Quantum Field Fabric
Started by DaveL, 2021.10.29, 15:09:09
DaveL
Probably the most important study of free energy, is the study and experiment working the Quantum Field Fabric.
Proof is necessary, and it must be personal.
The Field all around us filling all space vibrates, and this vibration is the Source of all matter and all energy.
It vibrates at a base frequency of 333000 Hz and a great many octaves above and below this based on geometric manipulation, 2x  4x  8x  [octaves].
Measure out a copper or aluminum tube or pipe, cut it off at 333 mm, and feel this vibration.
Greater mass is greater power.
http://www.resonantfractals.org/Doc/Joe_Cell/Space.html
This is only the beginning!
Dave L
DaveL
#1
My meters and scopes just see dead space.
658.20222 Ratio  V Electron  / V Proton
/4  =  164.550555  E/P
/4  =   41.137638  E/P  [Floyd Sweet VTA Turns Ratio]
/4  =   10.284409  E/P  [100 watt experiment Turns Ratio]
DaveL
#2
The native people of the South Western United states use quartz crystals for healing work.
When they toss the crystals into the water bath after use, steam will rise from the water.
http://www.resonantfractals.org/Doc/Quartz/Menu.html
DaveL
#3
This is a very low frequency at 135,000 Hz, and it is easy to feel, but it holds the dark side so many fear it.
All personal progress is a relationship between the one person, and the universe.
Realize that, and there is nothing you cannot cipher.
This is not a Religion, mass vibration is real!
DaveL
#4
5758 Hz will bring up a vibration field around gold. Detecting Elements
Gold Finger [GF]
3D Magnetics
Thanks Dave ,
I will be experimenting with these things next time I head out to our gold fields .
Out there a person connects with nature in a different way which is why many go out and don't care much if they don't find any gold .
Irony ... My favorite .
muDped
Yes!
Our Universe and Beyond holds many "Secrets" which to the prevalent Institutional way of thinking seem unfathomable.
Some are even dismissed as "nonsense!"
Not to worry.
It will all be slowly revealed and verified as we continue our most magnificent lives.
DaveL
Taping the Source Field
Using mediators, and routing vibration through a device. Sums, Multipliers, etc.
The Source field can be routed into and through a machine, then terminated back into the flow that never ends.
333000 => 37000   Source => Termination
The closest thing to a circuit, an EM educated person may fathom.
http://www.resonantfractals.org/Doc/Source_Field/Source_Field.html
DaveL
Making a car fly
Crank and Piston vibration routing, and fracturing.
The polygon form sets up single point nodes on the circle of motion, and these can transfer weight then cancel it.
http://www.resonantfractals.org/Doc/Lessons/Advanced/Applications/Light_Activation_Car.html
DaveL
How does the mystical, become the next science?
All objects, are the result of a convergent vibration field, which begins on the outer boundary of the universe and converges in through all space to the point of the object. Thus we can tune into all other objects in the universe, because the field sustaining them moves through us also. Just as the field that sustains us moves through them.
A fractal vibration of the target is all that is needed, and our world can also be observed from any location in this universe as well.
http://www.resonantfractals.org/Doc/Structure/OverSoul.html
This was known thousands of years before our culture rose up, and is still taught today as zazen practice, which can produce accuracy both locally on earth, and through the galaxies between inhabited planets.
DaveL
The Atom is a conscious field also with the same form as the human brains spirit.
This is a science, it is not a religion, because we can achieve 100 percent accuracy with it, and also measure frequencies, and distances.
Fractal science gives ability to measure both great distance, and small distances, when combined with perfected awareness.
Navigation of a light ship through the universe, must have a pilot who can see from the outer boundary of the universe.
Measuring the frequency of an atom must have an engineer with comprehension of the fractal system of the vibration that creates and sustains it.
As we peer deeply into the atoms, and measure them, we can thus create them at larger dimension, to self power our world in the same way they self power. We need go no deeper then the atom, to achieve this.
This is mastery of the Quantum Field Fabric and IT's awareness.
http://www.resonantfractals.org/Doc/Lessons/Advanced/Lesson_1.html
DaveL
Where is the power?
Power lies in the higher frequency ranges. It has no value to us until we learn to downshift the frequency, and still maintain the power into the smaller fractal. This is accomplished using geometric reduction of the dimensions.
There is a safe method for sensing, and there is a dangerous method for power application.
Reference:
We now come up with two different sets of numbers. I call them the safe chart and the dangerous chart.
333,000
3,330,000
33,300,000
333,000,000  = 333 Mhz [ for sensing work only, will not self sustain with power ]
333,000 x 512 =  170,496,000 = 170.496 Mhz [ Will self sustain with power ]
[ Here we enter the danger zone ]
These are two different goals,
1 - To detect the presence of a specific atom 10x
2 - To duplicate or create the Isotope that powers an atom at larger fractal dimension. Powers of 2x.
I refer you back to the Geometric Expansion Document for a reference, one more time.
http://www.resonantfractals.org/Doc/Joe_Cell/Law_Of_Geometric_Expansion.html
DaveL
#12
Vibration Power
Flows towards the smaller octave coupled in from the larger fractal.
This is why atoms are so powerful yet so small, the strong force is derived from the universes outer boundary as a smaller fractal of it via the Proton.
Joe cell obtains tremendous power, enough to run an engine, from this effect, setting up a recursive vibration loop.
This loop of energy moves the opposite direction through the EM circuit that the electrons do.
It will move towards the positive charge source in an electrical circuit. In the cell it will move towards the center tube against the electron flow.
DaveL
Logic and Structure
The conscious awareness existed before the human form body could exist. As everything that manifests from the Quantum Field Fabric, does this as a result of awareness desiring to observe it.
IT was there at the beginning of the structure, and shared it's awareness with each part that it created through the Field.
Thus our awareness, whatever that is, is a part of the original awareness that created all things, from the Field.
This is self evident in the experience.
However inside the ego mind of the physical body it is a shrouded mystery for sure.
The experience I speak of is in the manifesting of elements in a Joe Cell, and once one experiences this phenomena, we realize we have the power to create matter using correct vibrations projected into the water as it naturally manifests H1 atoms in the inflow mode.
The isotope level is where we have enough connection with the universe, to become creators with our small awareness.
We need not go any deeper, as to quarks, or the parts below atoms that do not self sustain.
The tremendous power we discover is the H1 atom, and when it starts to combine with itself and other atoms we get a tremendous inflow of energy, and field compression so powerful it can crush a large steel container to 1/2 it's volume, sucking inwards in a flash.
This is the implosion effect of the Joe Cell, very dangerous and not a toy.
Knowing the water bond resonance frequency hands us the power to disassociate water molecules into H1 and O1 atoms, if we are careful not to overheat and produce H2 and O2 instead.
DaveL
Bifilar Coils
Because the atom has 3 field forces, this may not seem comprehensible, however there are important things to observe here that can greatly increase the power of coils.
We must first recognize a directional component of EM to comprehend the advantage of the bifilar coils system that Tesla handed us.
Two wires near one another with current flowing in the same direction will repel and push apart, spreading out the field into a less dense space.
If we configure the coil to have a greater voltage between the turns, this electrical field will then attract and draw them back together, and compress the density of the magnetic field. This will then approximately double the magnetic field flux over a normal coil. We wind two conductors the same direction down the coil, then wire them in series aiding, so 1/2 the voltage now appears between the two conductors and compresses the field back inwards.
Two wires near one another with current flowing in opposite directions will pull together, compressing the field inwards. Same coil wind, but this coils is so compressive, it can begin to manipulate the nuclear center of the atom, the Isotope level. It can thus access the Free Energy component of the field.
This second coil opens a new door for electronics, one of nuclear energy manipulation, without destruction of the atom.
In the combining of these two coil systems with correct frequency manipulation we can set up free running electrical systems, which can self power and also respond to changing load conditions to regulate them as atoms do. Electric Field Magnetic Field and spin direction or motional field [Tempic Field].
This has already been shown to work.
This technique is so powerful, it has been silenced to this day. I know of at least two who have accomplished this in our age, and been shut down and silenced as soon as the techniques were posted as to data to get them working.
The war on this is a social war, and why I will not show working machines publicly, I offer comprehension, and direction, and that is where we will conquer this war.
DaveL
Spin Fields
One must review, motion is a field force that must be present for an electric field, and a magnetic field to manifest in the Field Fabric.
Electron and proton spin opposite directions in the same magnetic field orientation creating the positive and negative charges of the Electric field force.
In figure 1 the electron and proton are separated, if the Magnetic fields are in attraction the spin field is in repulsion.
In figure 2 if the spin fields are in attraction the magnetic fields are in repulsion.
A neutron removed from the atom, will fly apart within 10 to 15 minutes producing an electron and a proton.
Figure 5 is most interesting indeed.
This is directly from the data of physics, and electronics people in general do not go this deep.
Now the frequency differential between E and P is a ratio that never changes when they are in proximity to one another, generating a hydrogen atom.
This is the first engine of nature I am aware of, completely self powering, and self recovering.
With the frequency ratio now known, one has everything they need to design the circuit with two kinds of coils described above such that it will emulate the atom.
Electric, Magnetic, and frequency [Tempic]
Dealing with all 3 is more complex indeed, but when you cipher this, you will have what has been sought after.
http://www.resonantfractals.org/Doc/Magnetism/Magnetism.htm
Here I started out with far more complexity in order to finally after all these years realize this.
DaveL
Copper and Iron
Iron does not have a nuclear hook, it has an electron hook.
Copper has a nuclear hook, but does not have an electron hook.
Only elements with a nuclear hook, can be manipulated using vibration and spin coupling, as the magnetic field pointed inwards can be used to vibrate them up. Aluminum, Bismuth, Copper, Hydrogen are the ones I have played with extensively.
These are the free energy materials we have easy access to.
Drop the magnet down the Aluminum or copper tube, and it falls slowly, having its "motion" effected.
This is an inertial manipulation as no opposing magnetic field can be measured to be present.
We have gone to extreme methods to prove this.
The magnetic falls slower due to the Tempic field of the metals used above.
The magnetic flux of the magnet is not bent in any way, as it falls through the tube.
The solution is a nuclear force.
The copper or aluminum is the source.
Thus we can pull up conical fields from either one, but producing magnetic fields happens in the electron shells which have no mass or inertial qualities to get excited about.
DaveL
Following the power
Starting out as an electronics experimenter, I was like you guys mostly, with a wide knowledge of how it all works, and absolutely no idea how free energy could even be possible, or where it might come from. Study of ones like Tesla caused us to focus on the electric and magnetic fields, and yet there was no solution found there to explain power from "nothing at all".
The magnet dropped through the metal tube of copper or aluminum opened a new door, as we could not identify the presence of an opposing magnetic field with enough power to slow the magnet down. We cut a slot down the pipe to stop any currents, and yet the magnet still fell slower.
Turns out the positive charge of the atom is contained inside the strong force field bubble with the reversed spin field on it, and protons do not flow down a wire, yet positive charges can. A HV negative charge will burn you, but a HV positive charge will throw you across the room without burning you.
It became obvious to us, where the power of motion was coming from, the nuclear level inside the strong force field bubble. Spin.
It was then time to open the field of physics, and finally NMR in attempts to cipher all this, we had to come to know the atom, as physics people supposedly do. The problem with physics people is they want give the 3 field forces different names.
So there is then a disconnect between the electronics and physics people creating a feel felt barrier, and no one actually attempts to feel the fields inside the atom and compare them to EM technology.
We could not get magnets to spin around one another with nothing in between them!
Electric fields as well would not produce the ring shaped fields in the air, holding the electron shells outwards from the center of the mass of the atoms.
EM fields just come up short to explain how atoms work!
And yet we realized the motion of the field that has power to move objects comes form the nuclear center of the atom.
It is related to spin direction of the nuclear mass changing.
The new term "inertial fields" became self evident.
Inertial fields, and the power to create motion comes from the mass of the atom.
Thus began the study of manipulation of the mass of the atom, and eventually "mass vibration" was found to be the solution.
That these kind of fields can become coherent, exactly like electric and magnetic fields can, was the tipping point.
This was something not even considered in physics or electronics until NMR science realized it.
NMR science however is also masked with so much new terminology it is very hard to cipher what we need from it.
They think in terms of atomic levels, and have no concept of a coherent mass field becoming larger then a small group of atoms in the human body.
That we can now create very large coherent fields of mass vibration and generate power from these as inertial force, is still beyond current science.
Here is where it became a fringe science only for those with comprehension of all three of the field forces.
With "motion" now set up to become a field force we could expand much larger then the atom, we stepped into something new.
DaveL
The Development of Tempic Field Force
Wilbert Smiths paper on "The New Science" offered something we then needed, both terms for, and operational concepts for.
The "field density" of space itself for one.
The "field fabric," he likely got from Max Planck, the fabric of the universe being stretched and containing tiny forms of spin that are cancelling.
Light velocity is a function of the field density the light travels through, it is not a constant to be ignored, it is a variable.
We can operate on space to alter light velocity and field density.
The Field Fabric has the geometry of a scalar cancelling system.
Tempic field is the first kind of energy that can be manifest from space and formed into layering due to the nature of vibration, creating the structure of atoms.
E and M field are then derived from it by adding directional vectors of motion at 90 degrees.
This geometry then hands us the methods of fractal calculations.
The first accurate graphic of the three field forces and how they work geometrically. Wilbert's "Quadrature Concept." Walter Russel's block diagrams.
The powering structure does not start out with electric or magnetic fields, they are the top of the structure! The outside. The part that is entropic.
By now we had a pretty good mental model of the atom and how frequency plays an important part in how the nuclear center operates.
No one however could cipher how to get energy out of this, as NMR offered only very weak RF responses to what was applied to the atoms, and certainly not any over unity present in that mental model.
In order to make advances we would need access to the frequency as a Tempic field energy vibration, and we had no idea how NMR could play a roll in this back then. Developing strong force fields that can cause electron shells to orbit them, was well beyond us at that early time.
Tesla studied this energy of motion, when a person was killed from loading or unloading one of his generators at Niagara falls too fast.
The shock wave went out from the generator and could knock people over. Even through a piece of glass he could feel the sting of this energy.
This related to a change of the motion of the mass of the generator, and not the electrical field, as the glass would block that.
This was the turning point for Tesla and where he began the experiments that have been suppressed to this day.
We discover the vibration wave can be intercepted at 90 degrees to the wire, and kept from emanating outwards, placed back into the circuit.
Today called power factor, where the solution back then was to force the E and M fields back into phase balance by adding large capacitors, before the geometrical solution was ever attempted using 90 degree coil systems.
The power of the EM fields when loaded causes them to split in copper wire medium, due to the structure of the atoms of copper.
We have called this "the current lags the voltage in inductive circuits." All copper wire is inductive. So even if it does not split at the generator, it will split at a load that has copper wire in it with conventional winding methods. Capacitors are added in attempts to force this back into alignment, and spike suppressors are also used.
Bidini showed that extra energy could be gained by channeling these spikes into another storage system, and using them to either charge a capacitor or a battery. The faster the transition of current the more spikes could be produced and the greater the energy in each one. Pulsed motors were a result, and also fast transitions with circuits that could switch on and off at micro second rates. The spikes had to be contained and the energy drawn from them or being around these could become painful, very painful as we discovered in the TPU systems.
At Helsinki Finland Roshin and Goddin as I recall constructed a device which worked. It produced 8 kw of energy output after it got up to speed, and was based on the geometry that Searl had developed as a child.
The device developed a blue aura around it, the stuff of electron orbits, controlled from a greater force that could hold them in place.
They then came up with a stupid theory about imaginary sheets of Aetheric [time space] energy, which frankly made no sense, but then they were just a couple of college students starting out. LOL! It was never suppressed because no one could ever understand it from the documentation, or could likely ever construct magnets like that on their own.
It had both magnetic attraction along the tops of the rollers to the central core, and it had magnetic repulsion along the sides of the rollers operating off the copper sheet. So the nuclear force was present there from the copper. It did not have any of the rest of the layers Searl thought it should have from his law of the squares, which is also a tremendous mess of unsound logic if you ever read through his documentation on this.
Anyway what was important here is what works, and what works is the iron and the copper, are able to produce a free energy system, if we only understand and can engineer the basics of how the 3 fields interact, to produce the free energy that every atom does.
Bashar - 333000 Hz
The first channel of psi talents , higher self, that handed us real data!
This gave us ability to access the nuclear levels, finally!
You see the NMR calculations rely on determining the frequency of an atoms isotope based on a magnetic field intensity, and we have to then supply the frequency of the Hydrogen atom at that intensity to get the rest of the atoms frequencies from the tables.
We did not know the frequency of a hydrogen atom, with no magnetic field applied!
Neisem Harriman handed us the other part, the Proton is a fractal of the entire universe.
Thus now I knew the frequency of the H1 atom with no external magnetic field. It is a fractal of the 333000 Hz field of the universe, the field fabric itself. This is why the H atom is the first and most prevalent one to exist in nature.
By now I was working alone, and my educated colleagues were disappearing.
I stuck the frequency stack into the NMR charts and out came the frequencies for all the atoms on the charts, with no magnetic field applied!
I began testing them with calipers and everyone I tested worked.
I could now create an Isotope at bench sizes, and start to play with them, to see how they interacted with E and P fields.
I discovered this is the basic system of Walter Russel's conical coil device. If built to spec as a large Isotope they self power.
However the 30 degree natural angle then become very dangerous...
Again Bashar indicated how to tame it, by using a 33 degree tip angle.
The atom itself gave the answers to free energy as to actually engineering it.
As well it opened the doors to control of inertia and gravity, as the mass is the location in the atom having to do with weight, and T field motion.
Mass is a field that can be manipulated using vibration techniques on atomic levels.
The Field Fabric can be used to manipulate this directly, using no other source of power.
It is all about accurate frequency control of vibration energy.
The Field itself provides the power.
I now have a relatively good idea how Alien craft can self power, and travel, levitating, and then zooming off with little inertial connection to the earth.
Wilbert Smiths description of various scalar coils, handed us the best method to open this door.
http://www.resonantfractals.org/Doc/Scalar_Coil/Fundamentals_Scalar_Coils.html
http://www.resonantfractals.org/Doc/Gravity/Gravity.html
DaveL
A Lifetimes Education
I was about 16 taking my first course in high school in electronics.
Age 17 learning of Einstein's relativity from a nuclear physicist taking a break to teach high school physics for one year.
Age 20 or so when I started my higher education in electronics.
Now at age 67, sharing what I gained from continual questions of phenomena I had witnessed over a long career in communication and powering systems in electronics.
About 51 years of learning, that never ended.
They say a younger generation can learn faster if given the correct information, I hope that is true.
Another lifetime is too long to wait for these advances.
Copper medium has two Isotopes, two different atoms with two different frequencies. They can be chained together and manipulated as one field in different orientations, using geometry [vector addition]. If we sum the two frequencies, they will both align and operate as one spin. If we add them at 90 degrees we get a new frequency that will force them into quadrature alignment. These manipulations are all possible by calculating an exact and correct frequency to apply to them using a scalar cancelling coil system.
Mass vibration is the solution, and the beginning of "The New Science" that Wilbert Smith indicated is possible.
The science of the Advanced Alien Cultures.
DaveL
Ultrasonic Levitation
This video shows what is possible as to layering of fields using vibration energy.
https://www.youtube.com/watch?v=XpNbyfxxkWE
It gives a mental model of something much smaller we call the atoms layering, where electrons are trapped into orbitals.
The vibration however is much smaller in it's layering, but the visuals are similar.
The atom is not vibrating the air, it is vibrating the Quantum Field Fabric.
DaveL
100 Watts
In one of my first experiments, replicating Floyd Sweets set up, I tweaked by feel the geometry of the atom that was constantly in my mind at that time. It worked, and felt really good to be inside this vibrating field bubble, that made me reflect on what creation must feel like.
http://www.resonantfractals.org/Doc/V2EM/100watt.html
My wife came in, because her computer monitor was doing strange things, as she passed through the blue aura of the field the hair on her arms stood up and she screamed. I reached over and unplugged the cord from the wall, and the 100 watt light did not even flicker.
I have since identified the vibration feeling present that day as the electron proton ratio, the yin yang ratio of all matter. Finally I found the source of that feeling I was tweaking that was so spellbinding to me. It was actually right there in the first document I had compiled on magnetism, but I had no idea back then that a ratio was an important method of setting up self sustaining vibrations.
My very first document researched well before my first experiments were begun.
I detailed all the sources inside the atom with magnetic fields, and how they all fit together, in attempts to pinpoint how the atom could self sustain, and self correct.
The 3SD was studied also, and I assumed it operated from the magnetic and electric fields, but later realized it was simply the vibrations they produced as platonic form, convergent to a center point in space that created the important effects.
http://www.resonantfractals.org/Doc/Magnetism/1_Theory_of_the_Universe.htm
This was a compiled set of what we knew as the laws of physics, and attempts to understand the 3SD design, a multilayered set of spheres that rotated in opposite directions with magnet patterns glued on the spheres in platonic form designs. We got very bogged down in the design and our assumptions, and really missed the important points.
One of the groups built one, and had some rather strange experience with it, effecting their perceptions.
It scared them so much they totally stopped working with it.
Now I can tell you why this happened, they made the sphere much larger then the physical brain, and it took them right out of body, while still awake in the physical. That was not what they were seeking at the time, they were seeking free energy! LOL! Instead they got a conscious experience.
Brings back the memory of the 100 watt experiment where I got both the conscious experience and the 100 watts of free energy.
Kosol was an accurate psi person, first one I ever met who always got it right. He would call me up to tell me what I was working on and try to then steer me to notice specifics I was not aware of. I never told him anything I was doing, but he always knew.
As I got into the resonant fractals and measuring the length of wire and tubes we separated, as he wanted us to do it all using intuition and direction of his higher guidance. He was responsible for my first experience with an alien culture, that was absolutely real for me. I will never forget that time.
The 3SD is a communication device, and when tuned correctly can connect one with any other culture out there who has telepathic ability, using the spherical field bubble system to scan the universe. Kosol had a Lyrian group contact me using their 3SD system. It was very real.
They were attempting to establish open communication with earth people, and told me to perfect this on our planet first where it could be verified as accurate, before attempting to contact other cultures out there.
It had taught me that telepathy was not a hit or miss thing, if we set up the frequency of the brain correctly it was very stable and repeatable.
Full 360 degree images with depth, could be transmitted and received with total accuracy. You can see all the way around you, and see everything even behind objects. What is more you can feel them. The 3SD is the very geometry of our conscious field in the physical.
Took me a long time to ever reveal this to anyone.
Diagram attached
DaveL
What came next
After the Alien world had done this with me, it took time to realize all these things and make these connections. Machine assisted telepathy!
I was seeing out from inside their lab space and seeing all in the room. I drew pictures of them!
I then began design of the RM-1 unit, and using Wilbert Smiths scalar coil system instead of twirling spheres with magnets on them to set up the vibrating fields, as it was not really the EM field we were operating on but the Tempic field of pure vibration. This is what the brain uses as a sensory exchange system. The geometry of the conscious field inside the physical realm.
The Fgen into a scalar bismuth coil, could produce a similar effect on a calcite crystal sphere.
Using this tool I learned to slide by conscious field to other locations on the earth and observe others experiments in progress.
http://www.resonantfractals.org/Doc/Magnetism/Specs.htm
Photo attached
partzman
Dave,
All this is very interesting however, you had made a comment on a post a week or so ago that I can't seem to find now, but you said something like " this energy comes from the dark side", etc.  This is somewhat bothersome to me so I'm wondering if you would you elaborate more on this please?
DaveL
Changes in my reality
EM is not the bottom line on energy or information.
There is a vibration technology that is at the root of all the advanced races.
They worked with Wilbert Smith as well to hand us all we needed to know.
They worked with me, and through Kosol to hand us all we needed to start this exploration into the Field Fabric of the universe.
The CU field [consciousness unit] is the expression of consciousness inside the universe of matter and energy.
All these basics, that are the foundation of the technology, that allows us to advance beyond the material sciences, and into the experienced sciences.
The discovery that we have a 4th density world setting right on top of us! A 5th density world on top of that!
The saucers can transient between these realms, and the physics is different in each one.
This is where they go when they vanish.
One can now understand why they come in and shut down the nukes, the 4th density world is right there on top of this one, and light does not pass between these levels, but a nuke changes all that. I was able to punch a hole into 4th density and observe little grey heads peering down at me using only some monster coils of 44.5 foot length wound in CCW format. What can we imagine a nuke can do?
For me now, my reality is totally different then in my youth and in my formal education.
I do not have any faith, I know, and that is a big difference in the exploration of science.
I have discovered, if we can witness and thing, we can eventually cipher how it works, and there are no limits on our ability to do this.
We have enough awareness, and power to reason, to work through anything we realize is real. We also now have the correct hardware inside our bodies to work with the vibration field bubbles directly and even begin to engineer them. That is the most exciting part really, the new technologies we can begin to cipher accurately.
I have since been able to channel the Grey protocols of nature, and realize the universal directive to create life in all possible forms in this universe, and to respect life as we find it. It is all conscious, from the level of atoms, to the levels of 5th density light beings. The very fabric of the universe is aware, and will hand you the answers for the asking once you connect with IT. This connection however is through accurately created vibration field bubbles of spherical and multilayered design.
Our psi people were right about the vibration thing, but they never learned to quantify it, and that is what I have added to this work, on top of what Wilbert Smith handed us, a coil that can be used to generate vibration field bubbles.
With accurate telepathy, we can expose every lie being told us, imagine how that changes a world.
That about sums it up I think.
The conspiracy people do not like me, because most of what they dream up is not accurate, but self created.
The channelers do not like me because I brought science into their holy realm, where they are absolute authorities unto themselves.
The religions probably see me as demonized, and the scientists detest a field force they cannot control or understand!
I stand in direct opposition, in a state of truth, being seen as wrong, misguided, or blind, by most all the other organized belief systems.
And yet this will bring them all together into one truth, the same truth, and only the universal laws must eventually be agreed on by all beings present inside the one universe. The universe is the ultimate authority, and its laws must be realized to create a self sustaining civilization.
