2026-08-15, 06:20:24
Author Topic: Accurate measurement of pulse fall time with low side MOSFET?  (Read 3362 times)
I have a typical circuit with a load switched by a low side MOSFET, driven by a gate driver.
How can I measure the pulse fall time with an oscilloscope that has a 1x-10x passive probe?
When the MOSFET turns off, the probe takes a very long time to discharge, so I can't see the real pulse fall time.
Or is something else slowing down the fall time?
(I'm very new to MOSFETs and low side switching...as you can tell.)
EDIT:
Can I connect the output through a capacitor and run the other side to ground through a 50 ohms resistor and scope across the resistor (with scope inverted)?
Using a capacitor and resistor like I mentioned above works, but the voltage level is greatly reduced.
So, I doubt what I see is accurate at all, but it does resemble the gate pulse for the most part.
EDIT:
Figuring the probe and capacitor are making a divider, I'll try a resistor from probe to ground.
We can put a simple fast transistor in emitter follower with a low emitter load resistance (for example 50 ohm), as a buffer in output of the MOSFET.
It will have a high impedance for the MOSFET so it will not disturb its operation, and a low impedance for the scope so it will not be disturbed by it, and will isolate one from the other.
In all cases, the scope must of course have a maximum working frequency compatible with the MOSFET fall time (F > 1/toff). The probe in 1x will be the best option.
« Last Edit: 2022-09-02, 11:39:33 by F6FLT »
Depending on voltage level, you might get results by putting a small piece of tape over the target wire and clipping over that, letting the probe couple dielectrically.  You'd likely lose the DC component though :(
Lazy me would also try putting a series resistance between probe and device-under-test just to see if it helped.
How do I connect the transistor to the MOSFET output? A cap and resistive divider to the base?
I should mention that this MOSFET is going to operate from with a Vs of 50v to 4kv, DC.
With such high voltage you can try using 1 : 100 probe
Probe has known (quite small) capacitance, you can take it into account in you measurements if it has significant influence.
The problem is no longer the same if the voltage must exceed the KV. There I have no real solution. To measure the voltage accurately, a very expensive high voltage probe is needed..
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 06:20:24
