2026-08-15, 08:17:56
Pages: 1 2 [3]
Author Topic: Alberto Molina-Martinez principle (The Rotating Magnetic Field)  (Read 11371 times)
I understand nothing.
Yet you demonstrated the polyphase RMF using an old motor stator as I recall. It appeared that you knew what you were doing.
bi
Could I use this to construct similar devices with rotating virtual magnetic field ?
I will not name this person :(
If I supply three phase to coils with three rings.
At least it looks much simpler.
I'll try it tomorrow for sure.
Looks interesting. How will you detect a rotating magnetic field?
I'll wait for your test results.
bi
You should be able to induce a current but not generate a rotating magnetic field unless the chokes are out of phase.
Anyway our virtual magnetic field will be moving along the wire of the second coil. Consequently it won't create the EMF.  Magnetic field ought to be perpendicular across the wire. But how to do that ?
Can you draw what you mean ?
Group: Mad Scientist
What have you tried with the 3 cores so far?
mags
Unfortunately, nothing.  :-[
if the windings on the cores, we will call them primaries, are the same wire, same number of turns, count the turns  and wind the secondary with say 10 more turns than that number of turns of 1 of the primaries.  now you put the 3 primaries in series and apply input to see what you get out.  pulse or sine input.  You should get more voltage out than in, which would seem backwards of the norm as you will have nearly 3 times more total turns on the primaries than the secondary.  if the primaries are in parallel, you should get more than 3 times the output voltage than the input voltage. more due to the 10 extra turns on the secondary.
mags
It's kind of strange reading all the posts prior to AI.
Where today we can just ask an AI and get an accurate answer in seconds. AI tells us...
"One-sentence summary
Flux linking describes induction from the circuit’s point of view (changing total flux), while flux cutting describes induction from the charge’s point of view (magnetic force on moving charges); they are two complementary ways of describing the same physics."
Bada boom bada bing, too easy.
Pages: 1 2 [3]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2026-08-15, 08:17:56
