . It is not contained in the egotistical techno ravings of the grandiose.it is in the clues from the inventor which I have been given the honor to convey as best i could.
At this point i believe that I have failed in that regard and I offer my sincere apology to those with expectations this might succeed in the shorter term.
Many are doing really great work and I admire you for that it just sad (actually tragic)that you are not using the main clue!
There are many other great threads that will satisfy your passing interest and perhaps even have some success in some way.
Lindsay Mannix
Post by: ion on 2019.02.09, 18:40:43
May I ask that the topic summary post above be clarified: when quoting others by putting a box around it and identifying from whom the quote came or italics and quotation marks when quoting other than your (GK) own words.
Also it is signed by LM, not yourself, further confusion.
Also this is showing up very strange on my screen with lots of color changes to red that don't occur and other problems.
I understand there are html errors.
GK You said:
QuoteOriginal text with spelling, grammar and punctuation errors. Mannix uses a lot of 3 periods through out the text.
How are ... significant?
Are we to now believe LM coded information into his writing with the # of periods he used, as he also uses a lot of .... and .....?
How far and deep does the cryptography go? because in secret transmissions there may be keys that negate prior cryptic entries? we could go in circles forever.
People are starving and the planet is getting polluted. Time is running out.
Post by: Grumpy on 2019.02.09, 18:59:07
SM said Tao had the "secret" with his post about Tesla's Radiant Electricity work.
Did anyone pursue this?
Post by: ion on 2019.02.09, 19:28:45
Quote from: Grumpy on 2019.02.09, 18:59:07
My  hypothesis for a radiant event goes something like this:
When electrons are compressed  (pressed together) along the length of a conductor, and if the compression force is high enough something has to give, and what gives is this: charge is exited from the wire perpendicularly and with great speed and force.
The image is a wire surrounded by perpendicular blue sharp needle like charges. The exiting charge can electrify objects in the vicinity.  It can sting the skin. The charge can be "collected" as a current and used to fill capacitors.
The question remaining is how to create the electron compression? Reflected waves of a tuned transmission line? possibly there may be a few ways. The Tesla literature on this effect may provide the clue.
I have some possible supports to this hypothesis, but I don't want to disrupt GK's train of thought so I will allow him lead here.
Post by: poynt99 on 2019.02.09, 20:53:37
Quote from: giantkiller on 2019.02.09, 18:23:23
Are you saying SM wrote this and Lindsay merely passed it along, or that Lindsay wrote it based on detailed operating principles passed on to him by SM?
Post by: giantkiller on 2019.02.09, 21:39:24
QuoteReflected waves of a tuned transmission line?
The circular Tesla coil provides the reflections from behind instead of reflected from the non terminated point.The red text in the story are what I added. These clearly point to a 'C' or ring shaped device.
Point two Tesla coils head on at each other and feel the pressure. This is the device set up that Hutchison uses to transmogrify disimmilar metals into one.
QuoteAre you saying SM wrote this and Lindsay merely passed it along, or that Lindsay wrote it based on detailed operating principles passed on to him by SM?
Either or. Lindsay presented this. Now if Lindsay didn't understand electronics or antenna transmission operation then he was the perfect patsy of SM to satisfy the masses. But why should this matter? This story came from the horses mouth. Lindsay could have make comments about the validity of the content but he didn't. Either he needed SM because he didn't understand and was hanging on for the technology or SM just threw a story to squash the curiosity. Or Lindsay knew full well an open source release wasn't possible and worked tightly with SM. I tend to believe this one because Lindsay was a salesman and knew he could bump this game up into bigger and more money on a global scale.
Now back to the technology:Has any tried multiple Tesla coils like Hutchison showed? Has any one looked at the rings like circular T-coils? Has anybody but me fired these monsters up and felt the pressure breeze or their skin crawl? Scares the hell out of my dogs.
The circular T-coil is a magnifying amplifier due to repetitive cyclical emissions impacting the previously applied resonance. The outer winding, the secondary is pulsed to resonance. That is then impacted by the primary strike(just like a Tesla coil). The helical nature emits a transmission at the end of the coil which butts up against the starting point of the secondary. Keep the driving source low in potential to see the heterodyning occurring at antinodes around the ring.In the last test I tried two primaries types. The one wrapped around the twin lead secondary (heavy EMP applied) and the magnet windings (light pulsing) on the ring magnets in my SWR coupler board. This is where I stopped. I could see the activity appearing on the ring secondary like its supposed to do. Two different sized cannons. At this stage of operation it is like testing a formula one race car in the garage. It can only show itself on the track which is what I want some else to do. One doesn't have to build anything new. Everybody here has the required testing equipment.I first experienced the self feeding loop by sequentially connecting 5 stunguns in a loop. I fired the first one sequentially and the rest all took off in order. This was a one time shot as the guns all fried each other. The bench lit up lit up like fire works. But I proved what I wanted to see. Then I removed the transformers and mounted them so I could probe the connections better. This created a nice chain of operations to work with. At the same point I migrated the guns to a PC power supply. This all created an operational loop of repeatability.So at this point the operational blocks are large enough to not only operate but cause serious damage. I flew unabashed into the tests with the smaller devices but now caution is my only protection. Because I finally saw that the reflections could be duplicated by sending another signal in the same direction at a different rate or into each other.
Post by: Grumpy on 2019.02.09, 21:43:54
I bet The Real "Final Answer" is much simpler than most of the ideas discussed on this forum.
Post by: ion on 2019.02.09, 21:50:12
Quote from: poynt99 on 2019.02.09, 20:53:37
Hi Poynt
You had some interesting things to add to this thread: http://www.overunityresearch.com/index.php?topic=3258.0
then it got seriously derailed as threads usually do.
Glad it only went a single page.
Post by: Grumpy on 2019.02.09, 21:52:09
Previous thread on The King's Story:
http://www.overunityresearch.com/index.php?topic=3258.msg54744#msg54744
Post by: poynt99 on 2019.02.09, 23:17:13
And a personal email from Lindsay in July 2007:
Darren,
yes all there will be of help.
I belive that it is the us govt that is supressing it.
The parable was enjoyed by Steven a lot, you can be
assured of that.
The Carl hurst doc is,an explanation in hindsight.
here is a picture that I have sent to steven for
comment..it is as close as i can get for now.
the king story fits it too!! ha!
Thank for understanding
Post by: TinMan on 2019.02.10, 01:38:28
Quote from: ion on 2019.02.09, 21:50:12
Hi Poynt
OK,both yours and Grumpy's links go to the same thread,where poynt only made two post's which contain no information or ideas at all  ???
Post by: giantkiller on 2019.02.10, 02:28:15
My story post does not show red lines. Just HTML.
I used the text tools in the post page here and this is what they did.
Its too bad my repost of the story in so html'd.
The red inserts spell out alot.
Post by: ion on 2019.02.10, 03:50:42
Quote from: TinMan on 2019.02.10, 01:38:28
Okay Brad, fair enough, I should have clarified that they were interesting to me from a historical perspective. I have been trying to recreate the historical timeline of events in the  attempt to discover if there are discrepancies in the story. It is part of a 13 year exhaustive study, and every little piece is important (to me) logged and memorized.
Post by: JimBoot on 2019.02.10, 10:44:49
A bit more history involving Sandgropers Brad http://www.keelynet.com/interact/archive/00000563.htm
Post by: ion on 2019.02.10, 13:32:09
Quote from: JimBoot on 2019.02.10, 10:44:49
I'm familiar with that clip. Maybe Lindsay will come forward and tell the story of why he later reversed his opinion of SM. We know of Brians character as inventor / con man.
If you read all the posts in that thread regarding the device, you can see that the guys at Keelynet are soooo confused. Not that Jerry Decker and the boys there are so straight up either.
Post by: TinMan on 2019.02.10, 14:21:29
Hey,this bloke is just up the road.
Think we can track him down?
If so,im going to pay him a visit.
Post by: TinMan on 2019.02.10, 14:35:39
Hey,i remember when this motor came out.
This collins bloke is no small fry.
http://rexresearch.com/collins/collins.htm
I need to find this man.  O0
Post by: ion on 2019.02.10, 15:02:06
Quote from: TinMan on 2019.02.10, 14:35:39
AFAIK he is deceased. He claims to be the inventor of the TPU, which I highly and seriously doubt. LM knows more.
From BC:
Quote'My commitment to God when he saved my life and showed me the vision of
a new way of generating electricity was real and I have endeavoured to
bring it to fruition from that day.
If you really want to know what BC was about watch the hour long sales pitch he makes to two investors, and listen carefully.
It's after the first 7:39 of this video:
https://www.youtube.com/watch?v=W_fRKxz_UNo
BC is the guy on the left when the video first opens.
At 7:39 he is seated on the left and does the sales pitch.
How the Russian "joseph4younow" got a copy of this video when no one in the states or anywhere else that I know of had a copy is interesting. It did not surface until 2012.
BTW here is GK's 2014 video:
https://www.youtube.com/watch?v=36RGonC_Zgs
Post by: Grumpy on 2019.02.10, 15:35:11
It is interesting to note that SM says the technology was in development for 20 years.
Does that agree with the discovery being made while exploring spatial aspects of audio speakers? (the delayed bifilar pulse)
While history is interesting, it doesn't bring us closer to the goal.
Where are the rotating field experiments or demonstrations?
SM clearly stated that TPU's have a rotating field and that it is required.
Post by: ion on 2019.02.10, 15:50:56
Grumpy said:
QuoteWhile history is interesting, it doesn't bring us closer to the goal.
Understanding the history enables one to begin looking under the right rocks. This should bring one closer to the goal.
QuoteWhere are the rotating field experiments or demonstrations?
Some are show and tell types, others work in private and will show when they have something worthwhile.
Post by: Grumpy on 2019.02.10, 16:17:03
Quote from: ion on 2019.02.10, 15:50:56
He already told everyone which rocks to look under.
I bet there are only about 3 people on this forum who have developed a rotating electric field that does not use the 90 phasing method.
Of these three, all of my stuff is packed in boxes in my cellar, and I have no bench to work on at the moment, not even a space on a table.
You do not feel you have anything worthwhile to share.
The third person isn't sharing his build,and I don't blame him at all.
Everyone else is spinning there wheels, and wasting their years.  Pages and pages of discussion, rediscussion, over and over and over.  I love to talk about it so I am guilty of this along with everyone else.
SM stated that Tesla's RE effect was the secret (when Tao posted it) and that rotation was required.  It doesn't take a religious leap of faith to develop that RE effect into a rotating field.
Post by: Reiyuki on 2019.02.10, 17:06:13
Quote from: Grumpy on 2019.02.10, 16:17:03
Thanks for the advice O0 O0
But to speak in analogy again, imagine trying to describe the dynamics of a modern jet turbine to a population is still getting used to building steam engines. ???
I think it is more an engineering challenge than a conceptual one.  Everyone is designing their own injectors, turbine blades, sizes and shapes.  Because of the numerous variables (ie: points-of-failure), most cannot get their turbines spinning fast enough to generate useful thrust.
I think we'll see more success when more of the necessary component parts are standardized.  It will remove many of the engineering challenges facing the potential replicator.  Most of us playing with MOSFETS and high-voltage tend to generate more smoke than power. :P
Is rotation absolutely necessary, or can we at least detect some measurable effects using single-core impulses?
If rotation is required, then do you think it's practical to get the required rotation using cymatics instead?  https://www.youtube.com/watch?v=S1H8f5DyBwc
Post by: giantkiller on 2019.02.10, 17:29:43
Without Tesla, Marconi would just be another public charlatan.
Post by: Centraflow on 2019.02.10, 18:21:29
I have a question to ask, where did the brown paper drawings come from and who drew them?
I am an investigating scientist and when things get confusing I stand back so as I can see the trees, not just the wood.
I also have points written on the wall, things that are, IMO, correct.
1.   All the TPU's shown must work on the same basis. Stupid to think each one works on a different principle.
2.   The small open TPU lighting 200w of lamps looks quite basic. The electronics equally must be basic because there is not a lot of covered space, so keep it simple.
3.   SM cut open and into pieces, a TPU with a jigsaw. To cut any iron wire would be very difficult with a jigsaw, even thin iron wire, but copper or aluminum are soft metals!!!
4.   DC with a hash output. I think that is misleading, need to think from where would the DC with hash come from with a load of coilsrunning at frequencies!!!!!!!!!!
5.   The coils around the loop are not big and if the "core" is not iron the inductance will be very small. Switching a small inductance will need a very short on cycle and at a reasonably high frequency or you will blow mosfets. You could use a charging choke as part of these coils, CMC's !!!!!
6.   What do the coils do with such a low inductance? Maybe they are not just coils, and if wound over copper or aluminum wires or "frame in the open TPU", their capacitance is greater than their inductance.
7.   The kick, what is the kick that is talked about, and the example of the jump lead across a battery. I must admit that got me for a while until recently, you have to think of all the power hitting in one place, the frequencies hitting in one place. I think SM used a spectrum analyser much more than a scope after all his job was sound and he saw this buildup and the final kick with a power gain.
I can go on and on, but I think I have made my point, you need to take each question and try to answer it before moving on to the next. You need to be logical with your answers, you do not need stun guns etc the toroid produces it's own HV through IMO accelerated charge and why it takes a few seconds to build up.
IMO the large TPU with two CMC's is two units in one, SM removed the output stage so as he could have a direct RF type capacitive discharge, it was not DC.
Title: Re: The final answer...
Post by: giantkiller on 2019.02.10, 19:25:00
QuoteSM cut open and into pieces, a TPU with a jigsaw. To cut any iron wire would be very difficult with a jigsaw, even thin iron wire, but copper or aluminum are soft metals!!!
Do not be deceived. These were just props for the distraction. I have always pushed for the deliberate distraction because that would be the way out for SM if he ever got questioned. In the California house he had a toy trainset on a circular track by the door. No other items except a dining room table and coffee table. Even the garage was empty. Clues abound.
QuoteIMO the large TPU with two CMC's is two units in one, SM removed the output stage so as he could have a direct RF type capacitive discharge, it was not DC.
Boom! Two fuses in gap compartment. One good, one blown. Two potentiometers in front.
Post by: Grumpy on 2019.02.10, 19:35:52
(https://media0.giphy.com/media/7eIJatffSoc7u/giphy.webp?cid=3640f6095c607c284d4756786fe5966d)
Post by: ion on 2019.02.10, 20:23:16
I apologize to GK for quoting Grumpy's post #263 with (giphy.webp) which showed up on my screen as a blank with no content in WinXP running an earlier version of Firefox. I thought I was replying by quoting a blank as more of a question why it was blank, but now find that there was indeed content (giphy.webp) that was not visible to me for some reason. I will check this out using a different browser, to see if I can view the original content.
Has anyone else had this problem using Firefox?
edit: I can see the content (giphy.webp) using Google Chrome
Post by: JimBoot on 2019.02.11, 11:16:38
Quote from: TinMan on 2019.02.10, 14:21:29
Collins was no joke. His radial engine got a lot of kudos as I remember. Maybe this bloke is still around Brad. http://www.padrak.com/ine/SMARK.html
Post by: forest on 2019.02.12, 09:13:55
The kicks produced by two transformers - what do you have here ? I think Closed loop is the answer...
The same thing  did Hubbard and Hendershot.
Kicks adds = voltage rise
voltage rise x the same current = acceleration = power
Post by: Bob Smith on 2019.02.12, 18:25:24
Quote from: forest on 2019.02.12, 09:13:55
Forest,
I'm not sure what you mean by closed loop. Are you implying an internal feedback system, and perhaps a secondary shared by both transformers?
Bob
Post by: ion on 2019.02.19, 13:51:15
Read my post #264 above
Post by: Magluvin on 2019.02.19, 23:31:40
Quote from: ion on 2019.02.10, 20:23:16
I use xp still on a couple laptops and pc, but cant watch internet vids on YT and such, and updating my browser(comodo icedaragon firefox based) says no updates for xp version.  Maybe I need to try plain firefox..   On other laptops and pc I use win7 and use the prog GWX Control Panel to stop win 10 from downloading and installing, as that was a big problem a couple years back.  Windows 7 bugged me all the time to install win10 and come to find out, using GWX that microsoft already downloaded tons of gigs of Win10 without my consent.  GWX deletes all that and stops it all period.
Win7 is ok.  Im still an XP guy though, as long as it lasts ;)
Mags
Post by: TinMan on 2019.02.20, 13:40:25
Quote from: Magluvin on 2019.02.19, 23:31:40
Mags
As am i Mags.
There has been no better OS.
Fast ,and reliable.
Now most viruses and worms have long forgotten about XP  O0
Post by: muDped on 2019.02.20, 18:20:34
I, on the other hand, am 99.9% Linux functional.
I do, however, have an old Canon Laser Printer which
is Windows Limited so have to, on occasion, boot up
Win 98 to print anything.  I don't ever go online with
Windows so it stays clean.  Without bloatware it is really
quite efficient.
WinXP and others of the same family are being kept alive
in ReactOS. (https://www.reactos.org/)  It is free.
Post by: forest on 2019.02.21, 11:38:56
The secondary does not influence primary then a lot of secondary primary secondary primary and closed loop and kicks adds ,voltage multiplication and a small initial current then the rotating field maybe somehow Hubbard did it with added output cores as both limiting (inductance) and output (large area - high factor transformation from HV)
Something like that IMHO
Post by: Verpies on 2019.02.21, 12:07:42
Did you make it last longer with this hack (https://www.expertreviews.co.uk/software/8089/how-to-get-new-windows-xp-updates-for-free-until-2019-with-a-registry-hack) ?
Post by: Magluvin on 2019.02.21, 12:29:24
Quote from: verpies on 2019.02.21, 12:07:42
Im updated to service pack 3, but maybe your link can get me more.  Thanks  ;)
Mags
Post by: giantkiller on 2019.02.23, 06:10:08
https://electronics.stackexchange.com/questions/3881/what-is-a-50-ohm-antenna-how-would-you-make-one (https://electronics.stackexchange.com/questions/3881/what-is-a-50-ohm-antenna-how-would-you-make-one)
Post by: F6FLT on 2019.02.23, 10:49:04
Quote from: giantkiller on 2019.02.23, 06:10:08
A "50 ohms antenna" is just an antenna that has a resistive impedance of 50 Ω, but any antenna can be a 50 Ω antenna by adjusting the length of the elements and/or their internal capacitive and inductive couplings and/or by adding inductive or capacitive components.
The antenna impedance is not related to physical constraints regarding its ability to radiate. The only physical impedance independent of the antenna is the free space impedance (https://en.wikipedia.org/wiki/Impedance_of_free_space) (376 Ω) but the antennas don't need this impedance. To be effective, they only need to reduce conductor resistance and eliminate capacitive and inductive impedance, so that it is mainly the radiation resistance that the transmitter sees. The radiation resistance (https://en.wikipedia.org/wiki/Radiation_resistance) is the equivalent load resistance fed by the transmitter, but whose energy is radiated and not transformed into heat as in an ordinary resistance. The art of making an antenna is therefore to ensure that the total resistance of the antenna is as close as possible to the radiation resistance and its impedance is purely resistive.
One of the simplest effective antennas (but not very directional) is the dipole antenna (https://en.wikipedia.org/wiki/Dipole_antenna). As its impedance is 73 Ω, it adapts directly to the impedance of 75 Ω of common coaxial cables, and can be connected to a transmitter/receiver of 50 Ω even without an impedance transformer, with very satisfactory results. It is the best choice for beginners who want to build an antenna.
With two common telescopic antennas, you can easily make an adjustable dipole from 80 MHz to 600 MHz. I built two of these for all my tests.
Post by: giantkiller on 2019.02.23, 21:27:18
Quoteadjusting the length of the elements and/or their internal capacitive and inductive couplings and/or by adding inductive or capacitive components.
To increase the length of the antenna I add a length of wire loosely curled(to save space). The diameter is greater than the field of this added coil so the inductance is kept small? Tighter coil and smaller wire increases inductance.
Post by: F6FLT on 2019.02.24, 09:47:45
Quote from: giantkiller on 2019.02.23, 21:27:18
Hi giantkiller
The gain of using a thick wire rather than a thin one, has the main advantage of increasing its surface area, thus reducing the disadvantage of the skin effect. The interest is not necessarily obvious near the end of an antenna element because we have there the least current. At the end the current is zero and the voltage is maximum.
It should be noted that this addition also has a capacitive effect that will go in the same direction as the effect of the coil inductance: lower the tuning frequency. For example, terminal conductors are often placed at the end of a vertical quarter-wave antenna, but perpendicularly. They allow to shorten the length thus the height to less than 1/4 wavelength. This is interesting for AM broadcasting on the lower frequencies of the bands. A large terminal coil can have a similar capacitive effect.
Post by: giantkiller on 2019.02.24, 19:18:29
Thanks for this.The basis for this question is pertaining to the schematic attached.
My quandary has always been (because of an attitude of perfection) antennas are made specific to resonate at a certain single or range of frequencies. But then components are added to shift that range. So my curiosity asks why would one make a specific antenna and then have to adjust the resonance point away from the natural resonant frequency? If one were working at the certain frequency wouldn't it be best to make the antenna fit that then add components to enhance the antenna at the natural frequency? And I also have computed the harmonics of the natural frequency into an oscillator in the TTL range of operation. But does that diminish to operative characteristics? My next computation would then find the harmonic that is closest to a 3rd, 5th, 6th, 7th or 9th harmonic.
Post by: thx1138 on 2019.02.25, 01:44:30
Quote from: giantkiller on 2019.02.24, 19:18:29
Think of Tesla's mechanical oscillator that he almost brought buildings down with. Many times you don't want the exact resonant frequency because the device would then self destruct and possibly take other valuable materials/devices with it.
Post by: giantkiller on 2019.02.25, 05:44:23
Quote from: thx1138 on 2019.02.25, 01:44:30
The force is strong with this one.
Post by: F6FLT on 2019.02.25, 09:55:21
The idea that there would be a "natural frequency" is based on nothing more than impedance matching. It is arbitrary. For example, a "half-wave" dipole would have a very poor efficiency if used with an impedance transmitter of 300 ohms instead of 50 or 75 ohm, even for a frequency with a wavelength equal to twice its length.
The "natural frequency" is only the ability of the combination [antenna + transmitter output circuit (or receiver input) + transmission line] to favour current in the radiation resistance.
There is no theoretical need to have antennas related to wavelength, they are only engineering needs to optimize currents and fields. Any variable current flowing in a conductor radiates, it depends only on the intensity of the current and the radiation resistance.
But antenna construction with elements multiples of the quarter-wave or half-wave, generally facilitates adaptation to the common impedance of transmitters, reduces the inductive or capacitive components of the impedance, and optimizes the radiation resistance in comparison to the conductor resistance, often with a simple mechanical design. So we use them instead of just any piece of wire with an added tuning circuit.
In the case of an antenna shortened by the addition of coils or terminal capacities, coils and capacities do not contribute to radiation or very little, but contribute to losses and degrade the ratio between radiation resistance and conductor resistance. It is therefore in our interest to avoid them. If you want a possible adjustment, you can always make the elements a little longer than necessary and then cut them gradually to reach the optimum.
Post by: F6FLT on 2019.02.25, 10:27:04
The big idea of the antenna, and it took me a while to understand the consequences, is as follows. It is better understood in the case of the reception I will take, but the effect is always reciprocal.
The local ambient electromagnetic field from a remote transmitter creates an induced current in the antenna. Lenz's law causes this induced current to create an electromagnetic field that opposes the ambient field.
However, in a field, we have energy: the energy density is 1/2(Ɛ.E²+B²/µ), and the energy is conserved. So where does the energy from the ambient field go when the current in the antenna creates a field that opposes it?
Well, in the antenna current! So, thanks to the current induced by the external field, the more the antenna produces a field that opposes the ambient field in the largest possible volume, and the more energy is collected from this field. This needs the adaptation of the impedances of all the components constituting the circuit as a whole: receiver input+line+antenna.
This also introduces the idea of the electrical antenna volume, which is to be increased. With good design it can go far beyond the physical volume occupied by the antenna (this also explains, but only in reception, the considerable gain that can be expected from negative impedances, which by reinjecting energy opposite the ambient field, allow more energy to be recovered in the current. But that's another story...)
Of course if we want only a confined local field, for exemple for NMR applications, we don't need these considerations. It's another problem, especially because of standing waves.
Post by: Reiyuki on 2019.02.25, 15:14:36
Quote from: F6FLT on 2019.02.25, 10:27:04
One exception that we've seen on the bench is with iron/nickel wire. >:-)
Ferromagnetic wire can be induced at any angle while inside a changing magnetic field.  Instead of a reciprocal reaction, induction appears to occur through alternate saturation+desaturation of the wire itself (parametric variation of inductance).
Post by: Centraflow on 2019.02.25, 17:12:41
I think this is an excellent video for those reading here, this is similar to the inside of my STEAP TPU
https://www.youtube.com/watch?v=adJp1zO9qfo
Enjoy
Post by: giantkiller on 2019.02.25, 20:22:23
Now if I replace the antenna with a coil the same question exists but with a different perspective:
QuoteMy quandary has always been (because of an attitude of perfection) coils are made resonate at a certain single natural frequency. The component has inherent inductance too. But then components are added to shift that range. So my curiosity asks what do we gain by making a specific coil and then have to adjust the resonance point away from the natural resonant frequency? If one were working at the certain frequency wouldn't it be best to make the coil fit that then add components to enhance the coil/circuit at the natural frequency? And I also have computed the harmonics of the natural frequency into an oscillator in the TTL range of operation. But does that diminish to operative characteristics? My next computation would then find the harmonic that is closest to a 3rd, 5th, 6th, 7th or 9th harmonic.
Because in using the windings to produce a magnetic field we want to use the external field in a near field expression. And at resonance we get strong field that costs less energy using the swingset analogy than off resonance.
My basic tenant is to add a capacitor to the coil to promote the natural resonance other than pick another resonant point.
Post by: giantkiller on 2019.02.26, 01:30:26
Well, well, well:https://futurism.com/room-temperature-superconductor-patent?utm_source=Digest&utm_campaign=d4e51cca9b-EMAIL_CAMPAIGN_2019_02_25_06_02&utm_medium=email&utm_term=0_03cd0a26cd-d4e51cca9b-246559249&mc_cid=d4e51cca9b&mc_eid=a666f8a7ec (https://futurism.com/room-temperature-superconductor-patent?utm_source=Digest&utm_campaign=d4e51cca9b-EMAIL_CAMPAIGN_2019_02_25_06_02&utm_medium=email&utm_term=0_03cd0a26cd-d4e51cca9b-246559249&mc_cid=d4e51cca9b&mc_eid=a666f8a7ec)
QuotePais' application describes a wire consisting of a metal coating over an insulator core. An electromagnetic coil surrounds the wire, and when activated by a pulsed current, this coil causes a vibration that allows the wire to act as a superconductor at room temperature, according to the application.
Post by: F6FLT on 2019.02.26, 09:29:54
Quote from: Reiyuki on 2019.02.25, 15:14:36
There is no exception. It is question of electromagnetic waves, i.e. radiation, not of ordinary induction in the near field.
A field, even a variable field, is not a wave. The wave is formed at about a wavelength of the radiating element, this is called the far field. See here the difference between near field and far field (https://en.wikipedia.org/wiki/Near_and_far_field). A wave is a combined autonomous E and B field that propagates at a speed c=1/√(Ɛ.µ).
If your working frequency is 1 Mhz, you must be 300 m away to talk about electromagnetic waves. At 100 KHz, you must be 3 Km away. At 10 KHz, you must be 30 Km away....
If you are at less than a half-wavelength, what you see is only the near field, which is captive, not a wave, completely linked to the current generating it, the energy being constantly exchanged between the field and the current. It is remaining in the system, it is not radiated. E and B are not perpendicular and can be everything, not related to the Poynting vector. For such a near field, you do not need an "antenna", an inductive coupling from a coil is sufficient. An antenna is only made to promote the formation of the far field, i. e. the radiation.
Anything like a ferromagnetic wire or any wire can be induced at any angle by a near field, the only requirement is that field lines cross the circuit surface somewhere, if we are speaking about induced current (if it's induced magnetization, it's obvious).
(https://www.overunityresearch.com/index.php?action=dlattach;topic=860.0;attach=31370;image)
Post by: F6FLT on 2019.02.26, 10:10:31
Quote from: giantkiller on 2019.02.26, 01:30:26
GREAT news! Not yet clear how it works.
Post by: Smudge on 2019.02.26, 11:05:54
Quote from: F6FLT on 2019.02.26, 09:29:54
Having spent many years in industry dealing with near-field radar (mine detectors, metal detectors, missile and torpedo target proximity detectors) using both electric and magnetic fields I can tell you that the fields definitely propagate at light speed, they do not appear instantaneously.  While agreeing that energy appears to be constantly exchanged between the field and the source this tells me that there is propagation both ways.  Something propagates from the moving charges and something returns back.  It is difficult to visualize what those somethings are, call them what you like sub-photons, virtual photons whatever, but one thing I am sure of.  Space if full of these virtual particles and the source doesn't shoot them out willy-nilly, the propagation is linked to those received from space.   Thus our concept of a near-field energy is really just a change in the pattern of the virtual particles surrounding the source, a change from so called "flat space" where the pattern of all the virtual particles passing through is the same everywhere.
Post by: ion on 2019.02.26, 12:39:04
Gk   nice find!
Regarding the RTSC patent application, note that abrupt mechanical vibration is a key factor. Phase transition at the insulator/conductor boundary is also claimed to play a role. Ordinary aluminum can be the thin film material.
I'll read it further to see if this lies within the realm of home experimentation.
Smudge: I get it regarding your last post here.
Post by: F6FLT on 2019.02.26, 13:58:56
Quote from: Smudge on 2019.02.26, 11:05:54
Nothing goes faster than the speed of light. So is the near field. It expands/contracts around conductors carrying a varying current. It does so at the speed of light, which means that a point at a distance d from the conductor will not feel a change in field strength until a time t=d/c after the current change. Nevertheless, this field does not propagate as a wave because it is not autonomous.
It is only when the round trip is too far from the current source that the field beyond separates, can no longer return to the current source, becomes autonomous and propagates as an EM plane wave as shown on the image taken from Wikipedia and that I completed.
Below this distance of the wavelength order, E and B do not form a plane wave and are not perpendicular, it is not an electromagnetic wave but a "quasi-static" field, such as a standing wave, despite its influence going back and forth at the speed of light. That's why it is noted "reactive" and "non radiative".
Post by: F6FLT on 2019.02.26, 15:29:25
Quote from: ion on 2019.02.26, 12:39:04
Gk   nice find!
Hi Ion,
It sems it could be within the realm of home experimentation, we have to learn how to make the coating, but we have also to know the powers needed for the pulses and vibrations. I see no mention about that.
The patent has a reference to another interesting paper of the inventor Salvatore Cezar Pais (US Department of Defense/Navy) The high energy electromagnetic field generator (https://www.inderscienceonline.com/doi/abs/10.1504/IJSPACESE.2015.075910). You can download it from sci hub, using the DOI.
As for the superconductor, his method is to shake matter by various means (rotations, non-linear vibrations) but at disproportionate levels: frequencies in the range of 109 to 1018 Hertz, field intensity values in the range1024 to 1028 Watts/m2, all using a 2 m diameter disc rotating at 30000 RPM and loaded at 50000 Coulombs!... for the propulsion of a spacecraft by interacting with the quantum vacuum which becomes polarized and exerts a negative pressure.
He refers to Puthoff and Haish who are not unknown to me more for their innovative ideas that can make us dream, than for the technology that their ideas could have generated and of which I see no trace anywhere.
But if the patent really works, it would restore credibility also to this whole field of propulsion and inertia manipulation.
Post by: Smudge on 2019.02.26, 17:26:29
Quote from: F6FLT on 2019.02.26, 13:58:56
I understand all that, it's text book stuff, I was brought up on it.  But a field is something we measure, and if we measure over ever smaller time increments we find that the field effect becomes quantized, the field effect is made up of individual quanta arriving at the measurement point.  Then it makes no sense to describe a photon as a wave packet, it is more like a packet of quanta arriving with their spacing associated with a wavelength.  For a photon to be associated with a frequency there must be a minimum number of quanta appropriately spaced.  Also words like "fields expanding/contracting" or "fields separating" have little meaning with regard to what is really happening with those quanta, those virtual particles arriving at our measurement point.
Post by: giantkiller on 2019.02.26, 17:28:40
QuoteNothing goes faster than the speed of light.
Quantum mechanics proves differently. Action at a distance. But the distance doesn't matter...
QuoteI'll read it further to see if this lies within the realm of home experimentation.
Doesn't anybody see the TPU in there? We are already doing it...
A helical antenna wrapped around a charged conductor. Look at Wattsup's experiments.
Or is somebody waiting to publish a white paper when its safe to claim the glory?
Post by: ion on 2019.02.26, 17:47:18
It's interesting that the USPO seems to accept applications for ideas that seem to be untested. The RTSC patent app seems to say "if it could work, it might work like this"
I have downloaded but not yet reviewed his other two entries, one of which was granted, the other is an app waiting for approval
Post by: F6FLT on 2019.02.26, 18:35:25
Quote from: Smudge on 2019.02.26, 17:26:29
It explains why your objection of the speed c of the near field doesn't invalidate the fact that it doesn't propagate.
A propagation is a radiation when it's question of wave. A "radiation is the emission or transmission of energy in the form of waves (or particle)". The near field doesn't propagates, there is not even a single wavelength in the volume where it's created, it's not a wave but a varying field.
"fields expanding/contracting" has been used in the context of classical physics, not QM. "Field lines expanding/contracting" would have been better than "field", but it's just an image. We all know what a magnetic field is in classical physics, assignments of vectors to points in space.
In any case, a propagating photon is really a wave packet. See https://physics.aps.org/articles/v5/86 .
"A pulse of light can have almost any shape in space and in time, determined by the amplitudes and phases of its frequency components.
Surprisingly, single photons can also be generated in a variety of complex shapes. "
Post by: F6FLT on 2019.02.27, 10:46:39
Quote from: ion on 2019.02.26, 17:47:18
The "inventor" has two other even more exotic patents:
A "High Frequency Gravitational Wave Generator" and a "Craft using an inertial mass reduction device"!
His references to Harold Puthoff in support of some of these patents are worrying. Harold Puthoff is indeed one of the scientists in charge of the 1970s experiments on Uri Geller at the Stanford Research Institute. He concluded in the final report that Uri Geller had psychic powers, which I already mentioned here (https://www.overunityresearch.com/index.php?topic=403.msg71972#msg71972). These experiments were then revealed to have flaws everywhere (Puthoff is an "engineer and parapsychologist", not a physicist).
Also the principle of HFGW was invalidated, the possible signal it would generate being demonstrated at a level many orders of magnitude lower than this exotic theory predicted.
The author of this patent therefore seems to me to belong more and more to this lineage of Puthoff et al., from which nothing has ever come out of their ludicrous ideas.
I regret that I became enthusiastic about this announcement. What is amazing is that the US government endorses this kind of patent, and pays for it.
Post by: ion on 2019.02.27, 22:41:07
Quote from: F6FLT on 2019.02.27, 10:46:39
Agreed on all points especially the last where taxpayers actually fund this.
Post by: forest on 2019.02.28, 11:14:14
Is this patent really valid ? I saw Russian video years ago with exact the same embodiment tested experimentally . I piece of wire inside a ferrite core made of ferrite rings glued together with coil on top pulsed.
Post by: giantkiller on 2019.03.01, 05:44:36
I was keyed in on the aspect of the helical over the charged carrier.
This has appeared many times in the overunity arena, in all types of configurations.
Most of the people just focus on the individual build instead of the common configuration.
Post by: F6FLT on 2019.03.08, 14:04:01
A new paper that is related to what we were talking about above with the near-field and far-field distinction: "The birth of radiation" (https://iopscience.iop.org/article/10.1088/1361-6404/aafee9).
Here the analysis is done in the time domain, and only for the electric field.
"The topology of electric field lines in electric dipole radiation of angular frequency ω changes during each cycle. From the beginning of each cycle to the time tc given by ωtc=√2−arctan (√2−1/√2)≈0.8 there is no reconnection of field lines. In the time interval t=tc to t=1/ω electric field lines separate from the charges on the dipole and close on themselves, but the closed loops eventually die away. For times t=1/ω to t=π/2ω the closed loops do not fade away but fly off to infinity as radiation. This sequence is repeated twice per cycle, with field direction reversal in the second half-cycle."
According to this text, we would therefore have different physical phenomena depending on the time observed in the signal period. I find that surprising.
Post by: giantkiller on 2019.05.05, 18:08:47
https://www.warp-drive-physics.com/updates-and-design-improvements (https://www.warp-drive-physics.com/updates-and-design-improvements)
The take away nugget is:
QuoteMagnetic fields of resonating inertial mass between a top positive charge and a bottom negative charge is essentially the effect of Townsend Brown Electrodynamics as I call it.
Post by: giantkiller on 2019.05.05, 19:32:55
Funny how all these models match up...
I figured since Russia and China are buddy buddies in Damascus this would be a good time to push the envelope farther.
We don't have much time left.
History will be over soon.
Isaiah 17:1
QuoteA prophecy against Damascus: "See, Damascus will no longer be a city but will become a heap of ruins.
(for the non believers and argumentative).
The original microphone in the speaker image got SM's attention real fast along with the mentioning of the stun gun.
Post by: giantkiller on 2019.05.05, 19:44:49
QuoteResonance is achieved by pulsing the power (on and off, at a frequency), making use of the flyback magneto-static from collapsing magnetic fields.
I found this in 2006 with the iron wire core in the GK4 using eclipsing frequencies. This created rogue waves in the iron wire core(microwave expressions).
I later went back to the stun gun engines for a simpler drive.
This is also why the 90 degree coupling works.
The eclipsing frequencies is the key to the drive protocol. Over the years many have tried to achieve this in other ways, better components, cores, metals, conductors. All for naught.
But by using the eclipsing frequencies the drive can be controlled better. This alleviated the iron core from spewing sparks which kept the energy in an amperage form instead of a HV expression. With amperage the device stages can be guided into normal circuitry for power extraction. With electrostatics the Biefeld-Brown expression can be utilized.
Special topologies have to be used to co-mingle the two.This is why the TPU model picture in the last post is so informative.
Past this point you will get visitors.
I reside under a top secret test area for military protocol testing.
I know a few lurkers have been waiting for this post.
There will be no schematics or videos.
Post by: Bob Smith on 2019.05.07, 23:24:57
Quote from: giantkiller on 2019.05.05, 19:32:55
Isaiah 17:1 (for the non believers and argumentative).
Love that microphone and bell image. To me it says we have two LC arrangements with a 90 degree secondary coupling on each providing feedback. Two sets resonating at their own frequencies on top of one another produce a heterodyning effect. As far as the stun gun mention, what comes to mind is charging and discharging a capacitor.
My 2 cents worth of observation.
Yes, it would be good to get this thing unwrapped before the grid goes down  ???
Bob
Post by: giantkiller on 2019.05.08, 01:23:53
Ding, ding, ding...
Now we just have to find a prairie dog that knows electronics. :D
Here: I put some bait in the trap:
Destructive, harmonic power reflections.
There were some frequencies exposed in the movie 'UFO'. Add CU and FE.
Post by: F6FLT on 2019.05.08, 08:51:57
Quote from: Bob Smith on 2019.05.07, 23:24:57
...To me it says we have two LC arrangements with a 90 degree secondary coupling on each providing feedback. Two sets resonating at their own frequencies on top of one another produce a heterodyning effect. ...
It's not a heterodyning effect. A heterodyning effect results in the apparition of signals at new frequencies, from signals at different frequencies. To achieve this, two signals must be multiplied by each other, and signals at the sum or difference frequency of the first two signals appear. This is due to the fact that a multiplication in the time domain is equivalent to a sum in the frequency domain, simply as a consequence of: sin(a).sin(b) = 1/2 cos(a-b) - 1/2 cos(a+b), replace a with ω1.t+φ1 and b with ω2.t+φ2.
Multiplication in the temporal domain is only possible with non-linear elements, which is not the case with ordinary L and C.
Whatever the arrangement, the superposition of currents or fields in LC circuits will never give new frequencies if L and C are constant and there are no other non-linear elements in the circuit. It is easy to verify it experimentally, provided you are a little experienced because it is easy to confuse, seen from the scope, a superposition with a multiplication of 2 signals, the shapes can be similar. It is better to see the FFT spectrum, it leaves no doubt.
Post by: giantkiller on 2019.05.08, 13:24:17
The tpu is a rogue wave generator. Heterodyning is used for harmonics. The goal is to achieve accumulative transmission reflections fed back into the resonance. An Emp is a mass dispersion of these in what looks to be a single shot. SM stated that the unit draws lightning from the sky. It actually produces it. It 1996 no one was dealing with or they were squelching this kind of energy production. But now we see how useful this energy can be applied. The microwave oven circuit exemplifies the charge pumping portion of the tpu circuit, i.e. half wave rectifier into a magnetic spark gap/magnetron. The tpu had magnets in it. Rogue waves/emp discharges applied to soft material/food. Thumbs up! Energy from the vacuum. Measure it however you want. Its too simple to own. That is why SM went through all the shenanigans to demo it. And boy did everybody fall for it. A real feat of physical and verbal prestidigitation. Hell, he even pocketed the magnets.
Post by: F6FLT on 2019.05.08, 16:39:08
Heterodyne is probably present in TPU since it uses non-linear elements. But it is not generated by LC circuits or in coupled fields, only in transistors or diodes of electronic circuits.
The problem is that obviously no one understands anything about it, and obviously everyone wants to imagine explanations, and so does SM, if I rely on your sentence: "SM stated that the unit draws lightning from the sky".  C.C
However, no one has replicated the overunity, and there are so many possibilities of magnetic or capacitive couplings, that the results can be anything, and if it's weird, that's not surprising. This does not mean that the operation is unconventional. It is necessary to be very good in electronics engineering to model it, given the large number of parameters to be taken into account, some of which are not easy to measure and even to see (hidden capacitances).
There is no sense in looking for explanations for something that no one observes working as it should, that is, with overunity. Normally, we try to explain what we observe, not what we would like to observe.
While imagining an overunity operating principle can help to properly build the machine to implement it, invoking the ZPE or lightning from the sky or "rogue wave" without any operational basis is fiction.
Post by: giantkiller on 2019.05.08, 17:28:13
The mind that is addicted to measurement can not see what the charlatan actually shows. SM showed working devices. He expressed a lot of physics but not in those affiliated terms. He gave a lot of reverse analogies of operation which sounded like magic. Those who crave measurement have been on this reverse engineering mindset path for over 17 years now. Because they want facts or numbers. But no one has ventured into the realm of destructive, reflective harmonics. This comes from heterodyning in an established field. The heterodyning comes in two ways. One is the purposeful mixing of frequencies at any and all power levels. And Two from the purposeful mixing of established fields with other fields i.e. Bloch wall exercise and EMPs.
The measurements are great for the books, papers and doctorates. But in this exercise the common man does not care about how the explosions happen, just get them to the store in their vehicle or give them hot food at the press of a button while the insecure want affirmation from their adventures. There is enough documentation from this journey to prove the technology is feasible. I have given enough operational examples to prove the technology. These piggy back off of other's declarations. I am not the only one looking for a prairie dog.
There will no money made from the TPU venture only death. I have absolute proof that this technology is not allowed nor will it be tolerated here.
All efforts are trying to claim reward for what Tesla, Dollard and a great other men have already published. Yet Pandora's soapbox is always beakoning from greater and greater heights for the vain to fall from.
Wattsup's configurations showed destructive reflections without the harmonics(Now this is the biggest gold nugget ever).
Two loop transmitter/receivers facing each other in an harmonic envelope. If you ever see this working you WILL run down the street in total amazement.
Post by: F6FLT on 2019.05.09, 09:26:45
Reverse engineering is a good idea, but only if you have engineering, which is not the case (no schematics).
However, the good ideas you can have about supposed engineering, why not use them directly to imagine a new system, rather than imagine how a system that we don't have a realization could work?
Because if the idea is good, no matter how you implement it, you no longer have to do something that looks physically like what SM did.
Post by: Centraflow on 2019.05.09, 17:55:57
Quote from: F6FLT on 2019.05.09, 09:26:45
Very true, but if your idea requires a similar shape as SM's then they are going to have some visible similarities, such as magnetic loops. You are a radio ham and as so you know what I am talking about. We know that high voltages and currents circulate around such TX/RX loops, but they are 180º out of phase, so no real power.
Magnetic loops as the name infers are magnetic in the near field and as so magnetic induction can be high within that field, also they do not need to be elevated above the ground like other antennas.
This leaves the loop with a different ground plane with reference to the earth, this IMO is where capacitance between two loops can be used to draw in that ZPE and from where we can extract the energy in a form that is usable through phase changed induction. One plate of the capacitor is to a floating ground and the other is counterpoised with the ionosphere, extract at the right phase angle and we have real power.
Post by: giantkiller on 2019.05.09, 19:00:19
@F6FLT:
Also there is no need for reverse engineering if you 'have' schematics because most of the pertinent information is supplied. There is nothing to be reversed except SM's statements. Such chicanery and charlatism was on purpose.
QuoteThe problem is that obviously no one understands anything about it, and obviously everyone wants to imagine explanations, and so does SM, if I rely on your sentence: "SM stated that the unit draws lightning from the sky".
When anybody talks about about free energy the hackles and defenses go up.
You poked before you peeked. The twist is this device, at certain stages, produces sparks into the air. In my history of quoting SM I repeatedly stated he turned operational statements backward.
From my experience you are a fairly recent newcomer, ableit an antenna person which is what I had been harping for a long time.
We can debate about levels of knowledge till the planets collide which will just waste time.
I have nothing to prove and I am sure you have a lot offer.
But you do not know what I know.
My statement is:
This is a weapon. Let that sink in.
Post by: muDped on 2019.05.10, 00:30:54
Quote from: GiantKiller
My statement is:
Those who possess it have many more in their
arsenal.  The Black Hole of Black Projects sucks
it all in.
But only for a time.  All will be revealed.
Post by: giantkiller on 2019.05.10, 02:40:19
Quote from: muDped on 2019.05.10, 00:30:54
it all in.
Yes. If one is found in possession of the signature generating device, well...
So I throw down the gauntlet here:
In OUR we now have enough antenna engineers that are familiar with power transmission feedback.
The idea is to create a transmission circuit that reverbs power reflections and capture them.
Gone are the days of trying to capture the shake and shimmy of particular anomalies of special circuits. Harmonic reverbs at a very minute level.
Imagine showing up in Israel with this device? Let alone get it on a plane or have it go through customs.
Right here I have shown my hand of aces. I have known for +12 years and have promoted this design.
While everyone is trying to power light bulbs I have been sitting on the revised, new and improved Ark of the Covenant(right out of the Bible, described and built by King David(and there are those who refuse to believe)), with a history of blowing things up, from flesh to neighborhoods.
The critical part of the circuit is the tuning(LC(BobSmith, Centraflow)). That is the configuration to achieve the protocol of slowing down the EMP or the capturing of the reflective harmonics to a usable train of flowing energy instead of letting it fly loose. 8) Or, God forbid, grounding it(Kapadnaze grounds his because he is not returning it to a government sponsored loop system).
Now doesn't this approach seem more attainable? What? The free energy train has been derailed? By just a simple twist of examples and the whole science switches track.
The whole time the design has been right under everyone's noses.
The warning is: Should one build the circuit do not, I repeat do not let the reverbs back into the power grid. I have done that too. That is why SM stated 'If you connect the TPU to ground you lose it.'  ;D He's damn right you'll lose it. The authorities will be knocking on your door.
I escaped by the skin of my teeth on this one.
I went from burnt nerves to the shaking the structure of the house to the blowing house electronics to damaging the neighborhood electronics to the transmitting power reflections in the house grid system. I thank God the GFI outlets stopped me there. The next step was obvious. The next design can cause fires in other abodes. SM even had the power towers next to his rental home. Area destruction would have been so easy.
I could have gone down in history with this one but decided freedom and my D.O.D retirement more precious.
I saw Dollard's history playing with with TPTB(the powers that be).
I worked this 'Cat and Mouse' game to its inevitible progression.
My avatar here is the answer everyone has always been looking for.
It is time to 'Release the hounds.'
Post by: F6FLT on 2019.05.10, 08:09:42
Quote from: giantkiller on 2019.05.09, 19:00:19
@F6FLT:
Reverse engineering is about understanding how real equipment works, and obtaining the plans, or if you have the plans, understanding the operating principle so that you can make your own realizations from the principle.
If you don't have the plan or the equipment, you don't do reverse engineering, you don't do anything more than play a guessing game.
I have nothing to prove...
So your goal is achieved.  :)
Post by: F6FLT on 2019.05.10, 08:11:01
Quote from: Centraflow on 2019.05.09, 17:55:57
Hi Mike,
The ground is not required as long as we are dealing with dipoles. A conductive loop is a magnetic dipole, so no ground is required.
An electric dipole antenna is also a dipole, and therefore no ground is required for its operation. Why does it have to be placed high? Because there is a capacity between it and the ground and the tension at its ends is high, so there could be significant losses when it is horizontally polarized, as well as an upward radiation pattern by reflection, rather than horizontally. In a vertical position, the ground does not matter, but obviously the higher the dipole is, the further it will radiate in the horizontal plane, before reaching the earth.
On the other hand, with a vertical quarter-wave antenna which is a monopole, the ground is necessary for operation, it is the ground that provides the image of the electrical charges that allow the quarter-wave to function as a dipole, it has the same role as the second element of the electric dipole antenna.
And at a distance from a wavelength, it generates exactly the same electromagnetic wave as a magnetic loop. It should not be forgotten that a vertical magnetic loop provides a horizontal magnetic field but also, as soon as it radiates, a vertical electric field, just as the vertical quarter-wave antenna provides a horizontal magnetic field at the same distance. There is no mystery, all this is modelled very well, it is done every time a new radio station is installed, or telephone operators deploy their mobile network.
The idea of using the ZPE cannot be inferred from these banal operations, it is a completely unexpected and gratuitous idea unrelated to any operating principle and that nothing of the behaviour of these elements can support. The ZPE is invoked every time we want to see overunity somewhere without having the slightest idea of how it works, and often for a reason because it doesn't work. It's the easy way out. When I am told how energy could be extracted from an already minimal energy state, which is the ZPE, then I might say that there is an idea. Right now it's just a magic word that we put on anything.
Post by: Centraflow on 2019.05.10, 15:07:24
Quote from: F6FLT on 2019.05.10, 08:11:01
Hi Mike,
Here is an excellent video from an air friend which really does explain the magloop
The term ZPE was just that, a term. The energy charge which exists, always, is between the earth and the ionosphere, this is what I am after, that charge. A mag loop is similar to a dipole but not exactly the same, many are confused with that, the circumference of the loop has to be less than 10% of the wavelength being used or it just will not work and is unique to the mag loop AFAIK.
I used to have a 20m mag loop and a G5RV, on 20m, the mag loop worked better and was very quiet as far as noise was concerned. On 10m I used a sigma IV vertical which is a very special antenna with a loop ground plane, best contact was 10w from the UK to Perth in Australia and giving me a 5 9 at the height of sunspot activity, the world of antennas is huge and not all understood, we all are learning every day ^-^
Well back to building my special type of dual mag loop O0
73's
Post by: giantkiller on 2019.05.10, 18:13:13
Great pearls, my friend!
Quotethe circumference of the loop has to be less than 10% of the wavelength being used or it just will not work
https://www.youtube.com/watch?v=adJp1zO9qfo (https://www.youtube.com/watch?v=adJp1zO9qfo)
And isn't it odd that the loop in the video is the same size as the LTPU?
QuoteSo your goal is achieved.
Not yet. I have a few more avenues to include from other areas of electronics so as to not expose myself.
Ready?
QuoteWhy grounding is so important ? Improper grounding or earthing can create a lethal hazard. Correct grounding is essential for correct operation and safety of electrical equipment. Most countries have strict regulations about how electrical installations are earthed for safety. Earthing can solve many problems, but it can also cause new ones. One of the most common problems is called the "ground loop" or "earth loop".
Why a ground loop is a problem ?
Ground loops are a mystery to many people. Ground loops are the most common cause of AC line frequency hum in sound systems. A ground loop in the power or video signal occurs when some components in the same system are receiving their power from a different power source from other components. This may cause your system to have different ground potentials. This becomes a problem because amplifiers and mixers need an electrical earth connection to their chassis to provide screening against interference. Audio input leads are screened against interference and the screen inevitably connects to the same earthing point in the amplifier / mixer. Audio signal (from a guitar for example) is a variable voltage relative to earth. When the earth potentials of two or more pieces of equipment are different, the relative signal is less stable, screening is compromised and interference manifests itself as hum. Ground loop is a common problem when connecting multiple audio equipment together. Considering the quantity of equipment used on a typical stage it is surprising that ground loops are not more common. Ground loops commonly cause a humming noise to audio signals and interference bars to picture. Ground loop makes the system sensitive to pick up interference from mains wiring which can lead to erratic operation of the equipment or even damage to the equipment. Audio-frequency ground loop problems are typically in the low millivolt range, but there does not have to be much interference in a grounding system to cause problems in your audio system because of the hugh amount of amplification applied to microphone and instrument sources. Remember that there is no absolute ground. There is a certain amount of resistance to electrical current between all grounding points. This resistance can change with humidity, temperature, connected equipment and many other variables. No matter how small, the resistance can always allow an electrical voltage to exist across it. The ground wires between wall sockets and power company transformers are not perfect conductors and neither is the shield of your signal cable. If they were, ground loops would not be a problem. Certain types of cable screening can give better results because they cover the inner signal cores completely eg foil screening in multicores and braid screening on good quality XLR microphone leads.
http://www.epanorama.net/documents/groundloop/index.html (http://www.epanorama.net/documents/groundloop/index.html)
The middle stage of the stun gun is a ground division. It is normally called a charge pump stage. The microwave oven has the same circuit but the internal spark gap has been incorporated in the magnetron.
This section of the circuit can be flexed in a multitude of ways to achieve a resonant magnetic envelope. It is also a great place to position coupling antennas to.
The goal is to make this section perform like the field expression of the secondary of a Tesla coil. And it is pretty simple because in the circuit we actually create a physical loop instead of the natural loop of the Tesla coil physics.
Now apply the High Q amplifier circuitry (radio tuning) to this section and one can easily see the oscillator in stage 1 of the stung gun circuit.
Putting this all together we have a stungun, a transmit/receive radio, and a ground loop difference. It really is this simple, like SM stated.
SM made many off handed statements about exercising the potential in the ground loop section. His best one was when he was working on a 'special' speaker system he noticed an anomaly. Yeah right... It was the normal feedback loop in an incorrectly connected amplifier system. No magic here. Shat gets blown up in a self oscillating system. That system thumps too when you stand in front of the concert speaker. It is good practice to not place anything on the speakers when playing.
One more:
Pager motors in the small units and a speaker in the LTPU black box. Why not? Great feedback indicator and fulfills an inductive requirement. Plus a little magic in the demonstrations.
Has there ever been any TPU conversation of any synchronizations between the vibrations received when holding a unit and the operational talk that SM gave?
The overwrap is a helical antenna that fires in a circular fashion as a feedback mechanism. Magnetic field manipulation in the audio range.
The TPU is a ground loop exercised in a harmonic fashion via tuned charge pump through antenna coupling.
End of story.
Post by: Bob Smith on 2019.05.13, 17:28:07
Great Jeri Ellsworth video, Mike.
What struck me about the magloop is that the coil and variable cap arrangement doesn't "kill the dipole," to quote TB.  The setup got me thinking about why litz wire might be a better way to go for a TPU (i.e., in this case, a single coil of mult stranded wire with both ends terminating at terminals of a capacitor).  SM is alleged to have talked about using is lamp wire, and I'm wondering if this jibes well with the litz wire idea as a more effective way forward. Lots of people talked about lamp wire giving more surface area (skin effect), but there are other benefits from charging inductors in parallel.
Interesting that Jeri talks about how the voltage in the magloop goes to the cap, while the current stays in the coil.  This seems corroborated by Eric Dollard & TT Brown's Borderlands video showing how resonance separates amperage/magenetism from voltage/dielectricity in an RLC setup.  Here's the link cued up: https://youtu.be/6BnCUBKgnnc?t=1386
With GK's little nugget about his avatar, this arrangement begins to make more sense to me.
Obviously lots of other steps.
Bob
Post by: giantkiller on 2019.05.13, 18:24:00
Quote from: Bob Smith on 2019.05.13, 17:28:07
Interesting that Jeri talks about how the voltage in the magloop goes to the cap, while the current stays in the coil.  This seems corroborated by Eric Dollard & TT Brown's Borderlands video showing how resonance separates amperage/magenetism from voltage/dielectricity in an RLC setup.  Here's the link cued up: https://youtu.be/6BnCUBKgnnc?t=1386 (https://youtu.be/6BnCUBKgnnc?t=1386)
Bob
In the Eric video @ 34:00 he spills the beans!
The HV comparisons are immense.
Apply that information to a device trying to produce a usable voltage and one can invariable see if the device in question is even close to the Mark(pun intended).
TEM is Edison.
LMD is Telsa.
See the problem with most of the standard training now?
Post by: forest on 2019.05.15, 18:34:08
giantkiller
Could it be that in so created ground loop electrons continously flow ? What my intuition told me immediately is connection between Barbosa& Leal patents and Corum brothers analyse of Tesla receivers (crystal radio).
I'm trying to connect all this but I never worked on radio circuits.
Can we create such ground loop which is in the same time magnetic loop (like Tesla said - amplification of current in antenna) and do not radiate radio waves ? Correct me if all I said is buulshit , because I have no experience but I'm quite sure the final device should not radiate EM
Post by: giantkiller on 2019.05.15, 18:56:29
Quote from: forest on 2019.05.15, 18:34:08
giantkiller
SM placed the amperage clamp meter in the center of the LTPU and the meter showed ac current. Electromagnetics at large.
Now imagine if you will (in my best Rod Serling voice), a large oscillating resonance between those two rings sliding back and forth, up and down the center modules. A magnetic gradient will be measured.
Post by: ion on 2019.05.15, 23:00:56
Quote from: giantkiller on 2019.05.15, 18:56:29
The clamp meter SM used (UEI DL235) was capable of reading DC static fields external to the device as well as AC. I purchased the identical unit and it has a zero button to null out the residual static earth magnetic field. The manual is attached that describes the use of the zero button, and you can see SM zero the meter using the button right before he waves it around the unit. So are you positively sure he was reading an external AC field? I would leave all options open until proof is given.
I also purchased the Extech Wattmeter DW6060 used by Dr. Schinzinger so that I might further understand if it's use as seen in the video is accurate. I also intend to purchase additional test equipment as seen in the videos, such as field search coil and field meter, also the EMI tester, DMM etc.
IMO No one I repeat no one yet has demonstrated a working stand alone TPU  similar in shape, size, simplicity and power output as SM has, so thus far it's all talk no action. Prove me wrong.
Post by: giantkiller on 2019.05.16, 00:05:23
The TV interference and the thumping advertise AC. Not dismissing D.C.
Post by: Room3327 on 2019.05.16, 17:49:48
Quote from: ion on 2019.05.15, 23:00:56
Hi Ion,
  The clamp on ammeter I used, and it too registered current around my TPU builds, was a d'arsonval mechanical movement an old Sperry Mod. SPR-300 and I really don't know how to explain it.  I can't get the meter to budge around any and all things I have waved it at, but stick it by a TPU of mine with a rotating field and it registers.  I thought a motor field would do the same trick but I don't get any movement around running motors either so I don't know what to say except that a working TPU must have a similar rotating field to what I have got going on in my builds. My builds are about the same size, shape and weight as S. Marks, and my meter is totally different then his but showed the same thing, with some tunings on my TPU I had readings just over 40 amps with 600 ma. input to the toroid.  I don't think S. Marks ever showed more then 2 amps. on his.
Room
Post by: giantkiller on 2019.05.16, 18:04:05
And we notice here that there is an oscillatory harmonic in the midst of the resonant bouncing.
https://www.youtube.com/watch?v=8HVA00LnKBc (https://www.youtube.com/watch?v=8HVA00LnKBc)
Heterodyning and eclipsing frequencies cause very high transients in space(EMPS).
This can be see as 'Action at a distance' in some surroundings.
A Tesla coil has EMPs inside the resonant magnetic field.
I post this extra because of his attention to magnetic detail:
https://www.youtube.com/watch?v=B015P0XFl9g (https://www.youtube.com/watch?v=B015P0XFl9g)
Post by: F6FLT on 2019.05.19, 12:56:32
Quote from: giantkiller on 2019.05.16, 18:04:05
In this video, we see only permanent magnets subjected to the low frequency magnetic field of an electric magnet. It's very commonplace.
Post by: rensseak on 2019.05.19, 20:49:57
Quote from: F6FLT on 2019.05.19, 12:56:32
Here the full video of it.
https://youtu.be/HKoUd8l7yZE (https://youtu.be/HKoUd8l7yZE)
Post by: Chet K on 2019.05.19, 20:58:02
last I heard Marco was not well [end of last year
in my last exchanges with him he mentioned quote " Waiting to Die" [from illness]
I did reach out again but got no response ,will try again in-case he is reading here.
always loved his thoughts and contributions.
Chetkremens@gmail.com
Post by: Magluvin on 2019.05.19, 23:17:49
Quote from: rensseak on 2019.05.19, 20:49:57
I remember this vid.  The kick coil looks to be a toroid winding, probably orbo effect to drive it.  I wonder if there were many more magnets inline if the input would remain the same?
I remember a few vids some years ago that had 1 driver spinning a sphere mag and then setting small jars with sphere mags all around the driven sphere, and even setting up more jars, and more jars. And they were all spinning.
I think it was lidmotor that initialized that trend back then.
Mags
Post by: giantkiller on 2019.06.09, 17:58:46
Tpu like setup:
https://www.powerelectronics.com/power-management/step-down-dc-dc-converter-eliminates-ferrite-cores-50khz-enabling-power-supply-chip?PK=UM_Classics06119&utm_rid=CPG05000006675567&utm_campaign=26112&utm_medium=email&elq2=f1128cc7ee5045cfa33949677cfaf2e7&oly_enc_id= (https://www.powerelectronics.com/power-management/step-down-dc-dc-converter-eliminates-ferrite-cores-50khz-enabling-power-supply-chip?PK=UM_Classics06119&utm_rid=CPG05000006675567&utm_campaign=26112&utm_medium=email&elq2=f1128cc7ee5045cfa33949677cfaf2e7&oly_enc_id=)
Post by: Centraflow on 2019.06.11, 14:53:23
But the TPU uses ferrite cores in all models, even in the one that looks as though it does not, Peter found it, a small CMC which I have the same one. each coil has 29mH and if wired to buck together the inductance nearly cancels at 0.5mH, but wired so as not to buck the inductance is X4 at 116mH.
This seems to only happen when wound together on the same ferrite, but if they are an air coil the inductance only adds simply, X2, and not X4.
Now if you mix charge displacement current between two magnetic loops which have a capacitive connection, current can be induced into a voltage boost, overwound, scenario which is in phase with the boosted voltage, you don't need much if looped somehow as even at 50kHz the power will escalate out of control. (boost circuits and class E amplifiers are between 90-100% efficient) ;)
Post by: giantkiller on 2019.06.27, 22:08:07
And further more...
Post by: Reiyuki on 2019.06.29, 07:40:34
Quote from: giantkiller on 2019.06.27, 22:08:07
And further more...
That will all work on the same loop?!  :o
Back to the bench >:-)
Post by: giantkiller on 2019.06.30, 07:04:00
They are shown in circular 3s, 5s and 6s combinations.The center power generation is an Alcubierre drive, not really a propulsion drive. More of a resonant generator that feeds the Tesla coils.There is a tuning capacitor in the charge pump and drive frequency that shifts the balance on the TTB reflectors. Thereby shifting the mass while still maintaining elevation.
The excessive field generation is why onlookers get burned.
The larger Alcubierre models are shown driving a charge pump into a large laser based ionic drive. I often wondered why this medieval step is used when a straight resonant power generation would perform the same event. Space is filled with atomic structure so magnetic manipulation is all that is needed.
Two ring configurations performing destructive resonant transmission reflections. No different that placing an amplified microphone in a driven speaker cone.When pointing an electric guitar at an amp one has two coil loops facing each other. One transmitting the other receiving. The change in the feed back comes as the direct face to face coil alignment is altered at slight angles. When the two coils are left alone in a powered parallel alignment, equipment self destructs. Possibly has a use, yes?
Title: Re: The final answer...
Post by: giantkiller on 2019.06.30, 18:00:47
QuoteFor every action there is a reaction, and think how a transformer can buzz with AC. Now make it a square wave and you could hammer it around a bit, even more so than with sinusoidal AC. So, it depends on your frequency a bit, too, I'd say, for you to set up a noticeable or worse mechanical standing wave in your transformer itself. However, depending on the size and robust quality of the transformer it should be OK to do at your power level, at least. On the other hand, will you get square wave out? I think it won't be "as square" as the input. The windings (and their proximity to the plates, if any), also create a changing inductive environment, so it may goof with the shape of electrical wave(s) a bit. And the fact that the transformer will have those mechanical waves (manifested as vibration or sound), assumedly worsening at certain frequencies, leads me to believe that it will not pass all frequencies at the same efficiency, thereby further distorting the "squareness" of the wave. That may be saying the same thing twice in two different ways, but maybe at least for more than one reason. It may be, though, that the two are just manifestations of the same condition. Not sure at the moment. Either way, not going to be a perfect representation of the input. Also, I wonder if you are going to get EMF (or reverse EMF) effects at the points of voltage reversal, which may grossly distort the output.
Post by: giantkiller on 2019.06.30, 18:11:42
QuoteThis is exactly what happens in the ignition system of older cards with points. The make-and-break of the points provided a 12 V square wave to the ignition coil (a transformer)!, which then output several thousand volts. A similar method was also used in "the olden days" to produce high voltage AC from a battery, such as in spark-gap radio transmitters./
Post by: giantkiller on 2019.06.30, 20:00:16
Like SM stated: Much like a radio...
https://en.wikipedia.org/wiki/Direct-conversion_receiver (https://en.wikipedia.org/wiki/Direct-conversion_receiver)
https://en.wikipedia.org/wiki/Reflex_receiver (https://en.wikipedia.org/wiki/Reflex_receiver)
Same as it ever was:
 https://en.wikipedia.org/wiki/Regenerative_circuit (https://en.wikipedia.org/wiki/Regenerative_circuit)
Post by: giantkiller on 2019.06.30, 21:20:23
Superregenerative receiver
QuoteThe superregenerative receiver uses a second lower-frequency oscillation (within the same stage (https://en.wikipedia.org/wiki/Squegging) or by using a second oscillator stage) to provide single-device circuit gains of around one million. This second oscillation periodically interrupts or "quenches" the main RF oscillation.[38] (https://en.wikipedia.org/wiki/Regenerative_circuit#cite_note-38) Ultrasonic quench rates between 30 and 100 kHz are typical. After each quenching, RF oscillation grows exponentially, starting from the tiny energy picked up by the antenna plus circuit noise. The amplitude reached at the end of the quench cycle (linear mode) or the time taken to reach limiting amplitude (log mode) depends on the strength of the received signal from which exponential growth started.  A low-pass filter (https://en.wikipedia.org/wiki/Low-pass_filter) in the audio amplifier filters the quench and RF frequencies from the output, leaving the AM modulation. This provides a crude but very effective automatic gain control (AGC).
Post by: giantkiller on 2019.08.04, 17:39:11
The device must resonantly transmit to achieve overunity.
Poor Eric Dollard is not allowed to transmit.
His experiments are all receivers. Good start but not the full picture. He is under the radar with his new approach though and he will go down in history. If he would only transmit...
Post by: giantkiller on 2021.04.21, 00:25:27
I thought this might open some minds.
Post by: poynt99 on 2021.04.21, 00:45:26
I think the big one was more than double the power though????
Post by: giantkiller on 2021.04.21, 01:24:00
Oh yes. What I posted here is a configuration. The two center horizs are parallel to each. As each charge pump rises in field volume the center TPU is crossed triggering a large collapse onto the large middle or smaller bottom FE loops. That wire is then the new conductor. The LTPU is actually two. This is why there are 3 sets of wires that show up in the cross cut TPUs.We are all experienced in resonant field collapses. Most circuitry dumps this to ground. The TPU has no ground.
Post by: muDped on 2021.04.22, 05:06:42
Quote from: ION on 2019-05-16
I am very much in agreement with this post made by ION nearly two years ago.
Not only has no on been able to successfully replicate the TPU but, in addition, no one has rationally theorized where the Anomalous Energy Demonstrated by the TPU may have been sourced from.
The fact that Daniel Pomerleau has made similar demonstrations witnessed by several audiences of observers with simple coils of wire provides food for thought, however.
Additionally, certain Conjurers or Magicians have publicly displayed the ability to illuminate Light Bulbs during their stage acts without any sort of electrical connection at all.
So where does the Energy come from?
Why does it seem that only certain people have the ability to make it manifest?
There must be an answer which makes Scientific Sense.
I do sorely miss ION and his analytical capabilities and his common sense.
Post by: giantkiller on 2021.04.22, 13:55:54
https://www.nuenergy.org/nikola-tesla-radiant-energy-system/ (https://www.nuenergy.org/nikola-tesla-radiant-energy-system/)
QuoteEnergy Directly from the Atom
The radiant energy system is a self-oscillating capacitive system. Once it is set into oscillation, very little power is expended in keeping it going. Because it is an electrostatic oscillating system, only a small amount of charge moves through the system per cycle, that is, the coulomb per seconds = amps are low. If the charge is used at a low rate, the energy stored in the system will be turned into heat at a slow rate enabling the oscillations to continue for a long period of time.Tesla's "COIL FOR ELECTRO MAGNETS," patent #512,340 is a very special coil design because, unlike an ordinary coil made by turning wire on a tube form, this one uses two wires laid next to each other on a form but with the end of the first one connected to the beginning of the second one. In this patent Tesla explains that the double coil will store many times the energy of a conventional coil.[1] Measurements of two coils of the same size and with the same number of turns, one with a single, the other with a bifilar winding, show differences in voltage gain. These bifilar Tesla's coils can be explained solely on the basis of their electrical activity. A bifilar coil is capable of holding more charge than a single wound coil. When operated at resonance, the distributed capacitance of the bifilar coil is able to overcome the counter – electromotive force (e.m.f.) normal to coils, inductive reactance.
Because of the electrical activity, a bifilar coil does not work against itself in the form of a counter – e.m.f., the potential across the coil quickly builds to a high value. The difference between the turns becomes great enough that the energy is practically all potential, at this point, the system becomes an electrostatic oscillator.
Minimal work is done in my radiant energy system due to the absence of wasted displacement currents. As small heat losses occur, oscillations are maintained by surplus charge generated by atomic catalytic reactions, energy is siphoned from the kinetic moments of these charges. Very low energy expenditure allows power delivery to an electrical load over an extended time period without an external fuel supply. After an initial input of energy from an outside source, the radiant energy electrical generator will operate as a very efficient device.
By reviewing history it is understandable why some inventions are not commercialized. It is economics, not science, that is the main factor. It will be remembered that alternating current was opposed by powerful financiers in Tesla's time.
Michael Pupin, noted in his autobiography:
"...captains of industry...who were afraid that they would have to scrap some of their direct current apparatus and the plants for manufacturing it, if the alternating current system received any support. A most un-American attitude...but ignorance and false notions prevailed in the early nineties, because the captains of electrical industries paid small attention to highly trained scientists."[2]
It takes very little energy to promote a resonant field.
The charge pump is the heart of microwave ovens, analog tv, automotive ignition systems. and stun guns. SM even promoted the exploding TV as an accelerating charge pump of vast amounts of energy. The main problem with the exploding T.V. circuit was there were no components in place to dump the collapsing field to ground. Sm stated 'There can be no ground in the TPU.'
I promoted setting a charge pump of a 20 foot diameter next to an airport. He emphatically stated 'No'. I got his attention.
Application of the High Q multiplier circuit merged with the charge pump circuit is the TPU schematic yet no one tries this.
The field in the charge pump(the large vertical windings) builds and crosses the space to the center toroid triggering a field collapse into the middle FE loop. This creates a one way magnetic diode. Does anyone catch this? The original promotion was '90 degree coupling'.
I am the only one who has spent years showing the subsections of this circuit without conjecture from the greats, Ion, Marco, SM, Erfinder and the others that left immediately after I exposed the charge pump as an integral part of the device. The last statement made to me by Moab was 'Put a diode in it!'. Configuration proof.
I even built the large TPU in accordance with what we have seen and proved the configuration works as a charge pump replicating the field size and strength promoted in the exploding TV. I even EMPd 5 cable routers throughout the last neighborhood I lived in. More proof. The energy is there.
Final answer is and for the new members that are eager the schematics are in my previous posts across OverUnityResearch and OverUnity. They are out of sequence.
Exact copy of TPU is the LTPU build using twin lead outer wrapping. The device is staring everyone right in the face. Build that model with the large vertical air core as part of the charge pump and one will see the field strength meter show the energy. What is the final standalone device? You will see it when you start blowing shat up. The largest TPU is the Alcubierre device. Another example in our faces. Yet people want destructive propulsive detonations or free demos.
I know there are watchers that want the final answer handed them so they can self promote themselves into history. Marco warned me about this and now I have to watch this action unfold.
I am not into this for followers or fame. From the smallest to the largest devices there are many examples of the technology out there so one can not really be the hero.
It is the High Q multiplier circuit merged with a charge pump, i.e. the exploding T.V.
There it is, schematics and demonstrations. The trolls, weasels and prairie dogs finally have what they have been searching for...
Post by: giantkiller on 2021.04.22, 20:27:01
Because the TPU is an inert device it can be conspicuously housed in an inconspicuous housing.
This then can be transferred across borders relatively easy and dispersed to objective points.
Any information divulged past what has been could be deemed as a national security threat.
Its simply a charge pump...
Post by: muDped on 2021.04.22, 23:27:48
A Charge Pump is a type of DC to DC Converter which operates as a DC Transformer in effect.
Where do you suppose the "Charge" that is "Pumped" originates from and how is it accessed relating to the TPU?
Charge Pumps are indeed a fascinating study:
Charge pump - Wikipedia (https://en.wikipedia.org/wiki/Charge_pump)
Charge Pumps (https://www.maximintegrated.com/en/products/power/charge-pumps.html)
What is a charge pump and why is it useful? (https://www.powerelectronictips.com/faq-what-is-a-charge-pump-and-why-is-it-useful-part-1-faq/)    Part 2 (https://www.powerelectronictips.com/charge-pump-useful-part-2/)
What is Charge Pump : Working & Its Applications (https://www.elprocus.com/what-is-charge-pump-working-its-applications/)
A Related article:  Voltage Multipliers (https://en.wikipedia.org/wiki/Voltage_multiplier)
Post by: Reiyuki on 2021.04.24, 21:51:21
Quote from: muDped on 2021.04.22, 23:27:48
When dealing with a complex machine I find it useful to look for the major components, see what they do and how they might fit together can often give a better idea how the whole machine functions.
Typical jet engine:
compressor fans -> intakes and compresses air.  Also acts as a one-way valve to prevent combustion air from exiting out the front
combustion stage -> fuel injected, combustion heats and expands air in the chamber
exhaust fans -> absorbs a portion of the energy in the exhaust forward to the compressor fans to maintain the cycle.
Charge Pump -> Turns AC into HVDC with some hash (sound familiar?)
Ferromagnetic wire -> Absorbs magnetic waves at any angle, as opposed to diamagnetic wire which must be parallel to the opposing wire.  (personally I found nickel works even better than iron)
In conventional charge pump circuits you will generally find a single inductor used.
Imagine if that inductor served more than one purpose.  You could do all kinds of things with it, including enhance or even operate another charge pump.  A dual-purpose for what would otherwise be a wasted magnetic impulse.
For reference, I haven't completed G's more *interesting* toys, but I have confirmed some of the individual components and principles ('iron wire migraines' will ring a bell for some..) >:-)
Post by: giantkiller on 2021.04.25, 17:38:45
Further on...The resonant charge pump exists in a lot of places
Post by: Reiyuki on 2021.04.26, 19:33:45
Quote from: giantkiller on 2021.04.25, 17:38:45
GK, might I recommend nickel strip rather than iron wire for others trying to replicate the effects?  It Can be found a thousand places and is used for spot-welding battery packs.
Certain iron alloys seem to work far better than others, while nickel strip is universally >95% pure and has the same effect (better than HD FE garden wire in my experience).
As always, thanks for your contributions O0
(ps:A few elements in your schematic above pop out at me.    1: ferromagnetic wire used inline and not being 'pulsed' directly.  2: battery power only, no ground mentioned, and 3: Charge pump portion in blue is 'floating' as only one wire is connected to the rest of the circuit.  I suspect the placement of the cap and diode is essential...)
Post by: giantkiller on 2021.04.26, 23:33:46
The snubber fet can be connected inductively to the charge pump to further isolation and / or with a spark gap/neon in there.
And yes there are better components and materials but SM blurted Radio shack so I stuck with the 1996 era retail items.What is not apparent in the schematic is the FE and the Charge pump loops are in parallel.
And there are actually double the charge pumps. This relates to the two tpus picture I posted previously.
SM showed the single TPUs then the large TPU.
In between? He cut the three layer tpus in sections showing the top and bottom charge pumps and the middel FE wire with the inductive loops intertwined.
He even shows the twining in the wiring from the outer ring to the inner center toroids.
SM showed so much in the mechanics.
Post by: Reiyuki on 2021.05.05, 21:36:05
Quote from: giantkiller on 2021.04.26, 23:33:46
In between? He cut the three layer tpus in sections showing the top and bottom charge pumps and the middle FE wire with the inductive loops intertwined.
That is neat O0.
The ferromagnetic wire core picks up the 'hash' from the charge pump as-expected, but the hash keeps getting larger and larger in amplitude as static voltage is built-up in the verticals (net power in is constant throughout the cycle).
It gives that beautiful inverted-trumpet shape >:-)
Post by: giantkiller on 2021.05.06, 00:32:47
And each segment starts off with a minnie EMP! The iron loves that.
A loop of iron wire essentially becomes a Permanent Magnetic Holder. Storage if you will.
I have connected LED/Resistor/cap across a break for it to light.
Imagine doing that with powerline transformers.
Raise the distance from the ring to the trigger to increase power. The volumetric space of the magnetic sphere increases placing more impact/events on the iron wire.
A 17 in diam LPTU gives a resonant 3 feet toroidal area.
The next step is to put a quadrature pulsed driver in place of the center toroids. This will impose another effect on the field. I sure wish we had a viewing filter to see the 3d interplay.
What breaks the pulsing at the end? A spark gap somewhere?
Congratulations on achieving that. Now there are 2. I wonder if SM is still available?
I got that same scope. I like it a lot.
Attached are my detonators.
Post by: Reiyuki on 2021.05.06, 01:49:45
I knew I'd pique your interest with that one ^-^
At the moment it is not even 1/2 of a TPU, maybe at most 1/3rd.  Instead of building a complete unit, I am studying the individual modules one-at-a-time.
* 3 turns of iron wire 12in diameter wrapped with a couple dozen turns of speaker wire, helically, similar to fTPU.
* Charge pump is a cheap off-the-shelf unit, underpowered to limit power and peak voltage.  <150mw at the moment so as to not let out the magic smoke.
https://www.amazon.com/Boost-Power-Module-Voltage-Generator/dp/B01GM9B4R0
* Gas discharge tube serving as the snubber  (have tried 230v and 600v so far).
* Each piece of speaker wire is charged to an opposite potential and the GDT snubber releases the stored potential.
* Measured scope output is on the iron wire 'core'.
Excluding the 'EMP' event, the intensity of oscillations in the wire core seemed to be proportional to the voltage gradient in the charge pump, and NOT on the input power.  That's really weird and something I will have to confirm later with an HV probe.
Post by: giantkiller on 2021.05.06, 02:07:09
In case you haven't noticed you have achieved 3d induction. Iron is an antenna.
This whole time the 90 degree induction was blown off because the minds were trained to look at copper.
But antennas listen well. You know, 'Like a radio'... O0 (famous TPU quote)
Thank you for these tests. I've been 'out there' for neye on 15 years now.
I almost forgot: The next steps are akin to Tesla coil tuning and testing (http://www.hvtesla.com/tuning.html).
He shows methods of safe testing.
You don't not want to smoke your equipment. There are only two things that limit you and that is lack of equipment and FCC transmission regulations. Not just radio...Dont be a prairie dog.
You are about to see some really cool shat(thats William Shatner to you).
You get enough of these proofs done and they build up to...
My LTPU frame is 100% plastic.
You can actually take a stun gun circuit and insert your loops in the charge pump stage.
Thats if you want a larger EMP.
That can integrate a snubber into the unit at the same time.
So instead of adding a chemical medium like Stanley Meyer does we just grab the EMP. >:-)
Courtesy of Spherics and the other guy.
Post by: giantkiller on 2022.01.21, 05:22:35
Turns out that the TPU is a 2 stage resonant Linear accelerator that expands and collapses in on itself. This is where the thumping comes from.
The rotating magnetic field goes bidirectionally through the center of the device in a twisting fashion.
Post by: Allcanadian on 2022.01.24, 04:28:06
Hey GK
Nice to see you back and I always enjoyed your posts, they make me think and thinking is good...
It looks like Mike aka Centraflow is making some progress in this area. Have you considered magnetic field displacement?. No to expand or contract a magnetic field from it's source but displace ie. move a magnetic field. Many in the past such as Moray and Schauberger spoke of "flowing magnetism" possibly the alter ego to a motional electric field ie. Weber?.
In this respect the source is not actually "the only source".
Post by: giantkiller on 2022.01.24, 05:16:04
I was waiting for someone to respond:
#1
I am haunted by the charge pump circuit, a simple diode facing into a cap. The tap point is between.EVGray patent 4,595,975 shows this.He doesnt drive the motor with current but a HV smack from the discharge tube firing. That smack/rogue wave/emp/bellyflop pushes the motor along with external emf. This is a bruteforce method as he is driving standard motor/stator configuration.
#2
 The Alcubierre drive is a two field bubble, one larger that the other. The ring is the TPU but driven differently as in tapping a resonant field to keep it energized on both rings.
 Spark gaping one of the fields against the other like two Tesla coils facing each other.
#3
In the current test of an EMF drive the guy takes a HVAC 6" to 8" connector and attached a household microwave magnetron to the side. He produces propulsive force. I'm like what?
My idea is to attach three facing inward to produce a vectored point culminating to a higher propulsive force. But this will show up on the equipment in the other 'Area' where they test Top Secret and black comm protocols.
These 3 designs produce very noisy signatures that the FCC and military disdain in the public access. This is the same noise path that Dollard went down till he got in trouble. The little tabletops work but to scale up takes a secluded environment. Flipping magnets in a ring are actually the correct direction but too small to propel any sizable vehicle. But #3 is the model that matches the AG craft with the multiple outlets on the underside. Shifting the field would perform a variable Alcubierre instead of a straight line linear propulsion that he promotes. The days of tubular craft are so passe.
 The charge pump is the starting point and key to planetary escape.
Wardencliff and Colorado Springs lab are perfect examples of very large charge pumps.
Post by: giantkiller on 2022.01.24, 17:32:03
The force acts on the electron only when the magnetic flux lines are cut.
...because excitation is the only way matter absorbs electric energy without heating. We have heard this before
...Very little energy is required at higher frequencies to produce sheets dense enough to exhibit anomalous effects.
http://webozz.free.fr/Free%20energy%20data/magvid.htm (http://webozz.free.fr/Free%20energy%20data/magvid.htm)
https://sites.google.com/site/freeeeenergy/magvid (https://sites.google.com/site/freeeeenergy/magvid)
I could pull quotes from this page all day that match up with the three previous designs.
Post by: AlienGrey on 2022.01.24, 19:44:59
Quote from: verpies on 2022.01.24, 09:43:55
It is also a charge pump.
Eee heckers! Well there is a thought, with the war between the new president Joe Biden and the Space X Tesla car manufacturer Elon Musk concerning the US cant let go of Coal production or petroleum semi fossil fuel is anything to go on it looks like Biden wants to kill off Zero point technology and production!
before any one says this is off topic I think this concerns all of us.
Post by: giantkiller on 2022.01.24, 23:18:19
Quote from: AlienGrey on 2022.01.24, 19:44:59
Eee heckers! Well there is a thought, with the war between the new president Joe Biden and the Space X Tesla car manufacturer Lon Musk concerning the US cant let go of Coal production or petroleum semi fossil fuel is anything to go on it looks like Biden wants to kill off Zero point technology and production!
Oh no. I believe you are right on target.
But instead of more detail entering:
Has any one here thought about approaching Elon? All the info on this site is valid and I can assure everyone that the solution IS in the site if not in my posts.
All anyone needs to know is 'Charge pump' and the output head its attached to.
For instance my biggest design is two parallel coils 10 meters across triggered with a Tokamak spark gap fired by a FET switch 5x5x5 meters, grown in space or a current sharing array.
Think of it like a large Tesla coil/TPU configuration. The two coils configured like Alcubierre per the previous description.
I would bet this would get Elon's attention. This could be built in 30 days and we would be testing a prototype travel in space.
The clincher is 'And no one would be the wiser for we OUers are considered fringe.'
Search 'How to contact Elon'. I already have.
Linear accelerators, microwave ovens, lasers, rail guns... I could go on.
 The age of larger generators is over. This is the age of charge pumps. The EVGray schematic has a charge pump in it. The Tpu thumped.
Post by: giantkiller on 2022.01.24, 23:38:33
I just sent an invite to Elon on Twitter.
Cajones, eh?
Post by: giantkiller on 2022.01.25, 21:13:08
https://openems.de/start/index.php
(https://openems.de/start/index.php)https://www.opensourceimaging.org/project/open-ems-a-free-and-open-electromagnetic-field-solver/ (https://www.opensourceimaging.org/project/open-ems-a-free-and-open-electromagnetic-field-solver/)
Post by: Allcanadian on 2022.01.26, 19:06:20
GK
QuoteAll anyone needs to know is 'Charge pump' and the output head its attached to.
Conceptually we would want a charge pump to act like a heat pump. A heat pump can have a COP>6 and move 6 times more heat energy than is input electrically to drive the process. In this respect the notion of free energy and overunity is ambiguous and not required. What were actually talking about is moving more of energy A using a smaller amount of energy B, B being our input.
I have already done it and it's not that difficult however as many other successful inventors have said the output must be independent of the input. That is we cannot move heat using more or other heat directly and the input must be independent of the output.
For example, some claim we cannot move a lower heat into a higher heat without work, heat being a measure of molecular motion. They claim this is true because the higher heat naturally flows into the lower heat. Which suggests a certain degree of ignorance on there part because nobody suggested the process should be natural. In fact we know it cannot be natural and must be man made using our intelligence and a measure of control. We control the process to ensure it cannot act naturally but more so in a practical way which benefits us.
This is what supposed free energy is all about, using our intelligence and knowledge to control something so that is does not act naturally. It does not do what it's supposed to do but something else many might deem unnatural. Think about it, man flying is unnatural but we did it, man going to the moon is unnatural but we did it thus nature has little to do with our intelligence and making progress.
Our intent should be to defy nature to do our bidding...
Post by: giantkiller on 2022.01.26, 19:52:52
(https://kids.kiddle.co/images/thumb/f/f2/Manetron_Magnet.jpg/600px-Manetron_Magnet.jpg)
Post by: giantkiller on 2022.01.27, 00:33:22
Quote from: Allcanadian on 2022.01.26, 19:06:20
Dont forget, we are not building a wave guide to deflect but are using a resonant structure to push against.
One can search anything and find answers but the one thing I can not find is the useful gathering of the explosive energy from the emp impact on a resonant field. I am sure the military and DARPA know this. But the science is the same as knowing about dynamite. The fuse burns to set off a cap. The impact excites the nitro and the rest is history. The Nitro is held stable by peanut oil. That initial spark can be a fire cracker like in the old days.
The Tesla coil magnifies the small internal discharge into a monstrously huge external one.
That is why my avatar is what it is where the discharge head points back into the resonant structure like the TPU and Don Smith's cart model.
The impact causes a ringing that is harvestable.
Power transmission systems have physical dampeners because a slight wind can start a destructive resonance which will destroy the towers or transformer groups. They ring themselves to death.
Nature wants stability through entropy but the resonant magnetic field is tool to work this in the opposite way. Physicists state a small push at the correct time produces greater output.
In the California living room Steven Mark held a TPU to his side. It was still running. He was showing a way to measure any motion from an EMP strike against a resonant field.
The only information that was able to leak out was 'viewers said it thumped'. Would be interesting to hang one from a tether to 'see' this action. Nobody posted this test.
But this test is an easy one because I have a Tesla coil with an audio input and the output wire, floating in space, sings. Those are vibrations impacting ear drums with intelligent information at a distance.
The spark gap is driven with audio and transferred through the resonant field.
Post by: F6FLT on 2022.01.31, 16:19:47
Quote from: giantkiller on 2022.01.27, 00:33:22
...Physicists state a small push at the correct time produces greater output...
Physicists only say that a small repeated push in phase with the resonance period allows to store energy step by step in the resonant system, which can lead to a very large energy, but not more than the sum of what we have brought in each step.
Post by: giantkiller on 2022.01.31, 17:59:29
Quote from: F6FLT on 2022.01.31, 16:19:47
Correction. Resonant waves in the ocean tear ships apart by a side hit. Power transmission towers can fell by the resonant impacts that arent dampened. A slight rhythmic wave of the hands in a tub of water can move 80lbs of water over the edges.It is either a slight rhythmic motion or a high impact that this anomaly shows up.
Post by: Verpies on 2022.01.31, 18:04:06
Quote from: giantkiller on 2022.01.31, 17:59:29
That is merely the effect of the energy output.
What he has written was that this output is not greater than the sum of many smaller energy inputs.
Ditto
Ditto
Addition is not an anomaly.
Power amplification has a high yawn factor.
P.S.
Energy amplification is an anomaly, though.
Post by: AlienGrey on 2022.02.01, 11:37:39
Try https://www.youtube.com/watch?v=J6sw17VAJcI  try point at 7.05
Post by: AlienGrey on 2022.02.01, 20:24:28
If you go to Woopyjump Lorenz
You will find 2 video's that might be of use to convert unless you want to re invent the wheel
Woopyjump
Maxi energy pumping with mini kacher 1 .
wmvhttps://www.youtube.com/watch?v=RVZpL6mdW38
Teslacoil a replication of Tinselkoala amazing 220 bulb lighting
https://www.youtube.com/watch?v=ZDFEevnkuq0
Post by: giantkiller on 2022.02.02, 18:14:44
@AlienGrey,In these experiments all he is doing is altering, by addition, the discharge path.
This is why the amperage doesn't change.
In fact the lamp presents a higher impedance in the path but just happens to complete another more resistive leg of a parallel circuit.
Post by: AlienGrey on 2022.02.02, 22:59:10
Post by: AlienGrey on 2022.02.02, 23:12:18
Quote from: giantkiller on 2022.02.02, 18:14:44
Hi Mr JK I get what you are saying, but I haven't done this experiment as such as he has shown  in his video recently, but I must ask if this is an assumption or have you performed this experiment your self as if it's down to discharge one would expect some power fluctuation and if so
did you use a desk top mains power supply or a stand alone battery and if you did what differences if any did you notice and what conclusion did you notice if any ?
Post by: giantkiller on 2022.02.02, 23:40:50
I used mains and battery. As long as there is a spark gap with a step up transformer the energy is there. Its the field in the air that lights up the neon. The filament bulb needs a meter in line with it to show the current. If no current then its the field which would have to be more powerful than we see there. I am not bashing his tests. A lot of people have seen this type of operation. The next step is to get the excitations into a larger charge pump of resonant LC circuit like a Tesla coil does. Most charge pumps don't need to be on frequency. The diode just keeps accepting current into the tank. Its a half wave power circuit. Then the output heads match the molecular interface i.e., 5g, ovens, MRI, Tesla coils, stun guns, Tokamak, xray machines.The TPU head resonates the two single sidebands of a base frequency into two tanks. The thumping is the transformer action that crosses the collector by the cross coupled triggered shutoff by each spark gap in the black boxes. Works like a radio and produces EMPs as show on the amperage meter in the middle.
The guy that created the electronic propulsion engine test with hvac tube and home microwave oven circuit really intrigues me.This picture has cables running to detonators all focused at the center.
(https://nationalatomictestingmuseum.org/wp-content/uploads/2020/09/trinity-8-web.jpg)(https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fwww.atomicheritage.org%2Fsites%2Fdefault%2Ffiles%2FTR-224_4x5-cropped_0.jpg&f=1&nofb=1)
Post by: giantkiller on 2022.02.05, 05:39:13
Quote from: AlienGrey on 2022.02.02, 23:12:18
If Mr. Woopy put a motor in series with the discharge bulb he would replicate E.V. Gray's motor circuit. E.V. made the statement that the motor did not increase current load from what I can remember about his demos.
Post by: giantkiller on 2022.02.11, 04:25:07
Post by: giantkiller on 2022.04.25, 20:06:31
Placed for reference.
Post by: giantkiller on 2022.08.24, 16:02:19
I believe I did not post this when I should have before.I had been going over a simpler self oscillating feeder signal to the charge pump. The high Q mulitplier works but an outside signal is needed or something additive that the circuit can read.I had done a magnetic feedback in the past but it wasn't self starting(remember SM swiping a magnet) hence I added the audio version and this addition kick starts everything into action.With the audio loop added in league with the High Q ckt the system now blows the audio amp. This is a very specific artifact as now energy has been produced which is not from an over conducting mechanical connection but reverb and resonance.
(https://media.discordapp.net/attachments/957111791614324776/1011862617104601179/PHYZXTPU20220424.jpg?width=493&height=576)
Post by: mkjekyll on 2022.08.24, 20:59:24
Hi GK,
Most of those integrated audio amps are class D so one has to be cognizant of the switching frequency and heterodyning resonance modes.  They have the low pass on the speaker output but generally not anywhere else.  Try low passing the input and or a zener limiting circuit and you may save some amps.  Though any fast high voltage is going to punch through the semiconductor junction, often hard to catch and protect from.  TVS don't seem to always catch it and die easily also.  SM is right about vacuum tubes for benching this kind of thing, way more robust.
Mick
Post by: giantkiller on 2022.08.25, 00:58:12
Quote from: mkjekyll on 2022.08.24, 20:59:24
Hi GK,
Mick
The TDA2003 is bullet proof while the TDA2005 blows up.
When the kick occurs the silicon breaks. Tubes can handle that. The kick is like an EMP but way shorter in time.
I have performed both. The companion pulse is a single entity.I switched to the TDA2005 to achieve polyphonic operation in a lower number of modules. And not that these are mandatory. I am just through creating ckts when the block operations are out there to be had in the market. I am not concerned with my builds looking like a TPU as far a circuit configurations go. The main operation is feedback with gain between antennas. This is why the high Q ckt looks so close to a TPU. The TPU is an air core coil, a stadium if you will. The center toroids perform and the listeners/verticals receive. This is why the height and distance are seen. With out loose magnets in the ckt the thumping comes from aerial machinations. I also have placed FE wiring in parallel to achieve vibrations. This becomes a tuning feedback mechanism.
What I was aiming for were multiple things when I posted the microphones in speaker pic to SM back in 2006.The use of audio feedback achieves self oscillation with gain. This added to the high Q ckt achieves a snubbing effect as the high Q is strictly magnetic and relies on distance whereas the audio has both magnetic and air volume.
This is what I have so far. With the addition of audio my device thumps including my bench. Whats interesting is without a true power usage demo no one believes the intermediate steps.But this is ok as the PTB murdered Aaron Salter in the guise of a mass shooting by the correct party, when he advertised his water car accomplishment. He stepped into the public buffoonery spotlight.
Post by: mkjekyll on 2022.08.25, 05:17:51
GK,
Yeah the 2003 is class AB
What is required to get the full feedback effect in terms of voltage and current to the aerials?
I have some high voltage 500v very low current MOSFETS that switch very easily and fast, barely any gate capacitance close to subminiture vac tubes specwise.
If you are using a speaker I have no doubt you have a thump.  There are places one does not venture without enough subwoofer.
But I am a bit confused, you say with the addition of audio, are you driving the antennas with the TDA2003 also, or only an additional speaker?
Can the TDA2003 handle the kick or does it shoot through dead?
Post by: partzman on 2022.08.25, 13:46:46
Quote from: giantkiller on 2022.08.24, 16:02:19
Grumpy,GK,
Having designed and manufactured many audio amplifiers, I somehow fail to see any advantage to the audio feedback portion of your block diagram.  The signal output from the amp you are using to drive the charge pump will be limited in frequency, voltage, and current as dictated by the power supply and other amp design factors no matter the feedback.  But one thing will be certain, the amplifier output will be COP<1 and by a goodly amount if the design is analog.  Even with class D, the efficiency will be <100%.  So IMO, this element does not provide any source of gain or if it does and I'm missing it, I would like to have it explained.
So what is the gain mechanism, the High-Q multiplier and what is creating the "spikes"?
Sorry, just trying to understand!
Post by: Grumpy on 2022.08.25, 13:57:35
Grump has nothing to do with this...LOL!
Post by: giantkiller on 2022.08.25, 14:39:36
Quote from: mkjekyll on 2022.08.25, 05:17:51
GK,
I have positioned the tda2003 in many distances with many volume settings. It just runs with out any problem.Here is one of my paths to use the self oscillation. All of the connections I have tested in the past.
One of my suspicions is SM used pager motors as amplifier outputs. This would present a gyroscopic artifact to the operation.The gyroscopic or jogging would have been noticed in the monophonic units. The polyphonic LTPU was never rotated.
SM held a clamp on ampere meter near the center toroids. The obvious place to show where the activity is coming from.
There are no ground connections shown or complete circuit loops on purpose. This diagram shows the block operations in module form.The dual toroids in upper left are what intrigued me about the Class D amp. Members had posted about this circuit before.I thought I would pursue that avenue.Boss Audio mono amp. The output stage is top left, the output chokes are the two yellow toroids underneath.
Post by: Hakasays on 2022.08.25, 14:46:10
Quote from: partzman on 2022.08.25, 13:46:46
My personal supposition is that the gain mechanism is due to parametric variation inside the iron wire.
Permeable iron will absorb a certain amount of magnetic flux from a nearby resonating coil, lets assume an iron core of 10mH storing 1a of flux, totaling 0.005 joules.
When the iron wire is pulsed, current flows inside orthogonally, which decreases the permeability of the iron.  At peak current lets say the inductance is only 1mh, which is only able to store 0.0005 joules of magnetic flux.  The remaining 0.0045 joules are 'ejected' from the iron core.
We can then deduce watts from joules-per-second.  If these permeability-altering pulses occur 1000 times per sec,  then we arrive at (0.0045 joules * 1000hz) / 1 sec = 4.5 watts.
Rather than pushing/pulling against a ferromagnetic core, we're making the core 'disappear' by saturating it.  This takes energy, but the energy required to induce the change no longer correlates with the energy leaving the transformer.  And most of the energy required to induce the parametric change can be recovered afterward.  Cause and effect are 'decoupled' from each-other.
Energy production by parametric variation is mathematically analogous to changing the spring constant of a spring as it is being compressed/expanded, or changing the mass of an object as it is being lifted/dropped.  It makes sense on paper and works in most circuit simulators, but whether it work in practice is yet-to-be-seen..
Post by: Grumpy on 2022.08.25, 15:54:33
PeterAE (on this forum) reproduced the iron delay and subsequent pulse according to Spherics' directions.
He has a topic about here somewhere.
Energia Celeste also used a similar approach, even patented a couple of devices, but went silent after that.
The compressed pulse occurs around 220ns delay.
The pulse messes with everything and is quite problematic.
Poynt99 was able to simulate the circuit and pulse in Spice, also on this forum somewhere.
Post by: giantkiller on 2022.08.25, 16:00:27
Quote from: Grumpy on 2022.08.25, 15:54:33
Wasnt this the companion pulse, you, Jason and I worked on?It is like a single echo of an very short emp.
Post by: Grumpy on 2022.08.25, 16:14:19
Quote from: giantkiller on 2022.08.25, 16:00:27
That's the one!
https://www.overunityresearch.com/index.php?topic=37.0
check this post out: 1012ns and Boom!
https://www.overunityresearch.com/index.php?topic=37.msg803#msg803
Post by: partzman on 2022.08.25, 16:44:27
Quote from: Grumpy on 2022.08.25, 13:57:35
Ah, my bad!!! Sorry!
Post by: giantkiller on 2022.08.25, 17:51:03
Quote from: Grumpy on 2022.08.25, 16:14:19
That's the one!
https://www.overunityresearch.com/index.php?topic=37.0 (https://www.overunityresearch.com/index.php?topic=37.0)
https://www.overunityresearch.com/index.php?topic=37.msg803#msg803 (https://www.overunityresearch.com/index.php?topic=37.msg803#msg803)
Yep. You flick reality just right and you get disciplined.
I got the setup going and Jason wanted to create an automated controller.
We tried but there were design errors and it didnt turn out so well. At that time he was also trying get into his new adult life in gear so we dropped any further efforts.
Back to the companion pulse: There seems to be an impact point where the surrounding atomic medium responds. Single wire or air coil doesn't matter which. The impact seems to dislodge some balance which causes severe perturbations. Tesla mentioned this. I also believe this is how TTBrown achieved electrogravitic propulsion. Its all tied together on this one artifact.My stance is this is the one thing that matters and all anomalous effects are this one thing but just achieved with numerous setups.A strong resonance gently massages this wall, so to speak and it responds.
The goal is get this to bounce continuously like Peter saw.
 No doubt a snubbed resonant charge pump is the captivation engine which I believe is the TPU.
This is a capacitor...
 What do you want to bet these are related?
Post by: giantkiller on 2022.09.15, 04:52:57
I need a sine wave chirp protocol and am looking for any ideas.
I have 4 Jason Owens SSRBs but the inputs are digital and the base freq of 4.29 just passes through the FETS.
A 555 sine wave gen is ok as the stability is not a concern.
I can flip flop enable it for the chirp.
Why do I ask here?
Because there are always better answers from others.(https://www.overunityresearch.com/data:image/png;base64,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)
Title: Re: The final answer...
Post by: giantkiller on 2022.09.17, 16:48:22
Full Stage configuration
Post by: giantkiller on 2022.09.20, 19:03:18
The power grid operated producing sine waves always supplies electrons in a smooth delivery which will produce a COP<1 because there is no high frequency impact on any metal medium.
This is what keeps the citizen tied to an energy bill as the environment is not excited with resonance but merely pushing and pulling a magnetic rotor consuming the passing electron flow which is the measurement by which the bill to be paid is calculated.
The spark gap technology shows different. The surrounding metallic medium including the additive resonantly generated magnetic field can easily be pressurized at the speed of <c and when released the pressure of return is greater >c, i.e. COP>1.
What needs to be addressed is the ratio of flux volume impact returning to a conductor compared to the pressure energy needed to push the flux outward.
A low power sine is used to build the field then the high potential emp is implemented within that field to 'disrupt' and the kinetic impact upon return / incoming flux back to resonance is collected.
A gap of iron powder or keeper will allow coherence for self sustaining resonance, i.e. permanent magnetic current holder.
https://www.youtube.com/watch?v=SuAZFe4HNMw (https://www.youtube.com/watch?v=SuAZFe4HNMw)
All need to absorb what Patrick states in the 4 categories of the vid. He spells it all out.
https://drive.google.com/drive/folders/10Fmwn0PvRQ04pKLlt0ttZC287hVRg5B1 (https://drive.google.com/drive/folders/10Fmwn0PvRQ04pKLlt0ttZC287hVRg5B1)
Post by: F6FLT on 2022.09.21, 09:46:20
I'd rather have a grid that provides me with real energy with COP<1 than virtual energy with COP>1.
Virtual energy with COP>1 can't run a washing machine, which is a pity, but it can run discussions which, unfortunately, are not virtual.
Donald Lee Smith C.C.  The funny thing is that those who claim to know the secrets of COP>1 energy use and pay for COP<1 energy to produce their websites or videos, as subscribers to the power grid.
Post by: giantkiller on 2022.11.09, 20:03:21
Integrating what I had posted to SM and he agreed at that time then validated by Moab later in a conference call.
I am using an amplifier with a speaker as input and output for signal coupling producing an auditory feedback based Armstrong oscillator.
There are other integrations coming dealing with the feedback loop into the charge pump.
This is another step into the generation side of the paradox.
The FE loop is dead ended in this rendition as I have posted previously about certain ways to connect it in to further augment the operation.
As always more proof that this radio is an antenna feeding itself.
I use this build as a testing receiver for other signal generation and tracing.
The tuning consists of the mic to speaker spacing and the 2 inch diameter speakers. The mics and speaker are all 2 watts 2 inch speakers.
Post by: giantkiller on 2022.11.11, 01:40:44
Did this test again. I see this many times when a horizontal winding is FE.
Post by: partzman on 2022.11.11, 14:35:43
Quote from: giantkiller on 2022.11.11, 01:40:44
Interesting!  Do you have an open circuit voltage ratio relationship between the number of toroid turns and the inner Fe/copper winding turns?
Post by: giantkiller on 2022.11.11, 16:32:25
The two pathways are current and/or activity.
Next I am connecting the parallel Cu to a charge pump.
One can not simply draw current out of low turn configurations in what we speak of here.
The low turn configurations are antennas.
The pic I showed is 3 antennas in one, the outer being a helical. There have been nobody seeking out helical antenna theory.
I see most experimenters heading to current and power but never striving for antenna theory.
My take has always been from the antenna aspect that interfaces with charge pumps.
This follows right along with dumping power reflections to ground or spacing equipment to buffer or to produce anti phase harmonics.
I say this is a good approach to get power to homes and businesses but it is not what the OU configuration needs.
The device must float, be resonant, have harmonics and be able to corral the reflections.
If you can not manage the reflections you will get conduction at leakage points.
SM mentioned lightning from the air but I have always said he is making statements in reverse to get past the NDAs.
The lightning shoots away from the device. This points to a stungun, charge pump or Tesla coil.
And he was always promoting careful handling of devices.
Moray, Smith, Hendershot, Ammann bros, Kunel, Tesla Arrow and others all squeeze or pressure the flux field in some way to get the rhythmic reflections from pumping action.
Stun gun, audio feedback loop, 90 degree coupling, Fe wire are the initial statements I made publicly that pulled SM out of the corner.
And these items still stand today integral to my designs and testing. The journey has been frought with blowing up equipment on the bench and in a wide area.
 So this works.
The final stage is harmonics from reflections with power  :o on the bench. :o
Post by: lfarrand on 2022.11.11, 19:41:07
I, too, believe that antennas are worth studying in our pursuit for OU. There's something strange that happens at the interface between near and far fields (https://en.wikipedia.org/wiki/Near_and_far_field), the Fresnel region. At some point the receiving coil / antenna has little to no loading effect on the transmitter. A broadcasting antenna blasts EM waves into the air and any number of receivers can tune into the signal. The broadcasting power is not dependent on the number of receivers. The signal can be amplified on the receiving side by using an antenna wound around a ferrite core, or by amplifying using a local power source.
I've always wondered about sympathetic vibration, thinking about how tuning forks work in particular. If the mechanism works for mechanical sound waves then it could also work in a similar way for EM waves.
Taking two identical coils (length, weight, resistance, inductance, capacitance?), would applying a signal to one coil cause a sympathetic vibration in the other, similar to a tuning fork? If so, could this be a way to 'withdraw' power from an electrically resonant system (inductance + capacitance)?
Post by: mkjekyll on 2022.11.13, 03:49:53
GK,
What is the build of your toroid?  In the pic it looks like two coils on the side of a large wind of 300 ohm dipole antenna wire that may be the primary coming off the choke. Can you explain how your tpu's windings relates to the red, blue and green box of your schematic supra?
Sorry if you posted somewhere and I missed this, but I had a pretty good look around.
Mick
Post by: giantkiller on 2022.11.13, 06:01:31
The red is the Audio, the blue is the center toroid board, and the green is the FE horizontals inside the vertical twin lead windings.
The two smaller lamp cord windings are primaries.
SM has one on the LPTU while Don Smith has two in his green cart coil if my memory serves me.
I put them on adhoc to have another access point for feeding this whole antenna setup.
Post by: Hakasays on 2022.11.13, 16:26:26
Is it a one-way action?   Does energizing the horizontal winding act on the verticals?
Post by: giantkiller on 2022.11.13, 16:48:37
I know this works both ways and or in all directions from previous tests.
The signal activity doesnt always lead to progress.
When ever I do a configuration change I should try every which way and even loose, but alas I stay on the intended focus and forget to redo other tests.
But its on my plate today. I had done a previous setup where the operation turned into a magnetic diode.
Its back in my notes.
But once again I do a configuration to test what I am going for then leave the bench at the point.
The current two test are 1: feed the audio feedback into a charge pump, 2: EMP the center toroids and watch the Cu horizontals.
I am most positive the activity will travel.
I have injected 1- 10 hertz sine waves into the verticals and watched the swr meter sway at a distance of 6 feet.
At the end of the day is the toroidal field reports activity from any injection point. This is going in both directions since the device I have is one huge antenna spreadsheet.
I had a lot on my life plate this last two years and have whittled a lot away so my time is getting more open to a specific and limited number of other life addictions, the TPU being always first and foremost.
 I have my router table back up and running so now I am able to produce mounting standards for large coils.
The smaller TPUs are comprised of the high Q multiplier circuit.
Post by: giantkiller on 2022.11.14, 05:05:08
The reverse 90 degree coupling confirmed.
Signal injected at Red arrows on the horizontal Cu lamp wire transfers to the horizontal FE wire through standard induction. Then transfers to the verticals from the now Fe core and picked up at blue arrow.
The signal fed into the parallel Cu to the FE then read at a primary that is over the verticals.
The angular change happens at the Fe wire. It is a wire when parallel and a core when perpendicular.
This now makes the documentation for the 90 degree coupling in both directions complete.
Post by: lfarrand on 2022.11.15, 07:20:02
I've been reading about transmission lines and I can see the parallels with Don Smith's works, especially when reading about Standing Waves and Resonance (https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/standing-waves-and-resonance/) and Impedance Transformation (https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/impedance-transformation/).
(https://i.ibb.co/1XPBZNS/Resonant-Electromagnetic-Power-System-circuit.png) (https://ibb.co/1XPBZNS)
The trouble is that Don Smith doesn't explain using accepted academic terms, so it's difficult to follow his explanations and diagrams. You can see in the above image that there is a resistor R1 that he says is used to 'set the electron pump rate' when he probably means use a resistor to adjust the impedance matching of the system (http://kirkmcd.princeton.edu/examples/impedance_matching.pdf).
Post by: giantkiller on 2022.11.15, 07:42:13
It is an RC circuit.
In the Don Smith stage demo he wraps lamp cord around his arm like Otto's TPU winding to answer a question from the audience.It goes right by everyone.
I was always wondering if he was trying to avoid the powers that be by using vague, esoteric or weird new terms and descriptions.
The electron pump rate could also be a charge pump circuit.
Mueller had this all nailed down with very clear explanations.
Every one that attended his backyard demo walked away with the concept and rewrote it.
I dont know if the home video is still on the internet.
Post by: lfarrand on 2022.11.15, 11:07:38
Quote from: giantkiller on 2022.11.15, 07:42:13
Who is this Mueller character, if you don't mind me asking? I haven't come across any reference to him in relation to Don Smith.
Post by: giantkiller on 2022.11.15, 21:15:24
He held a backyard Demo of a spinning aluminum disc with holes in it to allow the cutting of flux between 2 magnets.
It works quite well. His daughter is Carmen Miller on Facebook. You can tell by the friends list.
In other pictures posted you could Steve Mark and Don Smith watching the demo.
He does a demo on his laundry room floor of two magnets kineticly flying apart. At the end of the demo he shows a 4 inch red TPU in the last frame.
Post by: lfarrand on 2022.11.16, 06:26:17
Quote from: giantkiller on 2022.11.15, 21:15:24
Very interesting. I think it's fair to say then that the Mueller demo was the genesis of the Steven Marks and Don Smith devices.
If anyone has a copy of that demo then I'd be very interested in watching it. I tried searching for it but nothing turned up. Do you happen to know Mueller's first name?
Post by: giantkiller on 2022.11.16, 18:25:15
I botched the first name. His daughter will talk to you on Facebook.I searched on Overunity.com.
Oh my very bad!
 Bill Muller
https://overunity.com/3842/muller-dynamo/ (https://overunity.com/3842/muller-dynamo/)
Carmen went through a divorce at the time which is mentioned on OU. So life happens with documentation.
I forgot to mention that Bedini was also in the audience.
 I know I saw one in one of his backyard demos where the center aluminum disc was just a disc with holes in for the flux to reconnect through.
Much simpler and lighter design.
But I dont want to harp or hammer on a particular device. The cutting of the flux is the key. Sm mentioned 'Cancelling the flux'. Same idea.
Then I found the Kunel patent. Same deal again.
Manipulate the static toroid field at any speed. Speed ranges from subtle driving to resonance to EMP.
All devices adhere to some velocity range.
Pick any OU device and the velocity will become apparent. The medium is the Larmor frequency.
Post by: lfarrand on 2022.11.16, 22:51:36
Quote from: giantkiller on 2022.11.16, 18:25:15
Oh my very bad!
 Bill Muller
Aha, very interesting again. Bill Muller was a name mentioned to me on the EV Gray group (https://groups.io/g/EVGRAY). I didn't realise how much of a pivotal role he played in the development of all these famous OU devices.
I was speaking to someone on that group and he said he went to visit Bill Muller several times, and apparently Bill confessed that the underlying principle of his devices was harnessing the inductive kickback.
Post by: giantkiller on 2022.11.19, 17:59:07
https://rumble.com/v1ovg9j--time-travel-miracle-.html (https://rumble.com/v1ovg9j--time-travel-miracle-.html)
Post by: giantkiller on 2022.11.27, 05:19:37
It is necessary...
Post by: giantkiller on 2022.11.30, 06:25:55
Post by: giantkiller on 2024.01.10, 07:03:29
The TPU is the exact opposite of the radio /tx/rx industry. There is a carrier/EMP and we harvest the resonant, modulated noise instead of isolating it out.
I love dropping info bombs to shake up the landscape.
Post by: F6FLT on 2024.01.11, 16:24:43
Quote from: giantkiller on 2024.01.10, 07:03:29
The TPU is the exact opposite of the radio /tx/rx industry...
That's probably why RX and TX can communicate, while the TPU has never produced anything useful.
Post by: chief kolbacict on 2024.01.11, 17:31:10
Quote from: F6FLT on 2024.01.11, 16:24:43
:D
Post by: giantkiller on 2024.01.11, 17:49:37
The cross over point is when you realize that reverb and reflection are the same.
First TPU in 1995 by William Mueller. Last 2 frames of his laundry room magnet demo.
He showed Don Smith, Steven Mark and John Bedini.
Bedini copied the magnet shear rotor device.
Don Smith built the ring on the cart device with the NST circuit inside the cart.
The schematic shows its plugged into the wall.
SM removed the line operation mode by causing the circuit to self resonate. The knowledge came from his audio background.
He labels the unit as a variometric device.
Dual side band in open TPU but across the ring instead of each on its own ring.
Post by: giantkiller on 2024.01.18, 18:42:41
The speaker in the audio feedback loop was replaced with a pager motor so the operation was silent, hence the vibration.
The mic still reads the magnetic field variations and then the signal is amplified causing higher power revolutions.
The distance of the mic to the motor controls the snubbing necessary so the amplifier is not blown.
The LTPU was created in pairs, even the fuse holders in the gap. But only one spark gap was necessary for operation, hence the missing fuse.
SM actually stated a blown fuse makes a wonderful spark gap.
https://rumble.com/v47x1f3-audio-feedback-loop-in-ltpu.html (https://rumble.com/v47x1f3-audio-feedback-loop-in-ltpu.html)
https://rumble.com/v47wxxu-audio-feedback-loop-for-thumping.html (https://rumble.com/v47wxxu-audio-feedback-loop-for-thumping.html)
The pager motor feedback version is in the works.
Post by: giantkiller on 2024.01.30, 19:33:06
Center Toriod
Post by: giantkiller on 2024.02.07, 05:32:04
Probable field definition of the Hutchison effect:
https://rumble.com/v4buxm9-february-6-2024.html (https://rumble.com/v4buxm9-february-6-2024.html)
A very tight resonant bandwidth:
https://rumble.com/v4bvrwr-h-field-modulation.html (https://rumble.com/v4bvrwr-h-field-modulation.html)
Probes:
https://www.aliexpress.us/item/3256805420265954.html?spm=a2g0o.order_list.order_list_main.23.4d0c1802cd4ehW&gatewayAdapt=glo2usa (https://www.aliexpress.us/item/3256805420265954.html?spm=a2g0o.order_list.order_list_main.23.4d0c1802cd4ehW&gatewayAdapt=glo2usa)
https://www.amazon.com/SaiDian-9KHz-3GHz-Antenna-Conducted-Radiation/dp/B097YCVCTX/ref=pd_bxgy_d_sccl_2/136-1061201-5820906?pd_rd_w=QxrQ7&content-id=amzn1.sym.839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_p=839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_r=PQF76PE0AK2MED7WKDY0&pd_rd_wg=vfINt&pd_rd_r=3d58bcf9-8093-4630-8d54-ab7f1fad834b&pd_rd_i=B097YCVCTX&psc=1 (https://www.amazon.com/SaiDian-9KHz-3GHz-Antenna-Conducted-Radiation/dp/B097YCVCTX/ref=pd_bxgy_d_sccl_2/136-1061201-5820906?pd_rd_w=QxrQ7&content-id=amzn1.sym.839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_p=839d7715-b862-4989-8f65-c6f9502d15f9&pf_rd_r=PQF76PE0AK2MED7WKDY0&pd_rd_wg=vfINt&pd_rd_r=3d58bcf9-8093-4630-8d54-ab7f1fad834b&pd_rd_i=B097YCVCTX&psc=1)
The keynote take away is this H field modulation can only be seen a few points off resonance and a slight sweep range.
I do believe this breaking new ground.
So when one has a device that worked temporarily then they stumbled upon this protocol.
It remains a mystery because of the lack of H probe.
Post by: Allcanadian on 2024.02.07, 16:45:29
GK
QuoteProbable field definition of the Hutchison effect:
The effects seem pretty easy to understand.
For example, years ago I thought doctors, ie. surgery for cancer, were primitive and barbaric and I still do. Rather than cut people open like animals why not converge multiple beams of energy like IR lasers on a point to destroy the cancer inside the body. Then 10 years later I heard someone actually figured it out and a friend with cancer near his brain was healed using this new technology.
The process is simple, no one beam of energy has enough power to disturb the material it moves through but where all the beams of energy converge it can. Obviously this is not induction nor should it be confused with induction. Were transporting EM energy to a point within a material which then dissipates and radiates energy outward from said point.
It should also become obvious that the point where the energy converges appears as the source of energy and not all the lower energy sources which combined to produced it. At which point the notion of an external action producing an equal and opposite external reaction becomes a mute point. The reaction is now internal and could take any number of forms. Ergo, many cold IR beams converging on a point dissipating and transforming the energy as heat.
Post by: giantkiller on 2024.02.07, 17:06:20
The target make up, convergence, harmonics, direction, angle and power levels(equal or mismatched(importante!)) all play an important part in manipulating the target.
Somewhere deep, the specifications of the incoming parameters and the target molecular structure are documented.
We on the outside have to explore to find the parameters and material synchronization protocols.
The turtle wins the race.
Remember SM stated just off the mark. O0
If one is aiming for power from the start then that will blow up equipment. These are due to temporary excitation windows.
These are vectoring alignments without control.
This is what we are not told about the Hutchison effect.
Post by: giantkiller on 2024.02.09, 03:05:09
QuoteIts to have an isolated power coupling for the becon lights on large antennas as to not have an electrical bond to other systems.
It's a high voltage (insulated) mains transformer with low capacitive coupling, for exactly what you said. Learning something new every day.
The RF energy is coupled to the tower/antenna in AM radio with a ring transformer. I call that spooky RF. I worked on an antenna once that was in a four tower directional array. We shut down all of the antennas except the main. At that point, we went circular instead of directional. As I was working on the tower, it would absorb the energy of the main tower and would burn me at peek amplitudes. Ouch !!
https://www.youtube.com/watch?v=wGDZK1Ifq50&t=2s (https://www.youtube.com/watch?v=wGDZK1Ifq50&t=2s)
Post by: giantkiller on 2024.03.10, 05:24:57
https://blog.teledynelecroy.com/2018/08/the-causes-of-ground-bounce-and-how-to.html (https://blog.teledynelecroy.com/2018/08/the-causes-of-ground-bounce-and-how-to.html)
In reading this article I saw there are many references to particulars in the TPU build and operation.
Lamp wire creates the multiple pathway problem.
