Aaron Salter
Started by giantkiller, 2022.09.29, 21:15:01
giantkiller
sergh
In this video, Aaron Salter at 1:13 said: "...my system uses sludge from electrolysis..."
https://www.youtube.com/watch?v=SAFQdYYXyls
17:36
"...You found a way... to use this sludge...
- Yes,... this is the holy grail of electrolysis."
https://www.youtube.com/watch?v=3M0W7P7-AdQ
https://www.youtube.com/watch?v=m388OgdmlOE
https://patents.google.com/patent/US9863309B2/en?oq=US9863309
From Patent US9863309:
QuoteThe engine system traps sludge generated during hydrolysis in a filter. The sludge is released from the filter by agitation, resulting in a gas containing the sludge which is then used during combustion to improve fuel efficiency.
What Aaron Salter suggested about combustible gas from the sludge in the cell matches some known, though less frequently discussed, phenomena in electrolysis systems:
What can happen:
Sludge buildup in electrolyzers:
Electrolysis of water, especially with salt or other electrolytes, often results in mineral deposits or "sludge" inside the cell - various metal oxides, scale, or chemical residues.
Gas trapped in sludge:
Some porous sludges can trap hydrogen bubbles or slowly release small amounts of hydrogen, especially under partial vacuum conditions such as those created by a pump or engine inlet.
Residual hydrogen storage:
If enough hydrogen is trapped or slowly released from this sludge, it can provide a short-term supply of combustible gas after power to the electrolyzer is turned off, potentially powering a short-distance engine.
"Free" hydrogen from sludge reactions:
Some claims suggest that chemical reactions in sludge can release hydrogen even without direct electrolysis, but this is less scientifically documented and requires caution.
Aaron Salter Jr.'s observation is a clear, real-world insight into how onboard electrolyzers can behave in unexpected ways. It highlights that hydrogen generation systems can have "hidden" gas reserves, perhaps explaining why his vehicle was able to travel several miles even after the power was turned off.
Aaron Salter Jr. lived in Buffalo, New York, so let's look at the typical characteristics of the water he might use in his electrolyzer, especially factors that might affect sludge formation and behavior.
Buffalo's drinking water source is primarily Lake Erie and local groundwater, with the water treated by the Buffalo Water Authority. Water quality reports provide an indication of common minerals and impurities:
Major ions/minerals (typical ranges in mg/L):
Calcium (Ca²⁺): 20–40
Magnesium (Mg²⁺): 5–10
Sodium (Na⁺): 10–30
Potassium (K⁺): <5
Bicarbonate (HCO₃⁻): 100–150
Chloride (Cl⁻): 10–30
Sulfate (SO₄²⁻): 10–30
Nitrate (NO₃⁻): <10 (varies with season and location)
Total dissolved solids (TDS): ~100–250 mg/L (relatively soft to moderately hard water)
Metals and impurities:
Iron (Fe): generally low, but some local sources may increase it
Manganese (Mn): trace levels
Silicon (SiO₂): usually present in small amounts
Possibly residual chlorine from disinfection treatment.
Effects of sludge formation in the cell
Calcium and magnesium carbonates:
These can precipitate as scale or sludge, especially under alkaline electrolysis conditions, forming deposits of CaCO₃ and Mg(OH)₂.
Chloride and sulfate ions:
Can contribute to the formation of corrosion products or complex sludge chemistry, potentially creating metal chlorides and sulfates in the deposits.
Trace metals (Fe, Mn):
Even small amounts can accumulate on the electrodes, forming oxide or hydroxide layers that trap gases.
Other possible impurities:
If Aaron used tap water without pre-treatment, residual disinfectants or organic matter could have affected the chemistry of the sludge.
Hypothesis 1: How impurities may contribute to hydrogen accumulation/release
Porous mineral deposits (carbonate and metal oxide sludge) act like a sponge, allowing hydrogen bubbles formed during electrolysis to be trapped and slowly released after power is turned off.
Some compounds, such as metal hydrides, may form temporarily on the electrodes or in the sludge, slowly releasing hydrogen chemically.
These deposits may also alter local pH and conductivity, affecting electrolysis efficiency and byproduct formation.
Aaron Salter likely used tap water from the Buffalo area, which is:
Moderately soft with calcium, magnesium, bicarbonates, chlorides, and sulfates.
Contains trace metals and dissolved minerals that contribute to the formation of a mixed mineral sludge in its electrolyzer.
It is possible that nanostructured particles with zeolite-like properties can form in the sludge inside a high-power electrolyzer under certain conditions, although direct formation of true zeolites is less common.
Here's why and how:
Zeolites are aluminosilicate minerals with a highly ordered porous structure, often formed hydrothermally in natural or synthetic environments. Their defining feature is a crystalline framework with micropores that can trap gases or ions.
In electrolyzers:
Electrolysis involves strong electric fields, high pH (alkaline conditions), heat, and the continuous splitting of water.
Minerals such as calcium, magnesium, silicon, and aluminum (if present in the electrodes or impurities) can precipitate and reorganize under these conditions.
Complex oxides, hydroxides, and possibly hydrated aluminosilicates can form amorphous or nanostructured porous particles somewhat analogous to zeolites, but usually less ordered.
Nanostructuring and porosity:
Electrochemical environments can create nano- and microscale deposits and sediments with high surface area and porosity.
They can trap gases (e.g., hydrogen bubbles), acting as molecular sieves or sponges.
Even if not ideal zeolites, such materials can have similar adsorption/desorption properties, facilitating the storage and slow release of hydrogen gas.
Aluminum/Silicon Sources:
Aluminum may come from electrode materials, gaskets, or contaminants.
Silicon dioxide may be present in water impurities or glass components.
If present, these elements may promote the formation of aluminosilicate phases.
Supporting Evidence:
Studies in alkaline water electrolysis systems show the formation of layered double hydroxides, oxide nanocrystals, and other complex nanostructures on the electrodes and within the slurry.
Some studies are investigating engineered zeolite coatings or zeolite-derived materials as cell components
(Stanley Meyer coating on tubes)
sergh
I know I wrote this years ago in one of your topics at Stefan's
Not sure if he's still a member here ...however Chris Hunter ( FE forum handle Alaskastar) had entered a contest
hosted by the Alaska Board of education or ?( some entity that hosted science contests for older students?)
And Chris had entered and was hoping to win ...however he came in second place to a student who had built a "solid state"( no moving parts)
Propane  Compressor which utilized an attribute of Zeolite
According to Chris ( Alaskastar) this fellows compressor would take propane which had phase changed from liquid
to gas ...absorb the gas into the Zeolite..store the propane in the Zeolite  and then release it
Back after a small electric charge ( minuscule charge) as liquid ?
Been many years since I have spoken with Chris (Alaskastar)
Perhaps if necessary I will ring him..
However I do remember a big air conditioner company either bought the tech or was buying access to the tech .
The other thing that pops into the mind is Bob Lazar's Chevrolet Corvette
Which ran on stored hydrogen in a proprietary ( undisclosed) hydride....
(I believe this was also shared at Stefan's ( just a generic reference from lazar's YouTube vid on the car)
Very interesting topic for perhaps the safe storage of hydrogen ( lazar said his hydride tanks could be cut into pieces with the Hydrogen being unaffected ( remaining stable).
I believe a member here spoke with Lazar years ago .. ?
Will try to ring that member?
sergh
Hello, Chet!
Thanks you for the message.
1. Propane compressor with zeolite.
I wonder how it was made, although this technology probably has no direct relation to the free energy.
A propane pump, without moving parts. This is probably due to heating and cooling, if the device has no moving parts.
And the fact that it was possible to get liquid propane back from the compressor with a weak electric discharge.
I don't understand how this is possible.
But you write that the project was commercialized? Probably they won't give details.
A weak electric discharge, in zeolite...
I did something like that. A quartz tube, zeolite was poured into it. A copper wire is inserted into the zeolite, insulated with a thin glass tube. The wire is sealed inside the tube so that there is no galvanic contact with the zeolite.
On the outside of the quartz tube with zeolite, thin uninsulated wire was wound as a second capacitive contact.
Thus, the zeolite was inside the capacitor.
High alternating current voltage was applied to this capacitor, approximately 5 - 8 kilovolts 30 - 40 kilohertz.
The tube with zeolite was pumped down to a vacuum of about -98 kPa, so that the remaining air and water vapor inside began to glow beautifully.
The hydrogen sensor showed the presence of hydrogen in the pumped gas, just like with heating. But without heating to more than 400 degrees Celsius!
Of course, the tube heated up from the discharge, but not that much.
I assumed that the alternating voltage inside the capacitor could be rectified by the zeolite and decompose water.. But even in this case, such a dispersed decomposition of water is very interesting.
The process was unstable, since the insulation of the inner wire made of low-melting glass quickly deteriorated due to point breakdowns, the zeolite also burned in places to black balls. Not enough hydrogen was formed for overunity. For now, it is postponed for processing other options.
2. Hydrogen storage. In principle, this is known, the accumulation of hydrogen in metals and their compounds.
It is interesting to obtain hydrogen on demand, and not even the release of hydrogen in pure form, for example, in the form of gas, but immediately converting hydrogen into energy.
chief kolbacict
Quote from: Chet K on 2025.07.15, 21:04:00
I'm afraid ,he can't phone.  :)
sergh
to gas ...absorb the gas into the Zeolite..store the propane in the Zeolite  and then release it back after a small electric charge ( minuscule charge) as liquid ?
Hello, Chet!
I was thinking about this yesterday, talking to ChatGPT. Probably there is some little-known technology for desorbing gas from zeolite using an electric field or cold discharge. Of course, it is not clear, but it would be very cool! :D
I would not need a vacuum pump!
And then it would be possible to run the process in the pressure change cycle an internal combustion engine. In the current state I can't do this because the vacuum required to pump hydrogen out from the zeolite, is too low pressure, -98 kPa min.  It is impossible to create a good vacuum and high pressure in the cylinder in one cycle.
If you could find out the details of how this was implemented, perhaps we would take a step towards producing free energy. Of course, without violating any laws or rights.
sergh
Quote from: chief kolbacict on 2025.07.17, 07:07:26
Hmm, can you explain why it's funny?  :-\  :(
chief kolbacict
https://www.theguardian.com/science/2018/mar/30/scientists-solve-eggshell-mystery-of-how-chicks-hatch
Pay attention to the eggshell. It turns out that it has nanostructures and a complex structure. O0
And it consist of calcium.
sergh
a "solid state"( no moving parts) propane  Compressor which utilized an attribute of Zeolite
- near this?:
QuoteElectro-osmosis: pumping water with electricity and no magnets
https://www.youtube.com/watch?v=zzVa_tX1OiI
and this:
QuoteBackground
The story of this experiment begins with a chance meeting at a resort. At that time, I needed regular batteries, and my wife and I went to the store. There, seeing the expiration date of the Energizer AA batteries (about ten years), I tried to joke, remembering how Hodja Nasreddin promised the emir to teach a donkey to talk in 10 years. Hodja Nasreddin himself commented on this: "In ten years, either the donkey will die, or the emir ..." A customer standing nearby reacted to the joke. As it turned out, he was an engineer with Russian roots. Words led to words, and we were already discussing the problems of global energy. The conversation continued over a glass of tea. In that discussion, a new acquaintance told me an interesting story. The essence of the story is that, in the past, my vis-a-vis worked in a laboratory developing desalination plants for Australia. These plants operate on the basis of reverse osmosis filters. So, in one of the experiments, he obtained an abnormal heat release, with the accompanying destruction of the membrane. At that time, I did not attach much importance to this, but then this idea surfaced in my memory and began to haunt me. As a result, I went all out - took up experimental physics.
Cold nuclear fusion reactor in a glass of water
After a series of experiments, a very productive reactor was built based on a nanomembrane and a resonator of an original design.
The video shows the operation of the HF reactor with the release of an abnormally high amount of heat.
To convince skeptics of the authenticity of the experiment, some measures were taken. In particular, the setup was assembled on a glass stand. An ordinary candle was used to register the absence of hidden infrared radiation, and a neon lamp was used to register the absence of high-frequency electromagnetic radiation.
The primary energy source - the battery was connected using a relatively thin wire, which eliminates the possibility of transmitting a large amount of energy to the load.
If you have already watched this video, you may have noticed that the reactor releases a large amount of heat. Meanwhile, the reactor is powered by a battery consisting of four regular AAA alkaline batteries. The current, monitored with an ammeter, reaches a value of only 0.35 Amperes. Simple calculations allow us to conclude that the efficiency of the installation is many times greater than 100%, since the energy of the batteries is relatively small.
Initial data:
Water - 500 grams
Initial temperature of the solution - 22 ° C
Final temperature of the solution - 93 ° C
Time spent on heating - 720 seconds.
Heat capacity of water - 4.2 J / Gram * ° C
How much energy was released in total?
4.2 * 500 (g) * 71 (° C) = 149100 (J)
What power is required for this?
149100 (J) / 720 (sec) ≈ 207 (Watt)
Even if the battery was lithium-ion and delivered such power, it should generate a current of:
207 (Watt) / (3.6 * 4) (Volts) ≈ 14 (Amps)
It is clear that such high current values would require wires of a larger cross-section than those used.
Battery current measurements showed 0.35 Amps. At the same time, under load, a voltage of 4.82 Volts was recorded.
Let's calculate the power given off by the battery:
4.82 (Volts) * 0.35 (Amps) ≈ 1.7 (Watts)
It remains to calculate the efficiency:
207 (Watts) / 1.7 (Watts) ≈ 122 (Times)
I will hasten to answer the question about the prospects of this technology. So far, it has not been possible to ensure long-term operation of the reactor due to the rapid destruction of the membrane. The average operating time of the reactor is 35 minutes. The record is 1 hour 23 minutes.
https://www.youtube.com/watch?v=bxWuo2GCkrQ
(I found this video only in russian. Translation possible over subtitles)
sergh
Kolbacist, surprise!!!
Do you know that the author of this video about cold fusion in a glass and the author of the video about a Gauss gun on a piezoelectric element are the same person?
Hmm...:  :o
https://www.youtube.com/watch?v=AXB0VFBzjzk
the same in russian:
https://www.youtube.com/watch?v=shipH-bcrUo
Another view (in engl):
https://www.youtube.com/watch?v=7gZ_C-c7d0M
My opinion is ambiguous. Interesting. With piezo - impossible, I can't imagine how, except for a fake. But he is persistent in his video. Maybe it is also connected with this story about water desalination by reverse (electro-) osmosis in Australia? I didn't think before that it has the same source, the same author.
  :-\   - no activity for 11 years, except for these 3 videos. Doubtful, don't know what to think about it.
If I had 12 of these piezoelectric elements, and another 13 neodymium magnets of the same diameter, plus 20-30 meters of regular copper wire, I,  like anyone else, would make a Kapanadze generator in a couple of hours, the same principle as in  audio speaker, but magnets press on the piezo, the coil is connected in series with the load bulbs and all the piezos. Only initial short mechanical impulse is needed, from another large coil, on which a small capacitor is discharged through a spark gap.
12 X 10V = 220 V
More precisely, the number of piezoelectric elements for a pulsating current of 220 V must be greater by the square root of 2. But this is not essential.
chief kolbacict
Quote from: sergh on 2025.07.21, 12:04:38
I have watched it few years ago.  Only questions had remained.
[ur]lhttps://www.youtube.com/watch?v=shipH-bcrUo[/url]
There are interesting comment.
sergh
#12
about this:
I was thinking yesterday and came to the conclusion that only one type of current source can look like this. Such characteristics, discharge from impact or pressure, are possible only....
... in devices with charge accumulation. For example, a regular USB flash drive... yes, it accumulates charge during recording, but not so effectively.
You can charge a thick piece of plexiglass placed for a short time in an electron accelerator. Electrons penetrate into the plexiglass and remain there, creating an internal charge.
Production of Lichtenberg figures:
https://youtu.be/mJTjs4mDtZw?t=123
There may be a "charge sponge" inside this piezoelectric element. This is similar to a capacitor, in which the charge is not on the surface of the plates, but in the volume of the dielectric, preserved by insulation. The insulation is broken by external influence, impact or pressure, and the charge goes to the plates.
Probably the author did not mention in his video that this "piezoelectric element" after production or during the solidification process must first be charged with high voltage.
By the way, the powder gray matter that he adds when preparing the piezoelectric element is very similar to ground zeolite.
I found that the new calcium zeolite 5A, small balls 0.8 mm, for oxygen concentrators, has strange electrostatic properties. If you pour a little of these balls onto a polyethylene film, they form a periodic structure, they arrange themselves like checkers.
And it is very likely that this piezoelectric element may be the result of the first video about heating water, "LENR". That is, something like that from Australian membranes inside his reactor heats the water from high voltage sources:
PhysicsProf
Quote from: sergh on 2025.07.21, 12:41:37
Hmm...:  :o
12 X 10V = 220 V
You said, "this video about cold fusion in a glass" -which I'm interested in -
BUT I don't see any "cold fusion in a glass" in any of the videos you cite.  Can you clarify?
sergh
Hello,  PhysicsProf!
You paid attention to the last message, so the rest of the conversation fell out of context.
Please pay attention to the previous messages, specifically LENR, in the author's opinion (not mine), this part concerns, I will quote again the translation of the prehistory and the link to the video:
QuoteBackground
Initial data:
Water - 500 grams
How much energy was released in total?: 4.2 * 500 (g) * 71 (° C) = 149100 (J)
What power is required for this?: 149100 (J) / 720 (sec) ≈ 207 (Watt)
Let's calculate the power given off by the battery: 4.82 (Volts) * 0.35 (Amps) ≈ 1.7 (Watts)
It remains to calculate the efficiency:  207 (Watts) / 1.7 (Watts) ≈ 122 (Times)
The video about this "cold fusion" in a glass:
(I found this video only in russian. Translation possible over subtitles from YouTube settings )
sergh
I do not confirm or deny the author of this video, and have no relation to him. I only analyze the information for implementation in my (or others) experiments.
PhysicsProf
Quote from: sergh on 2025.07.22, 17:59:58
Hello,  PhysicsProf!
I see!
Thanks for this information...
chief kolbacict
Quote from: sergh on 2025.07.22, 09:51:33
https://youtu.be/-PMMK4KHXYU
And I remembered Wesley with his Coleman pipe.  :)
sergh
I do not find any similarity with the device described in patent GB763062A:
"A new apparatus for producing an electric current",
Inventors: HAROLD VICTOR COLMAN, RONALD WILLIAM DAVID SEDDON GI
"A mixture of salts of cadmium, phosphorus and cobalt is subjected to high frequency electromagnetic waves so as to become radioactive and release electrical energy. The mixture is contained in a quartz tube and protection from the gamma, alpha and beta rays is given by lead shielding. The electrical output, stated to be D.C. is taken directly from the ends of the quartz tube."  :(
https://patents.google.com/patent/GB763062A/en
chief kolbacict
Quote from: sergh on 2025.07.24, 09:02:35
Perhaps,Wesley don't came his mind, to hit with a hammer at that tube's edge.  Actually, if I was owner so much equipments, perhaps it doesn't come up with me too. But since I have nothing but a hammer, this is what comes to mind.
Please don't take this as flooding or mockery, I'm just trying to think. :)
At least the composition of the substances is not kept secret.
panyuming
chief kolbacict
#21
http://www.news.wisc.edu/17818
https://pubs.acs.org/doi/10.1021/jz100027t
https://en.wikipedia.org/wiki/Molten-salt_battery
    Capacity : 25–250 kWh per bank
    Efficiency of 87%
    Lifetime of 2,500 cycles at 100% depth of discharge (DOD), or 4,500 cycles at 80% DOD
sergh
#22
About this video, at 2:41:
Once upon a time, a long time ago, I had a regular piezoelectric plate from a alarm clock or something like that.
A regular piezoelectric beeper. Without additional elements, only piezoelectric ceramics and contacts.
So, when you press it and hold the static force, the voltage did not drop back to zero. There was a little left, say 5 millivolts DC. But it remained every time!
I was surprised then, but due to the insignificance of the effect, I assumed that these were some little-known features of the piezoelectric element, maybe it was destroyed this way or a galvanic effect.
Now I have tried what piezoelectric elements I had - everywhere the voltage returns back to zero.
If anyone wants, they can check on their piezoelectric elements - press lightly with something and hold, for example, with some kind of plastic clamp. Will the voltage drop back to zero?
Piezoelectric elements
chief kolbacict
It was fanny to watch as the beam flew beyond the edges of the screen when the vice screw was turned by several degrees.
But ,after a few second,the beam always came back to its place.
sergh
#24
Quote...laboratory developing desalination plants for Australia. These plants operate on the basis of reverse osmosis filters. So, in one of the experiments, he obtained an abnormal heat release, with the accompanying destruction of the membrane. ...
The Patent near this:
Integrated energy generation and desalination system and method
Method, apparatus and plant for desalinating saltwater using concentration difference energy
Redox desalination system for clean water production and energy storage
Renewable energy source using pressure driven filtration processes and systems
Another:
Experimental investigation of simultaneous hydrogen production and desalination via electrodialysis process
