2026-08-20, 14:57:59
Author Topic: Ark of the Covenant and Hutchison effect.  (Read 5832 times)
[youtube]http://www.youtube.com/watch?v=h89TaH6Er1Y[/youtube]
[youtube]http://www.youtube.com/watch?v=rW2Ynkcc2No[/youtube]
Where the wings touch is the zero point. This is the vector that Hutchison finds by 'Accident'.
that's awesome GK,  I love it!   O0
I believe this is ground shaking previously unforeseen except by Keely and the Ancients.
In regards to the tuning fork on the monitor:
At certain distance we see the triune of three. Then when the tuning fork is placed on the screen we see a triune of 6. If the Bloch wall could achieve closer proximity to the screen I believe we would see 9.
This is the reference of 3-6-9 that Keely spoke of.
Now in regards to the Tesla Coil support frame: the secondary coils have to be able to be moved closer to vary the Tesla coil heads in correct proximity to capitalize on the 3-6-9 placement.
Or
Within any area of distance the field is useful against a target that would correspond to the external field parameters. At the correct distance the actions are those of compatibility or complementation of the target's structure lattice whether molecular or atomic.
But how would you tweak the field, which is believed to be responsible for giving matter its substance?
We have witnessed this with Keely and Hutchison.
I took notice to the field display on the color monitor and since the distance is the factor of the of the field compression then that is the area to start in. This is portrayed in the Kunel patents. When the weak field is used and the area in question is the 3 element triune distance. Which makes sense.
http://www.keelynet.com/energy/rawls1.htm
With a less complex compression to work with this lends itself to an easier manipulation using a less defined control, i.e. a benchtop assembly.
Magnacoaster, like Kunel expressed focus on the weak field manipulation.
Or, just plain easier.
I am seeing more insight into this area:
http://www.msnbc.msn.com/id/48087875/ns/technology_and_science-science/t/higgs-boson-first-step-star-trek-transporter/#.UQBnD2dGbp8
[youtube]http://www.youtube.com/watch?v=xjoMMCA79-g&feature=youtu.be[/youtube]
Another step...
http://www.overunityresearch.com/index.php?topic=1648.msg28264#msg28264
Quote from: thx1138 on Today at 17:08:38
I've been looking into this but haven't yet located when and where Dr. Tesla made the statement about 3, 6, 9. A lot of web sites say he said it. I would just like to know the context. Does anyone know the article/interview/paper and/or the date he said it?
I read that too somewhere. I have too many reference piles to sort through physically. I do know that Keely talked about it extensively in the makeup up of atomic structures. When I saw the La Point video I placed it with what Rodin has taught. That is why I did the demo on the color monitor screen to show the pattern. Like Keely stated it goes infinitesimally smaller. As you get closer and closer to the Bloch wall the compression would show up then as 12, 15, 18, 21. But I do not have the testing device to show that small of granularity.
As @Ex has shown in his latest Barkhausen test that the core needs to saturated to start with but at a very minute level so as to be receptive to any external atomic harmonics and not dominate the space with a static over powering field. So this points to working at the flux density area of the 3rd triune, the weak field. The Barkhausen test attempts and succeeds at getting a 3rd triune flux density area as small as possible to have that compression level at the mass of the winding as best as possible.
  In regards to my current Keely-Hutchison build the closely coupled primaries would be incorrect in dealing with the weak field area of the secondary. These primaries are sitting in a high density area. The normal Tesla coils have the loosely coupled primary away from the secondary to work in the weaker field area. This explanation I have not found in the Tesla coil design documents. It is explained as capacitively coupled which is correct but that is where the explanation stops. The 3,6,9 field density area completes the design description. One can see my desgin goal for my current build being open to many changes pertaining to the ability to adjust many more parameters than just a limited number of things dealing with tuning to achieve an air discharge.
« Last Edit: 2013-01-28, 20:28:59 by giantkiller »
The final stage of this device is located at 168khz. I chose this range because it fits the operating parameters of the output stage. I need to build all the previous stages to produce this frequency. That way, in starting with the higher frequency, I will be more apt to produce the very high frequency heterodyning to produce the high speed wave eclipsing in the target material.
[youtube]http://www.youtube.com/watch?v=1JRl9NiKXT4&NR=1&feature=endscreen[/youtube]
I heard Rom Wyatt speak late 80's in California, on one of his speaking tours. I bought some video tapes with the discoveries later, and everytime I watch them I'm still amazed.  I remember he showed a video taken inside the cave where the ark was found, and it had some mysterious color inversion effect, same for the photos, which he sent to labs for analysis.
Quite fascinating stuff.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-20, 14:57:59
