2026-08-15, 03:07:25
Pages: 1 2 [3] 4 5 6 7 8 9 10 11
Author Topic: HHO Tubular Browns Gas Build  (Read 32707 times)
We have members globally ( open source community)
I must scratch my head about Arizona? I know we have some good people close to that area!
We may be able to host a meeting with Fast Freddy ( cover travel expenses to member close to his area!
I think SmOkey-2 might be fairly close ?
Will pass greetings message along when I speak with Stefan, he has been busy sorting his forum ( similar issues here/sorting ) plus also putting builder boards with moderator privileges!
These fellows ( our forum hosts here and OU.com) are one man bands with many other things going on in their lives
Thanks for your contributions…
A very nice thing indeed!!
Pascalite Clay:
https://www.pascalite.net/
Amazing Natural Remedies in Worland, Wyoming
Don't overpay for the help you need.  With the incredible power of healing clay from Pascalite, Inc., in Worland, Wyoming, you have the ability to get the relief you need at a reasonable price.
The strong power of the Pascalite clay is known to be a wonderful, natural wound care. A great natural remedy, Pascalite is amazingly effective on spider bites, infections, burns, rashes, and even facial acne.
"Our Story"
Find one of the best natural remedies for burns, bites, infections, minor wounds, and skin issues. At Pascalite, Inc., in Worland, Wyoming, we are the source of pure Pascalite clay. We use solar drying and never heat process our clay (which would destroy the enzymes in Pascalite). We grind it into powder to produce a great natural remedy for countless ailments. We also hand make additional products with the Pascalite clay as an ingredient."
William Baumgartner at the time was making his Vacuum Vortex Water Units (centripetal -inward movement,) ala Victor Schauberger water in which he added a little Pascalite clay to the water to "Energized" distilled water into healing water.  It was a nice little unit too!
That clay keeps me healthy, along with Vit. C ascorbic acid taken daily!
« Last Edit: 2022-01-26, 06:56:58 by vrand »
Chet,
First off - Thank you for hosting this great Forum!
Free speach and sharing of "Free Energy Devices" what a great place! :)
That is a great idea to visit Freddy, he was available to work on any HHO Project a couple of years ago, like he was doing these past 10 years!
Maybe we can get funding for Mr Wells to make another genset? Or fuel another car?
He likes to work in the HHO field.
He's even done Turbine fueled HHO testing.
Mr Wells is "Way Out There" at the Cutting Edge of HHO Research, having fueled cars, trucks, big rig freight trucks, 50kWp, 20kWp generator sets, 1.5MWp v16 Cat. generator power plant and other internal combustion engines.
There's some pretty impressive information in this thread.  I was wondering, as an aside, if any of those electrode surfaces are coated with tin oxide?  For the anti corrosion semiconductor band gap effect.
Hi,
The tube plates are sanded inside and outside with 40 grit or 80 grit sandpaper to make lots of "pointy" surfaces on the stainless steel so the HHO gas easily pops off.
At over 50Amps DC input my nickel plating peeled off the tube surfaces and mixed with the electrolyte. So had to sand off all the nickel plating that was done, which took 4 weeks of plating effort. Ugh...
Also added a 10"x 2.5" home water filter to catch any 5 micro or larger particles in the electrolyte.
Still testing, but so far this Tubular Browns Gas Neutral Plate 304L or 316L SS tubes are working marvelously with no special treatment or coating needed, just sanded surfaces!
Got some good info on nickel plating from
The DIY Science Guy Stefan
Nickel plating would work for Low Amps HHO Units, say under 30Amps.
https://www.youtube.com/watch?v=GOppb7jRGCc
It was fun plating, but after testing in high amperage ranges 50A to 175A, the nickel plating came off into the electrolyte.
Really anything on the tube surfaces, at over 50A, will come off the surface, and leave the stainless steel clean again for the next HHO gas to come off.
Re forum host
That is Peter (member peterae )
I am just a servant to open source FE community (all venues/forums)
and the community is actually quite amazing, with very deep global talent and resources!
Will send you a note on figuring out how to move forward with Freddy (making a plan ?)
Building End Caps
- 3d form to be filled with a mixture of epoxy and anchor cement
- place inside form a small 0.50" stainless tube section for the nipple and hose bib to sit on.
3d Drawing File over at "thingiverse"
Neg End Cap cast + Coat v6b
https://www.thingiverse.com/thing:5210984
Pos End Cap cast + coat v6a
https://www.thingiverse.com/thing:5211005
Hi vrand,
I get a 404 error trying to download these files.
Cadman
Hi vrand,
Cadman
Hi,
I just hit the url link and it goes to webpage where you can then download it. see attached webpage photo top right corner to Download.
Ultimaker Cura ver. 4.11.0 worked fine for me to open the STL file.
Update: 404 Error at Thingverse
see attached 3D STL files
here, no need to go over there.
« Last Edit: 2022-01-29, 20:11:27 by vrand »
Test Results Unit 1 + Unit 2, V624:
Amperage test Trying 2 Different Electrical Configurations for 2 of 3 Units.
Parallel vs Series Electrical connection
Each V624 Unit has 5 cells and 4 Neutral Plates.
Summary:
Parallel Electrical connection is more energy efficient than Series Connection; up to 33% higher efficiency (17-33% range).
(Less Cell Voltage = Less Heat = More Effiecient Faraday Electrolysis Process)
So for 100A input to 2 Units in Parallel the Amps per square inch goes down 50% to,
0.125A per sq.in. from 0.250A per sq.in.
Neg    Pos
 805     693    Cell Areas In. 1+2
 402     346    Cell Areas In. per Unit
 100    100        Amps input
0.125     0.144    Amps/sq.in. 1+2 Units
 0.250     0.289    Amps/sq.in. per Unit
Amperage Testing Results:
Cell 1+2 Parallel Electrical Connection
 C-Volts     V-In    A-In   Eff %
3.398     16.99    100   17%
 2.470     12.35    75    33%
 2.348     11.74    50    22%
 2.038     10.19    25    25%
 1.822     09.11    10    27%
Cell 1+2 Series Electrical Connection
 C-Volts     V-In    A-In
 4.083     40.83     100.00
 3.700     37.00     75.00
 3.001     30.01     50.00
 2.711     27.11     25.00
 2.300     23.00     10.00
Test Results Unit 1 + Unit 2, V624 :
Observations
We will call this 24 in. Unit, V624, meaning Version with 6 tube/plates and 24 in. long.
The stainless steel tubes in this design are 0.065" thick, or 1/16" thick.
For larger units, such as 8 foot tall units, the thicker the tubes, 0.130" or thicker, the more amps can flow thru it at less resistance which equal less heat loss.
Maybe that is what Freddy was using in his two 8 foot tall units, Freddy designated V96M, powering the Belize 1.5MWp Caterpillar V16 engine, or the one powering his 50kWp genset?
For seawater electrolyte, using solid nickel tubes would last longer than 304 or 316L stainless steel.
Also interesting is the adding of 100 to 200 Amps flowing thru water you start getting plasma and micro ball lightning, or EVO's per Ken Shoulders and a John Hutchison Effect.
Test Results V624 Units 1 + 2 + 3 Parallel Output:
 C-Volts     V-In    A-In
 2.000     10.00    10
 2.314     11.57    25
 2.620     13.10    50
 2.852     14.26    75
 3.060     15.30    100
 3.306     16.53    125
 3.504     17.52    150
 3.798     18.99    175
Gas Water Separators
See Flow Diagrams
To remind anybody doing this reseach that injury or death is possible in experimenting with HHO gas and this is for educational purposes only  and harm reduction!
7.5 or 15 gal Kegs
- Sanke 7.5 + 15 gal. kegs are a natural for HHO gas water separation process
- It has a built-in check valve and long neck tube that goes to the bottom of the tank.
- Pressure rated +50 psi vessal
- Stainless steel
- Low cost and available in aftermarket
How to open and reassemble a Sanke keg
See video
https://www.youtube.com/watch?v=1ZPfZ_AL380
RE-PURPOSE THAT BEER KEG, MAKE A KETTLE FOR YOUR STILL
See video
https://www.youtube.com/watch?v=ozXNfqcsMt4
« Last Edit: 2022-01-28, 04:03:07 by vrand »
50 kWp Genset - Gas Separators Cont.
- Whole House Water Filters similar to kegs w/o the ball check valve.
- Custom Build ASME Pressure Vessels (Freddy used a 35 gal vessel on the 50kWp genset)
« Last Edit: 2022-01-28, 05:00:34 by vrand »
Belize 1.5MWp Gas Separators and HHO Storage Vessels 6 - 250gal Barrels
Note the Whole House Water Filter on the side of the stainless steel barrel.
Belize running
see video
https://www.youtube.com/watch?v=uE_b6xGqyYY
« Last Edit: 2022-01-28, 04:42:22 by vrand »
Creating both Electricity and Heating in any electric generator set.
Now Mr. Wells, in his units had both the simple water exchanger (see Amazon link)  to the more elaborate Hitachi large industrial "Heat Exchanger" found on the 50 KWp generator build from 2017-2018.  see photos
350,000 BTU/hr: 30-Plate Heat Exchanger,
https://www.amazon.com/350-000-BTU-30-Plate-Exchanger/dp/B00496OK2A/ref=pd_lpo_5?pd_rd_i=B00496OK2A&psc=1
Heat Exchanger, Cont.
When adding +50 Amps and above to the V624 fuel cell there is a lot of HHO Gas and Heat being generated, that are difficult to get out of the cell fast enough.
So there is Pulsing and bursts of HHO gas output vs. the continuous stream of HHO and water electrolyte flowing out of the cell at amperages below 50Amps.
High Amps = High Heat = Arc Welding Currents = Plasma and Plasmoids
Arc Welders know higher current melts metal and fuses then together in a weld pool bead along the joints.
So that is where the heat exchanger comes in, to keep the High HHO gas output at high amperage going longer without boiling the water and making Steam as the heat builds.
At low amperage and output there is no noticable heat problems in the current HHO marketplace.
With this Tubular HHO Neutral plates design you will need a heat exchanger to keep the high HHO gas output going when needed.
Now that is where Freddy discovered on his 50kWp genset that you don't need +50A all the time, just in the beginning at startup to build up to the 40 PSI engine running operation pressure.  After it reaches the desired pressure then the amperage goes way down to 13.4A. and 27.32V DC (see photos below).
So the heat exchanger is needed most at startup then after reaching the set tank pressure for running the genset you are coasting along
Calc.
at 13.4A X 27.32V = 366W Fuel Cell Input for a 50kW output.
COP of over 50
That is the beauty of this Tubular Browns Gas HHO unit it is more highly efficient than the Flat Plat HHO units in the marketplace.
« Last Edit: 2022-01-28, 19:43:55 by vrand »
50kWp Genset - COP Calc.
Input Energy to power the 50kWp V96M HHO Unit estimate:
1- The Fuel Cell watts is 366W (at running operation 40psi), but it takes twice as much to generate that so equals 732W for the Power supply input.
2- Water Recirculating Pump watts is around 240W
3- Hitachi Heat Exchanger calc. 240VAC at 10A = 2,400W
Total Watts Input
 3,372W
If using the engine water cooling system you don't need the Hitachi heat exchanger so the input power is
3372 - 2400 = 972W input
The 50kWp genset output is 50,000W
COP of around 50
« Last Edit: 2022-01-29, 05:19:26 by vrand »
Total Watts Input
 3,372W
COP of around 50
Remarkable!
is there a video or written summary somewhere?  An introduction?
Theory of Tubular HHO OverUnity Operation
HHO at 40-64 psi + High Amperage at start = creates an energy conduit from Counterspace, Zero-Point Energy, Neutrons, EVO's, Plasmoids etc.
To be Continued
« Last Edit: 2022-01-29, 03:24:35 by vrand »
Remarkable!
Hi,
Check out Freddy's website:
Quantum Fuels
https://wellssportstore.com/quantum-fuels
and at the bottom his
Video Gallery
Has some of his most recent videos over the past 12 years.
He came on the scene in Aug. 2010 with his famous Ford truck running on his early HHO cell design.
The video of the screenshots of the instruments (Volts, Amps, PSI) was from his video titled
Last 50 KW video, tuned and polished, ready for prime time
https://www.youtube.com/watch?v=FzBe-Kip9_s
« Last Edit: 2022-01-29, 09:12:36 by vrand »
Hi,
Quantum Fuels
Video Gallery
"Forest for the Trees"
Tubular HHO, Browns Gas, Neutral Plate Tubes
I have been doing this since 2001 and assumed everybody knew this info.  ugh.
It was when I was explaining to an ebay seller from
Dunaszentgyörgy, Hungary
Population 2,585 (Jan 1, 2008)
powersolutions_hu ( 753 )
600A 40V 12V 24V current limited DC motor speed controller PWM RS232 arduino
https://www.ebay.com/itm/184460412779?var=692238514661
about needing a high amperage HHO power supply and he never heard of the HHO neutral tubes design and it needing 100's of amps.
I said if this guy who specializies in PS for HHO never heard of this, then there must be ALOT of others that also never heard of this.
So, that is why I am here at Over Unity Reseach "to get the word out" so to speak, so this info can be replicated by ANYONE and not just Freddy!
Freddy had a 10 year run of the market all by himself, so now its time for others to join in on the fun and beauty of this breakthrough energy device!
Inventor of the Neutral Plates in HHO Units was from a Bulgarian Inventor named:
Yul BROWN
The Bulgarian Inventor That Made Fire from Water
by Daniel Montiglio
https://www.foreigner.bg/the-bulgarian-inventor-that-made-fire-from-water/
Brown's Gas
Neutralization of Radioactivity
Rex Research
http://www.rexresearch.com/brown-haley/brown-haley.htm
Clean Energy Review
...We now proceed to the experimental results obtained by advanced transmutation which have direct bearing on the problem of disposal of nuclear waste fuel.
Interaction with ionic hydrogen and ionic oxygen
Brown's Gas has been developed by a Bulgarian-born Australian national, Prof. Yull Brown. In his process, water is separated into its two constituents, hydrogen and oxygen in a way that allows them to be mixed under pressure and burn simultaneously and safely in a 2:1 proportion.
The proprietary process results in a gas containing ionic hydrogen and oxygen in proper mixes which is generated economically and safely and which may be compressed up to 100 psi.
Brown's Gas is a "cornerstone of a technological edifice" with many commercial and industrial applications.
At this time, Brown's Gas generators are mass produced in the Bautou, a major research city in the People's Republic of China by the huge NORINCO factory which also manufacturers locomotives and ordinances -- and services the nation's nuclear industry complex.  Most of these generators (producing up to 4,000 litres/hour/2.4 water at 0.45 MPa with power requirements ranging from 0.66 kW up to 13.2 kW) are marketed for their superior welding and brazing qualities, costing between $ 2,000 and $ 17,000. Some units have been used for the decontamination of radioactive materials since 1991.  In general, Brown's Gas generators produce between 300 and 340 litres of Brown's Gas per 1 kW energy DC current approximately and one litre of water produces 1.866.6 approximately litres of gas. A generator which produces 10,000 litres per hour has been built specifically for the reduction of nuclear waste.
On August 24, 1991, Baotou's Nuclear Institute # 202 released a report, The results of experiments to dispose of radiation materials by Brown's Gas which establishes that experimentation on Cobalt 60 radiation source decreased radiation by about 50% or half-life of radiation --
but sometimes more radiation is decreased which needs investigation of possibilities for decreasing more of the radiation in single treatments of exposure to Brown's Gas flame, lasting only a few minutes, in the samples as described in the table below.
                                First Experiment                 Second Experiment
Source Intensity   580 millirads/hour                   115 - 120 millirads/hour
After Treatment    220 - 240 millirads/hour         42 millirads/hour
De-radioactivation of Cobalt 60 by exposure to Brown's Gas flame for less than 10 minutes.
1991 experiments conducted by Baotou Nuclear Institute # 220, People's Republic of China.
« Last Edit: 2022-01-29, 07:45:41 by vrand »
HHO Neutralization of Radioactivity - Recent 2021 Activity
Bob Greenyer
Has done some investigation into Brown's Gas and HHO and last year was to make a presentation the Japanese authorities in-charge of cleaning up the fallout of Fukushima.
And Propose using HHO Gas as an easily and affortable way of cleaning up the radioactivity, as Yul Brown did several decades earlier.
Fixing Fukushima - First test of HHO on CaCO3
https://www.youtube.com/watch?v=nIuZIqpBJWg
Aug 22, 2021
Martin Fleischmann Memorial Project
4.11K subscribers
Despite the spot pyrometer maxing out at 500ºC, it would appear that the CaCO3 had exceeded 825ºC by the end of the experiment , since it appeared to have decomposed into CaO.
The question remains though is that, since there was clear limelight - is this an indication of far higher temperatures?
Hello.
what is the plasma reaktor? How can i build it?
Lota
Hello.
Lota
Hi,
Freddy is calling his "plasma reactor" what we are calling the "gas water separator."
see above posts on Gas Water Separator
see video starting at 8:10 min.
900HP Camaro Build
https://www.youtube.com/watch?v=B_f74KApJRQ
Tubular HHO, Brown's Gas, Neutral plate/Tubes Discovery
Research and Development takes time.
The goal was to figure it out, and 2.5 years later I did.
Got most of the parts over the years, such as the 6 SS tubes, with 4 neutral plate/tubes,
only needing now to design the End Caps for the stainless tubes.
3D +PLA prints, epoxy, and cement casted End Caps to suport the Neutral plate Tubes and be an electric insulator to isolate the tubes from each other, ala Brown's Gas 1960's patent idea of Neutral flat plates.
« Last Edit: 2022-01-30, 03:56:58 by vrand »
End Caps Design
The current model V624 Fuel Cell has epoxy sealed end caps made from a 3D printed shell to then fill with epoxy and cement.
Someone could also make them out of teflon turned on a lathe and also design an O-ring sealed system.
I tried the o-ring without success, it leaked for both 1/16 and 1/8" diameter o-rings, so I went with epoxy sealant.  Epoxy stopped the leaks.
Epoxy is inert to water and electrolytes KOH or NaOH and anchor cement is strong enough mechanically to hold the tubes in-place and the combination has a high temperature resistance than just epoxy alone.
The 3D printed End Cap forms are accurate to 0.001" so the cell spacing of 0.065" was not an issue.
Freddy's V96M 8 foot tall unit looked to be 6" tube outside diameter. So anyone making one of those units would need a 3D printer bed that can print +6" end caps.
Attached are the STL 3D End Cap files format (404 error at thingverse)
Links when working
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 03:07:25
