2026-08-15, 07:33:15
Author Topic: copper vs iron core  (Read 54909 times)
Need some outside the box thinking here..
Besides the basic answer of flux density - what is different between a transformer with a iron core and a transformer with a copper core?
Hi DS
 The iron core utilises the magnetic field itself which in the case of an RF coil  would drop the frequency. When copper core or more usually aluminium is inserted it utilises the magnetic charge reacting as to produce an opposing magnetic force and this has the effect of increasing frequency. if you put a block of iron on an electromagnet fed with AC it sticks to it with force if on the other hand you place a block of aluminium in particular (weight) it floats above it. The same effect as in the cores.
There are shaded pole electromagnets that can pick up copper too. Almost iron-ic lol.
Steve
Darkspeed:
Copper is a non-magnetic material, I am pretty sure.  So they don't make transformers with copper cores.
Darkspeed:
Copper core transformers are made and sold:
http://www.alibaba.com/showroom/transformer-copper-core.html
They appear to have specialized applications.  I'd say non-sparking environments like mines and offshore drilling platforms.  Seems reasonable to me.
--Lee
« Last Edit: 2010-07-14, 22:18:53 by the_big_m_in_ok »
Well it's certainly a mystery to me, I looked up the relative permeability of copper and it's 0.999994.   For air it's 1.00000037.  That implies an "air core" transformer would work slightly better than a copper core transformer.
the_big_m_in_ok:
No offense but I would classify your link as a "junk" link.  I am not saying that copper core transformers don't exist but that link is not a good link.
« Last Edit: 2010-05-12, 05:25:22 by MileHigh »
Careful folks  ;)
When I buy a new carburetor for my truck I return the 'core' (the old carburetor) for a credit.
As applied to transformers, cores are items which can be rebuilt -or- used as re-cycle material.
There are transformers and other inductors with aluminum, copper, silicon-bronze and brass cores. I doubt you will find them on the web, except for the small RF types.
The purpose of these metals as 'transformer cores' is to control, cause, or adjust inductance. This doesn't mean a copper core may not have another reason.
MH is right. Such metals as the core of an inductor DO make it worse than an air-core. Sometimes that is needed.
Hey,
I need to turn in the my A/C compressor core today when I buy the new one. Its not copper. Its aluminum and steel.
So the copper core must be an adjustable core, if it is for control. I don't think I have ever seen a copper core transformer. I would suppose it would be for RF applications and not voltage stepping.
I think the link is for scrap metal.
If you bring donuts to my house (or pigs in a blanket) I will eat them!!
Time to make coffee. I am going so slow time has sped up tremendously!!!
Like MH said, permeability of copper is about 0.999994, and silicon steel is around 8,500, grain oreinted silicon steel is 30,000, ferrite is 1000.
Copper is diamagnetic, so it slightly repells a magnetic field.  All of the electrons are "paired" with no net magnetic moment per atom.
Side note: Disruptive discharge induced magnetisation of a magnetic material was discovered by Joseph Henry in 1842.
From page 19 of "The Free energy Secrets of Cold Electricty by Peter Lindemann":
In these several new observations, the phenomenon was violating electrostatic charge
principles experimentally established by Faraday. Projected electrostatic charges
normally spread out over the surface of a metallic shield; they do no penetrate metal.
This effect had certain very non-electrical characteristics. Tesla was truly mystified by
this strange new phenomenon, and searched the literature for references to its
characteristics. No such reference was found, except in the surreptitious observations of two
experimenters. In one case, Joseph Henry observed the magnetization of steel needles by
a heavy spark discharge. The extraordinary feature of this observation (1842) lay in the
fact that the Leyden jar, whose spark apparently produced the magnetizations, stood
on the upper floor of an otherwise electrically impervious building. Brick walls, thick oak
doors, heavy stone and iron flooring, tin ceilings. Moreover, the steel needles were
housed in a vault in the cellar. How did the spark affect such a change through such a
natural barrier? Dr. Henry believed that the spark had released special "light-like rays", and
these were the penetrating agencies responsible for the magnetizations.
Grumpy,
So needles 2 floors away were magnetized by a spark?  That's kind of hard to believe.
I'll go out on a limb and suggest that electron precession in one results in a current and in the other results in magnetization.  ;)
http://www.google.com/books?id=Q_oLAAAAYAAJ&pg=PA51&dq=francis+nipher+magnetic+storms&ei=o97qS4KyEqHwkwTQosGqCA&cd=3#v=onepage&q&f=false
see page 52
Francis Nipher discovered that when either terminal of an influence machine (electrostatic) was connected to a magnet, the strength was increased and attributed this to increased permeability of the air around the magnet.
the_big_m_in_ok:
Well, you said in the post I quoted from that you didn't think copper core tramsformers weren't being built.  I gave a link to a site which listed some transformers made with copper cores.  That was my point.
I tried the site again from the original post and it ran as usual.  Please keep in mind that some people's computers will not bring up some sites even if the address is spelled correctly and others can invoke the site normally.  I've seen it happen in front of me.  Was that what you meant?  You can't access the site?  You weren't specific as to the exact problem.
--Lee
I was just wondering if you can achieve some sort of conservation of domain ( magnetic ) in an iron core
http://www.leedskalnin.com/LeedskalninsPerpetualMotionHolder.html
can the same be true for a conservation of charge in a copper core
Why does the copper spend its energy as heat and transmission when there is no apparent loss in the magnetic system
What is the speed of the flux in the magnetic system? <C? Where is the blotch wall? Is it moving at <C?
In the first statement are you referring to "remanence"?
It is my understanding that copper can be charged, but it looses this charge gradually after the inducing force is removed.  Electrets conserve their charge.
There are losses in magnetic systems: eddie current, hysteresis losses, etc.
The speed of the magnetic flux depends on the properties of the medium.  Isn't flux a scalar?  It could change faster than the change can propagate.
Lee,
When I click the link it brings up a bunch of scrap metal sites. These are not copper core transformers. The one link on the top of the page says they sell a copper core transformer. The rest of the links in the list are scrap metal places. A "core" is referring to, as wavewatcher already said, is the old used part. It can be a transformer, carb, power steering pump etc etc. They make transformers with a laminated steel core with aluminum windings, and if you are scrapping it, you would call it an aluminum transformer core. Even though it has a steel core.
So your link had a link to one copper core trans for sale, the rest are "junk" yards and scrap yards. I think junk was a pun.
Grumpy and All:
What about this statement attributed to Francis Nipher:
Anyone care to comment?  (By the way, I wanted to read the referenced passage, and I saw the pages at work.  For some reason at home I can't open the book.)
I have a comment about Peter Lindemanm.  As far as I am concerned he doesn't really know much about electronics or electromagnetism at all.  I would take anything he says with a grain of salt.
...So your link had a link to one copper core trans for sale, the rest are "junk" yards and scrap yards. I think junk was a pun.
Okay, I looked at the site more carefully and you're probably right.
However, there's a Swedish company that sells various transformers and one class of these transformers deals with 'audio copper and amorphous strip laminated cores.
http://www.lundahl.se/tubes.html
I do agree, the last sentence address to me by MileHigh may have been a joke.
--Lee
Actually it wasn't a joke!  Just the use of the generic term!
coper core transformers exist.
I have seen them in person.
Three interlocked rings of copper like a magnetic transformer but this one was resonant.
You are correct if you are referring to the Westinghouse polyphase, interlocked toroid transformer. I built a transformer from the patent. It worked quite well.
However, the core and the coils were wound together (not as simply as some might think). What most would call a transformer core wasn't at the 'core' of the device. It was very efficient and could produce the effect of two rotating magnetic fields, on different vectors, but the same center.
And then there is beer. 8)
Before you go too deep into the beer you may wish to look at the single-phase, simpler version.
US Patent #4595843
-AND-
If you like to have a challenge.... Try this one US Patent#4639610
...."the effect of two rotating magnetic fields, on different vectors, but the same center." Not actual rotating magnetic fields  :)
No takers on my pop quiz so far!  lol
How about this fact that I stumbled upon:
What's going on there?  Why is the relative permeability of air that value?  What is that saying to you?
End of the pop quiz part II!
Pop quiz?
You do know there is a slight difference between air and vacuum?
Let me guess the universe is expanding? or is .00000037 the bong smoke content of the lab?  ;D
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 07:33:15
