2026-08-15, 06:01:10
Author Topic: Piston Project  (Read 26836 times)
Anyone see an opportunity here to harness back EMF?
http://www.youtube.com/watch?v=tgX5cz1SMiw
A very concise, interesting device; worth spending two minutes of your time.
Enjoy.
Hi Matt Watts,
I captured the schematic from the video and edited a little to show one possibility to capture the voltage spikes across the driven pancake coil at any relay switch-off when the magnetic field collapses in the pancake.  Perhaps a full wave rectifier across this coil would give more juice because it miay 'capture' some induction from the oscillating magnet too.
(Notice that in this latter case with the diode bridge across the coil, the input battery can also charge up the C puffer capacitor whenever the relay contacts are closed to energize the coil. This direct battery charge up to the C cap is not the case with the use of a single diode I indicated in the drawing.)
Some further thoughts:
I think a more refined capture of both the switch-off spikes and the induction from the magnet could be received in puffer capacitors when Skycollection used full wave diode bridges across the other three coils (and not across the driven coil as I suggested above).  This is possible because the collapsing field from the controlled coil would surely induce pretty much the same 'juice' in all the other 3 coils which are in close magnetic coupling with the driven coil, the full wave diode bridges would capture them too, together with the induced 'juice' by the oscillating magnet.
To reduce input power draw, if he uses the old bipolar version, the 555 timer circuit has a CMOS version with very low power consumption and the relay could be replaced with a MOSFET to get rid of the relay coil current draw. The 555 could also be built with a variable duty cycle control too.
My suggestions above would improve the overall efficiency in an attempt to explore a possible output looping back to the input battery source, once the input and the received output powers become known with a reasonable accuracy.  I am not saying the output will be higher than the input though... ;)
If by "harness" you mean get more out of it than you put in, then no.
As long as that bouncing object is a hard ferromagnetic object (also known as a "permanent magnet") then there is no chance for this to behave outside of Faraday's law of induction.
Such a hard magnet has magnetic domains that are frozen in place and cannot move.
This makes the magnet behave like a spring, which is a very conservative device (100% efficient at best) - see the animation below.
If however, the bouncing object was a piece of soft ferrite (or at least a laminated FeSi steel) in which domains can move freely, then there would be some hope for this device using a Modus Operandi described in this post   (follow the "point C" link in that post, too)
The above is an simplified conceptual schematic of the piston motor with a soft ferromagnetic bouncer and energy recovery.
The switches S1 and S2 should be low RDS(ON) MOSFET switches of course and they never should be ON at the same time.
@Matt Watts
Thanks for that post. That pancake coil and magnet is very similar to what I recommended to Tommy Reed, See diagram here;
http://www.overunityresearch.com/index.php?topic=2684.msg43396#msg43396
He would have had 8 of those pistons flying through multiple pancakes, not simply like in that video where the magnet acts only on one side. All with no cogging. All he had to do is use his flyhweel like a drive wheel with a few magnets on the edge and drive coils and he could have harnessed the bemf from the drive coils to reduce input and he could have eliminated the 8 piston control.
What people don't take into consideration is the phase delay that can occur in the magnetic domain.  IOW, with the right magnetic conditions it is possible to get almost a 90 degree phase shift between the applied mmf from the moving magnet (as determined by its instantaneous position) and the flux in the coil.  That produces an enormous armature reaction where our induction laws appear to go out of the window.  Whereas in normal generators the Lenz flux coming from the current induced into the coil appears at a phase such that the moving or rotating magnet sees a drag force, and that drag force equates to the power being supplied to the load, when you get this huge armature reaction that equality no longer applies.  Power to the load no longer comes directly from the drive shaft, it comes from the electron spins within the PM.  In its simplest form of a magnet rotating within a coil, maximum voltage hence maximum load current occurs not when the magnet axis is at right angles to the coil axis, but when the magnet axis is parallel to the coil axis.  Unfortunately it is virtually impossible to achieve this magnetic domain phase shift using air coils (although when room temp superconductors become available the situation is much easier).  The only possibility I can see is for a coil wound on a C core that has a very small air gap, like just a 1mm gap.  Then it is possible to load that coil with a very low value resistance so that the L/R time constant is long compared to the time for 1 cycle at the operating frequency, while at the same time the coil resistance is even lower and does not consume much power.  Then the magnet has to be a very thin disc (like 0.5 mm thick magnetized across its thickness) that passes through that gap.  This form of generator offers OU operation, but I am not aware of anyone trying to make one.
Yes, but that is possible only in soft ferro/ferrimagnetic materials.  Not in hard ones - like permanent magnets.
See this video for an illustration of the magnetic domain disturbance propagating in a ferromagnetic material.
http://youtu.be/U9lsaGtRBGc
That is a shortsighted statement.
Yes, a delay can be introduced before a magnetic pulse gets to a coil, but a coil will still react instantaneously when this pulse gets to it.
You could introduce even a longer delay with a slinky (a long spring) with a hard permanent magnet attached to one end of it and near a coi and the other end pulsed mechanicallyl.  Like this:
Pulse ---> |/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/| N--------S     Coil
Do you think that the delay offered by a slinky would allow the pulse to induce more energy in the coil, than pulsing the magnet directly?
C'mon think!
[/quote]
Hi All,
I like this idea of pulsing air core, I worked with different design in the past.
I would like to add that this basic design I put up does allow for this type of pulse design.
Even if I used a magnet linear core that moves through the air core, this will generate bemf and also allow a greater return of energy that was used due to the fact it's a motor generator design.
This is my basic desiign.
https://www.youtube.com/watch?v=p0YU4x3TEeQ
Many minds are better then one, I respect this very fact!
I will offer my basic skills of building prototypes to this interesting air core piston project.
In other words, I can be a team player, all I ask is for integrity that make us all respected.
Let's get started!
Tom
Tom
Verpies has some wonderful paths to explore.....
A very kind gesture and a wonderful opportunity for this community.
thank you for stepping up.
respectfully
You are making A HUGE CONCEPTUAL ERROR by thinking that a faster change of magnetic flux (dΦ/dt) will induce more current or energy in a coil.
Faster dΦ/dt causes larger EMF but not larger current (nor energy) to be induced in a coil.  This energy depends only on change of flux (ΔΦ) that penetrates the coil.
The induced energy does not depend on how quickly the magnetic field changes!  It does not depend on the flux density (B) either ...nor on its rate of change (dB/dt).
A Whitworh mechanism driving a magnet, as depicted on diagrams shown below, will not induce different current (nor energy) in the coil on the forward and back stroke.
Somebody on overunity.com even made an experiment that proved that with a superconducting loop.  See here.
Hi All,
This is my basic build I did today, still have to add the electronics to drive this simple pulse motor.
https://www.youtube.com/watch?v=gKSrQHgVujU
Tom
This motor will induce more electric power in the coil on the forward stroke than on the backward stroke, but not more energy.
If you are after asymmetrical power pulses, then it is easier to charge a motor capacitor with 1W for 10s and then suddenly short it with a screwdriver.  You can probably get 800kW for 1μs this way.
Hi Verpies,
Yeah I agree, but lets not forget the BEMF when the forward coil is pulsed.
Tom
Hi Tommey,
It does not matter when the EMF does not cause a current flow.
In an ideal shorted coil the induced voltage is a meaningless quantity anyway - it cannot be even accessed nor measured nor used in the Ohm's law without causing division by zero.
Coils are inherently current devices ...and capacitor are voltage devices.
Thus the electric energetics of coils should be judged by current
...and the energetics of capacitors - by voltage.
Maybe a multi cylinder setup of my engine design Tom?.
https://www.youtube.com/watch?v=Z4VJG8-9izQ
Ho Tinman,
I don't agree on this  noble gas engine, IC engine works off heat generated by a fuel.
I would just look at a plasma pulse to generate heat to drive a engine then a foolish  noble gas theory that won't have enough heat to do nothing at all.
I have could design a plasma engine, but just have other things to do like stay warm this winter...
Tom
Quote from: TinMan
That's quite an innovative approach TinMan!
Is your magnetic piston operating by attraction or
repulsion?
Yes indeed!
What is that magic clutch gizmo again?   I got to get me one of those.  So cool how you solved the angular misplacement problem of a typical ICE.
What I am getting at is a generally unrecognized phase delay that occurs in the magnetic domain.  I am not talking about a propagation time delay such as is known to occur in soft ferromagnetic materials.  Let me explain further.  The voltage induced into a coil is proportional to the time rate of change of the flux within the coil.  Some flux can come from say a moving magnet, but there is also a component coming from any current flowing in the coil, even if that current has been induced by the moving magnet.  So when we wish to accurately calculate the voltage applied to a load (and the current flowing in that load) we have to take account of the effect of the coil's inductance that adds its own self-flux to the flux coming from the magnet.  Under normal operating conditions that self-flux is usually negligible so we ignore it.  But we can create the condition where the self-flux is dominant.  If the flux from the magnet follows a sine wave then that condition is met when the load resistor is small compared to the reactance of the coil's self-inductance.  And under those conditions you get the coil current shifted by almost 90 degrees from where it would be normally.  That modifies considerably the torque waveform on the drive shaft, and it also creates interesting power flows to and from the atomic dipoles within the permanent magnet.
The attached pdf was written some years ago and illustrates the phasor diagram for the applied flux from the moving magnet, the self-flux from the coil current (called Lenz flux) and the resulting flux that delivers the induced voltage.  The paper also looks into the power waveforms and energy flows (a) at the mechanical input shaft and (b) at the electrical load where at large phase angles the power to the load is not delivered coincidently with power taken from the shaft.  Over parts of the cycle the shaft torque is negative, but note this is not the usual cogging torque associated with magnets moving relative to some ferromagnetic material.  This analysis assumed a magnet rotating within an air cored coil (but perhaps rotating at impossible speeds).  So the cogging torques are all self imposed by the load current itself.  If nothing else, this paper illustrates that there are things going on in the magnetic domain that are usually unknown or simply ignored.  And the reports of OU eddy current heaters where magnets move in close proximity to a highly conductive disc, and where that phase shift becomes a reality, support the view that this could be a route to OU.
Yes indeed!
Dear Matt.
Sprag clutch bearing.....  Like these.......
https://www.google.co.uk/search?q=sprag+clutch+bearing&newwindow=1&source=univ&tbm=shop&tbo=u&sa=X&ei=QaO6VIT5DIO27gbXrIC4CA&ved=0CCIQsxg&biw=1920&bih=943
I am not certain about this but may have been invented by Otto for his early atmospheric engine you commented upon last year.
Brad may have had a good reason for using this idea but for me I would have worked out the full stroke suitable for a standard crank and counter balance because there is energy gained from the mass of the magnetic piston on the down stroke.
Just let me verify that you really mean "domain" and not "domains".
Yes, but I do not like your terminology.
The voltage is induced across the coil - not "into" a coil.  The only electric thing flowing in the windings of a coil is current.
Yes, and these two fluxes are exactly equal and opposite through a surface spanning the hole of an ideal shorted air coil.
I don't know what you mean by "normal operating conditions".
To me a normal operating condition for a coil is a condition that maximizes the flux current flowing through it, because a coil inherently is a current device and any resistance to that current is just a sink to the energy stored in that coil.
No, the induced current and flux that it creates is never larger than the externally applied flux, (when if we start from zero).
The word "dominant" implies "larger than".
Inductive reactance implies a frequency domain analysis.  I will not analyze the system this way because in such analysis the starting conditions are undefined.
If you want to continue this analysis with me you'll have to do a full transient state analysis - in other words: you must start from zero current and zero flux and zero force.
"Normally" compared to what?
But torque is not proportional to the flux - it is proportional to the gradient of the magnetic flux density.  Thus you cannot assume that the torque is in phase with the flux magnitude.
I know Cyril Smith's work.
Flux does not deliver voltage.  Flux magnitude is not even proportional to the voltage. The rate of change of flux is.
The only thing that is proportional to the flux magnitude is the induced current in an ideal shorted coil (if you start from zero).
The paper also looks into the power waveforms and energy flows (a) at the mechanical input shaft and (b) at the electrical load where at large phase angles the power to the load is not delivered coincidentally with power taken from the shaft.
The mechanical input (torque) is not proportional to the magnitude of flux.  Flux does not cause any mechanical attraction - it's gradient does.  It's not surprising that the torque is not in phase with the flux.
If you mean the negative torque on a magnet moving relative to a coil, then this is nothing unusual.   Just take a look at my animation of the bouncing magnet over an ideal shorted coil.   The force acts on it in both directions periodically.
Hopefully you know that you are talking with him too.
He's got some good stuff that has allowed me to visualize concepts I thought were far from my abilities.
Something I would really like one of you guys to explain, is how the Lenz flux from a loaded secondary winding in a transformer changes the phase angle between voltage and current in the primary.  I'd really like to understand the mechanics of this.  I know it does it, but I do not fully understand why and have little appreciation as to how.
Thanks much,
M@
I had no idea.  The funny thing is that my father had known him from the Vortex-L list and OUbuilders list.
That's a good question.  If the flux generated by the primary is taken as a given (as input data to a problem) then this makes it equivalent to the problem outlined in Cyril's paper.  I will answer that because it will also be relevant to his analysis.
But first of all: do do I have to explain why the phase angle in a single coil (in a series RL circuit) that is driven by a sinewave voltage source is equal to tan-1(R/(L*2πf)) ?
In other words: Do I have to explain why the phase angle of a single coil (in a series RL circuit) depends on the frequency, resistance and inductance ?
Give me a few days to digest this:  https://en.wikipedia.org/wiki/RL_circuit
Maybe I can answer it for myself.
Yes, I do not mean "domains", I am talking about the magnetic "domain" as compared to the electric "domain".  In the electric "domain" we generally deal with voltage and current where the current is confined to flow along and within cylindrical conductors thus creating an electric circuit.  We also take account of effects due to interactions with electric and magnetic fields that appear outside conductors by having components such as capacitors and inductors.  We have well known means for analyzing such circuits in either the frequency domain or the time domain.
In the magnetic "domain" we deal with mmf and flux where the flux is generally (but not always) confined to flow along and within cylindrical core material thus creating a magnetic circuit.  However we are not taught how to perform dynamic analysis of this magnetic circuit.  At best we have a series of magnetic "resistors" (actually magnetic reluctance) but we do not have other magnetic components that take account of things external to the core material (such as your ideal shorted coil).  In the absence of such components we cannot perform dynamic analysis of that magnetic circuit.  As a matter of interest your ideal shorted coil appears as a magnetic "inductance" Lm (obeying mmf = -Lm*dPhi/dt) of infinite value, hence ensuring that flux Phi through the coil is zero.  A coil connected to a load resistor R appears as a magnetic inductance of value Lm=(N^2)/R where N is the number of turns.  Having the external (electrical) circuit expressed as a magnetic component allows us to discover phase shifts occurring in the magnetic domain that are otherwise hidden from us.
I can't argue with that, but in defence of my terminology the voltage appearing across the coil is the line integral (along the conductor) of the electric field E created by the changing flux (from E=-dA/dt) and that induction appears all along the wire.  Perhaps I should have said voltage induced into the conductor.
So the net flux through the coil is zero, the classical superconducting loop expelling flux.  And this is obvious in my phasor diagram where the operating point is to the left of the semi-circle.  But we are not talking about an ideal shorted coil, we are dealing with a real load resistor, albeit of low value.
I am talking about a PM generator where practical limitations of rotor speed keep the frequency low so normally the load resistor is of value greater than the coil reactance.
And I meant the induced current and flux that it creates is larger than the resultant flux through the coil, in other words close to the situation for your ideal shorted coil where the resultant flux is zero.
Could do that but ultimately the system will settle down to the situation as described.
Again I am talking about a PM generator which in its simplest form could be a magnet rotating within a coil.  Normally the peak induced voltage hence also coil current occurs when the magnet axis is at 90 degrees to the coil axis.  This is also the position where that same coil current creates maximum torque on the magnet.  When the coil current is shifted by almost 90 degrees peak current then occurs at a magnet position where torque is near zero.
Linear force on a magnetic dipole is proportional to the gradient of the flux density.  The gradient does not appear in the torque formula, see below.
That's me!
You are wrong there.  A magnetic dipole of moment mu in a field B exhibits a torque T of magnitude T = mu*B*sin(theta) where theta is the angle between the dipole axis and the field B.  I think you have confused this with the linear force F on a dipole that has a magnitude of F = mu*(dB/dx)*cos(theta) where B lies along the x axis.
Clever animation.  But the real issue here is whether a magnet bouncing over a coil that is not quite shorted has any potential for OU operation, that electrical output can exceed mechanical input.  You have not stated whether you agree with the magnetic domain phase shifts as indicated by my phasor diagram (although your ideal shorted coil analysis where the self-flux exactly cancels the applied flux would suggest that you do agree).  My personal view is that OU operation is possible but achieving it with moving parts is difficult.
Yes I was on Dave Squires's OUbuilders forum.  As a matter of interest who is your father?
Smudge (aka Cyril Smith)
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 06:01:10
