2026-08-15, 20:39:39
Pages: 1 2 3 [4]
Author Topic: SR193's (nextenergyru) TK Replication  (Read 120872 times)
With respect to Reply #60,
Some of the wiring connections are missing.  Enough that the whole diagram is just about unreadable to me.
--Lee
--Lee
  hi the_big_m_in_ok
look at this, is similar
forun http://realstrannik.ru/forum-strannikov.html?func=view&catid=19&id=102
   chauuu
  hi the_big_m_in_ok
   chauuu
Yes, thank you.  That's better.
I can identify most components. It a good improvement over what was shown before.
--Lee
  Going back to the SR device. Has anybody looked at Tesla patent #428,057 entitled Pyromagneto Electric generator?  O0
  When you read this patent it sounds very familiar to what SR said when he explained his device. By that I mean, and to paraphrase "Imagine something burning and rapidly cooling, then burning again"
  Also member LtBolo, on the OU site, back in September was at a point where he was building a good amount of heat in his cores. At that time CosmoLV said he was close.
  Some food for thought.
Respectfully,
Core
I think CosmoLV has some interesting ideas that he has not proven or even tested, but he thinks he is right so he keep pushing them out there.  So take everything he says with a grain of salt.
  hi the_big_m_in_ok
   chauuu
My favorite part is the ON switch, which appears to do nothing but short out the 12V battery.  What's up with that?
        hello friend humbugger
   I really do not understand
  but, hey found a forum in which a user named mishail71
 , is doing tests, and reported to us which is the essence of the system
 stick it translated the Essene   ;)
Hello!
Firstly we do not necessarily have the TT enough explosive momentum admixed to the main signal at the zero point of each half-cycle ...
Secondly we need to get rid of useless hysteresis loop.
That is, if we obtain positive wave meanders, then at this moment is the saturation of the core (magnetic induction). At first slowly and then a sharp jump in and then again a little raised (which would later there was no field). That is a chapel of the maximum efficiency of magnetic induction.
Thirdly us as we must maintain this same magnetic induction (saturation of the core), because the transition meanders in the negative half-cycle, we will close the hysteresis loop.
In other words, each half wave of reverse polarity will destroy the remanence serdechnika.I repeat everything again ...
That you understand we do not need!
The question is how to do so would not bring the matter before the circuit loop
hysteresis?
And at the zero point of each half wave remained remanence of the core for the next half wave of the same polarity.
With the success and makes the explosive pulse, creating a force induction core in each half-cycle ... ... Although there is another way to keep the magnetization of the core ...
Here are the two main things that must be satisfied ...
Yours!
links     mishail71     http://matrix.3nx.ru/viewtopic.php?t=134&postdays=0&postorder=asc&start=1050
    user youtube link  http://www.youtube.com/watch?v=NB1Hlxe-dVI
      lucky
@all
Just so everyone knows, I get this return (bounce back) when I enter...
http://www.001-lab.com
on the browser address bar:
http://001-lab.com/cgi-sys/suspendedpage.cgi
Both addresses do the same thing when clicked upon.  What happened?
--Lee
that account was suspended
Hello!
hysteresis?
Yours!
links:
    mishail71
    user youtube link
      lucky
It seems that he may be saying that it is important
to utilize discontinuous pulsing.
The pulses should be strong enough to take the
core to saturation;  then the magnetic field is permitted
to decay to remanence prior to the application of the
next pulse.
The direction of the magnetic field must not be changed.
Each pulse must have the same polarity.  Polarity reversals
destroy the effect.
There is more that is difficult to comprehend regarding core
saturation and how it is achieved or possibly exceeded.
Discontinuous pulsing is made use of in certain switch mode
power supply systems.
There is no core in TK's patent, or any mention of a core by him in any of the translations.  Every replication with a core is suspicious and not proven to be OU.
Lastly, the spark in the TK devices is not thick and has very little current to create a magnetic field to saturate a core.
This video was interesting, as were the schematics .  But I am also careful that this might be a waste of time, given that there is already a language barrier in place (Georgian/Russian).
I think it's probably easier to work back from experimental results with pulsed DC solenoid into air core, soft iron core, ferrite core, etc , but that's just my 2c on this.
hello friend
  it would also be very interezate, build a core of steel wire, such as using bicycles for the brake, I say this from experience above, using the welding set on a motorcycle and observed nowadays that more fluidesd circulating current for steely wires of the brakes, the chassis itself iron
heloo all
  @core  you  are thing very good   about heating but how to get heat out cores  and coling fast  how to say <ferith core make paramagnetic and magnetic the idea is ok. do you have idea for this :)
@all
--Lee
"Just so everyone knows," again:
I believe if the site master of   http//www.001-lab.com   ever decided to backup, or reconfigure, the database software suite, the above error message would be seen.
It took me awhile to figure that out from seeing it happen every so often on other sites.
--Lee
--Lee
Here the site works well from its home page at:
http://www.001-lab.com/001lab/index.php
In any case one can use google cache:
http://www.google.fr/#q=site:001-lab.com
Very good, exnihiloest.
Both sites load and run, even on filtered, borrowed computers at the public library.
Thanks.
--Lee
Pages: 1 2 3 [4]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 20:39:39
