Self-Running Tilting Tray
Started by Valeriy, 2015.03.18, 00:00:45
Valeriy
Self-Running Tilting Tray video:
US patent, Dr Drush idea
https://www.youtube.com/watch?v=nVSM__R1bqs
Wistiti
Hi Valeriy!
Interesting concept. Did you try it?
Thank you!
Paul-R
I can't think of any reason why this would work. It looks as genuine as a nine pound note. One of your lesser offerings, Veproject.
Valeriy
sure I tried, and it works but on my video only :P
Overboard
#4
North-south on the left, north-south on the right or vice versa, metal ball, fixed tack in the center.  Any so called "V-gate" will operate in both directions regardless of starting position.  Instead of running from the opening of "V" to the point to an increasing field strength, run the opposite direction and use the weakening field at the opening of the parallel "V" to escape the field using gravity.    The longer you build it the higher it will lift the rolling ball.  It is difficult to wrap a "V" into a Circle, linearly- two parallel angled magnetic lines produce the same effect.  There, I told you.
Valeriy
Overboard
Quote from: Valeriy on 2015.04.25, 20:00:50
You tell me then
Won't do any good, will it? You will just find a new way to mock me Munchausen.
