2026-08-15, 04:53:04
Pages: 1 2 3 4 [5] 6
Author Topic: The Aether and science  (Read 43979 times)
Nick thank you for your prompt reply i appreciate that, however what you are telling me isn't what i'm asking and doesn't help
I have built a few test devices such as sections one very much like yours and one like the Alexee Sergey some similar with digital katcher drive but different frequency to yours.
Re Delamorto's, I haven't built any sections of his circuits, but never the less he is a respected guy in this field.
Any way if you don't reply I wont bother as it off on a different track and I need the space
for other useful things like Solar panels and the like.
« Last Edit: 2022-08-25, 13:01:42 by AlienGrey »
I have built a few test devices one very much like yours and one like the Alexee Sergey similar gain with digital katcher drive a device and like you say different frequency to yours, respectfully what i'm asking is this, your telling me your push pull is generating an 18khz window with a Katcher modulation of 1mhz, set in that window that's great, but is the rise time of both signals at the same time as the 18khz window opens to allow the 1mhz wave in ? RESONANCE !
I suspect its similar to the build i have problems with on a scope, 'it doesn't lock'.
Re Delamortos, I haven't built any of his circuits, but never the less he is a respected guy in this field.
Any way if you don't reply I wont bother as it off on a different track (till it works).
    AG: Not sure how I should answer you. But, my kacher is constantly running at 1MHz, how can it fit inside the window of 18KHz that you mention?
Just remember that they don't run at the SAME frequency. And never have.
   This scope shot below was taken from one of Stalkers video, although it may not be his scope shot. But, it is showing the Kacher at running at 1.4MHz, while the push pull is running at 16.5KHz. It is one of the ways to run the device. Not the only way. Itsu tried to replicate those frequencies using his controlable Kacher circuit, but was not able to, as yet. Maybe something will change in the future to allow us to see some better results.
   We have more than just tested, and re tested, and could not replicate that scope shot. Nor obtain OU. Perhaps there is something wrong with the schematics, or something.
   I am making NO CLAIMS, and never have. If I had something self running, I would not be here, nor show it doing so.
   Sorry guys, but I don't really trust what is going on here, with some of the members, anymore. Nor care to be with those who died showing us what works,
 like Adrian Gustav.
  What does this have to do with the Aether. Everything...I believe.
« Last Edit: 2022-08-24, 21:15:30 by NickZ »
From an old thread post:
"How it works"  - RUSLAN, et. al.  FE Generator
It appears most are "lost" with respect to the approach and theory underlying these types of energy generators therefore consider the following.
It may seem foreign at first but take some time to examine this information, several times if necessary, then take a few days off before getting
"wrapped around the axal" and doing the"RTTY Running Open" routine! No Stupid Comments... PLEASE, for the sake of those who might be
interested in learning more - keep the comments to only relevent, detailed, technical discussion - amongst yourselves.
Background
From a recent post and exchange with AG {thread Moderator} -
"Your question is likely more sarcastic than inqisitive but, if not, lets consider:"
[[ AG, I'll post this one more time. If you feel the need to "scrub/moderate it again" so be it - your the moderator, however, a very detailed presentation,
including CAE analysis with files along with more reference and CAD models and other material, will appear soon on a technical web site that is more
suited to, and capable of, handling complex engineering and physics details. Target date is February - once the internet, in general, has been cleaned
and once again provides secured open access. We all know the current "state-of-affairs," FE/CE included (unfortunately for us, writ large! But this too
will soon pass) ]]
Reference Designations below relate to those found in the "Vasik041 - Documentation - " thread (or whatever it's called) and two patents that were
posted (and subsequently removed by AG as off-topic or not-the-focus of discussion or what ever). These patent links, again, are:
SPACE DISCHARGE APPARATUS
US2096460  filed 1936-01-23 issued Oct 19, 1937
Inventor F. B. LLEWELLYN Assignee BELL LABS (now AT&T)
https://patents.google.com/patent/US2096460A/en?oq=2%2c096%2c460
ULTRA HIGH FREQUENCY OSCILLATOR
US2520383A filed 1944-10-18 issued Aug 29, 1950
Inventor PALMER H. CRAIG Assignee INVEX Inc
https://patents.google.com/patent/US2520383A/en , or, copy of original filing for better view of formulas:
https://worldwide.espacenet.com/patent/search?q=pn%3DUS2520383A
NOTE: Patent US2096460 Fig 1. "cathode 4, grid 5" and Patent US2520383A Fig. 1. "2, G, P" are replaced by a "Tesla Coil" plus there a few other
modifications - [no heated cathode => vacuum tube not needed], Anode (second anode) is so called "Antenna;" however the theory of operation is valid
and describes the technology employed. Traveling Wave Tubes (TWT) further amplify the approach but carefully consider 2. below.
Discussion
1. You have a basic system, without the Kacher/Antenna component, consisting of: (a.) a push-pull transistor combination driving; (b.) a toroid transformer
[split TV yoke] with center tapped Primary winding {L1a & L1b} and three turn secondary winding {L3} that, in turn; (c.) functions as the primary for an
air core secondary {Inductor L4}; (d.) which excites or Oscillates; (e.) the Grenade coil (L5).
Assume the above combination efficiency is near 96% [resonant if need be but not neccessarily required]. Somewhat similar to a simplified switch-mode
power supply, however the COP is still less than 1 (no excess energy).
2. To add excess energy this scheme might use a pulsed (*1) High Voltage Generator (f.) Kacher {L6 & L7} preferably in axial allignment with L4/L5 but not
necessarily required (*2); and, since the Grenade is comprised of a Helical Coil (g.) it functions as a "Slow Wave" device with respect to the L5 Oscillating field
 (low/medium frequency in this case). *1 - HV => electron velocity; pulsed => phase; *2 without a focusing scheme the HV electron stream is (somewhat
randomly {?} ) distributed, but take into account the physical location of (f.) and the connected helix coiled  [so called] Antenna and also note their respective
voltage levels when analyzing electron {beam} distribution (the Anode/Cathode relation as found, for example, in an "O type" TWT). The Beam distribution
pattern will adhear to that found in Electrostatic field interaction.
3.  Keep in mind, Electrons are very light and can be easily accelerated by an electric field but can only be bent by a magnetic field {electric fields influence
electron speed, magnetic fields influence electron direction} (recall a CRT television - screen brightness <=> flyback transformer high voltage level - horizontal
and vertical raster scan <=> current driven yoke coil mounted on the CRT neck located right after the electron beam source but before the phosphor viewing screen).
4. By designing a device to have the HV Latcher emitted electron particles (called many different things) travel at or near the same speed (set by the HV
produced by a Katcher or Tesla Transformer or other high voltage generation scheme); as the field wavefront created by the Grenade coil {L4} signal nears
that of the electron particle stream (the electron beam), excess energy can be transfered from the HV particle stream to the Grenade Coil field thus increasing
the coil energy by four times the particle velocity (accelerated electron kinetic energy). This action is sometimes refered to as "Velocity Modulation."  A modest
transfer efficiency is typicall 35% but this can be near 90% with a good design and deliver amplifications exceeding 60dB (1x106 or 1 million).
5. Many, including me, believe magnetics or electrostatics are responsible for the energy transfer between the HV electrons and the signal field but if that were
the case this system would have been easily replicated many years ago. A hint to the transfer is shown by Tesla in his electron "gun" and plate demonstration
 and the theory is further supported in the patents referenced earlier.
6. High Q Resonant circuits help in increasing system efficiency but Resonance also complicates the ability to achieve overall excess added energy success.
This is clearly shown in wideband TWT Amplifier study.
7. Focusing on the electron particle velocity and signal field wavefront velocity while paying particular attention to their phases might well yield the energy
transfer mechanism. A numerical analysis appears to support this hypothesis as well as on-going Computer Aided Engineering finite element analysis.
The above postulation presents another viable way of viewing and solving the FE question. One should consider other approaches (and new methods) if
your current approach doesn't show progress after many many years! If we already knew the precise theory of operation and design techniques this system
would be in production (or at least leaked) by now.
IMHO this general Ruslan/Stalker scheme is very viable and only needs a bit of tweeking - less Q/Resonance initially with some detailed attention to electron
and field velocity and phase mechanics.
Methods and Techniques
Use Ansys AEDT and/or CST Design Suite CAE to varify/optimise operation (Solidworks CAD to draw coil, etc. parts; then import into CAE). Attempting a
hand-build is extremely difficult, as observed over the past 10 or more years, replications are near impossible. Engineering design methods and precission
CNC techniques are required; however the results are worth the effort. CAE also allows investigating many other FE methods, for example saturated Ferrite,
other non-linear devices, asymetric windings and transformers, etc.. CAE down the road can also assist in environmental analysis and optimization {Tesla in
vacuum is pretty wild, humidity in air is also pretty wild, etc.}!
TWT Theory - Derived Math links:  Dr.P.Prasanna Murali krishna
https://www.youtube.com/watch?v=Z7L-fiYNqS4
https://www.youtube.com/watch?v=zPkz-qWAr2g
https://www.youtube.com/watch?v=7K_Ok_XThyw
https://www.youtube.com/watch?v=63vnYb4sF2Q
https://www.youtube.com/watch?v=IMywVY_au20
https://www.youtube.com/watch?v=SkFRpSqomg8
TWT Information
Recent theory of traveling-wave tubes: a tutorial-review
https://silo.tips/queue/electron-devices-simulation-with-cst-studio-suite-richard-cousin-cst-cst-eumw-20?&queue_id=-1&v=1636076991&u=MzUuMTM2LjE5MC4xNDY=
Simulation of Traveling-Wave Tubes for Analysis and Optimization in Modulated Back-Off
https://d-nb.info/1217326774/34
Rant
I first proposed this theory of operation on an OU thread in, I believe, mid 2017 after reviewing the TopRuslan device. At first glance it had a striking r
esemblance to a TWT structure but at the time other duties and a lack of CAE tools delayed further in depth technical study. Shortly after many related
OU post, the OU cabal of shills, mis-information trolls and hucksters that resided on OU, and now elsewhere, I was banned for "disagreeing" with their
Golden Boys. BTW, the same banning, for the same reasons, happened at the AU forum. Moral - don't know more than the forum's fake experts and, for
sure, don't call them out or even remotely expose them (if they knew anything technical about the topic and/or not blocked those who do have some clue,
it would have all been completed more than 10 years ago).
I suspect that this banning thing will quickly migrate to this forum as well - so, if you briefly see this post, keep in mind my entire "data dump" will
appear on a credible web site very soon!
Thats all...
This is your version of how it works?
COP is less than 1...hmm....pretty sure ol' Kapanadze was getting better than that in the garden video.
Anyway, I always assumed... that Ol' Kap's coil had to be used as a scalar longitudinal wave emitter, with the outer coil as a collector.  The coil through the center is going to ground, meaning the outer coil is positive.  These waves are though to drive a current by the electric field gradient, avoid Lenz's Law, and this would be cold current.   The need for a battery to start it was indicative of this theory., assuming the pulses to the inner coil are over the battery DC.  Need that interaction for conventional current conversion.
I did build one, but could not drive the coil adequately to produce a strong enough scalar longitudinal effect, or change the frequency.  I probably could do better now, but I'm busy with another project.  You'd need to find the longitudinal resonance frequency for the coil.  The cold current will keep everything going once the battery is disconnected.  Assuming cold current is a real thing.
This is very unproven and speculative, but radically different than any other theories out there.
  Nice to hear that you tried it Grumpy. It's not as simple as it sound, yet Kapanadze was the first to show us again and again that it is possible. If not replicable at this time, it will be.
   BTW: the longest coil on the grenade is used as the output coil. It is 37.5 meters long,  There is an inductor coil above it I/2 as long 18 meters long. And, a thick short outter coil is the "antenna coil" as the top load from the Hv Hf Kacher signal.
  SL has got a pretty good idea of how it's supposed to work, but getting all to work is no picnic in the park.
Grumpy - sorry you didn't get one working, maybe soon.
NickZ got pretty close to perfecting it - (but) phasing the HV pulses is a real challenge,
even when you have an high frequency HV differential probe and synchronized bench generators
driving each part of the system.
Problem is, simpler low voltage pulsed / coil bench tests don't produce the effect.
Sorry Grum but your response to having actually built one indicates that might be a bit of a stretch;
especially if you have worked with or designed TWTs.
And, quite a few guys have demonstrated the operation, both on the bench and in the field. A good
source is Stalker - he has done some good theory as well, and Ruslan (39 or so videos).
Solarlab
As Grumpy mentioned to Nick
Here there are benches to self moderate (you would be in charge of the build presentation)
Even just move your data dumps to your bench
Also at Stefan’s forum for several years now
Same thing
You would be the moderator there too
You could post info here or there and it would be there in perpetuity
Never removed!
Only time things get removed is when terms of service agreements are violated
And owners are subject to defamation claims do to
“Other” statements by presenter or
Did not honor wishes of person who’s moderated board they post in !( I believe this happened to F6 at Wesley’s board at Stefan’s)
Example AG is not moderator of this board,however it seems you must have posted something at his moderated
Topic here ( where “He” moderates) and he moved it or removed it ?
Same happened at Wesley topic at Stefan’s forum (Wesley’s moderated board)
As I have begged you many times to get a bench here or moderated board at Stefan’s
And “NOTHING “ will ever be removed “NOTHING “ ( if it’s not against Terms of service agreement)
BTW
If you are truly here to help persons with kapanadze devices ( to get them working ??)
There are many here and elsewhere with non working units on the shelf !
Start a topic on your self moderated  bench !
PLEASE TEACH!!
  SL:
   I agree, seams like you have taken the time to study and analyse most of this, unlike some other members only taking wind guesses but no hands on verification to prove the point. Which is exactly what we need now, after all this time.
  And if it's not the Aether that is adding extra energy, and allows a self runner operate with NO input, I don't know what is.
When I built my version, only Kapanadze had one.  This was around 2010 or maybe even earlier.  No one else had built anything.  There were no replications.  Kapa didn't even have a youtube channel then.
https://www.youtube.com/channel/UCfHCwbUxzbiu7ncxPXkBYEg
Demonstrating some bulbs lighting means nothing.  Uncle Fester could light a bulb in his mouth (on TV=LOL!).
Show me the meter readings.
Show me the system self-running when the battery is removed, like Kapanadze did.  (Granted, he might have faked it somehow...wires everywhere...)
https://www.youtube.com/watch?v=HjQgpTiN4vw
Maybe he faked all of it.  Who knows?
 With people all around looking to see if it's faked, I don't think so.
There is also the video where Stefan and Tiger went to see Akula at his house
to see Akula's device run first hand. And no fake was detected. Also Ruslans field day,
Showing his 5000 watt output, from thin air. No power sources in sight.
The concept of RESEARCH as in "Over Unity Research", or any other, is to study solutions to problems.
The concept of "How To" is to Write a book or make a youtube with instructions on how to do or build something.
The concept of "Teach" is to structure a series of lesson plans designed to teach something, then "test" those you
have taught, and issue Sheep Skins.
The concept of open "Forums" is to 'scrap over stuff' and, from that, learn strengths and weaknesses,
recognizing them and make adjustments, as required. Also allows studying those involved, all be it unfortunately, from afar.
The ego's and myoptic-ness - in some cases - I find quite interesting, if not humourous, and [almost] educational.
I "Research", I "Write", I "Teach" and I also "Forum" and I find them all quite enjoyable!
Non are necessary but they are all fun!
Relax - we'll all get there; and sooner than you think...
Yes - this is my version of how it works!
Since you claim "this is very unproven and speculative, but radically different than any other theories out there" please elaborate,
in detail, what these other theories are.
Of particular interest are the theories presented by those who have already demonstrated working models. For example:
- Ruslan's theory?
- Kapanzdze's theory?
- Stalker's theory?
- and any others, such as Your theory?
Thanks in advance, every bit of knowledge is always appreciated.
What ever happened to Akula?
I remember people visiting Kapanadze too.
- Ruslan's theory?
- Stalker's theory?
If there is valid proof that those devices are OU, please point me to the information.
My theory is speculative as it is not proven.  I think it could work though.  Not hard to prove/disprove either.
I think someone told Kapanadze how to do it, same for Steven Mark, they just implemented the info, trying to get rich.
I don't pay attention to theories calling for transverse wave resonance, eyes of newts, or pixie dust.  Not when OU is concerned, as there is no OU there.
Also, if the inventor can not explain the workings in precise terms, then they do not know how it works and are speculating.
Kapanadze referenced Tesla's work as the source for his work.  Do you think he was wrong?
I saw some post on OU that your were involved in, and AlienGrey, that indicated Stalker had posted deliberate lies.  So, is his theory (whatever it is) valid?
If there are so many working devices, where's yours?  Set up a Bench here and we'll "will the damn thing to work" (old saying by poster "Moby")
Side note: got my avalanche transistor trigger circuit for 4500v MOSFETs working pretty good.  Kansas is in my sights!
  Yeah, Not only Akula, all others have vanished into "thin air", as well.
Adrian Gustav was possibly killed after showing a very similar device to mine, self running in the field.
So, there may be something to all this confusion and mistrust and fear. But, I highly doubt what AG invented about Stalker lying.
As AG has a good heart, but, has a habit being out in right field.
   Stalker on the other hand has been more than helpful with these projects. Although, he will not show any OU, nor self running devices actually self running any more. Nor will any one else, that would like to stay alive.
- Ruslan's theory?
- Stalker's theory?
Grumpy,
This is your (detailed) theory/version of how it works?  Ok, that wasn't really that informative or helpful, but thanks anyway!
Have a good one...
SL
« Last Edit: 2022-08-25, 08:12:11 by solarlab »
   Smudge:
   Thanks for your comments. If the relativity theory is what interests you, and others, you should cover that on a relativity theory, thread.
   This thread on this overunity forum is about the Aether, and how is relates to science, not relativity theory, but, Aether theory, instead.
This thread is indeed about ether and science.
But we don't see Nickz talking about it, except with ridiculous words like asking others to shake the ether or worse, to leave because they would question the ether while talking about relativity!
The subject is precisely to try to see if ether is science, and how. Relativity is a proven knowledge in terms of experimental results, and therefore observational predictions from the ether must be compatible with it.
And what do we see happening? What we see all the time: the deviation of the topic to the same old FE stories spread everywhere, about Kapanadze, Russlan, Akula & Co, from which nothing concrete has ever come out, whose facts are not even proven, whose credible experimenters here have never been able to reach a consensus on a particular anomalous effect, and without rational arguments or formalism about their connection to the ether and to science, which is the topic.
Some participants are in their religious war against science, a consequence of ignorance. When will they understand the subjects, stop spoiling them, come out of their obscurantism by tolerating the scientific method, and respect the others? I wonder.
O0
In his illusions... This is where we have the largest stock of machines that solve all the problems of the planet.
Illusions are a drug, a soft drug but a drug. As long as we have not understood that what interests humanity is not illusions but the realisation of its dreams, we have not understood everything about science.
Quote from: F6FLT on Today at 09:12:05
   Guys:
   Is this the guy that you want to allow to ruin this thread???  IF he is going to repeat the same BS day after day. I will leave you to him.
   Chet:  Can you do something about this, or do I need to talk to Peter?
Here we go !  >:-) >:-) >:-) >:-)
« Last Edit: 2022-08-25, 17:10:34 by AlienGrey »
   Guys:
   Is this the guy that you want to allow to ruin this thread, like what happened to the other thread we HAD???
   Chet:  Can you do something about this guy, or do I need to talk to Peter?
   This below is what Tesla said about the Aether, or Cosmic energy.  Should we disbelieve our greatest inventor? And, instead believe a guy that has been kicked out of and banded from several other forum sites, that he disrupted. If this issue can't be resolved, I have plan B.
   Everything that I have mentioned has to do with the Aether. And was also first mentioned by our greatest SCIENTIST:
   Tesla:
   https://youtu.be/QIZWrJkv6PE
   https://youtu.be/ySvRkQ31eOk
« Last Edit: 2022-08-25, 18:21:19 by NickZ »
Related Ruslan and other FE/CE Video Archives
Ruslan videos from the archive (getting old now but some other related videos as well):
http://matri-x.ru/video.shtml#16
DragonsLord76 youtube channel from his MATRI-X.RU website has many interesting and
informative videos on the subject:
https://www.youtube.com/user/DragonsLord76
{The Matrix forum is also well worth a look - might need to use Chrome browser - site is in Russian}.
Enjoy!
Fellows
Please explain why our host should be interrupted from his very busy work schedule?
He works away from home with no access!
 He supplies moderated benches here
Start a topic in your bench
Or move the topic to a bench
Moderate it yourselves !!
One thing is certain…unless a true anomaly is found
Or a testable theory towards that result?
This will go on for another decade with rinse and repeat in perpetuity!
I beg member Solarlab to bring some order to this ( start a bench ?
“Crickets”
Move the discussion to your bench
Hopefully experiments will accompany the move ?
Here it is best to have proof of a claim ..and video proof is no proof at all !
(Unless the video shows a method towards a verifiable result !
Show An anomaly?
This house is filled with builders ( and the other open source FE forum)
And all the boxes filled with past experiments !
Start a bench !!
And stay within terms of service agreements!
Give NickZ, Solarlab, and AlienGrey all their own benches.
Delete them later if they are never used.
I believe AG has a bench ?
Yes a good idea …
Will reach out for Peter on his day off …
(If he even has one this week ?)
He has been working many many hours lately!
   Here is some more information about what is Aether, and what Tesla said and did about it. His views, not Nicks, pertaining to what this thread is about.
   https://youtu.be/Rg-ugsB5Nao
   This one is for you AG, as you asked for it. "What is Aether"?
   We don't all need new threads, or "benches" we need to get rid of insults, and disrespect and control what is happening to our members, instead.
Everyone has a right to their opinions, but, when you call someone names and insults and try to ridicule them on a daily bases. I believe that to be against "company policy".
   Therefore, I think that it's really F6 that needs to move to his own "bench", where he can talk about his own opinions and ideas, without having to keep spreading his negative opinions about everything mentioned on this thread. Makes me wonder, why. While never showing proof of anything, at all, ever.
    However, We do need a new Akula/Ruslan/Stalker thread, which I may have to start, out of desperation, to constant and deliberate personal attacks from this guy. Now I see what AG had to go through, to be forced to having to delete and end, one of the most important threads, here.
So, being a thread moderator, is not always a good idea, when still having to put up with the same constant insults and attacks, and then having the job to "moderate" disrespectful people, is a pain in the...  And I can see why Peter would not want that job, either. But, something may be necessary, in order to control disruption.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 04:53:04
