Using a Photodyne Chopped Light Multimeter and grabbing a bright white led off the bench of unknown vintage, I ran these numbers using a HP constant current source over three decades of current.
Voltage across the Led is not the best way to characterize leds, better to use current through the LED, as the voltage drifts with heating. When voltage finally stabilizes, power may then be computed.
If these numbers are correct, they show a rather low efficiency, which can possibly be improved a bit with pulse mode operation. There is an interesting decline in efficiency when operated at higher steady state power.
We are still a very far cry from OU, even with the very best PV cells, since we lose almost 98% of the LED input power to heat and get less than 2% light power.
The Led was held right up to the sensing silicon receptor, positioned as close as possible. Of course I don't have full specs on the meter and it may not be seeing the LED at it's optimum power point or wavelength, nor do I have specs on the LED.
I also suspect the LED I tested may be partially damaged although it seems to light very brightly to the eye with 0.1 mA current. Until i get my hands on a new supply with data sheets and curves, I will consider my numbers suspect.
« Last Edit: 2014-09-24, 02:25:02 by ION »
