Daniel McFarland Cook discussion board // related to replication
Started by Chet, 2018.12.05, 17:44:26
sourcing period correct  iron wire for a few labs gearing up for replication
Grum mentioned "Drawn Pig iron wire "
here one Vendors specs approx 94% pure iron below
https://www.stenametalinc.com/pig-iron/pig-iron/
snip
Basic Pig Iron
Carbon (C): 3.5 - 4.5 %
Silicon (Si): 1.50% max.
Manganese (Mn): 1.00% max.
Phosphorus (P): 0.15% max.
Sulphur (S): 0.05% max.
Ingot weight: 10 kgs. max.
Foundry Pig Iron
Silicon (Si): 1.50 - 3.0%
Manganese (Mn): 0.50 - 0.90%
Ingot weight: 8 kgs. max.
Nodular Pig Iron
Silicon (Si): 0.50% max.
Manganese (Mn): 0.05% max.
Phosphorus (P): 0.05% max.
Sulphur (S): 0.015% max.
sample vendor   https://www.wireproducts.us/category/black-annealed-wire/5
ALL SUGGESTIONS WELCOME AND ENCOURAGED
Grumage
Hi Chet.
The " purer " the Iron, the better, those specifications look quite good.
It's just dawned on me that NMR might play a part in the process like the Meyer Mace device ??
Cheers Graham.
AISI 1008 and 1026 carbon steel seem most likely available
Steels containing mostly carbon as the alloying element are called carbon steels. They contain about 1.2% manganese and 0.4% silicon. Nickel, aluminium, chromium, copper and molybdenum are also present in small quantities in the carbon steels.
AISI 1008 carbon steel has excellent weldability, which includes projection, butt, spot and fusion, and brazeability. The following datasheet will provide more details about AISI 1008 carbon steel.
Chemical Composition
The following table shows the chemical composition of AISI 1008 carbon steel.
Element    Content (%)
Iron, Fe    99.31-99.7 %
Manganese, Mn    0.30-0.50 %
Carbon, C    0.10 %
Sulfur, S    0.050 %
Phosphorous, P    0.040 %
Physical Properties
The physical properties of AISI 1008 carbon steel are outlined in the following table.
Properties    Metric    Imperial
Density (composition 0.06% C, 0.38% Mn, 0.01% Si, annealed at 925°C)    7.872 g/cm3    0.2844 lb/in³
Mechanical Properties
The mechanical properties of cold drawn AISI 1008 carbon steel are tabulated below.
Tensile strength    340 MPa    49300 psi
Yield strength (depending on temper)    285 MPa    41300 psi
Elastic modulus    190-210 Gpa    27557-30458 ksi
Bulk modulus (typical for steel)    200 GPa    29000 ksi
Shear modulus (typical for steel)    80.0 GPa    11600 ksi
Poisson's ratio    0.27-0.30    0.27-0.30
Elongation at break (in 50 mm)    20%    20%
Reduction of area    45%    45%
Hardness, Brinell    95    95
Hardness, Knoop (converted from Brinell hardness)    113    113
Hardness, Rockwell B (converted from Brinell hardness)    55    55
Hardness, Vickers (converted from Brinell hardness)    98    98
Machinability (based on AISI 1212 steel as 100 machinability) The machinability of group I bar, rod, and wire products can be improved by cold drawing)    55    55
Thermal Properties
waiting for actual availability as well as vendors Mil spec sheet
Mil specs for one vendor
could not get image from PDF ,crumby pic for now ,
Jim
Thanks ,seems you landed the holy Grail......and I learned something new ?? [almost.... hopefully more after I speak with them on Monday]
if iron holds some secrets towards excess energy harvesting , this info seems crucial towards understanding micro environments which can happen in these experiments .
your link again
http://www.goodfellow.com/E/Iron-Rod.html
snip
Depending upon the temperature, pure iron can exist in three forms, namely alpha-, gamma- and delta-iron; alpha iron is a polymorphic form of iron which is stable below 906C; it has a body centred cubic lattice (bcc) and is magnetic up to 768C. Gamma iron is a polymorphic form of iron which is stable between 906C and 1403C; it has a face centred cubic lattice (fcc) and is nonmagnetic (n.b. its range of stability is reduced by the presence of carbon, manganese and nickel and it is the basis of the austenite solid solutions). Delta iron is the polymorphic form of iron which is stable between 1403C and the melting point; it has the same lattice structure as alpha iron.
end snip
here is ions historical link for a reference to the time frame of the patent and where wire technology  was in Cook's time [patent date 1871
as ion said " a good read" [fascinating techniques ,time period information and evolution ,
http://fortepianos.com/iron%20wire.pdf
on a side note makes me wonder about a whole new group of experiments under heated conditions ,and whether the anomalies seen
in micro environments [Like Mikes damaged stainless,or Celani and other ] can be better understood and utilized for true excess energy harvesting .
JimBoot
I've tweeted Goodfellow about pricing as the price link on their page is a 404.
TinMan
 Daniel McFarland Cook  thread here [Topic board Daniel McFarland Cook is on left side of main page [i just changed thread tittle for clarity]
http://www.overunityresearch.com/index.php?topic=1616.msg70418;topicseen#msg70418
Note below has nothing to do with this thread but is a mind bender topic which intrigues a few here [started with a water wheel idea that holds promise but not water  :o [leaks]]
https://overunity.com/18069/magnetic-flux-control-idea/msg527956/#new
JimBoot
Emailed Goodfellows will have pricing/availability soon.
Jim
spoke with Curtis at PA USA location ,Did mention you were also sourcing pricing info from Australia [mentioned contact info]
inventory number FE 005105 was chosen for a baseline grasp of costs [pricing strictly monitored
pricing as follows
FE005105   Iron Wire,
Diameter:0.025mm, High Purity:99.99+%, Temper:As drawn
340.00 US per meter available lengths to 20 meters
also asked for 18 gauge so as to check diameter and pricing relationship ??
part numbers
FE005172   Iron Wire,
Diameter:1.0mm, Purity:99.5%, Temper:Annealed
FE005180      Iron Wire,
Diameter:1.0mm, High Purity:99.99+%, Temper:As drawn
awaiting price quote for above
mentioned we might need 1000 total meters of .025MM to fill a 75 MM x 1.25 meter sleeve
Grum
fire up the furnace.................
Grumage
                       :o :D :D :D ;D
Post script.
As an experiment, could solid bar be used in place of multiple rods?
There's a firm in the UK that sells pure Iron to the Blacksmith trade. Max diameter of 30 mm.
partzman
Quote from: Chet K on 2018.12.10, 15:24:58
Jim
pricing as follows
FE005105   Iron Wire,
part numbers
FE005172   Iron Wire,
FE005180      Iron Wire,
Grum
Chet,
Did you really mean 0.025mm = .000984" ?  No wonder it is so expensive!
Quote from: Grumage on 2018.12.10, 16:39:22
                       :o :D :D :D ;D
Post script.
Dear Grum
Cook points out that the finer the wire for the core, the better, probably to reduce eddy currents which were also probably not well understood at that time. Discovered probably by empirical observation (Eureka! the unit made from fine iron wire does not get as hot in operation as the one made with a iron bar and also puts out more useful energy!)
I'm betting cook used ordinary iron annealed baling wire or soft iron music wire commonly available at that time so no high purity required, but would be an upgrade.
I'm guessing around  0.062 dia for the rods would suffice, 2 to 3" packed dia. by 3 to 4 ' lengths.
Also note that thermocouple grade iron wire type "JP" is 99.9+ purity, (see attached chart) and is also quite inexpensive @ $26 per kilo or less.
https://ualloy.en.made-in-china.com/product/oBlxrDRjnCWi/China-Pure-Iron-Thermocouple-Bare-Wire.html
Even from China this wire must meet all certs or temperature measurement using it would be in large error.
I'm sure it can also be had from US suppliers at low cost, as it is not considered valuable and rarely worth salvaging for scrap.
If you buy the thermocouple pair "J" wire, you get one Iron  "JP" and one Constantan "JN", the Constantan being useful for Celani experiments.....serendipity!
We need not look to anything exotic here considering the period of it's availability.
"JP" Iron is "positive" thermoelement
"JP" Constantan is "negative" thermoelement
Together they form a type "J" thermocouple for temperature measurement.
Grumage
Dear Ion.
I have to agree with your sentence, regarding the " exotic " statement.
We used to have a firm locally that re processed " wire " for resale, I'll see what they have to offer.
Cheers Graham.
Quote from: Grumage on 2018.12.10, 19:24:53
Dear Ion.
Cheers Graham.
I would use cheap and readily available soft iron baling wire .032 or .062 as a start. It is not too difficult to draw this down to finer diameters if needed in the future.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313.TR1.TRC0.A0.H0.Xbaling+wire.TRS0&_nkw=baling+wire&_sacat=0
https://www.grainger.com/category/baling-wire-and-lockwire/strapping-and-strapping-equipment/packaging-and-shipping/material-handling/ecatalog/N-131h
Paul-R
If the pig iron is quoted with 3% carbon and steel is quoted (elsewhere) with around the same, then this pig iron is probably not iron at all.
If the SG specifies R45 or R60 gas welding rods, these might be worth trying.
Grumage
Hi Paul.
The term " pig Iron " goes way back to the fist " Iron masters " the Darby's John Wilkinson etc. So named because the " floor " resembled piglets suckling from mother Pig.
This was the first " Iron " from the smelting of ore and charcoal and later coal as the process cleared the entire area of trees!
This Iron was then re melted to further alter its composition using the " art " of the time.
If you're living in the UK I would greatly urge a visit to Coalbrookdale in the Midlands, a working " industrial heritage " museum and close to the worlds first true " Iron bridge "
Cheers Graham.
Paul-R
Yes, I'm in Britain. The attached building belongs to that era. It is remarkable.
Presumably, you need iron and not steel because iron takes and sheds magnetism quickly and steel doesn't. the trouble is that all too many vendors don't know the difference, particularly those handling wrought iron who are often selling steel as iron. (In a few years there will be a lot of complaints since, as we know, iron doesn't rust whereas steel does). I don't know where to get true iron fine wire.
heard back from Vendor
FE005172   Iron Wire,
approx 1 Dollar US per meter
link again...http://www.goodfellow.com/E/Iron-Wire.html
Quote from: Chet K on 2018.12.12, 15:36:19
FE005172   Iron Wire,
try:
https://www.galwire.com/galvanizedmetalwire/cutwire.html
soft annealed iron wire bulk cut and bundles...scroll down page
ION
seems good potential except its soo far away....
I going to follow up on your gas spectrometer suggestion for analysis of a few cheap domestic wire sources here [IE.. floral twist wire .
see if Steve can use the University Lab for this testing ?.
had a few crazy days here ,but seems I can make some more calls tomorrow to other Vendors for Mil specs and pricing .
Much early work with Fe used "Swedish Iron" or "Norway Iron" because iron ore from that area had particularly good magnetic characteristics.  You will find some data on these and many other irons in "International Critical Tables of Numeric Data" first published in 1929 by The National Research Council of the USA.  A Google search will find archive copies in pdf format, I have one on my computer, file size 23MB.  I can post it here if necessary.  Below are two extracts.
Dear Smudge
Thanks for the reference.
Here is a direct link to download the\1930 edition.
https://www.nap.edu/catalog/20230/international-critical-tables-of-numerical-data-physics-chemistry-and-technology
edit: sorry this is just the index
