2026-08-28, 03:33:40
Author Topic: Amazing experiments with Robert-Boyle flask  (Read 5291 times)
Please watch experiments with different types of liquids:
https://www.youtube.com/watch?v=600rXtwOlkk
interesting, it seems to be the bubbles and foaming tendancy that pulls it up the tube
The CO2 in the liquid (beer) comes out of solution and carries some fluid up the tube with it. Which makes this a simple air lift pump using CO2  however both Victor Schauberger and Tesla proposed such devices which use naturally occurring dissolved gasses in an open cycle. Now if we had a solution which could absorb a gas then release it through a small variation of some property then we might have something.
It is also interesting to note that the low pressure side (foamy) draws liquid in and in the same instant the lower pressure also releases the dissolved CO2 which makes it self-sustaining until all the dissolved CO2 is gone.
This fluid experiment actually illustrates one of the mechanisms by which boats and ships have mysteriously sunk in the Bermuda Triangle.
The reason the fluid rises in the flask experiment is because it had less density when the CO2 comes out of solution.  So there is an imbalance in weights.
Similarly, in the Bermuda Triangle there are massive deposits of methane in the ground, and they can be triggered to release up to the surface in an abrupt chain reaction.  During this time the bubble rich water is less dense and as a consequence it can not sustain heavy ships, which sink rapidly as if they went off a cliff.
Disclaimer :   this is not my original idea, I'm repeating what I saw in a film documentary about the Bermuda Triangle.  Of course this does not explain the wildly spinning compasses and other bizarre electromagnetic effects, including time travel according to some.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-28, 03:33:40
