2026-08-15, 04:20:15
Author Topic: Coils  (Read 8348 times)
Placeholder for discussion of the coils in the AVEC Device...
What to use.
How to wind them.
I purchased my CCU coil assemblies at $40.00 each from des@coilwinding.us.
EDIT: Photo of purchased coils added.
« Last Edit: 2010-09-23, 05:03:49 by Rosphere »
Update to coil winding:
I made forms and crude tools to wind my own coils.
I'll post some pictures later
Edit:
update to information that Rosphere provided above.
https://www.coilwinding.us/
https://www.coilwinding.us/products
I have not tried them but they look great.
The CCU coils that a sequential driven in the AVEC device are wound like a Brooks coil, with a second coil of about 4 layers of heavier gage wire outside the Brooks coil, per the attached file. M4_build_diagram1
Note the image is not to scale.
The finished coils look like the ones Rosphere posted above.
In lieu of the outer coil, a DC bias can be used in its place.
These coils are pulsed with HV DC pulse of short duration (1500v minimum), while DC of 24v, through a 50 ohm rheostat to adjust current, is applied to the outer coil.
When pulsed, some sort of field or particle effect is projected out in all directions.
I am trying to figure out what this effect actually is.
A few ideas, partly based on old Borderlands clips:
 - Attraction/repulsion to metal foil
 - Attraction/repulsion to dielectrics (scotch tape)
 - Test for anomalous capacitor charging in-field(ground one lead?)
 - Could try using iron filings and applying a single pulse to see if a pattern emerges?
 - Test for film exposure to field (X-rays or something with similar effect?)
 - Test with foil or plate panel to see if the field can be focused/steered/reflected.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:20:15
