The final answer...
Started by giantkiller, 2011.05.28, 20:02:33
0 Members and 6 Guests are viewing this topic.
#325
Quote from: giantkiller on 2019.05.15, 18:56:29
SM placed the amperage clamp meter in the center of the LTPU and the meter showed ac current. Electromagnetics at large.
Now imagine if you will (in my best Rod Serling voice), a large oscillating resonance between those two rings sliding back and forth, up and down the center modules. A magnetic gradient will be measured.
The clamp meter SM used (UEI DL235) was capable of reading DC static fields external to the device as well as AC. I purchased the identical unit and it has a zero button to null out the residual static earth magnetic field. The manual is attached that describes the use of the zero button, and you can see SM zero the meter using the button right before he waves it around the unit. So are you positively sure he was reading an external AC field? I would leave all options open until proof is given.
I also purchased the Extech Wattmeter DW6060 used by Dr. Schinzinger so that I might further understand if it's use as seen in the video is accurate. I also intend to purchase additional test equipment as seen in the videos, such as field search coil and field meter, also the EMI tester, DMM etc.
IMO No one I repeat no one yet has demonstrated a working stand alone TPU  similar in shape, size, simplicity and power output as SM has, so thus far it's all talk no action. Prove me wrong.
giantkiller
The TV interference and the thumping advertise AC. Not dismissing D.C.
Room3327
Quote from: ion on 2019.05.15, 23:00:56
Hi Ion,
  The clamp on ammeter I used, and it too registered current around my TPU builds, was a d'arsonval mechanical movement an old Sperry Mod. SPR-300 and I really don't know how to explain it.  I can't get the meter to budge around any and all things I have waved it at, but stick it by a TPU of mine with a rotating field and it registers.  I thought a motor field would do the same trick but I don't get any movement around running motors either so I don't know what to say except that a working TPU must have a similar rotating field to what I have got going on in my builds. My builds are about the same size, shape and weight as S. Marks, and my meter is totally different then his but showed the same thing, with some tunings on my TPU I had readings just over 40 amps with 600 ma. input to the toroid.  I don't think S. Marks ever showed more then 2 amps. on his.
Room
giantkiller
#328
And we notice here that there is an oscillatory harmonic in the midst of the resonant bouncing.
https://www.youtube.com/watch?v=8HVA00LnKBc
Heterodyning and eclipsing frequencies cause very high transients in space(EMPS).
This can be see as 'Action at a distance' in some surroundings.
A Tesla coil has EMPs inside the resonant magnetic field.
I post this extra because of his attention to magnetic detail:
https://www.youtube.com/watch?v=B015P0XFl9g
Quote from: giantkiller on 2019.05.16, 18:04:05
In this video, we see only permanent magnets subjected to the low frequency magnetic field of an electric magnet. It's very commonplace.
rensseak
Quote from: F6FLT on 2019.05.19, 12:56:32
Here the full video of it.
https://youtu.be/HKoUd8l7yZE
last I heard Marco was not well [end of last year
in my last exchanges with him he mentioned quote " Waiting to Die" [from illness]
I did reach out again but got no response ,will try again in-case he is reading here.
always loved his thoughts and contributions.
Chetkremens@gmail.com
Magluvin
Quote from: rensseak on 2019.05.19, 20:49:57
I remember this vid.  The kick coil looks to be a toroid winding, probably orbo effect to drive it.  I wonder if there were many more magnets inline if the input would remain the same?
I remember a few vids some years ago that had 1 driver spinning a sphere mag and then setting small jars with sphere mags all around the driven sphere, and even setting up more jars, and more jars. And they were all spinning.
I think it was lidmotor that initialized that trend back then.
Mags
Centraflow
But the TPU uses ferrite cores in all models, even in the one that looks as though it does not, Peter found it, a small CMC which I have the same one. each coil has 29mH and if wired to buck together the inductance nearly cancels at 0.5mH, but wired so as not to buck the inductance is X4 at 116mH.
This seems to only happen when wound together on the same ferrite, but if they are an air coil the inductance only adds simply, X2, and not X4.
Now if you mix charge displacement current between two magnetic loops which have a capacitive connection, current can be induced into a voltage boost, overwound, scenario which is in phase with the boosted voltage, you don't need much if looped somehow as even at 50kHz the power will escalate out of control. (boost circuits and class E amplifiers are between 90-100% efficient) ;)
giantkiller
And further more...
Reiyuki
Quote from: giantkiller on 2019.06.27, 22:08:07
And further more...
That will all work on the same loop?!  :o
Back to the bench >:-)
giantkiller
They are shown in circular 3s, 5s and 6s combinations.The center power generation is an Alcubierre drive, not really a propulsion drive. More of a resonant generator that feeds the Tesla coils.There is a tuning capacitor in the charge pump and drive frequency that shifts the balance on the TTB reflectors. Thereby shifting the mass while still maintaining elevation.
The excessive field generation is why onlookers get burned.
The larger Alcubierre models are shown driving a charge pump into a large laser based ionic drive. I often wondered why this medieval step is used when a straight resonant power generation would perform the same event. Space is filled with atomic structure so magnetic manipulation is all that is needed.
Two ring configurations performing destructive resonant transmission reflections. No different that placing an amplified microphone in a driven speaker cone.When pointing an electric guitar at an amp one has two coil loops facing each other. One transmitting the other receiving. The change in the feed back comes as the direct face to face coil alignment is altered at slight angles. When the two coils are left alone in a powered parallel alignment, equipment self destructs. Possibly has a use, yes?
giantkiller
QuoteFor every action there is a reaction, and think how a transformer can buzz with AC. Now make it a square wave and you could hammer it around a bit, even more so than with sinusoidal AC. So, it depends on your frequency a bit, too, I'd say, for you to set up a noticeable or worse mechanical standing wave in your transformer itself. However, depending on the size and robust quality of the transformer it should be OK to do at your power level, at least. On the other hand, will you get square wave out? I think it won't be "as square" as the input. The windings (and their proximity to the plates, if any), also create a changing inductive environment, so it may goof with the shape of electrical wave(s) a bit. And the fact that the transformer will have those mechanical waves (manifested as vibration or sound), assumedly worsening at certain frequencies, leads me to believe that it will not pass all frequencies at the same efficiency, thereby further distorting the "squareness" of the wave. That may be saying the same thing twice in two different ways, but maybe at least for more than one reason. It may be, though, that the two are just manifestations of the same condition. Not sure at the moment. Either way, not going to be a perfect representation of the input. Also, I wonder if you are going to get EMF (or reverse EMF) effects at the points of voltage reversal, which may grossly distort the output.
giantkiller
QuoteThis is exactly what happens in the ignition system of older cards with points. The make-and-break of the points provided a 12 V square wave to the ignition coil (a transformer)!, which then output several thousand volts. A similar method was also used in "the olden days" to produce high voltage AC from a battery, such as in spark-gap radio transmitters./
giantkiller
giantkiller
#341
Superregenerative receiver
QuoteThe superregenerative receiver uses a second lower-frequency oscillation (within the same stage or by using a second oscillator stage) to provide single-device circuit gains of around one million. This second oscillation periodically interrupts or "quenches" the main RF oscillation.[38] Ultrasonic quench rates between 30 and 100 kHz are typical. After each quenching, RF oscillation grows exponentially, starting from the tiny energy picked up by the antenna plus circuit noise. The amplitude reached at the end of the quench cycle (linear mode) or the time taken to reach limiting amplitude (log mode) depends on the strength of the received signal from which exponential growth started.  A low-pass filter in the audio amplifier filters the quench and RF frequencies from the output, leaving the AM modulation. This provides a crude but very effective automatic gain control (AGC).
giantkiller
#342
The device must resonantly transmit to achieve overunity.
Poor Eric Dollard is not allowed to transmit.
His experiments are all receivers. Good start but not the full picture. He is under the radar with his new approach though and he will go down in history. If he would only transmit...
giantkiller
I thought this might open some minds.
poynt99
I think the big one was more than double the power though????
giantkiller
Oh yes. What I posted here is a configuration. The two center horizs are parallel to each. As each charge pump rises in field volume the center TPU is crossed triggering a large collapse onto the large middle or smaller bottom FE loops. That wire is then the new conductor. The LTPU is actually two. This is why there are 3 sets of wires that show up in the cross cut TPUs.We are all experienced in resonant field collapses. Most circuitry dumps this to ground. The TPU has no ground.
muDped
Quote from: ION on 2019-05-16
I am very much in agreement with this post made by ION nearly two years ago.
Not only has no on been able to successfully replicate the TPU but, in addition, no one has rationally theorized where the Anomalous Energy Demonstrated by the TPU may have been sourced from.
The fact that Daniel Pomerleau has made similar demonstrations witnessed by several audiences of observers with simple coils of wire provides food for thought, however.
Additionally, certain Conjurers or Magicians have publicly displayed the ability to illuminate Light Bulbs during their stage acts without any sort of electrical connection at all.
So where does the Energy come from?
Why does it seem that only certain people have the ability to make it manifest?
There must be an answer which makes Scientific Sense.
I do sorely miss ION and his analytical capabilities and his common sense.
giantkiller
#347
https://www.nuenergy.org/nikola-tesla-radiant-energy-system/
QuoteEnergy Directly from the Atom
The radiant energy system is a self-oscillating capacitive system. Once it is set into oscillation, very little power is expended in keeping it going. Because it is an electrostatic oscillating system, only a small amount of charge moves through the system per cycle, that is, the coulomb per seconds = amps are low. If the charge is used at a low rate, the energy stored in the system will be turned into heat at a slow rate enabling the oscillations to continue for a long period of time.Tesla's "COIL FOR ELECTRO MAGNETS," patent #512,340 is a very special coil design because, unlike an ordinary coil made by turning wire on a tube form, this one uses two wires laid next to each other on a form but with the end of the first one connected to the beginning of the second one. In this patent Tesla explains that the double coil will store many times the energy of a conventional coil.[1] Measurements of two coils of the same size and with the same number of turns, one with a single, the other with a bifilar winding, show differences in voltage gain. These bifilar Tesla's coils can be explained solely on the basis of their electrical activity. A bifilar coil is capable of holding more charge than a single wound coil. When operated at resonance, the distributed capacitance of the bifilar coil is able to overcome the counter – electromotive force (e.m.f.) normal to coils, inductive reactance.
Because of the electrical activity, a bifilar coil does not work against itself in the form of a counter – e.m.f., the potential across the coil quickly builds to a high value. The difference between the turns becomes great enough that the energy is practically all potential, at this point, the system becomes an electrostatic oscillator.
Minimal work is done in my radiant energy system due to the absence of wasted displacement currents. As small heat losses occur, oscillations are maintained by surplus charge generated by atomic catalytic reactions, energy is siphoned from the kinetic moments of these charges. Very low energy expenditure allows power delivery to an electrical load over an extended time period without an external fuel supply. After an initial input of energy from an outside source, the radiant energy electrical generator will operate as a very efficient device.
By reviewing history it is understandable why some inventions are not commercialized. It is economics, not science, that is the main factor. It will be remembered that alternating current was opposed by powerful financiers in Tesla's time.
Michael Pupin, noted in his autobiography:
"...captains of industry...who were afraid that they would have to scrap some of their direct current apparatus and the plants for manufacturing it, if the alternating current system received any support. A most un-American attitude...but ignorance and false notions prevailed in the early nineties, because the captains of electrical industries paid small attention to highly trained scientists."[2]
It takes very little energy to promote a resonant field.
The charge pump is the heart of microwave ovens, analog tv, automotive ignition systems. and stun guns. SM even promoted the exploding TV as an accelerating charge pump of vast amounts of energy. The main problem with the exploding T.V. circuit was there were no components in place to dump the collapsing field to ground. Sm stated 'There can be no ground in the TPU.'
I promoted setting a charge pump of a 20 foot diameter next to an airport. He emphatically stated 'No'. I got his attention.
Application of the High Q multiplier circuit merged with the charge pump circuit is the TPU schematic yet no one tries this.
The field in the charge pump(the large vertical windings) builds and crosses the space to the center toroid triggering a field collapse into the middle FE loop. This creates a one way magnetic diode. Does anyone catch this? The original promotion was '90 degree coupling'.
I am the only one who has spent years showing the subsections of this circuit without conjecture from the greats, Ion, Marco, SM, Erfinder and the others that left immediately after I exposed the charge pump as an integral part of the device. The last statement made to me by Moab was 'Put a diode in it!'. Configuration proof.
I even built the large TPU in accordance with what we have seen and proved the configuration works as a charge pump replicating the field size and strength promoted in the exploding TV. I even EMPd 5 cable routers throughout the last neighborhood I lived in. More proof. The energy is there.
Final answer is and for the new members that are eager the schematics are in my previous posts across OverUnityResearch and OverUnity. They are out of sequence.
Exact copy of TPU is the LTPU build using twin lead outer wrapping. The device is staring everyone right in the face. Build that model with the large vertical air core as part of the charge pump and one will see the field strength meter show the energy. What is the final standalone device? You will see it when you start blowing shat up. The largest TPU is the Alcubierre device. Another example in our faces. Yet people want destructive propulsive detonations or free demos.
I know there are watchers that want the final answer handed them so they can self promote themselves into history. Marco warned me about this and now I have to watch this action unfold.
I am not into this for followers or fame. From the smallest to the largest devices there are many examples of the technology out there so one can not really be the hero.
It is the High Q multiplier circuit merged with a charge pump, i.e. the exploding T.V.
There it is, schematics and demonstrations. The trolls, weasels and prairie dogs finally have what they have been searching for...
giantkiller
Because the TPU is an inert device it can be conspicuously housed in an inconspicuous housing.
This then can be transferred across borders relatively easy and dispersed to objective points.
Any information divulged past what has been could be deemed as a national security threat.
Its simply a charge pump...
muDped
#349
A Charge Pump is a type of DC to DC Converter which operates as a DC Transformer in effect.
Where do you suppose the "Charge" that is "Pumped" originates from and how is it accessed relating to the TPU?
Charge Pumps are indeed a fascinating study:
Charge pump - Wikipedia
Charge Pumps
What is a charge pump and why is it useful?    Part 2
What is Charge Pump : Working & Its Applications
A Related article:  Voltage Multipliers
